Part Number: CC1350
Other Parts Discussed in Thread: LAUNCHXL-CC1352P1, CC1352R, CC1352P7
Hello all,
I'm working on a design with a CC1350 and I plan on using both sub 1ghz and BLE. I want to implement a dual-band antenna design with a single PCB antenna exactly how it is in
LAUNCHXL-CC1352P1. (Dual differential -> RF switch -> TI SWRA227 antenna (DN024)).
- Can I replicate this exact antenna design on LAUNCHXL-CC1352P1?
- If yes, can I do the impedance matching with the following balun https://www.johansontechnology.com/datasheets/0900PC15A0036/0900PC15A0036.pdf?
- If not, can you recommend how to achieve the same type of design as I would like to avoid having two antennas?
