CC1310: How to use the printf function to print debugging information for CC1310 IAR and output it through the serial port?
Part Number: CC1310
Hi team,
Here's the request from the customer:
As the title says, how to use the printf function to print debugging information for CC1310 IAR and output it through the serial port?
Terminal IO can print, but the speed is particularly slow.
Using Display_ Printf can output, but with row and column data. How to directly output data without the row and column data?
Could you help check this case? Thanks.
Nick
