Hi Team,
There seems a inconsistency in the size of the board that found in the design file, can you please confirm the correct dimension? Please see image for your reference
Thank you
May
95.3 mm was the length of the old LAUNCHXL-CC1310 board.
119.8 mm is the length of the new LAUNCHXL-CC1310 board.
The design files are correct.
Richard
Hi Richard,
I just received update from customer, according to them the design files is not updated and they are looking for the latest allegro files of the board.
Thank you.
May
Hi Richard,
Do we have updated design files of the board?
Thank you.
May
Where is the file used for the right picture in the original post? If I look at the gerber files in https://www.ti.com/lit/zip/swrc319 found on https://www.ti.com/tool/LAUNCHXL-CC1310 it looks like the dimensions are correct. In addition I have not seen any complaints on this.
The Allegro .brd files available on TI.com are the old dimensions, whilst on our system they are the updated board dimensions. We will update the files available on TI.com to use the correct dimensions.
In the meantime, please find the updated Allegro files attached: LAUNCHXL-CC1310 Allegro Files
Zack
