we plan to use cc1312r7 implement our wisun solution. i see sdk5.20 already has wisun app. but some of the functions are from lib files. how can i generate these libs?
Please can you specify which libraries you want to generate and which function definitions you want to see. I assume you are talking about the border router and the coap node examples.
Siddanth
hi siddanth,
i need generate every lib by myself. i list most of them here.
${COM_TI_SIMPLELINK_CC13X2_26X2_SDK_INSTALL_DIR}/source/ti/ti_wisunfan/wisunfan_mac/library/tirtos/ticlang/bin/maclib_secure_cc13x2.a
${COM_TI_SIMPLELINK_CC13X2_26X2_SDK_INSTALL_DIR}/source/ti/ti_wisunfan/mbed_library/ws_router/tirtos/ticlang/bin/wisun_rn_mbed_ns_tls_lib_cc13x2.a
${COM_TI_SIMPLELINK_CC13X2_26X2_SDK_INSTALL_DIR}/source/ti/ti_wisunfan/ncp_interface/library/tirtos/ticlang/bin/wisun_ncp_lib_cc13x2.a
${COM_TI_SIMPLELINK_CC13X2_26X2_SDK_INSTALL_DIR}/source/ti/display/lib/ticlang/m4f/display.a
${COM_TI_SIMPLELINK_CC13X2_26X2_SDK_INSTALL_DIR}/source/ti/grlib/lib/ticlang/m4f/grlib.a
${COM_TI_SIMPLELINK_CC13X2_26X2_SDK_INSTALL_DIR}/source/ti/drivers/rf/lib/rf_multiMode_cc13x2.am4fg
${COM_TI_SIMPLELINK_CC13X2_26X2_SDK_INSTALL_DIR}/source/ti/drivers/lib/ticlang/m4f/drivers_cc13x2.a
${COM_TI_SIMPLELINK_CC13X2_26X2_SDK_INSTALL_DIR}/kernel/tirtos/packages/ti/dpl/lib/ticlang/m4f/dpl_cc13x2.a
${COM_TI_SIMPLELINK_CC13X2_26X2_SDK_INSTALL_DIR}/source/ti/devices/cc13x2_cc26x2/driverlib/bin/ticlang/driverlib.lib
thanks a lot
wenchuan
Is there any reason you would like to build your own library files? We do not provide makefiles in the SDK for building all the libraries.
Siddanth
we need do some improvement for your wisun implementation in order to deploy it. i see that the source code is there. why its makefiles are missing?
In most cases, we do not recommend making changes on the driver level. That is why, not all makefiles are shipped with the SDK.
Siddanth
