SMARTRFTM-STUDIO: Save SmartRF Studio settings
Part Number: SMARTRFTM-STUDIO
Other Parts Discussed in Thread: CC1310, TMDSEMU200-U
Save SmartRF Studio settings.
I want to control while exchanging multiple devices of the same type.
I tried to load the saved xml file by doing "Save Cfg" with "File", but it failed.
There is a slight change in the operating current, but no signal is output.
What is the cause?
The control target is CC1310.
Connected with TMDSEMU200-U.
best regards.
    Can you please confirm your SmartRF studio version as well ?
       Richard
  • Thank you for your reply.
    It is ver.2.23.0.
  • The cfg file was successfully read.
    It is possible by the following procedure.
    1. Open the Device Control Panel and do a "immediate" Reset Cfg
    2. Select the target cfg file with Open Cfg
    I'm glad I succeeded, but is this the procedure as designed?
    If so, it would be helpful to be a little more intuitive.
    thanks.
    Thanks for the feedback. Good to hear that you where able to successfully use the config file.
    The procedure you have described was not intended. This looks like a bug in SmartRF Studio. Would you be able to share the config file you are using?
    Øyvind
    Share the file used for the test.
    The settings are as per the file name.
    I hope it helps you.
    Thank you for your support.
    <?xml version="1.0" encoding="ISO-8859-1"?>
    <!DOCTYPE configuration SYSTEM "C:/Program Files (x86)/Texas Instruments/SmartRF Tools/SmartRF Studio 7/config/xml/configdata.dtd"[]>
    <dcpanelconfiguration>
        <Devicename>CC1310_PG21</Devicename>
        <Description>Saved configuration data</Description>
        <Patch>
            <Define>RF_MODE_PROPRIETARY_SUB_1</Define>
            <Cpe>rf_patch_cpe_genfsk</Cpe>
            <Mce></Mce>
            <Rfe>rf_patch_rfe_genfsk</Rfe>
        </Patch>
        <commandsettings>
            <Command name="CMD_TX_TEST">
                <Field name="commandNo">0x00000808</Field>
                <Field name="status">0x00000000</Field>
                <Field name="pNextOp">0x00000000</Field>
                <Field name="startTime">0x00000000</Field>
                <Field name="startTrigger">0x00000000</Field>
                <Field name="condition">0x00000001</Field>
                <Field name="config">0x0000000b</Field>
                <Field name="txWord">0x0000ffff</Field>
                <Field name="endTrigger">0x00000001</Field>
                <Field name="syncWord">0x930b51de</Field>
                <Field name="endTime">0x00000000</Field>
            </Command>
            <Command name="CMD_SYNC_STOP_RAT">
                <Field name="commandNo">0x00000809</Field>
                <Field name="condition">0x00000000</Field>
                <Field name="rat0">0x00000000</Field>
            </Command>
            <Command name="CMD_SYNC_START_RAT">
                <Field name="commandNo">0x0000080a</Field>
            </Command>
            <Command name="CMD_STOP">
                <Field name="commandNo">0x00000402</Field>
            </Command>
            <Command name="CMD_SCH_IMM">
                <Field name="commandNo">0x00000810</Field>
                <Field name="cmdrVal">0x00000000</Field>
                <Field name="cmdstaVal">0x00000000</Field>
            </Command>
            <Command name="CMD_RX_TEST">
                <Field name="commandNo">0x00000807</Field>
                <Field name="config">0x00000004</Field>
            </Command>
            <Command name="CMD_RADIO_SETUP">
                <Field name="commandNo">0x00000802</Field>
                <Field name="mode">0x00000001</Field>
                <Field name="loDivider">0x00000000</Field>
                <Field name="config">0x00000000</Field>
                <Field name="txPower">0x00000000</Field>
                <Field name="pRegOverride">0x00000000</Field>
            </Command>
            <Command name="CMD_PROP_TX_ADV">
                <Field name="commandNo">0x00003803</Field>
                <Field name="pktConf">0x00000000</Field>
                <Field name="numHdrBits">0x00000010</Field>
                <Field name="pktLen">0x00000000</Field>
                <Field name="startConf">0x00000000</Field>
                <Field name="preTrigger">0x00000000</Field>
                <Field name="preTime">0x00000000</Field>
                <Field name="pPkt">0x00000000</Field>
            </Command>
            <Command name="CMD_PROP_TX">
                <Field name="commandNo">0x00003801</Field>
                <Field name="pktConf">0x00000018</Field>
                <Field name="pktLen">0x00000014</Field>
            </Command>
            <Command name="CMD_PROP_RX_SNIFF">
                <Field name="commandNo">0x00003808</Field>
                <Field name="rxConf">0x00000000</Field>
                <Field name="syncWord">0x00000000</Field>
                <Field name="maxPktLen">0x00000000</Field>
                <Field name="address0">0x00000000</Field>
                <Field name="address1">0x00000000</Field>
                <Field name="endTrigger">0x00000000</Field>
                <Field name="pQueue">0x00000000</Field>
                <Field name="pOutput">0x00000000</Field>
                <Field name="csConf">0x00000000</Field>
                <Field name="rssiThr">0x00000000</Field>
                <Field name="numRssiIdle">0x00000000</Field>
                <Field name="numRssiBusy">0x00000000</Field>
                <Field name="corrPeriod">0x00000000</Field>
                <Field name="corrConfig">0x00000000</Field>
                <Field name="csEndTrigger">0x00000000</Field>
                <Field name="csEndTime">0x00000000</Field>
            </Command>
            <Command name="CMD_PROP_RX_ADV_SNIFF">
                <Field name="commandNo">0x00003809</Field>
                <Field name="syncWord0">0x00000000</Field>
                <Field name="syncWord1">0x00000000</Field>
                <Field name="hdrConf">0x00000000</Field>
                <Field name="addrConf">0x00000000</Field>
                <Field name="lenOffset">0x00000000</Field>
                <Field name="pAddr">0x00000000</Field>
            </Command>
            <Command name="CMD_PROP_RX_ADV">
                <Field name="commandNo">0x00003804</Field>
                <Field name="syncWord0">0x930b51de</Field>
                <Field name="maxPktLen">0x000000ff</Field>
            </Command>
            <Command name="CMD_PROP_RX">
                <Field name="commandNo">0x00003802</Field>
                <Field name="rxConf">0x00000088</Field>
                <Field name="address0">0x000000aa</Field>
                <Field name="address1">0x000000bb</Field>
            </Command>
            <Command name="CMD_PROP_RADIO_SETUP">
                <Field name="commandNo">0x00003806</Field>
                <Field name="modulation">0x00000000</Field>
                <Field name="symbolRate">0x00000000</Field>
                <Field name="rxBw">0x00000000</Field>
                <Field name="preamConf">0x00000000</Field>
                <Field name="formatConf">0x00000000</Field>
            </Command>
            <Command name="CMD_PROP_RADIO_DIV_SETUP">
                <Field name="commandNo">0x00003807</Field>
                <Field name="modulation">0x00000321</Field>
                <Field name="symbolRate">0x0080000f</Field>
                <Field name="rxBw">0x00000024</Field>
                <Field name="preamConf">0x00000004</Field>
                <Field name="formatConf">0x000000a0</Field>
                <Field name="config">0x00000008</Field>
                <Field name="txPower">0x000038d3</Field>
                <Field name="centerFreq">0x0000039a</Field>
                <Field name="intFreq">0x00008000</Field>
                <Field name="loDivider">0x00000005</Field>
                <OverrideField name="pRegOverride">
                    <OverrideBuffer name="override_use_patch_prop_genfsk.xml">
                        <Element32b>MCE_RFE_OVERRIDE(0,4,0,1,0,0)</Element32b>
                    </OverrideBuffer>
                    <OverrideBuffer name="override_synth_prop_863_930_div5.xml">
                        <Element32b>HW_REG_OVERRIDE(0x4038,0x0037)</Element32b>
                        <Element32b>0x000684A3</Element32b>
                        <Element32b>HW_REG_OVERRIDE(0x4020,0x7F00)</Element32b>
                        <Element32b>HW_REG_OVERRIDE(0x4064,0x0040)</Element32b>
                        <Element32b>0xB1070503</Element32b>
                        <Element32b>0x05330523</Element32b>
                        <Element32b>0x0A480583</Element32b>
                        <Element32b>0x7AB80603</Element32b>
                        <Element32b>ADI_REG_OVERRIDE(1,4,0x9F)</Element32b>
                        <Element32b>ADI_HALFREG_OVERRIDE(1,7,0x4,0x4)</Element32b>
                        <Element32b>0x02010403</Element32b>
                        <Element32b>0x00108463</Element32b>
                        <Element32b>0x04B00243</Element32b>
                    </OverrideBuffer>
                    <OverrideBuffer name="override_phy_rx_aaf_bw_0xd.xml">
                        <Element32b>ADI_HALFREG_OVERRIDE(0,61,0xF,0xD)</Element32b>
                    </OverrideBuffer>
                    <OverrideBuffer name="override_phy_gfsk_rx.xml">
                        <Element32b>0x00038883</Element32b>
                        <Element32b>HW_REG_OVERRIDE(0x6084,0x35F1)</Element32b>
                    </OverrideBuffer>
                    <OverrideBuffer name="override_phy_gfsk_pa_ramp_agc_reflevel_0x1a.xml">
                        <Element32b>HW_REG_OVERRIDE(0x6088,0x411A)</Element32b>
                        <Element32b>HW_REG_OVERRIDE(0x608C,0x8213)</Element32b>
                    </OverrideBuffer>
                    <OverrideBuffer name="override_phy_rx_rssi_offset_5db.xml">
                        <Element32b>0x00FB88A3</Element32b>
                    </OverrideBuffer>
                </OverrideField>
            </Command>
            <Command name="CMD_PROP_CS">
                <Field name="commandNo">0x00003805</Field>
                <Field name="csFsConf">0x00000000</Field>
            </Command>
            <Command name="CMD_PATTERN_CHECK">
                <Field name="commandNo">0x00000813</Field>
                <Field name="patternOpt">0x00000000</Field>
                <Field name="pNextOpIfOk">0x00000000</Field>
                <Field name="pValue">0x00000000</Field>
                <Field name="mask">0x00000000</Field>
                <Field name="compareVal">0x00000000</Field>
            </Command>
            <Command name="CMD_NOP">
                <Field name="commandNo">0x00000801</Field>
            </Command>
            <Command name="CMD_FS_POWERUP">
                <Field name="commandNo">0x0000080c</Field>
            </Command>
            <Command name="CMD_FS_POWERDOWN">
                <Field name="commandNo">0x0000080d</Field>
            </Command>
            <Command name="CMD_FS_OFF">
                <Field name="commandNo">0x00000804</Field>
            </Command>
            <Command name="CMD_FS">
                <Field name="commandNo">0x00000803</Field>
                <Field name="frequency">0x0000039a</Field>
                <Field name="fractFreq">0x00000000</Field>
                <Field name="synthConf">0x00000000</Field>
            </Command>
            <Command name="CMD_COUNT_BRANCH">
                <Field name="commandNo">0x00000812</Field>
                <Field name="counter">0x00000000</Field>
            </Command>
            <Command name="CMD_COUNT">
                <Field name="commandNo">0x0000080b</Field>
            </Command>
            <Command name="CMD_ABORT">
                <Field name="commandNo">0x00000401</Field>
            </Command>
        </commandsettings>
        <dcpanel>
            <Property name="m_chkCmdView" role="44">2</Property>
            <Property name="m_chkRfParameters" role="44">2</Property>
            <Property name="m_typicalSettings" role="33">Settings for 779 - 930 MHz band;50 kbps, 2-GFSK, 25 kHz deviation</Property>
            <Property name="m_testFuncPanel" role="37">0</Property>
        </dcpanel>
        <targetconfig>
            <Property name="m_cmbBoardSelection" role="46">0</Property>
            <Property name="m_chkDcDc" role="44">2</Property>
        </targetconfig>
        <rfparameters>
            <Property name="txPower" role="65535">10</Property>
        </rfparameters>
        <conttx>
            <Property name="m_rbtModulated" role="45">0</Property>
            <Property name="m_rbtUnmodulated" role="45">1</Property>
            <Property name="m_cmbDataFormat" role="46">-1</Property>
            <Property name="m_chkFreqSweep" role="44">0</Property>
            <Property name="m_chkChanSweep" role="44">0</Property>
        </conttx>
        <contrx>
            <Property name="m_cmbDataFormat" role="46">0</Property>
            <Property name="m_chkAutoScroll" role="44">2</Property>
        </contrx>
        <packettx>
            <Property name="m_edtPacketCount" role="42">100</Property>
            <Property name="m_edtFixedPktLength" role="42">20</Property>
            <Property name="m_edtPacketData" role="42">8f 37 92 39 10 5c 73 e7 4f 00 9e 5e 45 4e 66 33 82 a3 </Property>
            <Property name="m_edtAccessAddress" role="42"></Property>
            <Property name="m_chkAddSeqNbr" role="44">2</Property>
            <Property name="m_chkInfinite" role="44">0</Property>
            <Property name="m_rbtRandom" role="45">1</Property>
            <Property name="m_rbtText" role="45">0</Property>
            <Property name="m_rbtHex" role="45">0</Property>
            <Property name="m_chkAdvanced" role="44">0</Property>
            <Property name="m_cmbLengthConfig" role="46">1</Property>
            <Property name="m_grp802154g" role="20">0</Property>
            <Property name="m_edt802154gPktLength" role="42">20</Property>
            <Property name="m_rbt802154g2BCrc" role="45">1</Property>
            <Property name="m_rbt802154g4BCrc" role="45">0</Property>
            <Property name="m_chk802154gWhitening" role="44">2</Property>
            <Property name="m_chkFEC" role="44">0</Property>
            <Property name="m_cmbPreambleCount" role="46">5</Property>
            <Property name="m_chkAddress" role="44">0</Property>
            <Property name="m_cmbSyncMode" role="46">24</Property>
        </packettx>
        <packetview>
            <Property name="m_edtPktLength" role="42">20</Property>
            <Property name="m_edtAddress" role="42"></Property>
            <Property name="m_lblFrmPayload" role="41">8f 37 92 39 10 5c 73 e7 4f 00 9e 5e 45 4e 66 33 82 a3 </Property>
        </packetview>
        <packetrx>
            <Property name="m_edtAccessAddress" role="42">0x930b51de</Property>
            <Property name="m_cmbViewFormat" role="46">0</Property>
            <Property name="m_chkSeqNbrIncluded" role="44">2</Property>
            <Property name="m_edtDumpFile" role="42"></Property>
            <Property name="m_chk802154gMode" role="44">0</Property>
        </packetrx>
    </dcpanelconfiguration>
