CC1310: abnormal current during sleeping
Part Number: CC1310
Hi team,
Here's an issue from the customer may need your help:
1) When go to sleep with Task_sleep, it can reach within 5uA. It has been set to sleep for 4 seconds, but a trip current of about 25uA occurs every other time (less than 2 seconds). How did this happen?
2) Also is it possible to avoid closing the serial port via UART_close() before going to sleep, and the Serial Assistant prints an 00?
Thanks.
Cherry
  • Hi Cherry,
    Please can you elaborate on the current consumption? Maybe some plot of current consumption. Is the application running some thing at a period of 2 seconds?
    And if you close UART, you cannot perform the UART_write().
    Sid
