Other Parts Discussed in Thread: SMARTRFTRXEBK
Hi, In order to test CC1101-Q1 which EVB kit you would recommend me to buy? Could you please direct me to the link to ti.com for this EVB?
BR,
A
BR,
A
Hi Antonio,
due to vacation time an answer will be delayed. We will come back to you begin of next week.
Helfried
Ok please let me know once you have a suggestion ad hoc for CC1101-Q1.
BR,
Antonio
Hello Antonio,
the non-automotive versions of the EVMs could be used:
CC1101EMK433 for 433MHz operation
CC1101EMK868-915 for 868/915MHz operation
A base board is required as well:
SMARTRFTRXEBK
Jürgen
Hello Antonio,
the non-automotive evaluation system could be used which consist of:
Plugin modules:
CC1101EMK433 (for 433MHz band)
CC1101EMK868-915 (for 868/915MHz band)
Base board:
SMARTRFTRXEBK
Jürgen
Hi Juergen,
Thanks, I cannot find in ti.com the two plugin modules you are talking about, could you please send me the links of the two?
BR,
Antonio
Hi Antonio,
seems they are not available or no longer setup on ti.com however they are still orderable and on stock!
We may need a standard order to get them. Can you maybe check with your customer service?
Jürgen
