CC1310: where to initialize the sensorcontroller
Part Number: CC1310
Hello. Is there any difference where the sensorcontroller needs to be initialized? before the start of tirtos or after there was already a start  BIOS_start(); ?
example code:
// Start SensorControler
// Initialize the SCIF operating system abstraction layer
scifOsalInit();
scifOsalRegisterCtrlReadyCallback( scCtrlReadyCallback );
scifOsalRegisterTaskAlertCallback( scTaskAlertCallback );
// Initialize the SCIF driver
scifInit( &scifDriverSetup );
// Enable RTC ticks, with N Hz tick interval
scifStartRtcTicksNow( 0x00010000 / 5 );
scifStartTasksNbl( BV( SCIF_LED_DRV_TASK_ID ) );
  • When you generate code using Sensor Controller Studio the file "scif_how_to_use.html" is generated which explains in detail how to integrate the sensor controller with the application code. You can also take a look at the examples included in Sensor Controller Studio.
