LAUNCHXL-CC1310: Trying to decode 433.92MHz Data from Jansite TPMS transmitters
Part Number: LAUNCHXL-CC1310
Other Parts Discussed in Thread: CC1101, CC1310, CC110L, TEST2
I am working on a project to read TPMS data using the CC1310 and or CC1101/CC110L as a receiver.
I'm working with a TPMS sensor that broadcasts on 433.92MHz frequency.
I chose a sensor that has already been decoded in the open source library RTL_433.
My issue is when I do a packet receive on the CC1310 the data is completely different than the (golden data) from RTL-433.
I have access to the source code for RTL-433 and it appears the received bits are processed by
(1) Manchester Decoding the bitstream
(2) Inverting the bitstream.
I have used Manchester mode on the CC1101 and CC110L and inverted all the received bits manually in my text files of the output.
I can provide the full source code from RTL-433 if needed.
Based on the working source code from RTL-433 I see the preamble bits of the TPMS datastream are 0xA6, 0xA6, 0xA6 and the sync bytes are 0xDD, 0x33.
Essentially I am unsure why I can not find the desired string (8a5c24055000086c6a) anywhere in the multiple bitstreams recorded from all three of the sub 1GHz receivers and my dev boards.
Any help from someone who has used any of the CC1101, CC110L, CC1310 to decode TPMS data would be extremely helpful.
Golden Data:
8a5c2405510008ec7d
8a5c2405514208e078
8a5c2405514308667b
Base Frequency: 433.92(433.919830)    Channel number: 0      Channel Spacing: 199.951172 kHz    Data Rate: 1.19948 kBaud
Rx Filter BW: 58.035714     Manchester: Enabled     Modulation ASK/OOK      SYNC0: 0xDD     SYNC1: 0x33
13:36:08.726 | 7d | 55885 | 82 88 6f c2 6e bd 97 4f 57 cf f7 c3 aa 97 2b 9f 8d ad cc fe 72 fc e5 6e 76 90 ea 49 54 75 71 65 5e ba 30 d7 dc
                            59 21 db bc 0b 8f d0 32 58 0e 9b db 16 db cc d9 dc c4 a2 ef c5 93 c0 5f 95 9d 37 76 51 ce eb dd f6 da b7 2f 88
                            be da 22 31 2e 10 d1 1b 16 7e dd 2b 8a c6 9b 76 0f f0 40 68 11 8f 38 68 90 f7 c9 7e cb fe 92 88 dd ff b8 35 d1
                            fe 89 04 2f 2b db 93 aa df 7e 11 8d  |  -99 CRC error
                            OG Data:
                            Inverted Data:
                            7D 77 90 3D 91 42 68 B0 A8 30 08 3C 55 68 D4 60 72 52 33 01 8D 03 1A 91 89 6F 15 B6 AB 8A 8E 9A A1 45 CF 28 23
                            A6 DE 24 43 F4 70 2F CD A7 F1 64 24 E9 24 33 26 23 3B 5D 10 3A 6C 3F A0 6A 62 C8 89 AE 31 14 22 09 25 48 D0 77
                            41 25 DD CE D1 EF 2E E4 E9 81 22 D4 75 39 64 89 F0 0F BF 97 EE 70 C7 97 6F 08 36 81 34 01 6D 77 22 00 47 CA 2E
                            01 76 FB D0 D4 24 6C 55 20 81 EE 72
13:36:18.382 | 39 | 36001 | 09 8e d4 a3 6b 87 d3 6f b1 8d 61 8c 99 c2 71 51 4b 93 0e a5 0f f6 fa 8e bb 57 5d 38 29 4f 1b fd 20 c9 5b b1 c6
                            42 db 3e a7 84 16 11 d8 b5 d8 e7 8e 7c 59 bf eb bc 5f  | -100 CRC error
                            OG Data:
                            Inverted Data:
                            F6 71 2B 5C 94 78 2C 90 4E 72 9E 73 66 3D 8E AE B4 6C F1 5A F0 09 05 71 44 A8 A2 C7 D6 B0 E4 02 DF 36 A4 4E 39
                            BD 24 C1 58 7B E9 EE 27 4A 27 18 71 83 A6 40 14 43 A0
13:36:21.923 | b4 | 4972  | 0d 8c 4e 0e 8f af 94 d5 80 a8 51 05 6c aa 44 ff bb 26 5a 45 fd 9c ff ff fe 0b 3f ff dc ff cd cd 76 cc 76 15 3b
                            37 f5 4f fd 7a 6c 1f e5 6f 69 a6 f3 0d 1a e1 57 8c df 56 53 ca 41 88 de fd 05 fe 63 bd 17 82 fd 15 d7 64 cb 81
                            ff 4f 78 17 b8 7d 82 91 61 ee 4c c1 9e a3 32 5c 1a ea db 53 bd bd 49 88 b8 26 f6 dd 7b a1 d9 e1 89 7b 32 8b 61
                            8c f9 25 81 52 8b 5c 8c ab 47 6d e6 24 e2 d4 dc b2 01 c1 06 63 33 7c 91 d4 65 ef f5 15 ac af 65 6b 36 40 1c 9e
                            c9 22 5d bc f4 1e 2d 53 02 b9 98 b3 3b 1b 6c cd f0 19 f9 23 a0 d0 13 d4 6f f7 c5 2e b6 8f  | -100 CRC error
                            OG Data:
                            Inverted Data:
                            F2 73 B1 F1 70 50 6B 2A 7F 57 AE FA 93 55 BB 00 44 D9 A5 BA 02 63 00 00 01 F4 C0 00 23 00 32 32 89 33 89 EA C4
                            C8 0A B0 02 85 93 E0 1A 90 96 59 0C F2 E5 1E A8 73 20 A9 AC 35 BE 77 21 02 FA 01 9C 42 E8 7D 02 EA 28 9B 34 7E
                            00 B0 87 E8 47 82 7D 6E 9E 11 B3 3E 61 5C CD A3 E5 15 24 AC 42 42 B6 77 47 D9 09 22 84 5E 26 1E 76 84 CD 74 9E
                            73 06 DA 7E AD 74 A3 73 54 B8 92 19 DB 1D 2B 23 4D FE 3E F9 9C CC 83 6E 2B 9A 10 0A EA 53 50 9A 94 C9 BF E3 61
                            36 DD A2 43 0B E1 D2 AC FD 46 67 4C C4 E4 93 32 0F E6 06 DC 5F 2F EC 2B 90 08 3A D1 49 70
13:36:24.957 | 7f | 3753  | 37 3d 78 36 a9 55 dd 3c 70 3b f4 56 17 bf b1 48 54 74 cf 3d 72 da 9b fa 3e c9 97 78 70 51 30 e9 65 72 6d 7c ec
                            4d 38 d0 26 10 3a fa da 70 23 72 74 3a 1f c8 70 d4 18 45 4f 18 d8 bc 89 8c 2e 7f 5b cb cf b5 f6 3e c5 b1 87 fe
                            58 b2 55 97 80 0f 97 23 e3 5e 97 eb 2b 69 07 da ef cd 63 55 01 ac e3 0a b3 63 ef 2c 7b 01 75 85 43 b1 9a b7 c1
                            71 09 ed 4f f5 1a 5e cb 8d 10 ff b6 a8 ff  |  -74 CRC error
                            OG Data:
                            Inverted Data:
                            C8 C2 87 C9 56 AA 22 C3 8F C4 0B A9 E8 40 4E B7 AB 8B 30 C2 8D 25 64 05 C1 36 68 87 8F AE CF 16 9A 8D 92 83 13
                            B2 C7 2F D9 EF C5 05 25 8F DC 8D 8B C5 E0 37 8F 2B E7 BA B0 E7 27 43 76 73 D1 80 A4 34 30 4A 09 C1 3A 4E 78 01
                            A7 4D AA 68 7F F0 68 DC 1C A1 68 14 D4 96 F8 25 10 32 9C AA FE 53 1C F5 4C 9C 10 D3 84 FE 8A 7A BC 4E 65 48 3E
                            8E F6 12 B0 0A E5 A1 34 72 EF 00 49 57 00
13:36:27.962 | a5 | 26500 | 5a 59 b0 bf f0 18 cd 0b d0 43 68 cd ba 63 7c 78 ef ce c6 68 5b ff ff ff d4 91 c1 1f 6a 9a 7e f8 ff ff ed 8e 2a
                            5f 7d f1 84 3d 1f c4 d6 f7 7d 91 c2 7d 74 75 cb a1 5d 70 69 88 7a 98 b0 c9 25 0c ac 42 4e f2 e4 1f 0f 29 44 0b
                            e4 13 8e 5b 6e 6c 2b b4 fd 87 5c 99 cc c5 3d 23 78 16 b3 d2 d7 52 be c8 b1 79 47 15 96 17 66 69 e4 1d 8a ad 63
                            a6 d6 d6 fa c1 d6 6f 4f c1 b4 37 3a 94 29 6e e0 ab 7e 46 0c da 9f a9 fc 42 f1 b2 a8 d0 56 94 06 2c 64 65 97 ca
                            a6 3b e5 ae c2 3a e3 96 09 97 53 8a b5 14 27  | -100 CRC error
                            OG Data:
                            Inverted Data:
                            A5 A6 4F 40 0F E7 32 F4 2F BC 97 32 45 9C 83 87 10 31 39 97 A4 00 00 00 2B 6E 3E E0 95 65 81 07 00 00 12 71 D5
                            A0 82 0E 7B C2 E0 3B 29 08 82 6E 3D 82 8B 8A 34 5E A2 8F 96 77 85 67 4F 36 DA F3 53 BD B1 0D 1B E0 F0 D6 BB F4
                            1B EC 71 A4 91 93 D4 4B 02 78 A3 66 33 3A C2 DC 87 E9 4C 2D 28 AD 41 37 4E 86 B8 EA 69 E8 99 96 1B E2 75 52 9C
                            59 29 29 05 3E 29 90 B0 3E 4B C8 C5 6B D6 91 1F 54 81 B9 F3 25 60 56 03 BD 0E 4D 57 2F A9 6B F9 D3 9B 9A 68 35
                            59 C4 1A 51 3D C5 1C 69 F6 68 AC 75 4A EB D8
13:36:32.741 | c0 | 20288 | 99 dc fb d5 8b d1 fd 86 5c bf 0f e1 57 9e 42 88 61 14 38 f2 07 55 30 91 7c 5a 0d 82 86 ea cf 03 17 bc 13 fe 4c
                            12 a6 21 fc e5 56 7e be 3b 59 03 7e 46 ef db 0e 65 7b 4d c7 d0 d7 ec ca 90 41 20 24 8c 2c 82 20 8c ab fe 2b fb
                            a6 3f 64 68 32 ea e0 f3 c5 be aa 1d 6f 36 a6 45 73 c0 1a c6 a2 f6 d4 e9 44 bb 4e 4a cf 42 8e 43 25 17 5c e7 6d
                            bd 16 5a 7e 8c 80 5a 79 3f 9e 0d 96 a1 54 5b 4c 94 dc df db 50 14 35 7f 4f 3b 24 c2 11 8e 35 b6 5d 6c b6 43 a6
                            e5 d1 7d 90 51 f6 4d 7e 4a 54 99 4d 22 61 61 17 b0 ad b6 b6 1a f9 e0 dd 4f ff ff ff ff ea 39 ff ff f8 3f 8f a6
                            eb 23 87 9e fd  | -100 CRC error
                            OG Data:
                            eb 23 87 9e fd
                            Inverted Data:
                            66 23 04 2A 74 2E 02 79 A3 40 F0 1E A8 61 BD 77 9E EB C7 0D F8 AA CF 6E 83 A5 F2 7D 79 15 30 FC E8 43 EC 01 B3
                            ED 59 DE 03 1A A9 81 41 C4 A6 FC 81 B9 10 24 F1 9A 84 B2 38 2F 28 13 35 6F BE DF DB 73 D3 7D DF 73 54 01 D4 04
                            59 C0 9B 97 CD 15 1F 0C 3A 41 55 E2 90 C9 59 BA 8C 3F E5 39 5D 09 2B 16 BB 44 B1 B5 30 BD 71 BC DA E8 A3 18 92
                            42 E9 A5 81 73 7F A5 86 C0 61 F2 69 5E AB A4 B3 6B 23 20 24 AF EB CA 80 B0 C4 DB 3D EE 71 CA 49 A2 93 49 BC 59
                            1A 2E 82 6F AE 09 B2 81 B5 AB 66 B2 DD 9E 9E E8 4F 52 49 49 E5 06 1F 22 B0 00 00 00 00 15 C6 00 00 07 C0 70 59
                            14 DC 78 61 02
13:36:45.705 | 9e | 19835 | 48 b1 94 78 33 ed 37 d4 98 98 2d 9f 99 21 85 80 73 4d de 05 94 07 0a d4 a3 10 0a 89 24 a5 96 46 bf 4c db b7 69
                            0a 24 12 db 04 86 0d b7 3c 91 d0 f1 3d bf d3 ed a8 d6 f5 4d f4 f4 24 18 5f 73 a7 59 8e d7 e7 14 af 59 d9 4d ee
                            44 09 18 1e ab b1 c5 58 b1 d6 28 34 7b fe 3d d5 f3 63 b1 86 68 81 6a 2e 02 12 1a d7 31 3a da d7 aa cf 4a 19 f9
                            37 cd 7f ff ff ff be 1c c9 64 4a 67 fd 6f 6c 77 2b de d4 d5 f4 49 bf ef 96 22 e7 cf 3e c3 9d 7f fc 85 a1 61 47
                            c1 d6 c8 6f 77 f3 b8 1c  | -100 CRC error
                            Inverted Data:
                            B7 4E 6B 87 CC 12 C8 2B 67 67 D2 60 66 DE 7A 7F 8C B2 21 FA 6B F8 F5 2B 5C EF F5 76 DB 5A 69 B9 40 B3 24 48 96
                            F5 DB ED 24 FB 79 F2 48 C3 6E 2F 0E C2 40 2C 12 57 29 0A B2 0B 0B DB E7 A0 8C 58 A6 71 28 18 EB 50 A6 26 B2 11
                            BB F6 E7 E1 54 4E 3A A7 4E 29 D7 CB 84 01 C2 2A 0C 9C 4E 79 97 7E 95 D1 FD ED E5 28 CE C5 25 28 55 30 B5 E6 06
                            C8 32 80 00 00 00 41 E3 36 9B B5 98 02 90 93 88 D4 21 2B 2A 0B B6 40 10 69 DD 18 30 C1 3C 62 80 03 7A 5E 9E B8
                            3E 29 37 90 88 0C 47 E3
13:36:57.863 | 98 | 20416 | 3f f2 6a 22 fc 3e 75 c8 87 b7 a7 20 f5 2c ad 2f b8 44 03 be 7d 65 58 64 dd 8a a1 a2 81 e7 79 97 f3 15 42 47 05
                            b8 da 97 4d 46 28 6a b1 db 76 a9 34 34 97 1d ef 83 79 c1 58 00 ee 1b 4e 46 e4 07 86 e9 5e f3 76 12 a4 1c e8 91
                            17 2d c3 25 5a 22 e7 99 60 74 67 74 e3 47 bd 36 a7 d5 e5 4d 25 93 18 54 dc 91 54 40 f3 54 b3 79 60 8c b0 b8 06
                            39 f6 7d f5 3c 41 3c 76 83 fd 03 ed e7 18 b6 f6 c0 83 d5 b8 17 b3 c8 09 0c 6e ab 52 50 3e b3 a6 fe 85 b3 5e 37
                            cd 83  |  -99 CRC error
                            Inverted Data:
                            C0 0D 95 DD 03 C1 8A 37 78 48 58 DF 0A D3 52 D0 47 BB FC 41 82 9A A7 9B 22 75 5E 5D 7E 18 86 68 0C EA BD B8 FA
                            47 25 68 B2 B9 D7 95 4E 24 89 56 CB CB 68 E2 10 7C 86 3E A7 FF 11 E4 B1 B9 1B F8 79 16 A1 0C 89 ED 5B E3 17 6E
                            E8 D2 3C DA A5 DD 18 66 9F 8B 98 8B 1C B8 42 C9 58 2A 1A B2 DA 6C E7 AB 23 6E AB BF 0C AB 4C 86 9F 73 4F 47 F9
                            C6 09 82 0A C3 BE C3 89 7C 02 FC 12 18 E7 49 09 3F 7C 2A 47 E8 4C 37 F6 F3 91 54 AD AF C1 4C 59 01 7A 4C A1 C8
                            32 7C
13:37:01.620 | fb | 41317 | b2 45 ec 16 37 35 b8 97 a6 2f 06 03 31 e1 e8 f1 ac d6 c0 07 18 03 ff 4c 9c 86 c4 33 63 a5 ea 1d f7 8e 26 04 73
                            73 87 a9 af 5f 29 63 5e 2e 81 c4 bf 21 e5 12 b2 34 b9 a8 ab 0c 40 f7 2f 10 1a 27 93 aa d4 a1 36 f3 21 3d 9d 39
                            04 c5 2d c7 ec da ca 56 cf 5a 52 16 40 84 e9 11 ec a8 19 fb a0 48 49 59 20 f4 86 b9 8e 86 6d ec d3 34 41 a8 be
                            28 43 7a 27 2f e8 09 d2 21 0e 7c 27 e4 e6 81 db 5f 62 80 c2 77 21 76 12 c4 93 26 73 2c 66 54 af 04 be 23 79 2b
                            a3 11 75 a7 0f 7a e0 34 50 7b d1 32 f7 c2 ac 29 ad e5 8a 48 d3 3e cf 11 ce cb 50 91 6c 34 dd 7a cc b2 c5 55 e5
                            ae 85 82 68 54 04 3d 78 d2 40 07 79 30 ec 2c 5e 9b 11 d3 7d c7 7e 1f 51 2d 4c df ba 8d 52 38 e9 4c 3a 44 ef 8c
                            cb 33 63 85 3c 90 88 17 de b4 64 8f 40 36 3e 21 d2 9e 0e b4 8d 99 09 3f 9e a3 0f  |  -99 CRC error
                            Inverted Data:
                            4D BA 13 E9 C8 CA 47 68 59 D0 F9 FC CE 1E 17 0E 53 29 3F F8 E7 FC 00 B3 63 79 3B CC 9C 5A 15 E2 08 71 D9 FB 8C
                            8C 78 56 50 A0 D6 9C A1 D1 7E 3B 40 DE 1A ED 4D CB 46 57 54 F3 BF 08 D0 EF E5 D8 6C 55 2B 5E C9 0C DE C2 62 C6
                            FB 3A D2 38 13 25 35 A9 30 A5 AD E9 BF 7B 16 EE 13 57 E6 04 5F B7 B6 A6 DF 0B 79 46 71 79 92 13 2C CB BE 57 41
                            D7 BC 85 D8 D0 17 F6 2D DE F1 83 D8 1B 19 7E 24 A0 9D 7F 3D 88 DE 89 ED 3B 6C D9 8C D3 99 AB 50 FB 41 DC 86 D4
                            5C EE 8A 58 F0 85 1F CB AF 84 2E CD 08 3D 53 D6 52 1A 75 B7 2C C1 30 EE 31 34 AF 6E 93 CB 22 85 33 4D 3A AA 1A
                            51 7A 7D 97 AB FB C2 87 2D BF F8 86 CF 13 D3 A1 64 EE 2C 82 38 81 E0 AE D2 B3 20 45 72 AD C7 16 B3 C5 BB 10 73
                            34 CC 9C 7A C3 6F 77 E8 21 4B 9B 70 BF C9 C1 DE 2D 61 F1 4B 72 66 F6 C0 61 5C F0
Thank you
15:21:07.844 | cb | 59432 | 90 ac 4f ff ff ff ff ff ff ff ff ff ff ff ff ff e6 1d dd d5 5d 0c ba ca 39 51 f6 8f ea f2 fc 5b 2c fe 95 95 a2 d2 ea f0 be 93 00 b0 14 a1 3a 5c e8 4d 24 fa 73 4e 0e e0 19 5b c0 4e 36 0d 92 bc 03 31 87 2a a4 5b a0 61 86 7e 85 15 91 e9 78 44 cb 01 e0 89 c4 49 a6 33 cd 99 fb 48 a4 f6 2c e8 f1 62 a5 05 81 b5 c3 a3 81 8f 6a 77 07 07 db 28 8d c5 22 83 9b e3 9d c8 50 e3 cd 2b 5b a9 e0 85 38 88 d6 49 a3 a8 31 a3 9b 73 78 e1 70 ed 56 55 b3 37 8c 3a f4 89 8e ab 27 fb 75 8d e2 aa e2 5e 79 21 3d 55 ad 94 1c d8 03 2c 4f 6d 09 cd ae ef 3d 96 3a b6 f5 cd 9e 12 d9 f0 c7 75 84 75 83 8d 75 48 d1 e7 0c 89 3a 95 7c  | -114 CRC error
15:21:16.851 | 43 | 2311 | ff ff ff ff ff ff ff ff ff ff ff ff ff f4 7a e6 54 8a 0c 0c 19 f4 8c 76 21 80 04 10 6f ff ff ff ff ff ff ff ff ff ff ff ff ff fa 10 81 2a 24 e0 69 90 04 40 02 0b 94 a0 e8 42 d0 90 20 30 80 44 f4  | -113 CRC error
15:21:20.339 | bf | 32767 | db fd f5 ef ff de 7f f9 fd fd f7 fe ff ff ff ff ff ff ff ff ff ff ff ff ff ff fe fb ac ff 43 54 fe 7f 79 df ff 76 77 ce fd ab 7f af ff ff ff ff ff ff ff ff ff ff ff ff ff f6 f9 7f d9 e5 ff ea 9a fe d7 3a bf bf f7 f9 fa ed 7f f7 5e ff dc ff f7 ff fd f7 7d f3 f7 bf ff cd ee cf ff f7 ff fb f7 ff 7f de ea df e7 f7 af 7f 7c 8e ff 7f f7 ff 4d 1f cd fe 9d fd 7a 5f ff fd eb ff 79 8d f7 df ee ee ef ff f5 f7 f7 fe ca fd 7f bb f7 e7 f3 f9 78 7d ff f7 fe fd 7f ef bf bd 7e 7e ef fb 7e db fe 86 df fd 3f f2 2f ff db ff bd ba 79 d7 f9 ff fe df f5 e7 ef ae db ff d7 5f ef ef fd  | -113 CRC error
15:21:20.671 | 7f | 42233 | ee 23 e5 c6 49 cb 43 97 dd 6b f7 77 f5 bf 18 4f 3c ba a3 8c 21 2b de d5 27 fe fe d3 70 50 5e b6 cf 01 a8 82 73 9a a6 74 a4 bc 0c bc 58 d8 e0 46 41 d4 11 51 36 22 aa ac 22 c5 57 4a 8a b2 a8 ac 59 6e 65 8f 5f 78 09 25 f2 22 36 82 99 ea 5c ab 4c 58 14 3b 0c 9f ab 51 cd 93 16 0f 6e 5b 90 d0 02 03 3a 81 81 f0 94 75 0a 2f ca df cb ca 1f bb b7 31 44 52 15 63 b3 8b d5 64 97 31 a4  | -112 CRC error
15:21:21.278 | ff | 65407 | ff df bd f9 67 bb f4 ff f7 5e fe 9e ff df fd 9b ed bb fa fa bb df c6 fb ed dd d8 7d 5f df af ed af df fd ef 7b fe 7e ff 7d e7 ef ff db ff f7 93 ef dc ec fd ef de e6 eb bd df f9 bc f7 7d fa ed 7b ad ef fe f6 fb ef 97 48 f9 d8 7f bf 7e 7b 3f 9b e7 ff 7b ef 7f ff 7f ff dd ff f7 fb ff ef fe fd ff ff df ff dd 7f 8b 72 97 cf 3e c6 fc ce db 6f ae de ef fd d7 7b 7f 19 5b f7 db dc 5f eb ff eb 3e cf dd f9 de c6 f6 9d fe d7 ff 0e f7 ff ff 23 db df 77 3b 76 fb 7f 6f fb d9 ad 7f cf 7f 6f 73 f6 9d df 18 7f ce 78 bd 9e 64 ef 7e de 39 5d 7a ff 9b b4 e6 3f ee fd f7 64 74 f7 e4 fe bf df fb be fb ff ee 55 6b 6d 9f df 0e ff ff fb ef 89 f9 bb 8f 5e 7d e2 fc fb d7 7a b0 49 cf b3 7f ab d7 96 a8 2d d5 be ef 57 f7 ff 5d f1 7b d9 d4 fb a9 5b cb e7 fb 75 ef 1e 82 fb fb 8e 7f  | -114 CRC error
15:21:21.586 | 7e | 64943 | bf 37 fe ef fa 9d 5f ff f9 be bb ff df 6f 9d 47 6d 78 2f ed bf 6d bf fd 8e fe 9d bd d6 9d 13 b4 f7 e6 f0 fe bd e3 e8 b9 de ff 59 cd a6 b5 e7 e7 fe b2 b3 dd f5 5b ba 46 7f 7e 7b d8 bc fa fd 5f 4f bf db ce f7 f5 77 ff fe 7f b7 f7 ff ff fb eb f7 5e f0 f7 ba 66 df df af 7e 6c ff 65 5f 7f ce a7 79 7e de a6 eb ef fd ad f7 47 fd ef fb fe f7 5d 5f ff ad 07 2d e9 2e 6f fb ff f5  | -113 CRC error
15:21:22.102 | ff | 65535 | ff ff ff ff fb ff ff ed ff ff 7f f7 ff ff fd ff eb fd df ff ff ff ff fe ff ff ff f7 ff bf ff df ff ff ff fb df ff ff ed ff ff ff ff ef ff bf ff ff fd af ff e7 ff ff de ff 7d ff fb fe ef bf ff ff ff ff ff ff f7 ff f7 77 ff ff ff ef 7f ff ff ff ff ff ff ff ff ff bf fd ef ff f7 ff fe ff ff bf ff ff ff bf fd df ff fb df ff fb ff ff ff ef ff be ff 7f ff ff ff ff ff ff be ff ff ff ff fd df f5 ff eb ff ff fe db 7d f7 f7 ed fb ff 6f ff ff ff ff ff ff ff 7f 7f ff ff ff ff ff f7 ef ff ff ff ff ff df df ff ff 7f f7 ff ff ff fb ff ff ff ff ff be df ff 7f be bd fd ff fe ff df eb ff ff ff ff df ff ff ff db ff ff fb ff fd df df ff ff ff ff ff ff ff 7f fd ff ff ff ff ff ff ff ff ff ff ff ff ff ff 7f ff ff ff ff ff ff ff ff ff bf ff ff ff ff ff ff ff ff ff ff ff ff  | -115 CRC error
15:21:22.605 | ff | 65535 | ff 7f ff ff df ff ff ff ff ff ff ff ff ff bf 7f ff ff fe ff ff ff fd fb 7f ff ff fd ff ff df ff ff f7 ff bf df ff ff ff ff ff fe ff fd ef ff f7 fa ff ff ff df ff ef ff ff fb ff f7 fb ff ff ff ff f7 fd ff ff ff bf ff ff ff fe ff fb ff ff ff db ff ff ff bf ff ff ff ff ef ef ff bf ef ff ff fb ff 7f ff fe ff 7b ff fc ff ff ff fd ff ff ff bb 7e f6 ff ef ff ff d7 ff ff f7 f6 f7 f7 ef bf f7 ff fd ff ff ff df bf ff ff fa ff ff ff ff ff fc ff ef fe bf ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff fb ff 7f ff ff ff fb ff ff ef df ff ff ff f7 bf ff ff ff ff ff fe ff ff ff f7 ff ff ff df ff ef db ff 7f ff df ff ff df ff ff ff fb fe df fb ff ff ff ff fe fe ff ff ff ff ff f5 ff ff ff ff bf ff f7 ff fe ff ef ff ff bf ff ff ff ff ff ff fb ff ff 7f 9f ff ff ed ff  | -115 CRC error
15:21:23.327 | 66 | 51809 | 47 4e c4 b7 ff ff ff ff ff ff ff ff ff ff ff ff ff fd 7d c9 3a 07 ee 8c 45 74 cd 7f fd 46 98 a3 8f 61 83 18 38 3b 28 f9 65 49 94 94 8f 5f 51 8c 6c 8e 6c b4 13 a5 3b 14 30 a5 77 39 df 26 cf 9d 71 6f 7f cc 31 c1 80 d2 b6 26 e1 97 d7 f1 e2 d3 13 0f 78 ef 95 56 63 b6 e8 79 dc a8 3e 0e 49 31 91 7d 08 0e  | -112 CRC error
15:21:26.180 | 87 | 6938 | 04 00 20 10 20 18 7f ff ff ff ff ff ff ff ff ff ff ff ff ff 07 20 00 01 00 02 01 00 31 10 00 00 00 00 21 12 10 29 00 00 10 1f ff ff ff ff ff ff ff ff ff ff ff ff ff 80 00 04 00 20 01 00 90 00 08 00 00 00 04 00 00 00 00 00 00 00 40 00 00 14 00 1f ff ff ff ff ff ff ff ff ff ff ff ff ff 80 40 00 00 04 2c 60 00 00 80 00 00 00 00 00 3f ff ff ff ff ff ff ff ff ff ff ff ff ff 0a 00 90 80 00 00 00 08 00  | -111 CRC error
  • Golden Data:
    8a5c2405510008ec7d
    8a5c2405514208e078
    8a5c2405514308667b
    Base Frequency: 433.92(433.919830)    Channel number: 0      Channel Spacing: 199.951172 kHz    Data Rate: 2.39897 kBaud
    14:32:37.500 | c3 | 41035 | b1 eb 65 03 a3 f5 49 e5 ab 3f ba bd de 05 36 09 8c e7 e6 7d 7a bc 36 83 b7 9e 8c 96 9f 51 ce 83 7d a9 ec 68 7f 93
                                54 e0 d3 9d 91 94 aa df fb 00 a2 44 14 4d ff e9 f7 af 9e b7 9a 9f ff ef 6e 35 23 6a c7 12 04 72 1d b0 96 fe 72 9e
                                2e 4a 59 ff 76 f4 f7 20 0e a1 75 bd 6e e2 37 c8 8a df e6 45 81 8e 8e 67 b6 1c c8 56 52 25 a9 d4 74 1d 55 8f 20 ea
                                f8 0e 8a 44 97 4d f8 14 2c a3 e8 23 04 f5 5d 95 42 80 b4 fc ae 3b 43 f5 79 b1 86 7b fb 6c dc 41 14 cd eb 86 76 40
                                63 3b 7b 0c 31 65 9a 04 ec 9d c9 30 17 89 5b aa 9d fb 51 d9 51 b3 bc 53 eb a8 7d 99 4c 52 8c 65 f0 49 a4 66 5b 49
                                dd 65 c1  | -100 CRC error
                                Inverted Data:
                                4E 14 9A FC 5C 0A B6 1A 54 C0 45 42 21 FA C9 F6 73 18 19 82 85 43 C9 7C 48 61 73 69 60 AE 31 7C 82 56 13 97 80 6C
                                AB 1F 2C 62 6E 6B 55 20 04 FF 5D BB EB B2 00 16 08 50 61 48 65 60 00 10 91 CA DC 95 38 ED FB 8D E2 4F 69 01 8D 61
                                D1 B5 A6 00 89 0B 08 DF F1 5E 8A 42 91 1D C8 37 75 20 19 BA 7E 71 71 98 49 E3 37 A9 AD DA 56 2B 8B E2 AA 70 DF 15
                                07 F1 75 BB 68 B2 07 EB D3 5C 17 DC FB 0A A2 6A BD 7F 4B 03 51 C4 BC 0A 86 4E 79 84 04 93 23 BE EB 32 14 79 89 BF
                                9C C4 84 F3 CE 9A 65 FB 13 62 36 CF E8 76 A4 55 62 04 AE 26 AE 4C 43 AC 14 57 82 66 B3 AD 73 9A 0F B6 5B 99 A4 B6
                                22 9A 3E
    14:32:41.784 | fa | 43355 | d0 15 17 e5 ff 3d 9d 62 86 cc 35 72 db d7 6b 33 3c 0a 8c dd f4 26 4c 8c 0d e2 bc f8 bf e8 21 6d 25 12 20 36 35 d5
                                d6 d3 49 dc 15 9f 14 33 b9 e9 26 1d 4a 87 2b a7 bd fa 03 07 14 9b d4 20 b7 91 a7 d9 46 a4 21 c4 2f 3a bd 3b 38 1b
                                cb 85 dd d5 19 f2 6b d1 14 2d 2c 96 1e 34 49 bb 31 f4 dc 4d db cd ef a9 a9 7c 74 8f f9 e6 02 f1 29 07 9b 16 64 e5
                                6d 29 b8 c3 a9 34 da 49 b7 f0 28 63 c1 28 65 2e e1 05 dd f7 c4 eb e3 6b 16 12 29 0a f1 5d 6f b0 a4 f5 c2 6b da 7c
                                2a 6e c2 cf a6 53 24 ed bb 35 50 f7 40 fc b1 0d 6d db 09 0c cf a1 16 82 e7 8d 97 96 c2 f5 ce a0 5e 11 49 cc 87 f3
                                7a 61 2a a0 61 11 85 a6 d3 d8 07 4d 88 9f d0 40 c4 57 a6 d3 09 7d 37 db 6e 31 4e 61 94 43 b4 7c 87 51 f7 cc 9f 37
                                c4 8b db ab d8 e6 22 9e e9 f6 7e 1a ea 78 e1 47 e7 98 64 d3  |  -98 CRC error
                                Inverted Data:
                                2F EA E8 1A 00 C2 62 9D 79 33 CA 8D 24 28 94 CC C3 F5 73 22 0B D9 B3 73 F2 1D 43 07 40 17 DE 92 DA ED DF C9 CA 2A
                                29 2C B6 23 EA 60 EB CC 46 16 D9 E2 B5 78 D4 58 42 05 FC F8 EB 64 2B DF 48 6E 58 26 B9 5B DE 3B D0 C5 42 C4 C7 E4
                                34 7A 22 2A E6 0D 94 2E EB D2 D3 69 E1 CB B6 44 CE 0B 23 B2 24 32 10 56 56 83 8B 70 06 19 FD 0E D6 F8 64 E9 9B 1A
                                92 D6 47 3C 56 CB 25 B6 48 0F D7 9C 3E D7 9A D1 1E FA 22 08 3B 14 1C 94 E9 ED D6 F5 0E A2 90 4F 5B 0A 3D 94 25 83
                                D5 91 3D 30 59 AC DB 12 44 CA AF 08 BF 03 4E F2 92 24 F6 F3 30 5E E9 7D 18 72 68 69 3D 0A 31 5F A1 EE B6 33 78 0C
                                85 9E D5 5F 9E EE 7A 59 2C 27 F8 B2 77 60 2F BF 3B A8 59 2C F6 82 C8 24 91 CE B1 9E 6B BC 4B 83 78 AE 08 33 60 C8
                                3B 74 24 54 27 19 DD 61 16 09 81 E5 15 87 1E B8 18 67 9B 2C
    14:32:43.641 | 31 | 3397  | 4a 9b 0e 79 e0 c4 5e ac 7e f2 34 fc 57 d4 b5 32 a5 38 5b 99 4d a1 0e 83 a9 74 09 a8 3a bf 4e 89 f5 fe 26 54 f6 2e
                                d7 ff 5e 20 69 56 c3 00 b6  | -101 CRC error
                                Inverted Data:
                                B5 64 F1 86 1F 3B A1 53 81 0D CB 03 A8 2B 4A CD 5A C7 A4 66 B2 5E F1 7C 56 8B F6 57 C5 40 B1 76 0A 01 D9 AB 09 D1
                                28 00 A1 DF 96 A9 3C FF 49
    14:32:46.006 | 96 | 33474 | 71 96 25 d6 50 a7 c5 3d cd 9c f9 cf ee 8e e4 fc 46 e1 f2 6b 0a da 61 14 94 3e 2b d7 fd 7b 97 06 91 aa 74 b0 e7 d4
                                ef 2f 5d d1 fd d9 f2 8c a7 dd b1 13 56 87 cc cc 7b 0b cc 00 61 4b e9 56 aa fa 08 87 56 76 fa 76 97 52 fe 85 bd 0b
                                c6 7d 2c 30 d1 4c 74 58 e9 e3 82 f9 ee a9 fa 30 e8 7a 68 73 e2 aa 84 2f a4 5c 39 ab 3e 59 09 ee 56 ed fb 50 21 de
                                f1 49 a4 62 24 ab 83 53 88 ea 27 e9 18 c8 cb 63 12 8f b7 e4 19 6c 7a df 81 0a 4f ac 21 5b eb f5 14 34  | -100 CRC error
                                Inverted Data:
                                8E 69 DA 29 AF 58 3A C2 32 63 06 30 11 71 1B 03 B9 1E 0D 94 F5 25 9E EB 6B C1 D4 28 02 84 68 F9 6E 55 8B 4F 18 2B
                                10 D0 A2 2E 02 26 0D 73 58 22 4E EC A9 78 33 33 84 F4 33 FF 9E B4 16 A9 55 05 F7 78 A9 89 05 89 68 AD 01 7A 42 F4
                                39 82 D3 CF 2E B3 8B A7 16 1C 7D 06 11 56 05 CF 17 85 97 8C 1D 55 7B D0 5B A3 C6 54 C1 A6 F6 11 A9 12 04 AF DE 21
                                0E B6 5B 9D DB 54 7C AC 77 15 D8 16 E7 37 34 9C ED 70 48 1B E6 93 85 20 7E F5 B0 53 DE A4 14 0A EB CB
    14:32:50.683 | df | 44353 | 6c 2a c0 c7 6d 41 b2 43 ca da fb e2 23 51 f2 90 72 6e ff 54 18 99 c2 bb 7a 29 20 38 98 ec e4 3d 9f 6b 11 9f 61 34 95
                                d6 86 68 c1 40 a8 fe 2f 0a 08 24 be 75 8a 17 e6 c9 cc e4 86 3e be a3 a5 81 63 29 02 bf 93 b5 19 d9 44 d3 63 da ed 7a
                                97 0b d4 70 ae bf ac 52 1e e3 78 37 c9 e3 d9 87 6a 8a 2e 21 29 64 ff 6e 7c ab 3d e6 5a 36 3a 08 f3 5e 3d 65 15 cb a0
                                ff 72 f7 ae fe c4 27 27 9d 8d 53 18 9f ff 9f 29 c1 e7 e8 22 58 b4 bf 12 19 ee ae f8 04 b6 5b 48 81 c7 e9 f5 39 c5 e4
                                a3 b0 9b a9 1f bd c0 ed 12 8c dd ca 0c 3f a0 1a c9 39 d1 1e 09 76 58 af 3a df 4c 23 d9 a9 ef e4 b8 03 bc ea 8b 4e d7
                                71 17 9e 36 15 b1 8c 49 41 50 0e 56 b8 c6 2f d2 71 a9 7f ad 1c 64 55 51 59 f9  |  -79 CRC error
                                Inverted Data:
                                93 D5 3F 38 92 BE 4D BC 35 25 04 1D DC AE 0D 6F 8D 91 00 AB E7 66 3D 44 85 D6 DF C7 67 13 1B C2 60 94 EE 60 9E CB 6A
                                29 79 97 3E BF 57 01 D0 F5 F7 DB 41 8A 75 E8 19 36 33 1B 79 C1 41 5C 5A 7E 9C D6 FD 40 6C 4A E6 26 BB 2C 9C 25 12 85
                                68 F4 2B 8F 51 40 53 AD E1 1C 87 C8 36 1C 26 78 95 75 D1 DE D6 9B 00 91 83 54 C2 19 A5 C9 C5 F7 0C A1 C2 9A EA 34 5F
                                00 8D 08 51 01 3B D8 D8 62 72 AC E7 60 00 60 D6 3E 18 17 DD A7 4B 40 ED E6 11 51 07 FB 49 A4 B7 7E 38 16 0A C6 3A 1B
                                5C 4F 64 56 E0 42 3F 12 ED 73 22 35 F3 C0 5F E5 36 C6 2E E1 F6 89 A7 50 C5 20 B3 DC 26 56 10 1B 47 FC 43 15 74 B1 28
                                8E E8 61 C9 EA 4E 73 B6 BE AF F1 A9 47 39 D0 2D 8E 56 80 52 E3 9B AA AE A6 06
    14:32:51.675 | 6c | 8606  | d3 4e 75 e2 8f 95 15 f5 fb d0 94 bf 70 bf fc ea d8 4b 6d eb 1b 6a 60 7f ee 8a 77 bb b1 11 b0 e0 80 da 54 3d c5 00 34
                                d7 af b6 27 8d 8d 20 ac ae d5 6a 26 55 c0 dc 1a 2b 7a 8d f3 61 fd 00 7b b7 33 70 a7 67 ce 8f 2f f0 72 77 1c 25 05 d2
                                c0 0a 2c eb 47 9f b5 90 cb 41 9d 03 ef fa 43 fe 46 23 06 4c 32 07 4e 30 03 e6 69 b6  |  -99 CRC error
                                Inverted Data:
                                2C B1 8A 1D 70 6A EA 0A 04 2F 6B 40 8F 40 03 15 27 B4 92 14 E4 95 9F 80 11 75 88 44 4E EE 4F 1F 7F 25 AB C2 3A FF CB
                                28 50 49 D8 72 72 DF 53 51 2A 95 D9 AA 3F 23 E5 D4 85 72 0C 9E 02 FF 84 48 CC 8F 58 98 31 70 D0 0F 8D 88 E3 DA FA 2D
                                3F F5 D3 14 B8 60 4A 6F 34 BE 62 FC 10 05 BC 01 B9 DC F9 B3 CD F8 B1 CF FC 19 96 49
    14:32:55.081 | 1b | 29394 | 76 cb 73 ad 90 7f 34 31 68 46 b9 42 16 26 42 0a c1 a5 e7 54 64 80 9a f8 aa  | -100 CRC error
                                Inverted Data:
                                89 34 8C 52 6F 80 CB CE 97 B9 46 BD E9 D9 BD F5 3E 5A 18 AB 9B 7F 65 07 55
    14:32:57.860 | 15 | 36286 | bf ad bd 48 a5 aa 5e 7a d4 03 c4 f9 3b c4 c6 bb 12 d6 4d  | -101 CRC error
                                Inverted Data:
                                40 52 42 B7 5A 55 A1 85 2B FC 3B 06 C4 3B 39 44 ED 29 B2
    14:32:59.071 | 56 | 33223 | d2 a8 a1 d8 4f 77 de 97 92 73 d9 90 c0 9c 22 46 59 37 97 a9 68 cb eb 17 b4 2e 62 00 47 fd 7d 0b 71 9a 53 22 ea 2e 8d
                                26 a7 3e 11 06 4b 11 bd a8 1a 41 d5 f8 a0 16 eb 27 23 af e0 28 6f 26 e9 72 8a 50 43 70 e8 31 0d 10 35 26 44 9d 4a 96
                                e8 1c aa 4d 7a 44  | -100 CRC error
                                Inverted Data:
                                2D 57 5E 27 B0 88 21 68 6D 8C 26 6F 3F 63 DD B9 A6 C8 68 56 97 34 14 E8 4B D1 9D FF B8 02 82 F4 8E 65 AC DD 15 D1 72
                                D9 58 C1 EE F9 B4 EE 42 57 E5 BE 2A 07 5F E9 14 D8 DC 50 1F D7 90 D9 16 8D 75 AF BC 8F 17 CE F2 EF CA D9 BB 62 B5 69
                                17 E3 55 B2 85 BB
    14:33:00.008 | 6b | 5068  | 60 cb 7b 76 f8 97 5d e3 16 b7 56 88 3b 1b 38 bc ce 0e dd aa fc 9b 12 1b 72 94 25 40 19 3a 4f e1 b5 fb e7 71 c9 aa ab
                                b0 c4 f0 c9 9b bc f4 70 c5 f0 69 f4 e6 32 84 b9 2f 3c 15 8c 67 1f e9 d2 aa f6 bc f9 8f 3f cd a0 b1 3f 41 fb 61 09 0c
                                eb 7d 4e c0 8d 7f 07 c9 93 6b 18 51 fa 9f 58 29 28 f8 00 50 a1 61 4f 71 b1 85 54  | -100 CRC error
                                Inverted Data:
                                9F 34 84 89 07 68 A2 1C E9 48 A9 77 C4 E4 C7 43 31 F1 22 55 03 64 ED E4 8D 6B DA BF E6 C5 B0 1E 4A 04 18 8E 36 55 54
                                4F 3B 0F 36 64 43 0B 8F 3A 0F 96 0B 19 CD 7B 46 D0 C3 EA 73 98 E0 16 2D 55 09 43 06 70 C0 32 5F 4E C0 BE 04 9E F6 F3
                                14 82 B1 3F 72 80 F8 36 6C 94 E7 AE 05 60 A7 D6 D7 07 FF AF 5E 9E B0 8E 4E 7A AB
    14:33:00.532 | 0e | 17666 | ca cc 7f d5 de 2d a9 8f 14 8e c1 b9  | -100 CRC error
                                Inverted Data:
                                35 33 80 2A 21 D2 56 70 EB 71 3E 46
    14:33:02.119 | 5b | 7149  | d2 77 2e 7c e5 fc 2b 16 4c ec e1 07 50 bb db fa ff 31 47 14 1b 99 2d c4 63 b7 2d e6 23 fe b7 44 a9 4e 5d 26 ec e1 7a
                                7f 70 b6 9f 24 1c 3f 87 65 87 50 3e e4 72 07 04 93 fa 7c e6 d2 b8 3a c3 35 71 59 bb ca 82 8f 63 4d bd 03 0d fa 3d 22
                                5f 3c 42 e1 fa 4e fd fb 58 25 98  | -100 CRC error
                                Inverted Data:
                                2D 88 D1 83 1A 03 D4 E9 B3 13 1E F8 AF 44 24 05 00 CE B8 EB E4 66 D2 3B 9C 48 D2 19 DC 01 48 BB 56 B1 A2 D9 13 1E 85
                                80 8F 49 60 DB E3 C0 78 9A 78 AF C1 1B 8D F8 FB 6C 05 83 19 2D 47 C5 3C CA 8E A6 44 35 7D 70 9C B2 42 FC F2 05 C2 DD
                                A0 C3 BD 1E 05 B1 02 04 A7 DA 67
    14:33:04.154 | 94 | 52983 | 86 3b 90 a9 71 02 a8 f7 d3 3b 47 b0 84 bc 8b 54 dd d7 eb 72 48 50 1b 5a d1 74 d0 13 a1 47 c7 52 6d 4c df 8c 0f d4 78
                                fc 75 df 07 61 c9 42 bf ce fb 44 7f e8 96 ed 76 e2 38 38 f2 55 e8 97 60 91 64 d5 b2 ab a2 3c 5d c2 ce 51 8a 5e b0 f8
                                e5 4d 52 70 e1 19 46 a7 b0 80 65 b4 e9 4a 0f 27 c4 b9 4d ed b2 2c 75 66 ed c4 6b 9e 80 36 d4 07 20 d3 d2 49 aa fb 05
                                e7 40 dd 8e 71 c3 cf 6d 31 35 e9 73 8c 3d 25 14 bd 12 1c 83 50 54 e6 46 cb df ef 89 55  |  -98 CRC error
                                Inverted Data:
                                79 C4 6F 56 8E FD 57 08 2C C4 B8 4F 7B 43 74 AB 22 28 14 8D B7 AF E4 A5 2E 8B 2F EC 5E B8 38 AD 92 B3 20 73 F0 2B 87
                                03 8A 20 F8 9E 36 BD 40 31 04 BB 80 17 69 12 89 1D C7 C7 0D AA 17 68 9F 6E 9B 2A 4D 54 5D C3 A2 3D 31 AE 75 A1 4F 07
                                1A B2 AD 8F 1E E6 B9 58 4F 7F 9A 4B 16 B5 F0 D8 3B 46 B2 12 4D D3 8A 99 12 3B 94 61 7F C9 2B F8 DF 2C 2D B6 55 04 FA
                                18 BF 22 71 8E 3C 30 92 CE CA 16 8C 73 C2 DA EB 42 ED E3 7C AF AB 19 B9 34 20 10 76 AA
    14:33:06.813 | 1b | 62551 | 0f 40 b7 50 6d 41 6a 5d 61 3c 8b d0 dc ff b7 09 27 35 d9 62 e8 0a 47 34 94  |  -99 CRC error
                                Inverted Data:
                                F0 BF 48 AF 92 BE 95 A2 9E C3 74 2F 23 00 48 F6 D8 CA 26 9D 17 F5 B8 CB 6B
    14:33:13.723 | 6b | 9507  | c1 9b 81 e8 82 33 45 a6 2c 8a d8 2a f8 51 d4 52 0d f9 04 bf 10 29 97 29 2f 7f 8f ed be ee 3d b1 f7 34 d2 f9 b5 44 32
                                fa 38 01 9e 42 ee b2 a4 b6 c8 66 a2 41 cf 36 d7 85 d9 b1 60 69 e2 cc 8f 1c 70 dc 86 fc 7e d7 a4 85 90 c6 61 4d e3 87
                                51 af c9 15 95 f0 55 49 42 04 f6 0a 9f e6 bc b6 e2 af 98 ed 9b af d7 7a 2d b5 f2  | -100 CRC error
                                Inverted Data:
                                3E 64 7E 17 7D CC BA 59 D3 75 27 D5 07 AE 2B AD F2 06 FB 40 EF D6 68 D6 D0 80 70 12 41 11 C2 4E 08 CB 2D 06 4A BB CD
                                05 C7 FE 61 BD 11 4D 5B 49 37 99 5D BE 30 C9 28 7A 26 4E 9F 96 1D 33 70 E3 8F 23 79 03 81 28 5B 7A 6F 39 9E B2 1C 78
                                AE 50 36 EA 6A 0F AA B6 BD FB 09 F5 60 19 43 49 1D 50 67 12 64 50 28 85 D2 4A 0D
    14:33:16.111 | e6 | 22233 | d8 33 cd c9 c8 c7 8e 33 ad 26 67 ce b2 65 43 c7 e1 01 72 b8 2a 15 d0 02 33 3e 79 1b b9 b3 94 7d bb d2 64 63 86 46 c0
                                cd 98 a7 82 04 96 f6 09 1e 9b 3b 22 24 25 59 5b c7 4a 06 dc 9d 54 f2 8a b8 ba f4 43 c7 fe 96 0f bb 24 25 1d fb 83 bb
                                85 2d f0 6e 89 9d 04 b8 8c 6f 0a 70 93 4a 73 fe 1f 71 ec 2b 83 70 8d 3d 0b 37 8e 38 e5 2e 2a d9 03 91 3f e7 10 5c 62
                                1c 76 21 35 b7 d0 ad 87 88 a3 01 27 06 85 f4 7d 92 3e 2e e4 0a 44 a0 a9 7a a6 e8 0c 61 88 ac b6 a7 c8 5f 17 7b 0c 03
                                a3 4e 33 da 82 97 7f 48 90 18 a6 9e f3 a0 99 b9 bf ec 36 76 53 c3 26 0d 2e fe 35 c9 67 8d 29 cb ab f5 5e 5e d4 23 bd
                                d9 04 ce 30 50 e6 c3 c3 cb 1f 65 16 5f 83 d7 43 f1 1c 53 3a 66 6e 29 82 34 f4 5d 5d cc f2 3d 15 a2  | -101 CRC error
                                Inverted Data:
                                27 CC 32 36 37 38 71 CC 52 D9 98 31 4D 9A BC 38 1E FE 8D 47 D5 EA 2F FD CC C1 86 E4 46 4C 6B 82 44 2D 9B 9C 79 B9 3F
                                32 67 58 7D FB 69 09 F6 E1 64 C4 DD DB DA A6 A4 38 B5 F9 23 62 AB 0D 75 47 45 0B BC 38 01 69 F0 44 DB DA E2 04 7C 44
                                7A D2 0F 91 76 62 FB 47 73 90 F5 8F 6C B5 8C 01 E0 8E 13 D4 7C 8F 72 C2 F4 C8 71 C7 1A D1 D5 26 FC 6E C0 18 EF A3 9D
                                E3 89 DE CA 48 2F 52 78 77 5C FE D8 F9 7A 0B 82 6D C1 D1 1B F5 BB 5F 56 85 59 17 F3 9E 77 53 49 58 37 A0 E8 84 F3 FC
                                5C B1 CC 25 7D 68 80 B7 6F E7 59 61 0C 5F 66 46 40 13 C9 89 AC 3C D9 F2 D1 01 CA 36 98 72 D6 34 54 0A A1 A1 2B DC 42
                                26 FB 31 CF AF 19 3C 3C 34 E0 9A E9 A0 7C 28 BC 0E E3 AC C5 99 91 D6 7D CB 0B A2 A2 33 0D C2 EA 5D
    14:33:20.779 | 8b | 55412 | 3b ba eb ae 1d 92 b0 3f 0a 6d db 0c 7a 65 93 63 0e e5 a7 e9 d7 2c 68 a7 da 9d 34 68 13 3d 58 03 22 8d 37 8b 3c c0 ee
                                22 4e a5 ea 29 0a 75 e5 7c 2a 0a 1c 94 1f 27 be ae 8c 76 fc 01 39 54 66 25 60 2a 31 5d c0 d5 6a 46 9d 0a 97 71 af 5a
                                47 65 9f 04 be f5 65 e0 03 d5 5c f0 a6 2f a1 2a d1 43 35 86 be da 70 76 af 8d 5d 2b 1f fd e9 45 57 7e 5e 4b 69 66 c2
                                4e 7b 1d b4 72 d9 26 7e db d2 4f 6a 44 a8 09 13 2d 15 d8 33  | -101 CRC error
                                Inverted Data:
                                C4 45 14 51 E2 6D 4F C0 F5 92 24 F3 85 9A 6C 9C F1 1A 58 16 28 D3 97 58 25 62 CB 97 EC C2 A7 FC DD 72 C8 74 C3 3F 11
                                DD B1 5A 15 D6 F5 8A 1A 83 D5 F5 E3 6B E0 D8 41 51 73 89 03 FE C6 AB 99 DA 9F D5 CE A2 3F 2A 95 B9 62 F5 68 8E 50 A5
                                B8 9A 60 FB 41 0A 9A 1F FC 2A A3 0F 59 D0 5E D5 2E BC CA 79 41 25 8F 89 50 72 A2 D4 E0 02 16 BA A8 81 A1 B4 96 99 3D
                                B1 84 E2 4B 8D 26 D9 81 24 2D B0 95 BB 57 F6 EC D2 EA 27 CC
    14:33:23.790 | 30 | 50088 | fb 76 c1 1a a6 84 f3 45 33 e8 c4 33 20 aa bb 8c fb 46 ef 4b 7d e3 e4 c6 3b 59 d0 e1 d4 ff 41 86 04 b6 d8 84 30 63 ca
                                62 d8 2b f1 35 a1 7d  | -100 CRC error
                                Inverted Data:
                                04 89 3E E5 59 7B 0C BA CC 17 3B CC DF 55 44 73 04 B9 10 B4 82 1C 1B 39 C4 A6 2F 1E 2B 00 BE 79 FB 49 27 7B CF 9C 35
                                9D 27 D4 0E CA 5E 82
    14:33:26.050 | a8 | 1758  | bc 6e e6 7b 37 f5 c8 60 ee 98 7b 24 92 a9 90 5a 16 98 e0 51 a2 0d 0a 96 53 ed 23 ce b8 76 26 e4 53 fe b6 4f c5 e3 43
                                c5 f8 62 5b eb 47 4a 0e 28 24 7c a1 3a f4 fc 11 54 5c 22 1e 98 4f db 7e cc cf 75 39 05 ce aa 5e f9 5d 61 c4 dd 65 52
                                82 33 1e 8f e9 de 9f 31 c6 e9 5b 96 43 e9 a5 9c 54 db 7d ba 06 39 1c 1d aa 12 3d db 1d 19 63 c5 d0 d4 2f 6b 1d c3 f5
                                b4 59 84 23 86 88 72 a1 a5 69 b0 68 f2 d7 39 56 9a 3d 5c f4 57 29 59 8f 20 ef bf ff e2 a4 80 a0 c0 c3 61 1c 23 97 54
                                5e 5c b3 14 1d 7e 3f 0d 63 f4  |  -99 CRC error
                                Inverted Data:
                                43 91 19 84 C8 0A 37 9F 11 67 84 DB 6D 56 6F A5 E9 67 1F AE 5D F2 F5 69 AC 12 DC 31 47 89 D9 1B AC 01 49 B0 3A 1C BC
                                3A 07 9D A4 14 B8 B5 F1 D7 DB 83 5E C5 0B 03 EE AB A3 DD E1 67 B0 24 81 33 30 8A C6 FA 31 55 A1 06 A2 9E 3B 22 9A AD
                                7D CC E1 70 16 21 60 CE 39 16 A4 69 BC 16 5A 63 AB 24 82 45 F9 C6 E3 E2 55 ED C2 24 E2 E6 9C 3A 2F 2B D0 94 E2 3C 0A
                                4B A6 7B DC 79 77 8D 5E 5A 96 4F 97 0D 28 C6 A9 65 C2 A3 0B A8 D6 A6 70 DF 10 40 00 1D 5B 7F 5F 3F 3C 9E E3 DC 68 AB
                                A1 A3 4C EB E2 81 C0 F2 9C 0B
    14:33:29.652 | 07 | 12835 | e2 6a b4 2e 65  | -100 CRC error
                                Inverted Data:
                                1D 95 4B D1 9A
    14:33:31.244 | b7 | 35529 | ef dc 0c 2f 8f bf 89 7c 89 1d 04 13 ea b5 b5 f9 c9 f6 ee 3d bf ab 4c 78 f9 c6 47 f8 f8 27 bc eb ff 32 94 9b 8f fb 8e
                                bf ca 69 44 8c a8 e4 80 d7 e9 0a 43 ac 8e 1d 33 0a c5 e8 ef a7 05 66 f1 38 5d 26 69 c4 ce 6e 08 cc 6d 87 de 96 88 fd
                                14 59 2d 66 aa 5c 5c 42 91 f9 d7 55 5f f7 34 bf aa ae 17 75 1d 7c 44 66 cb 22 55 e4 03 ac 45 17 1c 35 47 d9 d0 fb aa
                                10 cb d3 e6 e2 45 10 88 91 6c db eb c0 bf 0f e1 61 6a 00 36 53 8b 5f 30 3d f7 e9 c3 ad 77 19 1c 11 f7 3b d0 7f a6 9c
                                1b 35 f2 43 eb 44 27 17 1d 81 46 24 2d e0 1c 5a 9b 1f da 3d cf 6f 6a 55 ea  | -100 CRC error
                                Inverted Data:
                                10 23 F3 D0 70 40 76 83 76 E2 FB EC 15 4A 4A 06 36 09 11 C2 40 54 B3 87 06 39 B8 07 07 D8 43 14 00 CD 6B 64 70 04 71
                                40 35 96 BB 73 57 1B 7F 28 16 F5 BC 53 71 E2 CC F5 3A 17 10 58 FA 99 0E C7 A2 D9 96 3B 31 91 F7 33 92 78 21 69 77 02
                                EB A6 D2 99 55 A3 A3 BD 6E 06 28 AA A0 08 CB 40 55 51 E8 8A E2 83 BB 99 34 DD AA 1B FC 53 BA E8 E3 CA B8 26 2F 04 55
                                EF 34 2C 19 1D BA EF 77 6E 93 24 14 3F 40 F0 1E 9E 95 FF C9 AC 74 A0 CF C2 08 16 3C 52 88 E6 E3 EE 08 C4 2F 80 59 63
                                E4 CA 0D BC 14 BB D8 E8 E2 7E B9 DB D2 1F E3 A5 64 E0 25 C2 30 90 95 AA 15
    14:33:34.687 | 0d | 34930 | b0 f4 c8 da ce 6f 5b 38 fe 3f b1  | -100 CRC error
                                Inverted Data:
                                4F 0B 37 25 31 90 A4 C7 01 C0 4E
    14:33:35.424 | 3f | 28424 | 5b de 42 57 26 56 fb 23 46 3a 06 91 39 e9 b8 6b 1f 14 2d 66 46 ae 9c bf 14 5f 10 9c 78 3d 9e bc 1d 6d c7 9c 8a 81 0b
                                12 94 ef 1b 69 4e 3f 65 14 ca 07 4e 1a 7b b5 90 cb 7a 8c 1a 91 11  | -100 CRC error
                                Inverted Data:
                                A4 21 BD A8 D9 A9 04 DC B9 C5 F9 6E C6 16 47 94 E0 EB D2 99 B9 51 63 40 EB A0 EF 63 87 C2 61 43 E2 92 38 63 75 7E F4
                                ED 6B 10 E4 96 B1 C0 9A EB 35 F8 B1 E5 84 4A 6F 34 85 73 E5 6E EE
    14:33:39.957 | 2b | 64517 | 96 ca 61 34 39 f0 55 af b6 3d 83 3b 85 14 bc 5f 93 1d 61 c9 d6 c7 f7 7d 79 2c 9b 66 e9 ed 47 db 33 d5 a9 43 42 df 36
                                3b 37  | -100 CRC error
                                Inverted Data:
                                69 35 9E CB C6 0F AA 50 49 C2 7C C4 7A EB 43 A0 6C E2 9E 36 29 38 08 82 86 D3 64 99 16 12 B8 24 CC 2A 56 BC BD 20 C9
                                C4 C8
    14:33:42.406 | 47 | 57180 | 26 53 71 cf 35 de db 43 cb 5d 2b e6 f5 a9 44 6c 90 e5 92 59 53 f9 2b 78 7d 42 7d cc 64 15 9d 59 c9 2d dd 6a 28 d9 09
                                75 2f 6c 87 40 fb ff 9e 28 72 48 bc ea 79 99 60 2a 3b ab c1 d4 2d 94 1c d8 4c 77 db a8 7f  | -100 CRC error
                                Inverted Data:
                                D9 AC 8E 30 CA 21 24 BC 34 A2 D4 19 0A 56 BB 93 6F 1A 6D A6 AC 06 D4 87 82 BD 82 33 9B EA 62 A6 36 D2 22 95 D7 26 F6
                                8A D0 93 78 BF 04 00 61 D7 8D B7 43 15 86 66 9F D5 C4 54 3E 2B D2 6B E3 27 B3 88 24 57 80
    14:33:46.467 | 05 | 23852 | fd 16 75  | -100 CRC error
                                Inverted Data:
                                02 E9 8A
    14:33:48.424 | 3a | 50009 | 84 ec cb a0 1e 78 9c c7 5d 91 a0 7a c6 88 b8 0a ca 36 a5 d9 11 63 43 ab fd 9a ec 69 8c fc 75 af c1 97 d0 b0 ae 10 12
                                7f c3 60 ba 95 ee ab 49 32 5d 69 2a 7f eb 52 96 96  | -100 CRC error
                                Inverted Data:
                                7B 13 34 5F E1 87 63 38 A2 6E 5F 85 39 77 47 F5 35 C9 5A 26 EE 9C BC 54 02 65 13 96 73 03 8A 50 3E 68 2F 4F 51 EF ED
                                80 3C 9F 45 6A 11 54 B6 CD A2 96 D5 80 14 AD 69 69
    14:33:51.056 | bd | 40381 | 18 d7 a6 85 8e 17 ff b4 65 e9 34 7a 98 28 cb 9a 92 56 cf f6 e5 4e 45 8e 5c 54 c6 d1 9b 3c f0 58 a6 8c 6b 18 16 d9 53
                                db cb b3 82 9d 12 95 0d 27 4e 7a a5 7c 51 3e 97 0c db 82 94 e0 4a ee 00 4c 51 f6 38 2c fd 2e ce eb 75 f9 f7 d4 b9 b6
                                e3 f4 be e1 bd de c3 2b 63 06 00 60 d2 8a 38 55 02 c9 d4 ec f6 f5 2c 4d f2 ed e4 7c e5 6c d1 5d a2 d5 dc 60 fb c2 59
                                c1 53 1e 2e 03 80 a1 4b 10 44 f6 d3 69 74 36 a7 b2 f9 b2 10 cf 20 fb ef 50 17 ae 1b 6f 1f 4e 26 3e b0 b2 89 09 f3 6f
                                75 5d dd d1 50 92 5d cd 45 82 df 0a 40 6e 0a c3 49 80 35 ac d6 d5 7c d9 1e 99 97 6a 80 02 4a  |  -99 CRC error
                                Inverted Data:
                                E7 28 59 7A 71 E8 00 4B 9A 16 CB 85 67 D7 34 65 6D A9 30 09 1A B1 BA 71 A3 AB 39 2E 64 C3 0F A7 59 73 94 E7 E9 26 AC
                                24 34 4C 7D 62 ED 6A F2 D8 B1 85 5A 83 AE C1 68 F3 24 7D 6B 1F B5 11 FF B3 AE 09 C7 D3 02 D1 31 14 8A 06 08 2B 46 49
                                1C 0B 41 1E 42 21 3C D4 9C F9 FF 9F 2D 75 C7 AA FD 36 2B 13 09 0A D3 B2 0D 12 1B 83 1A 93 2E A2 5D 2A 23 9F 04 3D A6
                                3E AC E1 D1 FC 7F 5E B4 EF BB 09 2C 96 8B C9 58 4D 06 4D EF 30 DF 04 10 AF E8 51 E4 90 E0 B1 D9 C1 4F 4D 76 F6 0C 90
                                8A A2 22 2E AF 6D A2 32 BA 7D 20 F5 BF 91 F5 3C B6 7F CA 53 29 2A 83 26 E1 66 68 95 7F FD B5
    14:33:52.564 | 6c | 37421 | 5a 0e 5b ba 30 c9 52 63 9c 53 63 77 4d aa de 43 ec 49 25 78 d3 11 d2 d6 97 a9 a8 de 11 4b 02 21 a1 66 a4 f5 8d c9 14
                                eb 6c 93 46 8a 77 f0 e6 7f e2 5b b8 9f a3 84 08 88 d7 f2 09 9f bf 67 36 42 b5 ed e0 e1 39 6d 64 06 83 15 fe 10 b0 f1
                                ff 63 e1 16 43 d6 54 d6 d2 86 b4 72 ee ca a9 24 bc c9 90 6f 34 9f 4b 37 32 4f b3 5e  | -100 CRC error
                                Inverted Data:
                                A5 F1 A4 45 CF 36 AD 9C 63 AC 9C 88 B2 55 21 BC 13 B6 DA 87 2C EE 2D 29 68 56 57 21 EE B4 FD DE 5E 99 5B 0A 72 36 EB
                                14 93 6C B9 75 88 0F 19 80 1D A4 47 60 5C 7B F7 77 28 0D F6 60 40 98 C9 BD 4A 12 1F 1E C6 92 9B F9 7C EA 01 EF 4F 0E
                                00 9C 1E E9 BC 29 AB 29 2D 79 4B 8D 11 35 56 DB 43 36 6F 90 CB 60 B4 C8 CD B0 4C A1
    14:33:57.895 | ff | 46452 | a0 3d 39 70 60 b0 21 3e 65 8d 63 98 2e 4b 6c 8d f7 55 99 cc 36 c4 0f f3 77 34 64 8f f7 3b 6f 95 3a 68 2f 2e 32 1a 01
                                c5 21 d9 91 84 92 c9 e4 f3 4d 51 85 d6 7c 15 13 27 97 b6 bf f2 79 57 8c a9 3b 5d 5c 4b da 38 a5 00 99 c2 ab 07 6e 75
                                40 4a 82 a3 48 61 57 11 99 fb 09 f0 eb b3 ba 5a 2c d3 53 b4 33 25 57 40 98 3f de 84 61 6d e3 ab a8 b6 e5 21 94 01 a1
                                60 b1 bb 4b 70 fe 9d 2e 0b ed 3d f8 ad 2f 40 05 b9 b9 7a 5f 86 a8 68 73 ea 9f c2 54 e8 f8 8f da c3 e7 a4 37 60 32 7d
                                38 0e db 5e 5a 33 dd c0 4e 8a 1e 90 e7 97 f1 b1 b4 3d 77 b1 67 1f aa 76 eb bc f2 e0 97 43 b1 5a 16 57 50 9b bf 96 5b
                                cc 87 e1 db 3b 90 39 4a 0d 3c 21 13 4d 24 aa 4a 56 b2 c4 b1 e3 9c a0 4b 1a 13 62 80 f3 99 bc e1 2f 9e b7 c0 6a e7 74
                                31 99 33 cb 2b 50 c3 03 82 2c df 12 7a ef ea 01 14 ae 94  | -101 CRC error
                                Inverted Data:
                                5F C2 C6 8F 9F 4F DE C1 9A 72 9C 67 D1 B4 93 72 08 AA 66 33 C9 3B F0 0C 88 CB 9B 70 08 C4 90 6A C5 97 D0 D1 CD E5 FE
                                3A DE 26 6E 7B 6D 36 1B 0C B2 AE 7A 29 83 EA EC D8 68 49 40 0D 86 A8 73 56 C4 A2 A3 B4 25 C7 5A FF 66 3D 54 F8 91 8A
                                BF B5 7D 5C B7 9E A8 EE 66 04 F6 0F 14 4C 45 A5 D3 2C AC 4B CC DA A8 BF 67 C0 21 7B 9E 92 1C 54 57 49 1A DE 6B FE 5E
                                9F 4E 44 B4 8F 01 62 D1 F4 12 C2 07 52 D0 BF FA 46 46 85 A0 79 57 97 8C 15 60 3D AB 17 07 70 25 3C 18 5B C8 9F CD 82
                                C7 F1 24 A1 A5 CC 22 3F B1 75 E1 6F 18 68 0E 4E 4B C2 88 4E 98 E0 55 89 14 43 0D 1F 68 BC 4E A5 E9 A8 AF 64 40 69 A4
                                33 78 1E 24 C4 6F C6 B5 F2 C3 DE EC B2 DB 55 B5 A9 4D 3B 4E 1C 63 5F B4 E5 EC 9D 7F 0C 66 43 1E D0 61 48 3F 95 18 8B
                                CE 66 CC 34 D4 AF 3C FC 7D D3 20 ED 85 10 15 FE EB 51 6B
    14:33:59.418 | 41 | 22348 | b7 55 34 83 db c3 2d b4 33 e0 3a e9 0c 3f eb ae 7f 2f 86 59 c8 29 22 bc 1f 29 b5 95 b5 ca 7f b1 af 77 ef 65 d1 19 86
                                30 4c 1f 7f 18 d0 e2 41 cf 93 2e a6 08 a1 e4 6a 3a 58 a0 dc 59 dc 30 0b  |  -99 CRC error
                                Inverted Data:
                                48 AA CB 7C 24 3C D2 4B CC 1F C5 16 F3 C0 14 51 80 D0 79 A6 37 D6 DD 43 E0 D6 4A 6A 4A 35 80 4E 50 88 10 9A 2E E6 79
                                CF B3 E0 80 E7 2F 1D BE 30 6C D1 59 F7 5E 1B 95 C5 A7 5F 23 A6 23 CF F4
    14:34:00.829 | b3 | 45226 | 3e 0f 66 78 8f 27 79 4e b5 f6 41 65 9c f1 89 2b ad e2 95 b8 af 38 a1 01 27 fe b1 02 ed 4b c8 fa 7b e6 cd 03 e4 a1 7d
                                ee 6f cf 7b a8 78 ad e6 09 23 48 08 67 08 9e 5d 7e be a0 13 81 e9 67 f5 af c0 bc 0d 7a 40 76 91 8e cb 87 5b c0 85 87
                                48 23 84 9e 83 7d 70 88 c4 7c 93 e4 3f 5f 79 f4 2f 50 7a c2 29 dc 0e 6b 7f fe a1 49 58 a3 79 77 de 8b 29 e3 f5 a7 a0
                                ba d7 db bf 33 ca 35 84 94 ac d7 84 2b e2 9e af 6f c2 36 91 5c 5a 3a 26 09 fd d2 e9 34 88 28 c3 9d 2a e8 72 36 fa 2d
                                cb 16 35 26 63 ac b2 91 db 50 c7 15 3f cb 78 67 76 81 a5 f4 fe  | -100 CRC error
                                Inverted Data:
                                C1 F0 99 87 70 D8 86 B1 4A 09 BE 9A 63 0E 76 D4 52 1D 6A 47 50 C7 5E FE D8 01 4E FD 12 B4 37 05 84 19 32 FC 1B 5E 82
                                11 90 30 84 57 87 52 19 F6 DC B7 F7 98 F7 61 A2 81 41 5F EC 7E 16 98 0A 50 3F 43 F2 85 BF 89 6E 71 34 78 A4 3F 7A 78
                                B7 DC 7B 61 7C 82 8F 77 3B 83 6C 1B C0 A0 86 0B D0 AF 85 3D D6 23 F1 94 80 01 5E B6 A7 5C 86 88 21 74 D6 1C 0A 58 5F
                                45 28 24 40 CC 35 CA 7B 6B 53 28 7B D4 1D 61 50 90 3D C9 6E A3 A5 C5 D9 F6 02 2D 16 CB 77 D7 3C 62 D5 17 8D C9 05 D2
                                34 E9 CA D9 9C 53 4D 6E 24 AF 38 EA C0 34 87 98 89 7E 5A 0B 01
    14:34:04.405 | eb | 26678 | ea 59 47 a3 e3 aa f6 71 62 38 4d df 9b 6e ef 7b e2 5d ac 3b 2a f5 10 34 0d 33 e9 9b 08 53 75 59 47 5f b8 fa f1 68 94
                                33 11 59 f3 91 98 d3 55 73 c7 4e 0b 4d 4d 7f f3 c1 b6 66 0c ba 9d 56 ad 7e eb 2a e6 d7 d1 4e f3 cb 54 76 3c 7f 08 26
                                ce d2 bd 3f 2b 72 33 9a f6 ec c4 d6 a1 1b ca 7e ec 7e 3c 4c 66 e0 c1 68 1f e7 85 fb 71 94 ad 23 7c ef f3 d8 48 fe b1
                                d6 19 4e 77 c5 a6 5b c2 bb ad f6 4e f3 b9 ed 51 41 36 db fb d0 36 cf 65 d1 08 e5 eb 8f 84 8d 2a ae f3 ad 54 2d a0 82
                                fa 15 15 c6 07 18 c9 9b 1e a2 dd 5d af 9d a2 8a db b7 85 63 bd ee 4b 49 2d aa 37 20 06 ca e7 9a 04 ac 4f 47 4b f5 ab
                                6c 59 9a 65 81 18 0d 1f 42 ac 1b 35 e1 18 be e5 cd 77 f8 01 ac 18 c5 9c e1 71 0a 36 bd e5 dc a3 56 a8 ed 4b ac 7d
                                | -100 CRC error
                                Inverted Data:
                                15 A6 B8 5C 1C 55 09 8E 9D C7 B2 20 64 91 10 84 1D A2 53 C4 D5 0A EF CB F2 CC 16 64 F7 AC 8A A6 B8 A0 47 05 0E 97 6B
                                CC EE A6 0C 6E 67 2C AA 8C 38 B1 F4 B2 B2 80 0C 3E 49 99 F3 45 62 A9 52 81 14 D5 19 28 2E B1 0C 34 AB 89 C3 80 F7 D9
                                31 2D 42 C0 D4 8D CC 65 09 13 3B 29 5E E4 35 81 13 81 C3 B3 99 1F 3E 97 E0 18 7A 04 8E 6B 52 DC 83 10 0C 27 B7 01 4E
                                29 E6 B1 88 3A 59 A4 3D 44 52 09 B1 0C 46 12 AE BE C9 24 04 2F C9 30 9A 2E F7 1A 14 70 7B 72 D5 51 0C 52 AB D2 5F 7D
                                05 EA EA 39 F8 E7 36 64 E1 5D 22 A2 50 62 5D 75 24 48 7A 9C 42 11 B4 B6 D2 55 C8 DF F9 35 18 65 FB 53 B0 B8 B4 0A 54
                                93 A6 65 9A 7E E7 F2 E0 BD 53 E4 CA 1E E7 41 1A 32 88 07 FE 53 E7 3A 63 1E 8E F5 C9 42 1A 23 5C A9 57 12 B4 53 82
    14:34:13.787 | 27 | 20046 | 54 f4 52 9d 80 0f 9b a2 88 7b 65 85 ae 56 07 82 78 b3 db b7 10 37 b3 45 0e 32 22 e7 65 c0 3b 25 7e 00 8f 60 e9  | -101 CRC error
                                Inverted Data:
                                AB 0B AD 62 7F F0 64 5D 77 84 9A 7A 51 A9 F8 7D 87 4C 24 48 EF C8 4C BA F1 CD DD 18 9A 3F C4 DA 81 FF 70 9F 16
    14:34:15.829 | 2b | 56414 | bf 22 e5 1b ec 7d 7b 7d 9f ed ce 15 af 73 3a 03 42 2f 2b 28 78 89 db 57 8f 0b a4 2d 79 b0 95 d0 3e 07 cf 80 a5 6c 8e
                                2b 3d  | -100 CRC error
                                Inverted Data:
                                40 DD 1A E4 13 82 84 82 60 12 31 EA 50 8C C5 FC BD D0 D4 D7 87 76 24 A8 70 F4 5B D2 86 4F 6A 2F C1 F8 30 7F 5A 93 71
                                D4 C2
    14:34:18.124 | b5 | 53741 | 7b 06 96 8e fa e9 a1 2c 50 5d a0 c4 3f 7e 87 f0 6c f7 8b f5 d8 9a fb b3 9d 4d 26 09 0e b8 f9 d7 e3 ad 60 cd 4f ce 8a
                                74 45 96 c4 88 35 b2 44 00 27 7f 0e d4 71 af de c7 9b d2 f8 8e 64 8b 1e ad 23 a1 6a 41 b1 7a 64 24 37 f6 c3 3d 62 d3
                                a2 98 1f a9 c3 b5 97 93 57 2a e4 47 a1 fb cd 09 73 bd a2 08 9b 5b d9 6b ec 13 70 aa b9 81 88 4c 99 be 85 b6 53 4e a8
                                5b bd fb ea ff 20 c7 00 d8 a4 a9 c5 27 a0 f5 e9 d1 f8 00 65 39 63 fa 32 98 6e fd 67 79 68 e0 9f d7 d5 34 3f 6c 2e 14
                                bb 5c 09 9b a0 8a 5a 14 0b 85 30 9b 5b b7 2d fc 1a 1d 75 21 26 80 1b  | -100 CRC error
                                Inverted Data:
                                84 F9 69 71 05 16 5E D3 AF A2 5F 3B C0 81 78 0F 93 08 74 0A 27 65 04 4C 62 B2 D9 F6 F1 47 06 28 1C 52 9F 32 B0 31 75
                                8B BA 69 3B 77 CA 4D BB FF D8 80 F1 2B 8E 50 21 38 64 2D 07 71 9B 74 E1 52 DC 5E 95 BE 4E 85 9B DB C8 09 3C C2 9D 2C
                                5D 67 E0 56 3C 4A 68 6C A8 D5 1B B8 5E 04 32 F6 8C 42 5D F7 64 A4 26 94 13 EC 8F 55 46 7E 77 B3 66 41 7A 49 AC B1 57
                                A4 42 04 15 00 DF 38 FF 27 5B 56 3A D8 5F 0A 16 2E 07 FF 9A C6 9C 05 CD 67 91 02 98 86 97 1F 60 28 2A CB C0 93 D1 EB
                                44 A3 F6 64 5F 75 A5 EB F4 7A CF 64 A4 48 D2 03 E5 E2 8A DE D9 7F E4
    14:34:20.957 | a1 | 36292 | e3 1c 6a ab 8d a1 ed 42 1c 2b 58 9c bc f0 af 57 10 d4 eb be 1a a1 b1 6d f1 26 8a 6a 2f 17 ba dd 24 34 05 8b ba fe 46
                                84 f7 10 42 3a fe 1d 98 1c 5f 72 76 a3 6d 83 23 ed e6 07 37 85 a7 df 2c 72 e8 33 a4 88 47 bb 87 08 a1 ca 16 c8 35 ca
                                ce 47 a5 13 94 4c c9 a3 e8 d3 98 90 ac 86 ce 34 90 30 03 d0 ab 7b a9 2a 16 df 44 dd 78 db f2 ca bb 2c e4 14 30 ba 5b
                                e6 5c c5 97 f3 e2 cc c3 12 d5 9b e7 21 ea 93 92 30 90 fa 9f 6a 9f e7 d1 7e 86 23 24 05 05 a9 11 ea 0e 16 86 4b 74 ba
                                7a b9 2f  |  -99 CRC error
                                Inverted Data:
                                1C E3 95 54 72 5E 12 BD E3 D4 A7 63 43 0F 50 A8 EF 2B 14 41 E5 5E 4E 92 0E D9 75 95 D0 E8 45 22 DB CB FA 74 45 01 B9
                                7B 08 EF BD C5 01 E2 67 E3 A0 8D 89 5C 92 7C DC 12 19 F8 C8 7A 58 20 D3 8D 17 CC 5B 77 B8 44 78 F7 5E 35 E9 37 CA 35
                                31 B8 5A EC 6B B3 36 5C 17 2C 67 6F 53 79 31 CB 6F CF FC 2F 54 84 56 D5 E9 20 BB 22 87 24 0D 35 44 D3 1B EB CF 45 A4
                                19 A3 3A 68 0C 1D 33 3C ED 2A 64 18 DE 15 6C 6D CF 6F 05 60 95 60 18 2E 81 79 DC DB FA FA 56 EE 15 F1 E9 79 B4 8B 45
                                85 46 D0
    14:34:21.672 | 39 | 22760 | a3 64 cb 1e 85 50 10 b6 ee 69 b0 8e d7 34 e2 72 4f 3d 2a 0c da d2 b9 c2 c5 5e 43 4c f3 87 3e e3 0c 40 2b 01 3c 82 94
                                99 9e 58 90 66 46 6f bf 6c d8 0c bb 3f c1 ba 55  |  -99 CRC error
                                Inverted Data:
                                5C 9B 34 E1 7A AF EF 49 11 96 4F 71 28 CB 1D 8D B0 C2 D5 F3 25 2D 46 3D 3A A1 BC B3 0C 78 C1 1C F3 BF D4 FE C3 7D 6B
                                66 61 A7 6F 99 B9 90 40 93 27 F3 44 C0 3E 45 AA
    14:34:22.113 | 1c | 15773 | 33 e3 a0 ad 11 e4 5d 54 3f f4 93 84 61 84 31 f9 91 77 17 11 83 9d 2b 46 bc 2d  | -101 CRC error
                                Inverted Data:
                                CC 1C 5F 52 EE 1B A2 AB C0 0B 6C 7B 9E 7B CE 06 6E 88 E8 EE 7C 62 D4 B9 43 D2
    14:34:23.730 | 67 | 49023 | a0 c1 81 3e 57 2a 32 a4 00 97 19 de 7b c8 e3 de ac 55 45 b9 ef 43 67 84 f0 38 cd 44 8f b8 fc a3 74 a0 ab 37 28
                                74 4d 13 f9 c0 48 fb 73 2c ab 69 d0 34 c7 26 06 ce 9c 2d f5 a6 47 bd 1e 3a 99 44 f1 c9 fe 19 d5 dd 92 1c 08 a9
                                34 a4 55 fa b1 d3 6d c5 14 d4 3a 35 78 93 77 78 ed ff 9b 5b 8e 4e c9 0c a8 f6 7b  | -100 CRC error
                                Inverted Data:
                                5F 3E 7E C1 A8 D5 CD 5B FF 68 E6 21 84 37 1C 21 53 AA BA 46 10 BC 98 7B 0F C7 32 BB 70 47 03 5C 8B 5F 54 C8 D7
                                8B B2 EC 06 3F B7 04 8C D3 54 96 2F CB 38 D9 F9 31 63 D2 0A 59 B8 42 E1 C5 66 BB 0E 36 01 E6 2A 22 6D E3 F7 56
                                CB 5B AA 05 4E 2C 92 3A EB 2B C5 CA 87 6C 88 87 12 00 64 A4 71 B1 36 F3 57 09 84
    14:34:28.483 | c0 | 48978 | e9 18 86 ac 1d 1c 57 98 e0 9d 86 92 79 ad 8f 0d 5b 3f c8 b0 95 69 ac b8 d7 a3 63 1f 0a fc 83 bb 51 51 a5 71 2b
                                0f d9 5e d3 3b a9 7b 08 23 32 c3 c3 11 ae 9a 23 02 15 1f 91 6a 83 5b 39 80 e9 08 f7 77 71 1f 1e ea b8 48 f7 c5
                                e9 3c b2 06 78 39 68 f7 e5 58 a0 da c3 e1 fe bd 29 46 fa 57 d9 d7 b9 e9 94 69 63 23 72 24 ae cb a3 d5 05 95 6c
                                d4 4d 61 06 d4 44 39 7d ab ce 1c e9 6e f5 45 eb 56 c2 a3 90 21 6f 99 9e 02 c8 5a e6 a1 af ae 4c ff 36 cf 5d e2
                                7f 24 cd 15 d2 55 b2 14 d6 2f df 1d ea 8e 6c cd 89 86 3d 65 f4 58 37 97 39 e2 26 f8 40 a6 77 12 3b 1a 00 24 50
                                8b 55 64 44 58  |  -99 CRC error
                                Inverted Data:
                                16 E7 79 53 E2 E3 A8 67 1F 62 79 6D 86 52 70 F2 A4 C0 37 4F 6A 96 53 47 28 5C 9C E0 F5 03 7C 44 AE AE 5A 8E D4
                                F0 26 A1 2C C4 56 84 F7 DC CD 3C 3C EE 51 65 DC FD EA E0 6E 95 7C A4 C6 7F 16 F7 08 88 8E E0 E1 15 47 B7 08 3A
                                16 C3 4D F9 87 C6 97 08 1A A7 5F 25 3C 1E 01 42 D6 B9 05 A8 26 28 46 16 6B 96 9C DC 8D DB 51 34 5C 2A FA 6A 93
                                2B B2 9E F9 2B BB C6 82 54 31 E3 16 91 0A BA 14 A9 3D 5C 6F DE 90 66 61 FD 37 A5 19 5E 50 51 B3 00 C9 30 A2 1D
                                80 DB 32 EA 2D AA 4D EB 29 D0 20 E2 15 71 93 32 76 79 C2 9A 0B A7 C8 68 C6 1D D9 07 BF 59 88 ED C4 E5 FF DB AF
                                74 AA 9B BB A7
    14:34:37.229 | 4d | 0678  | 96 7c 0b 32 0d c7 49 d3 c4 13 aa 90 9d 06 78 bb 92 78 1a 1f 94 95 a4 fe 1f 2d 4a 27 b9 b5 62 e8 dc 57 cb 07 c0
                                d7 33 6a 38 8e c7 1c 75 21 d4 4d d5 36 4a 1e 24 d3 69 3e c0 e6 79 77 88 e6 67 d9 d6 25 ce ae f3 26 d6 2b 99 24
                                eb  |  -99 CRC error
                                Inverted Data:
                                69 83 F4 CD F2 38 B6 2C 3B EC 55 6F 62 F9 87 44 6D 87 E5 E0 6B 6A 5B 01 E0 D2 B5 D8 46 4A 9D 17 23 A8 34 F8 3F
                                28 CC 95 C7 71 38 E3 8A DE 2B B2 2A C9 B5 E1 DB 2C 96 C1 3F 19 86 88 77 19 98 26 29 DA 31 51 0C D9 29 D4 66 DB
                                14
    14:34:45.627 | eb | 16550 | ee 5c ee 94 40 4c ac 2f 0c 29 7b 5f 8d b5 b2 bc 38 45 13 d8 f5 67 9d b5 6a f3 7f 74 9a 5e b2 5e b3 99 89 07 af
                                a0 15 e9 da 1f de de e2 1c 00 72 35 37 11 af 59 c5 7e e9 27 9a 1e a3 31 10 7f 99 0e 13 44 85 1c 06 dd 26 af dc
                                46 ee e0 04 39 a6 a5 06 d3 3b 5f bc cd df 53 b8 c8 37 84 47 d9 3e 78 e1 23 c0 ac 3c 60 51 65 be 1d 23 a6 df 75
                                93 72 cd 50 d2 09 cd 2d 9e 0d 8e 9e d3 fc 09 6c 72 63 3a 9c cc c8 89 d5 c0 8f a8 35 9a ae 61 87 2f 91 c6 14 3e
                                d2 f9 6f 9b ac 49 5a f0 e1 0e 5f f0 7b dc a1 af 42 96 78 df e8 20 ab 92 79 f1 ca db 5b 6f 37 93 9c 9e 05 55 e6
                                f3 86 17 66 16 54 52 74 4c 33 db 54 04 2f 05 fd 67 a9 60 3c 5a 7a ca fc 38 90 0d 27 a7 14 e7 f5 62 e7 f8 c6 39
                                9b dc 77 6a 3d 45 d4 c3 27 d9 d2  | -100 CRC error
                                Inverted Data:
                                11 A3 11 6B BF B3 53 D0 F3 D6 84 A0 72 4A 4D 43 C7 BA EC 27 0A 98 62 4A 95 0C 80 8B 65 A1 4D A1 4C 66 76 F8 50
                                5F EA 16 25 E0 21 21 1D E3 FF 8D CA C8 EE 50 A6 3A 81 16 D8 65 E1 5C CE EF 80 66 F1 EC BB 7A E3 F9 22 D9 50 23
                                B9 11 1F FB C6 59 5A F9 2C C4 A0 43 32 20 AC 47 37 C8 7B B8 26 C1 87 1E DC 3F 53 C3 9F AE 9A 41 E2 DC 59 20 8A
                                6C 8D 32 AF 2D F6 32 D2 61 F2 71 61 2C 03 F6 93 8D 9C C5 63 33 37 76 2A 3F 70 57 CA 65 51 9E 78 D0 6E 39 EB C1
                                2D 06 90 64 53 B6 A5 0F 1E F1 A0 0F 84 23 5E 50 BD 69 87 20 17 DF 54 6D 86 0E 35 24 A4 90 C8 6C 63 61 FA AA 19
                                0C 79 E8 99 E9 AB AD 8B B3 CC 24 AB FB D0 FA 02 98 56 9F C3 A5 85 35 03 C7 6F F2 D8 58 EB 18 0A 9D 18 07 39 C6
                                64 23 88 95 C2 BA 2B 3C D8 26 2D
    14:34:47.450 | 1d | 0960  | 58 9d 61 c5 83 ee 5d a2 66 91 c4 6e 9e 32 d0 23 d5 fa 67 b9 b0 ea 01 36 f4 3d 52  | -100 CRC error
                                Inverted Data:
                                A7 62 9E 3A 7C 11 A2 5D 99 6E 3B 91 61 CD 2F DC 2A 05 98 46 4F 15 FE C9 0B C2 AD
    14:34:50.034 | 71 | 55196 | 11 00 01 e5 49 94 89 7f 3d 3f 93 6a 4f 63 b5 9a 69 11 91 5c d4 0c dd f8 89 8e 13 85 af bc 2b de 55 e2 19 5e a0
                                25 f9 6a 07 2a 49 c6 37 4b 29 a6 3d 61 49 07 8d 65 8b 45 61 bb 77 be e3 83 f5 f5 a6 0c 23 e0 e6 7c 1b 2a 9d 86
                                96 b1 5d 5e 7c b7 35 f5 b8 d4 03 34 0c c7 34 90 71 5f fb 63 05 39 bc 12 9f 23 3c 01 1a 29 6a 37 70 bd c6 10 72
                                | -101 CRC error
                                Inverted Data:
                                EE FF FE 1A B6 6B 76 80 C2 C0 6C 95 B0 9C 4A 65 96 EE 6E A3 2B F3 22 07 76 71 EC 7A 50 43 D4 21 AA 1D E6 A1 5F
                                DA 06 95 F8 D5 B6 39 C8 B4 D6 59 C2 9E B6 F8 72 9A 74 BA 9E 44 88 41 1C 7C 0A 0A 59 F3 DC 1F 19 83 E4 D5 62 79
                                69 4E A2 A1 83 48 CA 0A 47 2B FC CB F3 38 CB 6F 8E A0 04 9C FA C6 43 ED 60 DC C3 FE E5 D6 95 C8 8F 42 39 EF 8D
    14:34:52.456 | f0 | 2814  | 8e bf 94 99 ef 7c c8 6c d5 22 a3 e8 b7 4e e5 77 62 42 91 c5 e8 ab 98 f1 25 ee 25 8b 39 42 ca ad 98 53 7e 75 c5
                                39 df 39 60 1e dc 79 0c 51 89 33 ef 43 bc b8 d2 a5 66 c2 06 c9 84 ef b9 f2 38 11 31 a3 f0 b8 13 16 57 b6 d5 27
                                31 3f 9c 66 0e a6 2e 3a 36 9d 5c 5b 18 26 b7 b7 5e d7 24 24 a3 2b 73 4a 46 10 bc 7c 37 b9 31 67 48 df 25 aa b1
                                f1 61 82 75 71 ce c7 9a 01 22 86 6f 8d b9 d1 ca 68 de 71 f8 8b b7 7b d9 5d 68 6b 34 85 09 51 5e 81 2c 24 60 96
                                b5 1d 5f 62 7e 5b 80 20 f8 9e 1d 10 25 67 49 4e 39 f7 3c b5 a8 91 2d e8 ce a7 71 1c 09 35 0a 04 6d 50 cd 06 5b
                                17 b4 fc 0b 08 89 b5 92 09 db ac e2 6e 0b 2e 74 71 9a ee 1d 6e be 93 38 cc c3 8f be 4c dc 9a 69 a8 2a 25 40 d9
                                77 d3 4a 4f 7e e5 66 d9 e1 c2 e3 47 cd ad e3 3b  | -101 CRC error
                                Inverted Data:
                                71 40 6B 66 10 83 37 93 2A DD 5C 17 48 B1 1A 88 9D BD 6E 3A 17 54 67 0E DA 11 DA 74 C6 BD 35 52 67 AC 81 8A 3A
                                C6 20 C6 9F E1 23 86 F3 AE 76 CC 10 BC 43 47 2D 5A 99 3D F9 36 7B 10 46 0D C7 EE CE 5C 0F 47 EC E9 A8 49 2A D8
                                CE C0 63 99 F1 59 D1 C5 C9 62 A3 A4 E7 D9 48 48 A1 28 DB DB 5C D4 8C B5 B9 EF 43 83 C8 46 CE 98 B7 20 DA 55 4E
                                0E 9E 7D 8A 8E 31 38 65 FE DD 79 90 72 46 2E 35 97 21 8E 07 74 48 84 26 A2 97 94 CB 7A F6 AE A1 7E D3 DB 9F 69
                                4A E2 A0 9D 81 A4 7F DF 07 61 E2 EF DA 98 B6 B1 C6 08 C3 4A 57 6E D2 17 31 58 8E E3 F6 CA F5 FB 92 AF 32 F9 A4
                                E8 4B 03 F4 F7 76 4A 6D F6 24 53 1D 91 F4 D1 8B 8E 65 11 E2 91 41 6C C7 33 3C 70 41 B3 23 65 96 57 D5 DA BF 26
                                88 2C B5 B0 81 1A 99 26 1E 3D 1C B8 32 52 1C C4
    14:34:53.622 | 32 | 54607 | 16 15 6d 16 02 62 cf 64 22 00 c4 e2 ad bf 20 fd 97 52 9f bb aa 76 54 44 7a 66 d9 7b 5a c9 ec a4 7b cb ec b7 e5
                                d3 40 ea a8 99 89 86 36 2d 49 60  | -100 CRC error
                                Inverted Data:
                                E9 EA 92 E9 FD 9D 30 9B DD FF 3B 1D 52 40 DF 02 68 AD 60 44 55 89 AB BB 85 99 26 84 A5 36 13 5B 84 34 13 48 1A
                                2C BF 15 57 66 76 79 C9 D2 B6 9F
    14:34:53.965 | 0b | 63759 | cd 65 ca f3 d1 5f 77 49 77  |  -99 CRC error
                                Inverted Data:
                                32 9A 35 0C 2E A0 88 B6 88
    14:34:55.957 | 0f | 37225 | 32 dd 77 1a d9 2f f7 01 b3 77 a7 a6 10  | -101 CRC error
                                Inverted Data:
                                CD 22 88 E5 26 D0 08 FE 4C 88 58 59 EF
    14:34:59.872 | 5f | 41409 | 56 51 6e dc f9 2d cf 93 ea d1 76 5f a0 43 7b 67 9b ff 38 29 17 17 a1 71 b1 2e 82 e3 76 33 fc 5f d1 0f da 1a 90
                                a1 9e df 82 36 9f 18 1f f0 70 3c ab 58 b8 2c 01 2b 14 63 86 74 fa 00 6c 65 7e bc 2e 5c 3a 9e f9 f2 1c 08 18 2b
                                c0 ef 7f d4 ff 6c 8f 79 23 0c ab 9d 82 ca d5 fb 50 3e 55  | -100 CRC error
                                Inverted Data:
                                A9 AE 91 23 06 D2 30 6C 15 2E 89 A0 5F BC 84 98 64 00 C7 D6 E8 E8 5E 8E 4E D1 7D 1C 89 CC 03 A0 2E F0 25 E5 6F
                                5E 61 20 7D C9 60 E7 E0 0F 8F C3 54 A7 47 D3 FE D4 EB 9C 79 8B 05 FF 93 9A 81 43 D1 A3 C5 61 06 0D E3 F7 E7 D4
                                3F 10 80 2B 00 93 70 86 DC F3 54 62 7D 35 2A 04 AF C1 AA
    14:35:01.860 | d2 | 23368 | 3c e3 e9 34 34 07 2c 5f 38 29 7c d0 ad 72 30 b6 0d 7c 47 13 ea 9b 84 04 fe 8a 38 d6 73 32 83 9c ae a4 7f 4f 35
                                3e 80 96 ae 51 9c 71 db 40 c6 9d f7 41 32 d4 f8 ff a3 e8 e8 65 a2 21 01 9f c0 e1 48 9a 4a ff b1 61 29 bd aa 9a
                                0f 52 ff bc 63 b4 6d be 2f 5e d6 a9 0f e5 b2 72 83 23 e8 5e 06 19 55 40 09 a9 43 12 30 a6 18 20 d1 ee 85 71 a9
                                9f 27 e4 b0 53 b6 cf 65 65 f8 e7 3b 71 0b 14 67 09 96 1e 24 5e f6 f3 f7 a7 b7 f8 fb 3e ac 11 03 5a ff a9 d7 31
                                79 1e 03 25 17 7d 0a 0e 75 0f 40 05 a7 6d 53 0d 2f 63 58 26 1b 09 40 ed 69 24 19 ad a2 5f cf 09 6d 51 12 0f 61
                                f7 cc 63 d2 bb bc f3 61 25 55 b3 f1 53 04 27 3e 23 95 34 18 57 20 4b  | -100 CRC error
                                Inverted Data:
                                C3 1C 16 CB CB F8 D3 A0 C7 D6 83 2F 52 8D CF 49 F2 83 B8 EC 15 64 7B FB 01 75 C7 29 8C CD 7C 63 51 5B 80 B0 CA
                                C1 7F 69 51 AE 63 8E 24 BF 39 62 08 BE CD 2B 07 00 5C 17 17 9A 5D DE FE 60 3F 1E B7 65 B5 00 4E 9E D6 42 55 65
                                F0 AD 00 43 9C 4B 92 41 D0 A1 29 56 F0 1A 4D 8D 7C DC 17 A1 F9 E6 AA BF F6 56 BC ED CF 59 E7 DF 2E 11 7A 8E 56
                                60 D8 1B 4F AC 49 30 9A 9A 07 18 C4 8E F4 EB 98 F6 69 E1 DB A1 09 0C 08 58 48 07 04 C1 53 EE FC A5 00 56 28 CE
                                86 E1 FC DA E8 82 F5 F1 8A F0 BF FA 58 92 AC F2 D0 9C A7 D9 E4 F6 BF 12 96 DB E6 52 5D A0 30 F6 92 AE ED F0 9E
                                08 33 9C 2D 44 43 0C 9E DA AA 4C 0E AC FB D8 C1 DC 6A CB E7 A8 DF B4
    14:35:04.047 | 6a | 16643 | 11 47 4a 5e eb f8 dc 23 7d f7 0a dc 87 9e cd c4 fe c2 64 31 69 a3 d4 ca b0 4c ec 15 47 0f c6 d8 97 fc 17 75 77
                                1b 3d a4 78 fb 1e 37 1d de 77 6c e4 59 f8 bd c2 5c 00 cc 08 ab 75 70 cc 07 39 f2 8f d0 2d b9 57 bc 58 a8 8d ec
                                31 23 03 e9 a8 bd 6d 95 c0 03 ac 9e 14 9e 07 b2 e5 9a e8 78 42 a3 6e f4 39 28 37 0d 89 09  | -101 CRC error
                                Inverted Data:
                                EE B8 B5 A1 14 07 23 DC 82 08 F5 23 78 61 32 3B 01 3D 9B CE 96 5C 2B 35 4F B3 13 EA B8 F0 39 27 68 03 E8 8A 88
                                E4 C2 5B 87 04 E1 C8 E2 21 88 93 1B A6 07 42 3D A3 FF 33 F7 54 8A 8F 33 F8 C6 0D 70 2F D2 46 A8 43 A7 57 72 13
                                CE DC FC 16 57 42 92 6A 3F FC 53 61 EB 61 F8 4D 1A 65 17 87 BD 5C 91 0B C6 D7 C8 F2 76 F6
    14:35:06.426 | 2c | 20491 | 15 43 f3 c5 c0 ed 33 44 f9 83 bd 6c 01 50 d7 60 91 de 77 a7 04 51 7d 63 c8 fd a0 24 b0 2e 8f 91 1a 81 4e 8e 2a
                                e8 dc cb 0c 18  | -101 CRC error
                                Inverted Data:
                                EA BC 0C 3A 3F 12 CC BB 06 7C 42 93 FE AF 28 9F 6E 21 88 58 FB AE 82 9C 37 02 5F DB 4F D1 70 6E E5 7E B1 71 D5
                                17 23 34 F3 E7
    14:35:10.245 | 98 | 54608 | 3e 42 9f 7a 15 49 3c e6 cf 59 a8 41 2b 0c 4f f4 32 ed 7e d2 f3 24 8d fc 08 c8 e6 e3 5e 24 0c 28 a3 bb 76 81 cc
                                93 b8 b0 b8 cf a8 bc ab b7 8f 49 d1 30 56 43 a6 db 17 ac 2b 2d 04 7f 4f 21 03 35 85 5f 3f 54 e8 6a 52 4d bd de
                                a8 5c 5c 83 5a 9c cc f0 c3 fc 6c 37 3e 26 2f 7a f0 d8 9e ed f1 a9 64 2c 83 d0 4b 42 32 19 b3 28 e4 d3 5c 53 b2
                                28 57 3d 78 17 9e 18 c6 3e e3 3a ec e5 c1 42 01 b2 d4 7d e8 cf ec 3f b7 29 48 81 08 23 e9 2b 18 e7 6d 3b a9 91
                                6f fb  |  -99 CRC error
                                Inverted Data:
                                C1 BD 60 85 EA B6 C3 19 30 A6 57 BE D4 F3 B0 0B CD 12 81 2D 0C DB 72 03 F7 37 19 1C A1 DB F3 D7 5C 44 89 7E 33
                                6C 47 4F 47 30 57 43 54 48 70 B6 2E CF A9 BC 59 24 E8 53 D4 D2 FB 80 B0 DE FC CA 7A A0 C0 AB 17 95 AD B2 42 21
                                57 A3 A3 7C A5 63 33 0F 3C 03 93 C8 C1 D9 D0 85 0F 27 61 12 0E 56 9B D3 7C 2F B4 BD CD E6 4C D7 1B 2C A3 AC 4D
                                D7 A8 C2 87 E8 61 E7 39 C1 1C C5 13 1A 3E BD FE 4D 2B 82 17 30 13 C0 48 D6 B7 7E F7 DC 16 D4 E7 18 92 C4 56 6E
                                90 04
    14:35:14.414 | f8 | 32688 | 77 56 fc 71 48 6c 4a e2 b3 4b 26 72 89 52 7e 84 c8 14 5d 91 9a 5e 2f 80 4a 6e c3 e7 1e 49 13 ef 55 c6 93 77 3d
                                0a c3 bf 9d 4a 73 c7 33 6c 04 23 9d 74 bd 46 4d d4 d3 43 6a 07 9a ea ea 5f 9e 1f 9c 56 25 26 c2 b6 4f 11 55 3e
                                75 ee 98 36 4a 8c ac 9b e1 49 5a 25 51 0b ce 8c 7d 21 de fc 2f 04 c1 8c 9f 4a f8 0c b2 56 eb 1d b7 ee 4e 60 58
                                40 2d dc 0d 6d d1 c0 50 0f 39 f4 af 0a 3c 37 bc b8 69 b2 1c 52 8e fa ab d5 86 da 57 52 17 3b 56 16 6b 55 dc a5
                                4e 6a ef 48 cd 0c e2 4d d7 39 63 b6 15 5b 7f 54 0a 8c 56 d5 0b 6a d7 fe 79 1e 8f 52 bb 73 e0 13 c0 e1 80 34 df
                                36 f4 37 50 e5 ce 35 12 b1 4e 8f d6 b3 d8 58 53 cd 96 32 30 1c ac 37 9e 02 3f 9d 5c 36 5d 76 d8 93 99 e4 72 3c
                                75 65 96 2c 69 ae f2 b9 02 a1 b2 bc bd ea d6 7e 0c 30 4a 22 4a 8a 52 be  | -101 CRC error
                                Inverted Data:
                                88 A9 03 8E B7 93 B5 1D 4C B4 D9 8D 76 AD 81 7B 37 EB A2 6E 65 A1 D0 7F B5 91 3C 18 E1 B6 EC 10 AA 39 6C 88 C2
                                F5 3C 40 62 B5 8C 38 CC 93 FB DC 62 8B 42 B9 B2 2B 2C BC 95 F8 65 15 15 A0 61 E0 63 A9 DA D9 3D 49 B0 EE AA C1
                                8A 11 67 C9 B5 73 53 64 1E B6 A5 DA AE F4 31 73 82 DE 21 03 D0 FB 3E 73 60 B5 07 F3 4D A9 14 E2 48 11 B1 9F A7
                                BF D2 23 F2 92 2E 3F AF F0 C6 0B 50 F5 C3 C8 43 47 96 4D E3 AD 71 05 54 2A 79 25 A8 AD E8 C4 A9 E9 94 AA 23 5A
                                B1 95 10 B7 32 F3 1D B2 28 C6 9C 49 EA A4 80 AB F5 73 A9 2A F4 95 28 01 86 E1 70 AD 44 8C 1F EC 3F 1E 7F CB 20
                                C9 0B C8 AF 1A 31 CA ED 4E B1 70 29 4C 27 A7 AC 32 69 CD CF E3 53 C8 61 FD C0 62 A3 C9 A2 89 27 6C 66 1B 8D C3
                                8A 9A 69 D3 96 51 0D 46 FD 5E 4D 43 42 15 29 81 F3 CF B5 DD B5 75 AD 41
    14:35:16.805 | a8 | 37364 | 82 5b 5f 9d 35 59 63 d0 9a 36 36 14 2f 2b 22 66 45 17 c9 d6 eb 77 01 ae e2 e0 6f b7 25 3d b6 ee 3d 26 6a 74 c4
                                86 6c a3 2f c6 a1 7e 9a 81 b8 8d 2b 07 46 a5 db 41 a6 34 d2 6b 9b 31 d1 c2 55 46 79 5e 6e 7d 57 db 31 36 95 87
                                81 36 0f 4c 5d 29 ce f0 d3 71 86 b8 7a 55 24 e7 3d 75 4b ef e1 63 b5 b1 4e a1 a6 7c df 15 b5 1c 3e 62 b6 b8 03
                                41 50 62 10 79 6d 87 01 e2 6a 74 ff 72 65 72 3a 7c 27 1a fe c9 e7 56 0c 93 73 f0 4a d5 b2 ac 9f 53 61 55 f7 66
                                19 97 a3 6d ba 6e b4 ea 1e 29 1a 7e da fb 3b 3c 25 ec  | -100 CRC error
                                Inverted Data:
                                7D A4 A0 62 CA A6 9C 2F 65 C9 C9 EB D0 D4 DD 99 BA E8 36 29 14 88 FE 51 1D 1F 90 48 DA C2 49 11 C2 D9 95 8B 3B
                                79 93 5C D0 39 5E 81 65 7E 47 72 D4 F8 B9 5A 24 BE 59 CB 2D 94 64 CE 2E 3D AA B9 86 A1 91 82 A8 24 CE C9 6A 78
                                7E C9 F0 B3 A2 D6 31 0F 2C 8E 79 47 85 AA DB 18 C2 8A B4 10 1E 9C 4A 4E B1 5E 59 83 20 EA 4A E3 C1 9D 49 47 FC
                                BE AF 9D EF 86 92 78 FE 1D 95 8B 00 8D 9A 8D C5 83 D8 E5 01 36 18 A9 F3 6C 8C 0F B5 2A 4D 53 60 AC 9E AA 08 99
                                E6 68 5C 92 45 91 4B 15 E1 D6 E5 81 25 04 C4 C3 DA 13
    14:35:17.559 | 30 | 57397 | 14 2a 01 47 71 e4 27 ed 9a 7a c0 93 2a a7 a9 bf fb 0d 42 31 26 a1 f8 63 1d fb 9e a9 34 29 cd 8d f0 06 b2 cc 8e
                                a6 e3 b5 2d 59 7c 7e cb e5  | -101 CRC error
                                Inverted Data:
                                EB D5 FE B8 8E 1B D8 12 65 85 3F 6C D5 58 56 40 04 F2 BD CE D9 5E 07 9C E2 04 61 56 CB D6 32 72 0F F9 4D 33 71
                                59 1C 4A D2 A6 83 81 34 1A
    14:35:18.332 | 65 | 27030 | a7 68 d4 67 ab 47 93 85 dd 0f ab a0 9d b2 e5 e1 a2 16 0e 83 ff d6 69 45 82 92 10 ba 90 74 71 6f 99 ad b9 3d b2
                                7b 36 da ce f8 58 79 59 67 b8 1e ea 36 68 0b 9b 4b 50 00 1a 70 a1 49 d5 a8 8b 84 67 95 21 a3 6f d4 22 ed 91 0f
                                29 4c 2a 21 b4 c8 ce d2 0b 91 e9 c1 52 7f ff 9a 63 c3 b4 79 7b b7 e5 42 7c  |  -99 CRC error
                                Inverted Data:
                                58 97 2B 98 54 B8 6C 7A 22 F0 54 5F 62 4D 1A 1E 5D E9 F1 7C 00 29 96 BA 7D 6D EF 45 6F 8B 8E 90 66 52 46 C2 4D
                                84 C9 25 31 07 A7 86 A6 98 47 E1 15 C9 97 F4 64 B4 AF FF E5 8F 5E B6 2A 57 74 7B 98 6A DE 5C 90 2B DD 12 6E F0
                                D6 B3 D5 DE 4B 37 31 2D F4 6E 16 3E AD 80 00 65 9C 3C 4B 86 84 48 1A BD 83
    14:35:19.830 | 10 | 25731 | a8 de 89 c8 aa 3b 66 64 d9 d2 c4 74 0b c9  | -100 CRC error
                                Inverted Data:
                                57 21 76 37 55 C4 99 9B 26 2D 3B 8B F4 36
    14:35:22.251 | 98 | 16517 | 9b 7f 08 c8 9a 1a 46 2a 48 c8 02 b5 8b e4 94 05 d8 ef 4d a7 39 dc 57 2b ed e6 f4 ef 07 77 cf 86 38 6d 91 71 b0
                                43 a3 02 66 87 6f 97 a7 bb 17 75 a2 5b 5a fb 06 d7 28 26 34 16 24 1f 71 a5 da fb e3 dc 7b e4 8e 57 d6 ff 84 a5
                                ec da 2c ae 49 9d 01 38 90 f0 ea 1d 85 3e f2 1a 46 57 83 7b a4 cf a1 a2 13 f5 95 3e be ef df 1d d6 58 4c 2b 4a
                                17 8d 32 fb ef 4e 67 96 cf 71 0b 5a 46 3e a6 6a 66 66 d5 8f 3a d7 d3 9e 2e 41 d9 ed d9 b8 79 60 85 2c 7c 04 a0
                                96 f1  |  -99 CRC error
                                Inverted Data:
                                64 80 F7 37 65 E5 B9 D5 B7 37 FD 4A 74 1B 6B FA 27 10 B2 58 C6 23 A8 D4 12 19 0B 10 F8 88 30 79 C7 92 6E 8E 4F
                                BC 5C FD 99 78 90 68 58 44 E8 8A 5D A4 A5 04 F9 28 D7 D9 CB E9 DB E0 8E 5A 25 04 1C 23 84 1B 71 A8 29 00 7B 5A
                                13 25 D3 51 B6 62 FE C7 6F 0F 15 E2 7A C1 0D E5 B9 A8 7C 84 5B 30 5E 5D EC 0A 6A C1 41 10 20 E2 29 A7 B3 D4 B5
                                E8 72 CD 04 10 B1 98 69 30 8E F4 A5 B9 C1 59 95 99 99 2A 70 C5 28 2C 61 D1 BE 26 12 26 47 86 9F 7A D3 83 FB 5F
                                69 0E
    14:35:25.267 | 81 | 21780 | 33 f4 6b b6 d4 f8 0c d9 48 52 fa 33 1f 21 02 48 03 13 a1 4a 2f 4c 4a 1d 41 7b 57 cb f6 6e 4a d0 50 78 58 5b b3
                                0d 9a df fd 54 c4 f2 74 d2 54 8b 55 7c 4d b5 9f 8e 89 ce 72 55 f9 e7 a4 7d 43 b8 59 f3 5c 26 58 d8 e2 5f 4f 4f
                                48 2d 50 f2 dc 88 61 af c1 f8 8e cb 1a 2d 06 6f 97 d5 41 e1 87 12 45 20 fb 22 7f 40 e8 85 82 5f fb 35 57 8a bc
                                db d3 ba 74 53 b4 79 ee 8b 4c 19 44 9f 6c 9d 67  | -100 CRC error
                                Inverted Data:
                                CC 0B 94 49 2B 07 F3 26 B7 AD 05 CC E0 DE FD B7 FC EC 5E B5 D0 B3 B5 E2 BE 84 A8 34 09 91 B5 2F AF 87 A7 A4 4C
                                F2 65 20 02 AB 3B 0D 8B 2D AB 74 AA 83 B2 4A 60 71 76 31 8D AA 06 18 5B 82 BC 47 A6 0C A3 D9 A7 27 1D A0 B0 B0
                                B7 D2 AF 0D 23 77 9E 50 3E 07 71 34 E5 D2 F9 90 68 2A BE 1E 78 ED BA DF 04 DD 80 BF 17 7A 7D A0 04 CA A8 75 43
                                24 2C 45 8B AC 4B 86 11 74 B3 E6 BB 60 93 62 98
    14:35:27.335 | 7c | 36167 | 80 f8 43 b1 bd 51 5c 6e 50 01 83 56 2e 4c 3c 89 6d 36 fe 2c 8a e5 26 77 fb 8d c1 94 80 f4 8f 64 f9 dc 42 23 09
                                53 45 17 0e d5 93 c3 16 1a 34 ff 6d 2b a9 c8 18 e1 d7 28 0f 27 84 7e 28 c4 a7 00 47 09 b6 6c 32 69 eb 78 f2 be
                                5c bf ce 5d 70 84 f4 15 02 9d a7 24 86 a3 dc cd fe c6 85 18 fb dd 6c e5 b7 ff 02 77 63 68 5c 37 f4 e5 9e 55 89
                                03 83 88 0e a2 e5 ba 85 be df 22  | -100 CRC error
                                Inverted Data:
                                7F 07 BC 4E 42 AE A3 91 AF FE 7C A9 D1 B3 C3 76 92 C9 01 D3 75 1A D9 88 04 72 3E 6B 7F 0B 70 9B 06 23 BD DC F6
                                AC BA E8 F1 2A 6C 3C E9 E5 CB 00 92 D4 56 37 E7 1E 28 D7 F0 D8 7B 81 D7 3B 58 FF B8 F6 49 93 CD 96 14 87 0D 41
                                A3 40 31 A2 8F 7B 0B EA FD 62 58 DB 79 5C 23 32 01 39 7A E7 04 22 93 1A 48 00 FD 88 9C 97 A3 C8 0B 1A 61 AA 76
                                FC 7C 77 F1 5D 1A 45 7A 41 20 DD
    Here is the received datastream from the CC1101. Both of the received datastreams are from Smart RF Studio with base frequency set to 433.92 Mhz and OOK decoding selected
  • Hi Steve,
    Here are some questions about the TPMS sensor that you are using:
    1. Is the modulation format Manchester encoded OOK?
    2. What is the data rate/symbol rate?
    3. Is the preample and the sync word also Manchester encoded or is it only the payload?
    4. What is transmitted by the sensor? Preamble+sync word+payload?
    Can you also add your configuration file for CC1101 here please?
    Haiatullah
  • Hi Haiatullah,
    1. The signal is manchester encoded. According to the open source documentation I found the modulation is FSK encoding rather than OOK. The reason I have been using OOK setting was due to the CC1101 only receiving data when I had the modulation set to OOK mode. I had the same experience on my CC1310 dev board.
    2. I am unsure about the data rate/ symbol rate. Is there a formula I can use to calulate using the working CC1101 code?
    3. Yes, the preamble and sync word are encoded in manchester along with the payload itself.
    4. The sensor transmits all of the fields Preamble + Sync Word + Payload.
    Here is a little more information from the open source SW doing the decoding:
    /** @file
        Jansite FSK 11 byte Manchester encoded checksummed TPMS data.
        Copyright (C) 2021 Benjamin Larsson
        based on code
        2019 Andreas Spiess and Christian W. Zuckschwerdt <zany@triq.net>
        This program is free software; you can redistribute it and/or modify
        it under the terms of the GNU General Public License as published by
        the Free Software Foundation; either version 2 of the License, or
        (at your option) any later version.
    Jansite Solar TPMS Solar Model.
    - Frequency: 433.92 +/- 20.00 MHz
    - Pressure: +/- 0.1 bar from 0 bar to 6.6 bar
    - Temperature: +/- 3 C from -40 C to 75 C
    Signal is manchester encoded, and a 11 byte large message
    Data layout (nibbles):
        SS SS II II II 00 TT PP 00 CC CC
    - S: 16 bits sync word, 0xdd33
    - I: 24 bits ID
    - 0: 8 bits Unknown data 1
    - T: 8 bit Temperature (deg. C offset by 55)
    - P: 8 bit Pressure
    - 0: 8 bits Unknown data 2
    - C: 16 bit CRC (CRC-16/BUYPASS)
    - The preamble is 0xa6, 0xa6, 0x5a
    TODO: identify battery bits
    Please see the register setting bits below with my current settings on the CC1101. These settings seem to be working, but I have to do all calculations on the MCU. This is not ideal because it is a massive overhead on the MCU. I would prefer to properly configure the CC1101 to do the decoding and just to SPI_Read the CC1101 after an interupt (GDO0) is received on the MCU.
    #define CC1101_DEFVAL_IOCFG2     0x0C        // GDO2 Output Pin Configuration - Serial out (synchronous)
        #define CC1101_DEFVAL_IOCFG1     0x2E        // GDO1 Output Pin Configuration - not used
        #define CC1101_DEFVAL_IOCFG0     0x0E        // GDO0 Output Pin Configuration - Carrier Sense output
        #define CC1101_DEFVAL_FIFOTHR    0x0F        // RX FIFO and TX FIFO Thresholds - 64 bytes in FIFO
        #define CC1101_DEFVAL_SYNC1      0xD5        // Synchronization word, high byte  11010101 01001111
        #define CC1101_DEFVAL_SYNC0      0x4F        // Synchronization word, low byte
        #define CC1101_DEFVAL_PKTLEN     0x09        // Packet Length
        #define CC1101_DEFVAL_PKTCTRL1   0x00        // Packet Automation Control
        #define CC1101_DEFVAL_PKTCTRL0   0x12 //0x30        // Packet Automation Control - synchronous data
        #define CC1101_DEFVAL_ADDR       0x00        // Device Address
        #define CC1101_DEFVAL_CHANNR     0x00        // Channel Number
        #define CC1101_DEFVAL_FSCTRL1    0x0F        // Frequency Synthesizer Control (was 0x06)
        #define CC1101_DEFVAL_FSCTRL0    0x00        // Frequency Synthesizer Control
        // Carrier frequency = 433.919830 MHz
        #define CC1101_DEFVAL_FREQ2  0x10        // Frequency Control Word, High Byte
        #define CC1101_DEFVAL_FREQ1  0xB0        // Frequency Control Word, Middle Byte
        #define CC1101_DEFVAL_FREQ0  0x71        // Frequency Control Word, Low Byte
        #define CC1101_DEFVAL_DEVIATN    0x40      // Modem Deviation Setting (+/-25.390625kHz)
        #define CC1101_DEFVAL_MDMCFG4    0x59        // Modem Configuration (59 = data rate = 20kHz - actual data rate is 10kHz but due to bi-phase coding need to double the rate, RX bandwidth 325kHz)
        #define CC1101_DEFVAL_MDMCFG3    0x93        // Modem Configuration (now 93 = data rate = 20kHz)
        #define CC1101_DEFVAL_MDMCFG2    0x10        // Modem Configuration (GFSK, No Sync or Manchester coding)
        #define CC1101_DEFVAL_MDMCFG1    0x21        // Modem Configuration Channel spacing 100kHz
        #define CC1101_DEFVAL_MDMCFG0    0xF8        // Modem Configuration
        #define CC1101_DEFVAL_AGCCTRL2   0x87       // AGC Control
        #define CC1101_DEFVAL_AGCCTRL1   0x58        // AGC Control
        #define CC1101_DEFVAL_AGCCTRL0   0x80        // AGC Control
        #define CC1101_DEFVAL_MCSM2      0x07        // Main Radio Control State Machine Configuration
        #define CC1101_DEFVAL_MCSM1      0x3C        // Main Radio Control State Machine Configuration
        #define CC1101_DEFVAL_MCSM0      0x18        // Main Radio Control State Machine Configuration
        #define CC1101_DEFVAL_FOCCFG     0x16        // Frequency Offset Compensation Configuration
        #define CC1101_DEFVAL_BSCFG      0x6C        // Bit Synchronization Configuration
        #define CC1101_DEFVAL_WOREVT1    0x87        // High Byte Event0 Timeout
        #define CC1101_DEFVAL_WOREVT0    0x6B        // Low Byte Event0 Timeout
        #define CC1101_DEFVAL_WORCTRL    0xFB        // Wake On Radio Control
        #define CC1101_DEFVAL_FREND1     0x56        // Front End RX Configuration
        #define CC1101_DEFVAL_FREND0     0x10        // Front End TX Configuration
        #define CC1101_DEFVAL_FSCAL3     0xE9        // Frequency Synthesizer Calibration
        #define CC1101_DEFVAL_FSCAL2     0x2A        // Frequency Synthesizer Calibration
        #define CC1101_DEFVAL_FSCAL1     0x00        // Frequency Synthesizer Calibration
        #define CC1101_DEFVAL_FSCAL0     0x1F        // Frequency Synthesizer Calibration
        #define CC1101_DEFVAL_RCCTRL1    0x41        // RC Oscillator Configuration
        #define CC1101_DEFVAL_RCCTRL0    0x00        // RC Oscillator Configuration
        #define CC1101_DEFVAL_FSTEST     0x59        // Frequency Synthesizer Calibration Control
        #define CC1101_DEFVAL_PTEST      0x7F        // Production Test
        #define CC1101_DEFVAL_AGCTEST    0x3F        // AGC Test
        #define CC1101_DEFVAL_TEST2      0x81        // Various Test Settings
        #define CC1101_DEFVAL_TEST1      0x35        // Various Test Settings
        #define CC1101_DEFVAL_TEST0      0x09        // Various Test Settings
    Thanks for the support!!
    -Steve
  • Hi Steve,
    You cannot use an OOK PHY to receive a FSK signal. They are completely different modulation formats. Furthermore, it it essential to know the datarate as the receiver BW, deviation etc. are all dependent on it.
    Our devices use preample consisting of a sequence of 1 and 0. As the TPMS uses a different preample, you will not be able to receive anything reasonable.
    In addition, CC1310 manchester encodes only the paylaod while the other two devices manchester encodes everything.
    Haiatullah
  • Hi Zack and Haiatullah,
    Zack:
    I've read over the previous posts you've sent.  The last post is exactly what I am trying to do, down to the SP37 or SP40T infineon TPMS sensor being used.
    I read that it is not possible to use the CC1101 outside of async mode (as I am now) to read this type of data.
    If that is true, the CC1101 will not work for my application. Doing all decoding on the MCU side will be too much of a burden for our system.
    Does the newer CC110L allow the proper on chip decoding of this data? (Meaning access to internal FIFO buffering and Manchester Decoding)?
    If not, could I accomplish my task with another TI chip instead?
    I got the CC1310 early on because there was no current dev kit for the CC1101. Now I have been able to make my own using a TrxEB board and CC1101 433mHz module from Amazon.
    Haiatullah:
    Please refer to the third link above from Zack.
    This previous poster from 7 years ago is trying to do exactly what I am down to using the same SP37 transmitter. I have both the Sp37 and Sp40T now since the Sp37 has been EOL'd since then.
    I think the previous poster provided more detail than me to answer your question.
    Thank you both for the support,
    Steve
  • The CC110L has less functionality than the CC1101 (see https://e2e.ti.com/support/wireless-connectivity/other-wireless-group/other-wireless/f/other-wireless-technologies-forum/153153/cc110l-vs-cc1101 ), so would not be a better solution for this.
    Unfortunately async mode with the CC1310 will give worse performance than the CC1101 as it is not designed for it. However, it is a SoC so that is an advantage.
  • Hi Zack,
    Which Do you have a different TI Sub-1GHz chip I should use to decode the TPMS signals?
    The SOC is not required for my application. We are already using an existing MCU in the product and would prefer a tranceiver to receive the signals and communicate with the existing MCU over SPI.
    Steve
  • I cannot find a device that would be better suited for this; all of our Sub-1 GHz devices currently supported will require a similar process for this particular TPMS signal to be decoded, I'm afraid.
    Zack
  • I will double-check within our team in case there is any further input we can provide and reply within this week.
    Zack
  • Thank you Zack, I look forward to your additional support!
  • - Frequency: 433.92 +/- 20.00 MHz
    - I: 24 bits ID
    - P: 8 bit Pressure
    I skimmed through some of the old posts and it looked like that the post that looked most relevant uses a slightly different format. If the packet format is as the above and you have known sync word you should be able to receive the data after the SS SS nibbles in the RX buffer if you set the sync word to 0xDD33 and by this avoid using async mode. Have I misunderstood something?
  • Hello TheGhostOf,
    Yes, you are correct. My issue is that when setting the correct frequency and sync word to use the CC1101 I receive data in Smart RF studio, but the received data has absolutely no match to the known good data that was received in RTL_433 (using RTL_SDR) receiver, and in async mode of the CC1101.
    If you see the included text files (Jansite CC1101_4_3.txt for example) I have the received data and also manually bit-inverted it on the next line. However, no matter what I do, In normal mode I am not able to find the TPMS hex bytes (8a5c2405510008ec7d or 8a5c2405514208e078 or 8a5c2405514308667b) in any of the outputs.
    I have tried manchester mode enabaled and disabled, SYNC0 = 0xDD & SYNC1 = 0x33, SYNC0 = 0x33 & SYNC1 = 0xDD, All modulation schemes (OOK, GFSK, ... etc), and all of the suggested data rates in Smart RF studio with absolutely no luck at getting the "golden data".
    Any help would be greatly appreciated.
    Steve
  • You need to know the datarate and modulation format. You can get some indication of this using a high end spectrum.
  • Hi TheGhostOf,
    Can you provide a link on how to take the data rate measurement and I will complete it today?
    I'm guessing just use an H-Probe?
    I have access to a high end SA on site.
    Steve
  • Hi The GhostOf,
    Please see screenshots below from my scope.
    Let me know if there are specific measurements I should take.
    Steve
  • Hi Steve,
    I am marking this thread as "resolved" due to moving to direct support. If you have further questions you want to ask on E2E you can reply to this thread within 30 days and it will reopen it.
    Otherwise the metrics will show that we are not trying to find a solution for you.
    Regards.
    Zack
