CC1352P7: about sidewalk quick start guide
Part Number: CC1352P7
Other Parts Discussed in Thread: ENERGYTRACE, SYSCONFIG
Hi team,
My customer followed up the TI Amazon Sidewalk Stack Quick Start Guide. Under the section of "Flashing the edge device", it mentions TI.bin. But, we cannot find the TI.bin inside the "TI Amazon Sidewalk Sample IoT App" github. Please help clarify where to get this. Thank you.
  “Under EdgeDeviceProvisioning/DeviceProfile_xxxxxx/WirelessDevice_xxxx, please select the TI.bin binary. Check Binary and set Load Addr: to 0xAE000 (0x56000 for P1 devices).”
  • Hi Jerry,
    TI.bin is generated at step 4 of the following guide: https://github.com/TexasInstruments/ti-amazon-sidewalk-sample-iot-app#4-provision-edge-device
    The customer also has the option to run the "sid_demo" project, which will take care of the web app, and certificate/file generation.
    sid_demo can be found here: https://dev.ti.com/tirex/explore/node?node=A__AJPr1BOrOlc2-enrxzSMqQ__com.ti.SIMPLELINK_CC13XX_CC26XX_SDK__BSEc4rl__LATEST
    Arthur
  • I refer to https://www.ti.com/tool/AMZN-3P-SIDEWALK-TOOLKIT and follow the step in sid_demo readme to run the example. I use FSK 900 MHz on CC1352P-7 LP when I test this. All the aws_access_key_id/aws_secret_access_key and my Amazon Echo 4th generation are set properly. However, I always get the error "<error> rnet_mac_scheduler_phy_event_notify is called with event = 7 is_current_radio_owner = 1". I attach my UART log of sid_demo for your reference. How can  I solve this error to make it work?
    [2023-04-20 13:34:42.736] [00000000003] <info> Sidewalk example started
    [2023-04-20 13:34:45.092] [00000002368] <info> DR state [1]
    [2023-04-20 13:34:45.092] [00000002369] <info> Protocol Switch:0
    [2023-04-20 13:34:45.092] [00000002369] <info> Dev Profile: type 2, mode:1
    [2023-04-20 13:34:45.092] [00000002369] <info> Dev Version: 944
    [2023-04-20 13:34:45.092] [00000002370] <info> Protocol Switch:0
    [2023-04-20 13:34:45.097] [00000002370] <info> Dev Profile: type 2, mode:1
    [2023-04-20 13:34:45.097] [00000002370] <info> Dev Version: 944
    [2023-04-20 13:34:45.097] [00000002371] <info> Set region 1, country: US, num cfg: 2
    [2023-04-20 13:34:45.097] [00000002372] <info> RTC compensation is not supported.
    [2023-04-20 13:34:45.102] [00000002373] <info> P2P chnl loaded: 0
    [2023-04-20 13:34:45.102] [00000002373] <info> PAN ID loaded:
    [2023-04-20 13:34:45.102] [00000002373] <info> A0 00 00 02 00
    [2023-04-20 13:34:45.102] [00000002373] <info> Def mcast retries: 1
    [2023-04-20 13:34:45.106] [00000002374] <info> Pairing state loaded: 0
    [2023-04-20 13:34:45.106] [00000002374] <info> Config version 4
    [2023-04-20 13:34:45.106] [00000002374] <info> init_chnl_seed, chsid:9, seed:3CB829CC0000
    [2023-04-20 13:34:45.106] [00000002374] <info> rnet_mac_disco_init state = 0, req_auth = 0,cur_ev = 0
    [2023-04-20 13:34:45.111] [00000002375] <info> min ch symbols ms 151 bcn time ms 167
    [2023-04-20 13:34:45.111] [00000002375] <info> 900MHz MAC Init: PRB:1 BCN:1 HDR:1, HDR_LORA:0 LDR:0
    [2023-04-20 13:34:45.111] [00000002376] <info> Ring-Net initialized
    [2023-04-20 13:34:45.116] [00000002376] <info> [MET] B:0 N:0
    [2023-04-20 13:34:45.116] [00000002377] <info> rnet_mac_disco_init state = 1, req_auth = 0,cur_ev = 0
    [2023-04-20 13:34:45.116] [00000002377] <info> Starting GWD Process in: PASSIVE_SYNC/FFS_MODE
    [2023-04-20 13:34:45.116] [00000002377] <info> rnet_mac_disco_start_sampling state = 1, req_auth = 0, cur_ev = 0 f = 0x3b71d r = 0
    [2023-04-20 13:34:45.121] [00000002378] <info> Disco sampling start SUCCESS! state = 2, req_auth = 0, cur_ev = 0
    [2023-04-20 13:34:45.121] [00000002378] <info> status changed: 1
    [2023-04-20 13:34:45.127] [00000002378] <info> Registration Status = 1, Time Sync Status = 1 and Link Status Mask = 0
    [2023-04-20 13:34:45.127] [00000002379] <info> Link 0 Mode 0
    [2023-04-20 13:34:45.127] [00000002379] <info> Link 1 Mode 0
    [2023-04-20 13:34:45.127] [00000002379] <info> Link 2 Mode 0
    [2023-04-20 13:34:45.152] [00000002380] <info> Disco stop sampling success. Time elapsed = 2 ms
    [2023-04-20 13:34:45.152] [00000002380] <error> rnet_mac_scheduler_phy_event_notify is called with event = 7 is_current_radio_o[00000017380] <info> Starting GWD Process in: PASSIVE_SYNC/FFS_MODE
    [2023-04-20 13:35:00.094] [00000017380] <info> rnet_mac_disco_start_sampling state = 1, req_auth = 0, cur_ev = 0 f = 0x3b71d r = 0
    [2023-04-20 13:35:00.094] [00000017381] <info> Disco sampling start SUCCESS! state = 2, req_auth = 0, cur_ev = 0
    [2023-04-20 13:35:00.122] [00000017381] <info> REG:ST(2):0
    [2023-04-20 13:35:15.097] �[00000018748] <warning> Disco submodule ended prematurely! ch = 45
    [2023-04-20 13:35:15.097] [00000022382] <info> Disco active. LSC=61, symb=32, rx_to_ms=151
    [2023-04-20 13:35:15.097] [00000027382] <info> Disco active. LSC=8, symb=32, rx_to_ms=151
    [2023-04-20 13:35:15.097] [00000032380] <info> PASSIVE GWD: Supervisor Timed-out
    [2023-04-20 13:35:15.101] [00000032383] <info> Disco active. LSC=24, symb=32, rx_to_ms=151
    [2023-04-20 13:35:15.101] [00000032383] <info> REG:ST(6):0
    [2023-04-20 13:35:15.101] [00000032384] <info> Disco stop sampling success. Time elapsed = 15002 ms
    [2023-04-20 13:35:15.128] [00000032384] <error> rnet_mac_scheduler_phy_event_notify is called with event = 7 is_current_radio_owner = 1
    [2023-04-20 13:35:15.218] [00000032484] <info> REG:ST(1):1
    [2023-04-20 13:35:19.403] [00000036674] <info> find_route [RT:0] [CMD:0:112:2]
    [2023-04-20 13:35:19.403] [00000036674] <info> data_send send -40
    [2023-04-20 13:35:19.403] [00000036674] <info> Wait for Sid api to notify to proceed with factory reset!
    [2023-04-20 13:35:21.409] [00000000003] <info> Sidewalk example started
    [2023-04-20 13:35:23.772] [00000002367] <info> DR state [1]
    [2023-04-20 13:35:23.772] [00000002368] <info> Protocol Switch:0
    [2023-04-20 13:35:23.772] [00000002368] <info> Dev Profile: type 2, mode:1
    [2023-04-20 13:35:23.772] [00000002368] <info> Dev Version: 944
    [2023-04-20 13:35:23.772] [00000002369] <info> Protocol Switch:0
    [2023-04-20 13:35:23.776] [00000002369] <info> Dev Profile: type 2, mode:1
    [2023-04-20 13:35:23.776] [00000002369] <info> Dev Version: 944
    [2023-04-20 13:35:23.776] [00000002370] <info> Set region 1, country: US, num cfg: 2
    [2023-04-20 13:35:23.776] [00000002372] <info> RTC compensation is not supported.
    [2023-04-20 13:35:23.782] [00000002372] <info> P2P chnl loaded: 0
    [2023-04-20 13:35:23.782] [00000002372] <info> PAN ID loaded:
    [2023-04-20 13:35:23.782] [00000002372] <info> A0 00 00 02 00
    [2023-04-20 13:35:23.782] [00000002373] <info> Def mcast retries: 1
    [2023-04-20 13:35:23.786] [00000002373] <info> Pairing state loaded: 0
    [2023-04-20 13:35:23.786] [00000002373] <info> Config version 4
    [2023-04-20 13:35:23.786] [00000002373] <info> init_chnl_seed, chsid:9, seed:3CB829CC0000
    [2023-04-20 13:35:23.786] [00000002374] <info> rnet_mac_disco_init state = 0, req_auth = 0,cur_ev = 0
    [2023-04-20 13:35:23.792] [00000002374] <info> min ch symbols ms 151 bcn time ms 167
    [2023-04-20 13:35:23.792] [00000002375] <info> 900MHz MAC Init: PRB:1 BCN:1 HDR:1, HDR_LORA:0 LDR:0
    [2023-04-20 13:35:23.792] [00000002375] <info> rnet_sec: Loading Setting (key=0xa) not on flash!
    [2023-04-20 13:35:23.796] [00000002377] <info> rnet_sec: Loading Setting (key=0x9) not on flash!
    [2023-04-20 13:35:23.797] [00000002378] <info> Ring-Net initialized
    [2023-04-20 13:35:23.797] [00000002379] <info> [MET] B:0 N:0
    [2023-04-20 13:35:23.797] [00000002379] <info> rnet_mac_disco_init state = 1, req_auth = 0,cur_ev = 0
    [2023-04-20 13:35:23.801] [00000002379] <info> Starting GWD Process in: PASSIVE_SYNC/FFS_MODE
    [2023-04-20 13:35:23.801] [00000002379] <info> rnet_mac_disco_start_sampling state = 1, req_auth = 0, cur_ev = 0 f = 0x3b71d r = 0
    [2023-04-20 13:35:23.805] [00000002380] <info> Disco sampling start SUCCESS! state = 2, req_auth = 0, cur_ev = 0
    [2023-04-20 13:35:23.805] [00000002380] <info> status changed: 1
    [2023-04-20 13:35:23.805] [00000002381] <info> Registration Status = 1, Time Sync Status = 1 and Link Status Mask = 0
    [2023-04-20 13:35:23.834] [00000002381] <info> Link 0 Mode 0
    [2023-04-20 13:35:23.834] [00000002381] <info> Link 1 Mode 0
    [2023-04-20 13:35:23.834] [00000002381] <info> Link 2 Mode 0
    [2023-04-20 13:35:23.834] [00000002382] <info[00000013382] <info> Starting GWD Process in: PASSIVE_SYNC/FFS_MODE
    [2023-04-20 13:35:34.774] [00000013383] <info> rnet_mac_disco_start_sampling state = 1, req_auth = 0, cur_ev = 0 f = 0x3b71d r = 0
    [2023-04-20 13:35:34.774] [00000013383] <info> Disco sampling start SUCCESS! state = 2, req_auth = 0, cur_ev = 0
    [2023-04-20 13:35:34.804] [00000013383] <info> REG:ST(2):0
    [2023-04-20 13:35:49.775] [00000018385] <info> Disco active. LSC=61, symb=32, rx_to_ms=151
    [2023-04-20 13:35:49.775] [00000023386] <info> Disco active. LSC=54, symb=32, rx_to_ms=151
    [2023-04-20 13:35:49.775] [00000027398] <warning> Disco submodule ended prematurely! ch = 33
    [2023-04-20 13:35:49.775] [00000027748] <warning> Disco submodule ended prematurely! ch = 65
    [2023-04-20 13:35:49.779] [00000028382] <info> PASSIVE GWD: Supervisor Timed-out
    [2023-04-20 13:35:49.779] [00000028385] <info> REG:ST(6):0
    [2023-04-20 13:35:49.779] [00000028385] <info> Disco stop sampling success. Time elapsed = 15002 ms
    [2023-04-20 13:35:49.900] [00000028485] <info> REG:ST(1):1
    [2023-04-20 13:35:59.877] [00000038486] <info> Starting GWD Process in: PASSIVE_SYNC/FFS_MODE
    [2023-04-20 13:35:59.877] [00000038486] <info> rnet_mac_disco_start_sampling state = 1, req_auth = 0, cur_ev = 0 f = 0x3b71d r = 0
    [2023-04-20 13:35:59.877] [00000038486] <info> Disco sampling start SUCCESS! state = 2, req_auth = 0, cur_ev = 0
    [2023-04-20 13:35:59.910] [00000038486] <info> REG:ST(2):1
    [2023-04-20 13:36:15.161] [00000000003] <info> Sidewalk example started
    [2023-04-20 13:36:17.514] [00000002367] <info> DR state [1]
    [2023-04-20 13:36:17.514] [00000002369] <info> Protocol Switch:0
    [2023-04-20 13:36:17.514] [00000002369] <info> Dev Profile: type 2, mode:1
    [2023-04-20 13:36:17.514] [00000002369] <info> Dev Version: 944
    [2023-04-20 13:36:17.514] [00000002370] <info> Protocol Switch:0
    [2023-04-20 13:36:17.520] [00000002371] <info> Dev Profile: type 2, mode:1
    [2023-04-20 13:36:17.520] [00000002371] <info> Dev Version: 944
    [2023-04-20 13:36:17.520] [00000002372] <info> Set region 1, country: US, num cfg: 2
    [2023-04-20 13:36:17.520] [00000002373] <info> RTC compensation is not supported.
    [2023-04-20 13:36:17.523] [00000002374] <info> P2P chnl loaded: 0
    [2023-04-20 13:36:17.523] [00000002374] <info> PAN ID loaded:
    [2023-04-20 13:36:17.523] [00000002374] <info> A0 00 00 02 00
    [2023-04-20 13:36:17.523] [00000002374] <info> Def mcast retries: 1
    [2023-04-20 13:36:17.528] [00000002374] <info> Pairing state loaded: 0
    [2023-04-20 13:36:17.528] [00000002375] <info> Config version 4
    [2023-04-20 13:36:17.528] [00000002375] <info> init_chnl_seed, chsid:9, seed:3CB829CC0000
    [2023-04-20 13:36:17.528] [00000002375] <info> rnet_mac_disco_init state = 0, req_auth = 0,cur_ev = 0
    [2023-04-20 13:36:17.533] [00000002376] <info> min ch symbols ms 151 bcn time ms 167
    [2023-04-20 13:36:17.533] [00000002376] <info> 900MHz MAC Init: PRB:1 BCN:1 HDR:1, HDR_LORA:0 LDR:0
    [2023-04-20 13:36:17.533] [00000002377] <info> Ring-Net initialized
    [2023-04-20 13:36:17.543] [00000002377] <info> [MET] B:0 N:0
    [2023-04-20 13:36:17.543] [00000002378] <info> rnet_mac_disco_init state = 1, req_auth = 0,cur_ev = 0
    [2023-04-20 13:36:17.543] [00000002378] <info> Starting GWD Process in: PASSIVE_SYNC/FFS_MODE
    [2023-04-20 13:36:17.543] [00000002378] <info> rnet_mac_disco_start_sampling state = 1, req_auth = 0, cur_ev = 0 f = 0x3b71d r = 0
    [2023-04-20 13:36:17.545] [00000002378] <info> Disco sampling start SUCCESS! state = 2, req_auth = 0, cur_ev = 0
    [2023-04-20 13:36:17.545] [00000002379] <info> status changed: 1
    [2023-04-20 13:36:17.548] [00000002379] <info> Registration Status = 1, Time Sync Status = 1 and Link Status Mask = 0
    [2023-04-20 13:36:17.548] [00000002380] <info> Link 0 Mode 0
    [2023-04-20 13:36:17.548] [00000002380] <info> Link 1 Mode 0
    [2023-04-20 13:36:17.548] [00000002380] <info> Link 2 Mode 0
    [2023-04-20 13:36:17.575] [00000002381] <info> Disco stop sampling success. Time elapsed = 2 ms
    [2023-04-20 13:36:17.575] [00000002381] <error> rnet_mac_scheduler_phy_event_notify is called with event = 7 is_current_radio_o[00000014381] <info> Starting GWD Process in: PASSIVE_SYNC/FFS_MODE
    [2023-04-20 13:36:29.516] [00000014381] <info> rnet_mac_disco_start_sampling state = 1, req_auth = 0, cur_ev = 0 f = 0x3b71d r = 0
    [2023-04-20 13:36:29.516] [00000014382] <info> Disco sampling start SUCCESS! state = 2, req_auth = 0, cur_ev = 0
    [2023-04-20 13:36:29.542] [00000014382] <info> REG:ST(2):0
    [2023-04-20 13:36:44.518] [00000019382] <info> Disco active. LSC=50, symb=32, rx_to_ms=151
    [2023-04-20 13:36:44.518] [00000024384] <info> Disco active. LSC=32, symb=32, rx_to_ms=151
    [2023-04-20 13:36:44.518] [00000029381] <info> PASSIVE GWD: Supervisor Timed-out
    [2023-04-20 13:36:44.518] [00000029384] <info> REG:ST(6):0
    [2023-04-20 13:36:44.522] [00000029384] <info> Disco stop sampling success. Time elapsed = 15002 ms
    [2023-04-20 13:36:44.522] [00000029385] <error> rnet_mac_scheduler_phy_event_notify is called with event = 7 is_current_radio_owner = 1
    [2023-04-20 13:36:44.643] [00000029484] <info> REG:ST(1):1
    [2023-04-20 13:36:52.353] [00000037202] <info> find_route [RT:0] [CMD:0:112:2]
    [2023-04-20 13:36:52.353] [00000037202] <info> data_send send -40
    [2023-04-20 13:36:52.353] [00000037203] <info> Wait for Sid api to notify to proceed with factory reset!
    [2023-04-20 13:36:54.358] [00000000003] <info> Sidewalk example started
    [2023-04-20 13:36:56.723] [00000002367] <info> DR state [1]
    [2023-04-20 13:36:56.723] [00000002368] <info> Protocol Switch:0
    [2023-04-20 13:36:56.723] [00000002369] <info> Dev Profile: type 2, mode:1
    [2023-04-20 13:36:56.723] [00000002369] <info> Dev Version: 944
    [2023-04-20 13:36:56.723] [00000002370] <info> Protocol Switch:0
    [2023-04-20 13:36:56.727] [00000002370] <info> Dev Profile: type 2, mode:1
    [2023-04-20 13:36:56.727] [00000002371] <info> Dev Version: 944
    [2023-04-20 13:36:56.727] [00000002371] <info> Set region 1, country: US, num cfg: 2
    [2023-04-20 13:36:56.727] [00000002373] <info> RTC compensation is not supported.
    [2023-04-20 13:36:56.733] [00000002373] <info> P2P chnl loaded: 0
    [2023-04-20 13:36:56.733] [00000002373] <info> PAN ID loaded:
    [2023-04-20 13:36:56.733] [00000002374] <info> A0 00 00 02 00
    [2023-04-20 13:36:56.733] [00000002374] <info> Def mcast retries: 1
    [2023-04-20 13:36:56.742] [00000002374] <info> Pairing state loaded: 0
    [2023-04-20 13:36:56.742] [00000002375] <info> Config version 4
    [2023-04-20 13:36:56.742] [00000002375] <info> init_chnl_seed, chsid:9, seed:3CB829CC0000
    [2023-04-20 13:36:56.742] [00000002375] <info> rnet_mac_disco_init state = 0, req_auth = 0,cur_ev = 0
    [2023-04-20 13:36:56.744] [00000002376] <info> min ch symbols ms 151 bcn time ms 167
    [2023-04-20 13:36:56.744] [00000002376] <info> 900MHz MAC Init: PRB:1 BCN:1 HDR:1, HDR_LORA:0 LDR:0
    [2023-04-20 13:36:56.744] [00000002377] <info> rnet_sec: Loading Setting (key=0xa) not on flash!
    [2023-04-20 13:36:56.747] [00000002378] <info> rnet_sec: Loading Setting (key=0x9) not on flash!
    [2023-04-20 13:36:56.747] [00000002380] <info> Ring-Net initialized
    [2023-04-20 13:36:56.747] [00000002380] <info> [MET] B:0 N:0
    [2023-04-20 13:36:56.747] [00000002381] <info> rnet_mac_disco_init state = 1, req_auth = 0,cur_ev = 0
    [2023-04-20 13:36:56.753] [00000002381] <info> Starting GWD Process in: PASSIVE_SYNC/FFS_MODE
    [2023-04-20 13:36:56.753] [00000002381] <info> rnet_mac_disco_start_sampling state = 1, req_auth = 0, cur_ev = 0 f = 0x3b71d r = 0
    [2023-04-20 13:36:56.762] [00000002382] <info> Disco sampling start SUCCESS! state = 2, req_auth = 0, cur_ev = 0
    [2023-04-20 13:36:56.762] [00000002382] <info> status changed: 1
    [2023-04-20 13:36:56.762] [00000002382] <info> Registration Status = 1, Time Sync Status = 1 and Link Status Mask = 0
    [2023-04-20 13:36:56.783] [00000002383] <info> Link 0 Mode 0
    [2023-04-20 13:36:56.783] [00000002383] <info> Link 1 Mode 0
    [2023-04-20 13:36:56.783] [00000002383] <info> Link 2 Mode 0
    [2023-04-20 13:36:56.783] [00000002384] <info[00000016384] <info> Starting GWD Process in: PASSIVE_SYNC/FFS_MODE
    [2023-04-20 13:37:10.726] [00000016384] <info> rnet_mac_disco_start_sampling state = 1, req_auth = 0, cur_ev = 0 f = 0x3b71d r = 0
    [2023-04-20 13:37:10.726] [00000016385] <info> Disco sampling start SUCCESS! state = 2, req_auth = 0, cur_ev = 0
    [2023-04-20 13:37:10.754] [00000016385] <info> REG:ST(2):0
    [2023-04-20 13:37:25.728] [00000021386] <info> Disco active. LSC=68, symb=32, rx_to_ms=151
    [2023-04-20 13:37:25.728] [00000026386] <info> Disco active. LSC=67, symb=32, rx_to_ms=151
    [2023-04-20 13:37:25.728] [00000031060] <warning> Disco submodule ended prematurely! ch = 1
    [2023-04-20 13:37:25.728] [00000031384] <info> PASSIVE GWD: Supervisor Timed-out
    [2023-04-20 13:37:25.732] [00000031386] <info> Disco active. LSC=43, symb=32, rx_to_ms=151
    [2023-04-20 13:37:25.732] [00000031387] <info> REG:ST(6):0
    [2023-04-20 13:37:25.732] [00000031388] <info> Disco stop sampling success. Time elapsed = 15002 ms
    [2023-04-20 13:37:25.760] [00000031388] <error> rnet_mac_scheduler_phy_event_notify is called with event = 7 is_current_radio_owner = 1
    [2023-04-20 13:37:25.849] [00000031488] <info> REG:ST(1):1
    [2023-04-20 13:37:35.829] [00000041488] <info> Starting GWD Process in: PASSIVE_SYNC/FFS_MODE
    [2023-04-20 13:37:35.829] [00000041488] <info> rnet_mac_disco_start_sampling state = 1, req_auth = 0, cur_ev = 0 f = 0x3b71d r = 0
    [2023-04-20 13:37:35.829] [00000041489] <info> Disco sampling start SUCCESS! state = 2, req_auth = 0, cur_ev = 0
    [2023-04-20 13:37:35.860] [00000041489] <info> REG:ST(2):1
    [2023-04-20 13:37:50.832] [00000046490] <info> Disco active. LSC=68, symb=32, rx_to_ms=151
    [2023-04-20 13:37:50.832] [00000051492] <info> Disco active. LSC=67, symb=32, rx_to_ms=151
    [2023-04-20 13:37:50.832] [00000055339] <warning> Disco submodule ended prematurely! ch = 29
    [2023-04-20 13:37:50.832] [00000056488] <info> PASSIVE GWD: Supervisor Timed-out
    [2023-04-20 13:37:50.836] [00000056491] <info> REG:ST(6):1
    [2023-04-20 13:37:50.836] [00000056492] <info> Disco stop sampling success. Time elapsed = 15002 ms
    [2023-04-20 13:37:50.837] [00000056493] <error> rnet_mac_scheduler_phy_event_notify is called with event = 7 is_current_radio_owner = 1
    [2023-04-20 13:37:50.956] [00000056591] <info> REG:ST(1):2
    [2023-04-20 13:38:00.934] [00000066591] <info> Starting GWD Process in: PASSIVE_SYNC/FFS_MODE
    [2023-04-20 13:38:00.934] [00000066592] <info> rnet_mac_disco_start_sampling state = 1, req_auth = 0, cur_ev = 0 f = 0x3b71d r = 0
    [2023-04-20 13:38:00.934] [00000066592] <info> Disco sampling start SUCCESS! state = 2, req_auth = 0, cur_ev = 0
    [2023-04-20 13:38:00.961] [00000066592] <info> REG:ST(2):2
    [2023-04-20 13:38:15.936] [00000071594] <info> Disco active. LSC=68, symb=32, rx_to_ms=151
    [2023-04-20 13:38:15.936] [00000076596] <info> Disco active. LSC=68, symb=32, rx_to_ms=151
    [2023-04-20 13:38:15.936] [00000079625] <warning> Disco submodule ended prematurely! ch = 61
    [2023-04-20 13:38:15.936] [00000081591] <info> PASSIVE GWD: Supervisor Timed-out
    [2023-04-20 13:38:15.940] [00000081594] <info> REG:ST(6):2
    [2023-04-20 13:38:15.940] [00000081595] <info> Disco stop sampling success. Time elapsed = 15002 ms
    [2023-04-20 13:38:15.940] [00000081595] <error> rnet_mac_scheduler_phy_event_notify is called with event = 7 is_current_radio_owner = 1
    [2023-04-20 13:38:16.057] [00000081694] <error> Error: Add to blocklist
    [2023-04-20 13:38:16.057] [00000081695] <info> REG:ST(1):3
    [2023-04-20 13:38:16.137] [00000081795] <info> Starting GWD Process in: PASSIVE_SYNC/FFS_MODE
    [2023-04-20 13:38:16.137] [00000081795] <info> rnet_mac_disco_start_sampling state = 1, req_auth = 0, cur_ev = 0 f = 0x3b71d r = 0
    [2023-04-20 13:38:16.137] [00000081796] <info> Disco sampling start SUCCESS! state = 2, req_auth = 0, cur_ev = 0
    [2023-04-20 13:38:16.167] [00000081796] <info> REG:ST(2):3
  • Just for your reference, I can see it works if I switch to use BLE. Any though on why FSK 900 MHz doesn't work?
  • Hi Yikai,
    The reason registration does not works is that it seems like FSK registration is still not enabled by Amazon, even though the PHY is.
    At the moment, you have to register your device through BLE, and then switch to FSK when registration has been done.
    I can give more details on how to do so if needed.
    Arthur
  • Yes, please give details about how to use FSK to connect. Thanks!
  • another issue is about the power consumption of sid_demo which shows about 1.2mA in my CCS EnergyTrace and this is much higher than competitor’s solution (also test with BLE sidewalk and it’s about 113uA). Is there any way to decrease the power consumption of sid_demo?
  • Hi YiKai,
    Thank you for your observations, here is what I personally observe using EnergyTrace, in BLE with the device connected:
    Does it matches with what you are seeing?
    As of the way to switch to FSK, I will be coming with steps today.
    By the way, about the FSK registration rollout for Echo devices, I will have news about it on Monday, thank you for your patience.
    Arthur
  • Yes, your power consumption screenshots match my observation. Do you think it can be improved?
    For switching to FSK, I will wait your input to test it.
  • YiKai,
    Do you happen to know the BLE connection interval of the competitor's solution? It seems like we could tweak that setting,
    Arthur
  • For now, I don't know the BLE connection interval of the competitor's solution but I will find it out later. Maybe you can tell me how to manipulate BLE connection interval or other settings such as TX power for getting more lower power consumption. By the way, do you have composed the steps for "register your device through BLE, and then switch to FSK when registration has been done."?
  • Do you have any update on this?
  • Hi Yikai,
    Please excuse me, I am still working on it, I have to make sure the instructions work for you, as my gateway does not have the same firmware as yours.
    Could you also please provide me with your Echo gateway DSN by private message so that I can check for its firmware type? It is located in both your Alexa app, and under the GW itself, like so:
    Regards.
    Arthur
  • Just send you by PM.
  • Here is a modified main.c for sid_demo that initializes the stack in BLE mode, then switches to FSK.
     * Copyright  2020-2023 Amazon.com, Inc. or its affiliates.  All rights reserved.
     * AMAZON PROPRIETARY/CONFIDENTIAL
     * You may not use this file except in compliance with the terms and
     * conditions set forth in the accompanying LICENSE.TXT file.  This file is a
     * Modifiable File, as defined in the accompanying LICENSE.TXT file.
     * THESE MATERIALS ARE PROVIDED ON AN "AS IS" BASIS. AMAZON SPECIFICALLY
     * DISCLAIMS, WITH RESPECT TO THESE MATERIALS, ALL WARRANTIES, EXPRESS,
     * IMPLIED, OR STATUTORY, INCLUDING THE IMPLIED WARRANTIES OF MERCHANTABILITY,
     * FITNESS FOR A PARTICULAR PURPOSE, AND NON-INFRINGEMENT.
    #include <sid_api.h>
    #include <sid_pal_crypto_ifc.h>
    #include <sid_pal_mfg_store_ifc.h>
    #include <sid_pal_storage_kv_ifc.h>
    #include <sid_pal_uptime_ifc.h>
    #include <sid_time_ops.h>
    #include <sid_900_cfg.h>
    #include <sid_demo_parser.h>
    #include <sid_demo_types.h>
    #include <FreeRTOS.h>
    #include <timers.h>
    #include <queue.h>
    #include <task.h>
    //FIXME: These are internal deps of sidewalk,
    // the application shouldn't be using these headers
    #include <sid_pal_log_ifc.h>
    #include <ti_itm.h>
    #include <ti/drivers/Board.h>
    #include <ti/drivers/apps/Button.h>
    #include <ti/drivers/apps/LED.h>
    #include <ti/drivers/Temperature.h>
    #include <ti_drivers_config.h>
    #include <ti/devices/DeviceFamily.h>
    #include DeviceFamily_constructPath(driverlib/sys_ctrl.h)
    #if SID_SDK_CONFIG_ENABLE_LINK_TYPE_1 == 1
    #include <app_ble_config.h>
    #endif
    #if SID_SDK_CONFIG_ENABLE_LINK_TYPE_2 == 1
    #include <app_900_config.h>
    #endif
    #include <assert.h>
    #include <stdbool.h>
    #include <stdint.h>
    #include <string.h>
    #define MAIN_TASK_STACK_SIZE        (2048 / sizeof(configSTACK_DEPTH_TYPE))
    #define RECEIVE_TASK_STACK_SIZE     (2048 / sizeof(configSTACK_DEPTH_TYPE))
    #define MSG_QUEUE_LEN 10
    #define MSG_LOG_BLOCK_SIZE 80
     //FIXME: this is actually less, but we have to set to 0x2000 for sid_pal_mfg_store_init to succeed
    #define MANUFACTURE_FLASH_SIZE          0x02000
    #define MANUFACTURE_FLASH_END           (MANUFACTURE_FLASH_START + MANUFACTURE_FLASH_SIZE)
    #define DEMO_BUTTONS_MAX                    1
    #define DEMO_LEDS_MAX                       2
    #define PAYLOAD_MAX_SIZE                    255
    #define DEMO_CAPABILITY_PERIOD_MS           5000
    #define BUTTON_PRESS_CHECK_PERIOD_SECS      30
    #define DEMO_NOTIFY_SENSOR_DATA_PERIOD_MS   15000
    #define CONNECT_LINK_TYPE_1_DELAY_MS        60000
    #define CONNECT_LINK_TYPE_1_INIT_DELAY_MS   5000
    #define PROFILE_CHECK_TIMER_DELAY_MS        60000
    #define LED_ACTION_REPONSE_PAYLOAD_SIZE_MAX 32
    #define SENSOR_NOTIFY_PAYLOAD_SIZE_MAX      32
    #define CAPABILITY_NOTIFY_PAYLOAD_SIZE_MAX  32
    #define SID_DEMO_APP_TTL_MAX                60
    #define SID_DEMO_APP_RETRIES_MAX            3
    enum event_type
        EVENT_TYPE_SIDEWALK,
        EVENT_FACTORY_RESET,
        EVENT_BUTTON_PRESS,
        EVENT_CONNECT_LINK_TYPE_1,
        EVENT_SET_DEVICE_PROFILE_LINK_TYPE_2,
        EVENT_NOTIFICATION_TIMER_FIRED,
        EVENT_BUTTON_PRESS_TIMER_FIRED,
        EVENT_SEND_MESSAGE,
    enum app_sidewalk_state
        STATE_SIDEWALK_INIT,
        STATE_SIDEWALK_READY,
        STATE_SIDEWALK_NOT_READY,
        STATE_SIDEWALK_SECURE_CONNECTION,
    enum demo_app_state
        DEMO_APP_STATE_INIT,
        DEMO_APP_STATE_REGISTERED,
        DEMO_APP_STATE_NOTIFY_CAPABILITY,
        DEMO_APP_STATE_NOTIFY_SENSOR_DATA,
    enum demo_app_led_id
        DEMO_APP_LED_ID_0 = 0,
        DEMO_APP_LED_ID_1 = 1,
        DEMO_APP_LED_ID_LAST,
    enum demo_app_button_id
        DEMO_APP_BUTTON_ID_0 = 0,
        DEMO_APP_BUTTON_ID_LAST,
    struct link_status
        enum sid_time_sync_status time_sync_status;
        uint32_t link_mask;
        uint32_t supported_link_mode[SID_LINK_TYPE_MAX_IDX];
    struct app_demo_rx_msg {
        uint16_t msg_id;
        size_t pld_size;
        uint8_t rx_payload[PAYLOAD_MAX_SIZE];
    struct app_demo_tx_msg {
        struct sid_msg_desc desc;
        size_t pld_size;
        uint8_t tx_payload[PAYLOAD_MAX_SIZE];
    struct demo_app_event {
        enum event_type type;
        void *data;
    typedef struct app_context
        TaskHandle_t main_task;
        QueueHandle_t event_queue;
        TimerHandle_t cap_timer_handle;
        TimerHandle_t button_press_timer_handle;
        TimerHandle_t device_profile_timer_handle;
        struct sid_handle *sidewalk_handle;
        enum app_sidewalk_state sidewalk_state;
        enum demo_app_state app_state;
        struct link_status link_status;
        Button_Handle button_1;
        Button_Handle button_2;
        LED_Handle led_handles[DEMO_LEDS_MAX];
        uint8_t led_id_arr[DEMO_LEDS_MAX];
        uint8_t button_id_arr[DEMO_BUTTONS_MAX];
        uint32_t button_press_mask;
        uint32_t button_notify_mask;
        bool button_event_pending_processing;
        uint32_t button_press_time_in_sec_id_arr[DEMO_BUTTONS_MAX];
        uint8_t buffer[PAYLOAD_MAX_SIZE];
    } app_context_t;
    typedef struct receive_context
        TaskHandle_t receive_task;
        QueueHandle_t receive_event_queue;
    } receive_context_t;
    /* Global mainly because bsp_evt_handler does not have a context pointer */
    static QueueHandle_t g_event_queue;
    static app_context_t g_app_context = {0};
    static QueueHandle_t g_receieve_event_queue;
    static receive_context_t g_receive_context = {0};
    void __assert_func(const char* file, int line, const char* func, const char* failedexpr)
        TI_LOG_ERROR("assert '%s' in %s:%s line %d", failedexpr, file, func, line);
        ITM_flushModule();
        taskDISABLE_INTERRUPTS();
        while(true);
    static void queue_event(QueueHandle_t queue, enum event_type event, void *data, bool in_isr)
        struct demo_app_event evt = {.type = event, .data = data};
        if (in_isr) {
            BaseType_t task_woken = pdFALSE;
            xQueueSendFromISR(queue, &evt, &task_woken);
            portYIELD_FROM_ISR(task_woken);
        else {
            xQueueSend(queue, &evt, 0);
    static void queue_rx_msg(QueueHandle_t queue, struct app_demo_rx_msg *rx_msg, bool in_isr)
        if (in_isr) {
            xQueueSendToBackFromISR(queue, rx_msg, &task_woken);
        else {
            xQueueSendToBack(queue, rx_msg, 0);
    static void on_sidewalk_event(bool in_isr, void *context)
        app_context_t *app_context = (app_context_t *)context;
        queue_event(app_context->event_queue, EVENT_TYPE_SIDEWALK, NULL, in_isr);
    static void log_sid_msg(const struct sid_msg *msg)
        for (size_t i = 0; i < msg->size; i += MSG_LOG_BLOCK_SIZE) {
            if (i + MSG_LOG_BLOCK_SIZE > msg->size) {
                TI_LOG_HEXDUMP_INFO(msg->data + i, msg->size - i);
            } else {
                TI_LOG_HEXDUMP_INFO(msg->data + i, MSG_LOG_BLOCK_SIZE);
    static void on_sidewalk_msg_received(const struct sid_msg_desc *msg_desc, const struct sid_msg *msg, void *context)
        TI_LOG_INFO("received message(type: %d, link_mode: %d, id: %u size %u rssi %d snr %d)", (int)msg_desc->type,
                     (int)msg_desc->link_mode, msg_desc->id, msg->size,
                     (int)msg_desc->msg_desc_attr.rx_attr.rssi,  (int)msg_desc->msg_desc_attr.rx_attr.snr);
        log_sid_msg(msg);
        if (msg_desc->type == SID_MSG_TYPE_RESPONSE && msg_desc->msg_desc_attr.rx_attr.is_msg_ack) {
            TI_LOG_INFO("Received Ack for msg id %d", msg_desc->id);
        } else {
            struct app_demo_rx_msg rx_msg = {
                .msg_id = msg_desc->id,
                .pld_size = msg->size,
            memcpy(rx_msg.rx_payload, msg->data, msg->size);
            queue_rx_msg(g_receieve_event_queue, &rx_msg, false);
    static void on_sidewalk_msg_sent(const struct sid_msg_desc *msg_desc, void *context)
        TI_LOG_INFO("sent message(type: %d, id: %u)", (int)msg_desc->type, msg_desc->id);
    static void on_sidewalk_send_error(sid_error_t error, const struct sid_msg_desc *msg_desc, void *context)
        TI_LOG_ERROR("failed to send message(type: %d, id: %u), err:%d",
                      (int)msg_desc->type, msg_desc->id, (int)error);
    static void on_sidewalk_status_changed(const struct sid_status *status, void *context)
        TI_LOG_INFO("status changed: %d", (int)status->state);
        switch (status->state) {
            case SID_STATE_READY:
                app_context->sidewalk_state = STATE_SIDEWALK_READY;
                break;
            case SID_STATE_NOT_READY:
                app_context->sidewalk_state = STATE_SIDEWALK_NOT_READY;
                break;
            case SID_STATE_ERROR:
                TI_LOG_INFO("sidewalk error: %d", (int)sid_get_error(app_context->sidewalk_handle));
                assert(false);
                break;
            case SID_STATE_SECURE_CHANNEL_READY:
                app_context->sidewalk_state = STATE_SIDEWALK_SECURE_CONNECTION;
                break;
        TI_LOG_INFO("Registration Status = %d, Time Sync Status = %d and Link Status Mask = %x",
                     status->detail.registration_status, status->detail.time_sync_status,
                     status->detail.link_status_mask);
        app_context->link_status.link_mask = status->detail.link_status_mask;
        app_context->link_status.time_sync_status = status->detail.time_sync_status;
        for (int i = 0; i < SID_LINK_TYPE_MAX_IDX; i++) {
            app_context->link_status.supported_link_mode[i] = status->detail.supported_link_modes[i];
            TI_LOG_INFO("Link %d Mode %x", i, status->detail.supported_link_modes[i]);
        if (app_context->app_state == DEMO_APP_STATE_INIT &&
                status->detail.registration_status == SID_STATUS_REGISTERED) {
            app_context->app_state = DEMO_APP_STATE_REGISTERED;
        if (app_context->sidewalk_state == STATE_SIDEWALK_READY) {
            TickType_t delay = pdMS_TO_TICKS(DEMO_CAPABILITY_PERIOD_MS);
            if (app_context->app_state == DEMO_APP_STATE_REGISTERED) {
                app_context->app_state = DEMO_APP_STATE_NOTIFY_CAPABILITY;
            } else if (app_context->app_state == DEMO_APP_STATE_NOTIFY_SENSOR_DATA) {
                delay = DEMO_NOTIFY_SENSOR_DATA_PERIOD_MS;
            BaseType_t ret = xTimerIsTimerActive(g_app_context.cap_timer_handle);
            if (ret == pdTRUE) {
                ret = xTimerStop(g_app_context.cap_timer_handle, 0);
                ASSERT(ret == pdPASS)
            ret = xTimerChangePeriod(g_app_context.cap_timer_handle, pdMS_TO_TICKS(delay), 0);
        if (!(status->detail.link_status_mask & SID_LINK_TYPE_1) && (status->detail.registration_status == SID_STATUS_REGISTERED)
            && (status->detail.time_sync_status == SID_STATUS_TIME_SYNCED)) {
        ret = xTimerChangePeriod(g_app_context.cap_timer_handle, pdMS_TO_TICKS(CONNECT_LINK_TYPE_1_INIT_DELAY_MS), 0);
        if (BUILD_SID_SDK_LINK_TYPE == 2) {
            if ((status->detail.link_status_mask & SID_LINK_TYPE_2) && (status->detail.registration_status == SID_STATUS_REGISTERED)
                BaseType_t ret = xTimerIsTimerActive(g_app_context.device_profile_timer_handle);
                    ret = xTimerStop(g_app_context.device_profile_timer_handle, 0);
                    ASSERT(ret == pdPASS);
                ret = xTimerChangePeriod(g_app_context.device_profile_timer_handle, pdMS_TO_TICKS(PROFILE_CHECK_TIMER_DELAY_MS), 0);
    static void on_sidewalk_factory_reset(void *context)
        TI_LOG_INFO("factory reset notification received from sid api");
        SysCtrlSystemReset();
    static void get_active_link_type(enum sid_link_type *link_type)
        if (g_app_context.link_status.link_mask & SID_LINK_TYPE_1) {
            *link_type = SID_LINK_TYPE_1;
        } else if (g_app_context.link_status.link_mask & SID_LINK_TYPE_2) {
            *link_type = SID_LINK_TYPE_2;
    static void send_msg(struct sid_msg_desc *desc, struct sid_msg *msg)
        if (g_app_context.sidewalk_state == STATE_SIDEWALK_READY ||
            g_app_context.sidewalk_state == STATE_SIDEWALK_SECURE_CONNECTION) {
            sid_error_t ret = sid_put_msg(g_app_context.sidewalk_handle, msg, desc);
            if (ret != SID_ERROR_NONE) {
                TI_LOG_ERROR("failed queueing data, err:%d", (int) ret);
            } else {
                TI_LOG_INFO("queued data message id:%u", desc->id);
                log_sid_msg(msg);
        } else {
            TI_LOG_ERROR("sidewalk is not ready yet!");
    static void factory_reset(void)
        sid_error_t ret = sid_set_factory_reset(g_app_context.sidewalk_handle);
            TI_LOG_ERROR("Notification of factory reset to sid api failed!");
        } else {
            TI_LOG_INFO("Wait for Sid api to notify to proceed with factory reset!");
    static void demo_app_notify_capability(void)
        struct sid_parse_state state = {};
        enum sid_link_type link_type = SID_LINK_TYPE_1;
        struct sid_demo_capability_discovery cap = {
            .num_buttons = sizeof(g_app_context.button_id_arr) / sizeof(g_app_context.button_id_arr[0]),
            .button_id_arr = g_app_context.button_id_arr,
            .num_leds = sizeof(g_app_context.led_id_arr) / sizeof(g_app_context.led_id_arr[0]),
            .led_id_arr = g_app_context.led_id_arr,
            .temp_sensor = SID_DEMO_TEMPERATURE_SENSOR_UNITS_CELSIUS,
        uint8_t temp_buffer[CAPABILITY_NOTIFY_PAYLOAD_SIZE_MAX] = {0};
        get_active_link_type(&link_type);
        cap.link_type = link_type;
        sid_parse_state_init(&state, temp_buffer, sizeof(temp_buffer));
        sid_demo_app_capability_discovery_notification_serialize(&state, &cap);
        if (state.ret_code != SID_ERROR_NONE) {
            TI_LOG_ERROR("capability discovery serialize failed -%d", state.ret_code);
            return;
        struct sid_demo_msg_desc msg_desc = {
            .status_hdr_ind = false,
            .opc = SID_DEMO_MSG_TYPE_NOTIFY,
            .cmd_class = SID_DEMO_APP_CLASS,
            .cmd_id = SID_DEMO_APP_CLASS_CMD_CAP_DISCOVERY_ID,
        struct sid_demo_msg demo_msg = {.payload = temp_buffer, .payload_size = state.offset};
        sid_parse_state_init(&state, g_app_context.buffer, sizeof(g_app_context.buffer));
        sid_demo_app_msg_serialize(&state, &msg_desc, &demo_msg);
            TI_LOG_ERROR("demo msg capability discovery serialize failed -%d", state.ret_code);
            return;
        struct sid_msg msg = {
            .data = g_app_context.buffer,
            .size = state.offset,
        struct sid_msg_desc desc = {
            .link_type = link_type,
            .type = SID_MSG_TYPE_NOTIFY,
            .link_mode = SID_LINK_MODE_CLOUD,
        TI_LOG_INFO("Sending demo app message notify capability");
        send_msg(&desc, &msg);
    static void demo_app_notify_sensor_data(bool button_pressed)
        struct sid_parse_state state = {0};
        struct sid_demo_action_notification action_notify = {0};
        struct sid_timespec curr_time = {0};
        uint8_t temp_buffer[SENSOR_NOTIFY_PAYLOAD_SIZE_MAX] = {0};
        action_notify.button_action_notify.action_resp = (button_pressed) ? SID_DEMO_ACTION_BUTTON_PRESSED :
                                                         SID_DEMO_ACTION_BUTTON_NOT_PRESSED;
        sid_get_time(g_app_context.sidewalk_handle, SID_GET_GPS_TIME, &curr_time);
        if (!button_pressed) {
            action_notify.temp_sensor = SID_DEMO_TEMPERATURE_SENSOR_UNITS_CELSIUS;
            action_notify.temperature = Temperature_getTemperature();
            action_notify.button_action_notify.action_resp = SID_DEMO_ACTION_BUTTON_NOT_PRESSED;
        } else {
            action_notify.temp_sensor = SID_DEMO_TEMPERATURE_SENSOR_NOT_SUPPORTED;
            action_notify.temperature = 0;
            action_notify.button_action_notify.action_resp = SID_DEMO_ACTION_BUTTON_PRESSED;
            uint8_t temp_button_arr[DEMO_BUTTONS_MAX] = {0};
            uint8_t num_buttons_pressed = 0;
            for (size_t i = 0; i < DEMO_BUTTONS_MAX; i++) {
                if (((1 << g_app_context.button_id_arr[i]) & (g_app_context.button_press_mask)) &&
                     (!((1 << g_app_context.button_id_arr[i]) & (g_app_context.button_notify_mask)))) {
                    temp_button_arr[num_buttons_pressed] = g_app_context.button_id_arr[i];
                    num_buttons_pressed += 1;
                    g_app_context.button_notify_mask |= (1 << g_app_context.button_id_arr[i]);
                    g_app_context.button_press_time_in_sec_id_arr[i] = curr_time.tv_sec;
                    BaseType_t ret = xTimerIsTimerActive(g_app_context.button_press_timer_handle);
                    if (ret == pdFALSE) {
                        BaseType_t ret = xTimerChangePeriod(g_app_context.button_press_timer_handle,
                            pdMS_TO_TICKS(BUTTON_PRESS_CHECK_PERIOD_SECS * 1000), 0);
            action_notify.button_action_notify.button_id_arr = temp_button_arr;
            action_notify.button_action_notify.num_buttons = num_buttons_pressed;
        action_notify.gps_time_in_seconds = curr_time.tv_sec;
        action_notify.link_type = link_type;
        sid_demo_app_action_notification_serialize(&state, &action_notify);
            return;
            .cmd_id = SID_DEMO_APP_CLASS_CMD_ACTION,
            TI_LOG_ERROR("demo msg notify sensor data serialize failed -%d", state.ret_code);
            return;
        if (button_pressed) {
            desc.msg_desc_attr.tx_attr.ttl_in_seconds = SID_DEMO_APP_TTL_MAX;
            desc.msg_desc_attr.tx_attr.num_retries = SID_DEMO_APP_RETRIES_MAX;
            desc.msg_desc_attr.tx_attr.request_ack = true;
            TI_LOG_INFO("Sending demo app message notify button press");
        } else {
            TI_LOG_INFO("Sending demo app message notify sensor data");
    static void demo_app_create_led_response(struct sid_demo_action_resp *resp)
        uint8_t temp_buffer[LED_ACTION_REPONSE_PAYLOAD_SIZE_MAX] = {0};
        sid_demo_app_action_resp_serialize(&state, resp);
            .status_hdr_ind = true,
            .opc = SID_DEMO_MSG_TYPE_RESP,
            .status_code = SID_ERROR_NONE,
            return;
            .msg_desc_attr = {
                .tx_attr = {
                    .ttl_in_seconds = SID_DEMO_APP_TTL_MAX,
                    .num_retries = SID_DEMO_APP_RETRIES_MAX,
                    .request_ack = true,
        struct app_demo_tx_msg *data = (struct app_demo_tx_msg *)malloc(sizeof(struct app_demo_tx_msg));
        if (data == NULL) {
            TI_LOG_ERROR("Failed to allocate tx data memory !");
            return;
        } else {
            data->pld_size = state.offset;
            memcpy(data->tx_payload, g_app_context.buffer, data->pld_size);
            data->desc = desc;
        TI_LOG_INFO("Led response created");
        queue_event(g_app_context.event_queue, EVENT_SEND_MESSAGE, data, false);
    static int32_t init_and_start_link(app_context_t *context, struct sid_config *config, uint32_t link_mask)
        sid_error_t ret = SID_ERROR_NONE;
        struct sid_handle *sid_handle = NULL;
        config->link_mask = link_mask;
        // Initialize sidewalk
        ret = sid_init(config, &sid_handle);
            TI_LOG_ERROR("failed to initialize sidewalk link_mask:%x, err:%d", link_mask, (int)ret);
            ITM_flushModule();
            goto error;
        // Register sidewalk handler to the application context
        context->sidewalk_handle = sid_handle;
        // Start the sidewalk stack
        ret = sid_start(sid_handle, link_mask);
            TI_LOG_ERROR("failed to start sidewalk, link_mask:%x, err:%d", link_mask, (int)ret);
            ITM_flushModule();
            goto error;
        return 0;
    error:
        context->sidewalk_handle = NULL;
        config->link_mask = 0;
        return -1;
    static void cap_timer_cb(TimerHandle_t xTimer)
        enum event_type event = EVENT_NOTIFICATION_TIMER_FIRED;
        if (g_app_context.sidewalk_state != STATE_SIDEWALK_READY) {
            delay = pdMS_TO_TICKS(CONNECT_LINK_TYPE_1_DELAY_MS);
            event = EVENT_CONNECT_LINK_TYPE_1;
        if (g_app_context.app_state == DEMO_APP_STATE_NOTIFY_SENSOR_DATA && g_app_context.sidewalk_state == STATE_SIDEWALK_READY) {
            delay = pdMS_TO_TICKS(DEMO_NOTIFY_SENSOR_DATA_PERIOD_MS);
        BaseType_t ret = xTimerChangePeriod(g_app_context.cap_timer_handle, delay, 0);
        queue_event(g_app_context.event_queue, event, NULL, true);
    static void button_press_timer_cb(TimerHandle_t xTimer)
        queue_event(g_event_queue, EVENT_BUTTON_PRESS_TIMER_FIRED, NULL, true);
    static void device_profile_timer_cb(TimerHandle_t xTimer)
        queue_event(g_event_queue, EVENT_SET_DEVICE_PROFILE_LINK_TYPE_2, NULL, true);
    static void turn_on_leds(enum demo_app_led_id id)
        if (id >= DEMO_APP_LED_ID_LAST) {
            TI_LOG_ERROR("Invalid LED id: %d", id);
            return;
        LED_setOn(g_app_context.led_handles[id], 100);
    static void turn_on_all_leds()
        turn_on_leds(DEMO_APP_LED_ID_0);
        turn_on_leds(DEMO_APP_LED_ID_1);
    static void turn_off_leds(enum demo_app_led_id id)
            return;
        LED_setOff(g_app_context.led_handles[id]);
    static void turn_off_all_leds()
        turn_off_leds(DEMO_APP_LED_ID_0);
        turn_off_leds(DEMO_APP_LED_ID_1);
    static bool is_led_on(enum demo_app_led_id id)
        bool ret = true;
            return false;
        LED_State state = LED_getState(g_app_context.led_handles[id]);
        ret = (state == LED_STATE_ON) ? true : false;
        return ret;
    static void process_action_response(struct sid_parse_state *state)
        uint8_t temp_button_id_arr[DEMO_BUTTONS_MAX] = {0};
        struct sid_demo_action_resp action_resp = {0};
        action_resp.button_action_resp.button_id_arr = temp_button_id_arr;
        sid_demo_app_action_resp_deserialize(state, &action_resp);
        if (state->ret_code != SID_ERROR_NONE) {
            TI_LOG_ERROR("de-serialize action resp failed %d", state->ret_code);
        } else if (action_resp.resp_type == SID_DEMO_ACTION_TYPE_BUTTON) {
            if (action_resp.button_action_resp.num_buttons == 0xFF) {
                g_app_context.button_press_mask = 0;
                g_app_context.button_notify_mask = 0;
                    g_app_context.button_press_time_in_sec_id_arr[i] = 0;
            } else if (action_resp.button_action_resp.num_buttons <= DEMO_BUTTONS_MAX) {
                for (size_t i = 0; i < action_resp.button_action_resp.num_buttons; i++) {
                    g_app_context.button_press_mask &= ~(1 << action_resp.button_action_resp.button_id_arr[i]);
                    g_app_context.button_notify_mask &= ~(1 << action_resp.button_action_resp.button_id_arr[i]);
            } else {
                TI_LOG_ERROR("Invalid number of button Max allowed %d received %d",
                        DEMO_BUTTONS_MAX, action_resp.button_action_resp.num_buttons);
        } else {
           TI_LOG_ERROR("Invalid response received %d", action_resp.resp_type);
    static void process_turn_all_leds(enum sid_demo_led_action led_action_req, struct sid_demo_action_resp *action_resp)
        if (led_action_req == SID_DEMO_ACTION_LED_ON) {
            turn_on_all_leds();
        } else {
            turn_off_all_leds();
        action_resp->led_action_resp.action_resp = led_action_req;
        for (size_t i = 0; i < DEMO_LEDS_MAX; i++) {
            bool result = (led_action_req == SID_DEMO_ACTION_LED_ON) ? is_led_on(g_app_context.led_id_arr[i]) :
                           !is_led_on(g_app_context.led_id_arr[i]);
            if (result) {
                action_resp->led_action_resp.num_leds += 1;
                action_resp->led_action_resp.led_id_arr[i] = g_app_context.led_id_arr[i];
        if (action_resp->led_action_resp.num_leds) {
            demo_app_create_led_response(action_resp);
        } else {
            TI_LOG_ERROR("LED response invalid num leds %d", action_resp->led_action_resp.num_leds);
    static void process_turn_leds(struct sid_demo_led_action_req *led_req, struct sid_demo_action_resp *action_resp)
        for (size_t i = 0; i < led_req->num_leds; i++) {
            if (led_req->action_req == SID_DEMO_ACTION_LED_ON) {
                turn_on_leds(led_req->led_id_arr[i]);
            } else {
                turn_off_leds(led_req->led_id_arr[i]);
        action_resp->led_action_resp.action_resp = led_req->action_req;
            bool result = (led_req->action_req == SID_DEMO_ACTION_LED_ON) ? is_led_on(led_req->led_id_arr[i]) :
                           !is_led_on(led_req->led_id_arr[i]);
            if (result) {
                action_resp->led_action_resp.led_id_arr[i] = led_req->led_id_arr[i];
        } else {
    static void process_action_request(struct sid_parse_state *state)
        uint8_t temp_led_id_arr[DEMO_LEDS_MAX] = {0};
        struct sid_demo_led_action_req led_req = {.led_id_arr = temp_led_id_arr};
        sid_demo_app_action_req_deserialize(state, &led_req);
            TI_LOG_ERROR("de-serialize led action req failed %d", state->ret_code);
        } else if (led_req.action_req == SID_DEMO_ACTION_LED_ON || led_req.action_req == SID_DEMO_ACTION_LED_OFF) {
            uint8_t temp_led_id_arr_resp[DEMO_LEDS_MAX] = {0};
            struct sid_demo_action_resp action_resp = {.resp_type = SID_DEMO_ACTION_TYPE_LED,};
            action_resp.led_action_resp.led_id_arr = temp_led_id_arr_resp;
            action_resp.gps_time_in_seconds = curr_time.tv_sec;
            if ((curr_time.tv_sec - led_req.gps_time_in_seconds) > 0) {
                action_resp.down_link_latency_secs = curr_time.tv_sec - led_req.gps_time_in_seconds;
            if (led_req.num_leds == 0xFF) {
                process_turn_all_leds(led_req.action_req, &action_resp);
            } else if (led_req.num_leds <= DEMO_LEDS_MAX) {
                process_turn_leds(&led_req, &action_resp);
            } else {
                TI_LOG_ERROR("Invalid led action req max allowed %d received  %d", DEMO_LEDS_MAX, led_req.num_leds);
        } else {
            TI_LOG_ERROR("Invalid led action request %d", led_req.action_req);
    static void receive_task(void *context)
        receive_context_t *rcv_context = (receive_context_t *)context;
        while (1) {
            ITM_flushModule();
            struct app_demo_rx_msg rx_msg;
            if (xQueueReceive(rcv_context->receive_event_queue, &rx_msg, portMAX_DELAY) == pdTRUE) {
                struct sid_demo_msg_desc msg_desc = {0};
                static uint8_t temp_msg_payload[PAYLOAD_MAX_SIZE];
                memset(temp_msg_payload, 0, sizeof(temp_msg_payload));
                struct sid_demo_msg msg = {.payload = temp_msg_payload};
                static struct sid_parse_state state = {0};
                sid_parse_state_init(&state, rx_msg.rx_payload, rx_msg.pld_size);
                sid_demo_app_msg_deserialize(&state, &msg_desc, &msg);
                TI_LOG_INFO("opc %d, class %d cmd %d status indicator %d status_code %d paylaod size %d",
                        msg_desc.opc, msg_desc.cmd_class, msg_desc.cmd_id, msg_desc.status_hdr_ind,
                        msg_desc.status_code,  msg.payload_size);
                    TI_LOG_ERROR("de-serialize demo app msg failed %d", state.ret_code);
                } else if (msg_desc.status_hdr_ind && msg_desc.opc == SID_DEMO_MSG_TYPE_RESP &&
                        msg_desc.cmd_class == SID_DEMO_APP_CLASS && msg_desc.cmd_id == SID_DEMO_APP_CLASS_CMD_CAP_DISCOVERY_ID
                        && msg_desc.status_code == SID_ERROR_NONE && msg.payload_size == 0) {
                    TI_LOG_INFO("Capability response received");
                    g_app_context.app_state = DEMO_APP_STATE_NOTIFY_SENSOR_DATA;
                        msg_desc.cmd_class == SID_DEMO_APP_CLASS && msg_desc.cmd_id == SID_DEMO_APP_CLASS_CMD_ACTION
                        && msg_desc.status_code == SID_ERROR_NONE) {
                    TI_LOG_INFO("Action response received");
                    sid_parse_state_init(&state, msg.payload, msg.payload_size);
                    process_action_response(&state);
                } else if (msg_desc.opc == SID_DEMO_MSG_TYPE_WRITE && msg_desc.cmd_class == SID_DEMO_APP_CLASS && msg_desc.cmd_id == SID_DEMO_APP_CLASS_CMD_ACTION) {
                    TI_LOG_INFO("Action request received");
                    process_action_request(&state);
    static void demo_app_check_button_press_notify(void)
        uint16_t next_timer_schedule_secs = 0;
            if ((g_app_context.button_notify_mask & (1 << g_app_context.button_id_arr[i])) &&
                    g_app_context.button_press_time_in_sec_id_arr[i] != 0) {
                next_timer_schedule_secs = curr_time.tv_sec - g_app_context.button_press_time_in_sec_id_arr[i];
                TI_LOG_INFO("Button press timeout pre check: button_notify_mask %x next_timer_schedule_secs %d",
                        g_app_context.button_notify_mask, next_timer_schedule_secs);
                if (next_timer_schedule_secs >= BUTTON_PRESS_CHECK_PERIOD_SECS) {
                    g_app_context.button_notify_mask &= ~(1 << g_app_context.button_id_arr[i]);
                    g_app_context.button_press_mask &= ~(1 << g_app_context.button_id_arr[i]);
                } else if (next_timer_schedule_secs > (curr_time.tv_sec - g_app_context.button_press_time_in_sec_id_arr[i])) {
            } else if (g_app_context.button_press_time_in_sec_id_arr[i]) {
        TI_LOG_INFO("Button press timeout post check: button_notify_mask %x next_timer_schedule_secs %d",
        ITM_flushModule();
        if (next_timer_schedule_secs) {
            BaseType_t ret = xTimerChangePeriod(g_app_context.button_press_timer_handle, pdMS_TO_TICKS(next_timer_schedule_secs * 1000), 0);
    static void initialize_pals(void)
        const sid_pal_mfg_store_region_t ti_mfg = {
            .addr_start = MANUFACTURE_FLASH_START,
            .addr_end   = MANUFACTURE_FLASH_END,
        sid_pal_mfg_store_init(ti_mfg);
        sid_error_t ret_code = sid_pal_storage_kv_init();
        if (ret_code != SID_ERROR_NONE) {
            SID_PAL_LOG_INFO("Sidewalk KV store init failed err: %d", ret_code);
            ITM_flushModule();
        assert(ret_code == SID_ERROR_NONE);
        ret_code = sid_pal_crypto_init();
            SID_PAL_LOG_INFO("Sidewalk Init Crypto PAL err: %d", ret_code);
            ITM_flushModule();
    static void main_task(void *context)
        initialize_pals();
        struct sid_event_callbacks event_callbacks = {
            .context = app_context,
            .on_event = on_sidewalk_event, /* Called from ISR context */
            .on_msg_received = on_sidewalk_msg_received, /* Called from sid_process() */
            .on_msg_sent = on_sidewalk_msg_sent,  /* Called from sid_process() */
            .on_send_error = on_sidewalk_send_error, /* Called from sid_process() */
            .on_status_changed = on_sidewalk_status_changed, /* Called from sid_process() */
            .on_factory_reset = on_sidewalk_factory_reset, /* Called from sid_process */
        struct sid_config config = {
            .link_mask = 0,
            .time_sync_periodicity_seconds = 7200,
            .callbacks = &event_callbacks,
            .link_config = app_get_ble_config(),
            .sub_ghz_link_config = app_get_sub_ghz_config(),
    #endif
        set_radio_cc13xx_device_config(&radio_cc13xx_default_cfg);
    #endif
        uint32_t link_mask = 0;
        _Static_assert(BUILD_SID_SDK_LINK_TYPE == 1 || BUILD_SID_SDK_LINK_TYPE == 2, "BUILD_SID_SDK_LINK_TYPE not supported");
        /* Init in BLE mode */
        link_mask = SID_LINK_TYPE_1;
        if (init_and_start_link(app_context, &config, link_mask) != 0) {
            goto error;
        ITM_flushModule();
        sid_handle = app_context->sidewalk_handle;
        app_context->cap_timer_handle = xTimerCreate("demo_cap_timer",
                                                      pdMS_TO_TICKS(DEMO_CAPABILITY_PERIOD_MS),
                                                      pdFALSE, (void *)0, cap_timer_cb);
        if (app_context->cap_timer_handle == NULL) {
            TI_LOG_ERROR("create capability timer failed!");
            goto error;
        app_context->button_press_timer_handle = xTimerCreate("button_press_timer",
                                                  pdFALSE, (void *)0, button_press_timer_cb);
        if (app_context->button_press_timer_handle == NULL) {
            TI_LOG_ERROR("create button press timer failed!");
            goto error;
            app_context->device_profile_timer_handle = xTimerCreate("device_profile_timer",
                                                          pdFALSE, (void *)0, device_profile_timer_cb);
            if (app_context->device_profile_timer_handle == NULL) {
                TI_LOG_ERROR("create device profile timer failed!");
                goto error;
        while (1) {
            struct demo_app_event event;
            ITM_flushModule();
            if (xQueueReceive(app_context->event_queue, &event, portMAX_DELAY) == pdTRUE) {
                switch (event.type) {
                    case EVENT_TYPE_SIDEWALK:
                        sid_process(sid_handle);
                        break;
                    case EVENT_FACTORY_RESET:
                        factory_reset();
                        break;
                    case EVENT_BUTTON_PRESS:
                        demo_app_notify_sensor_data(true);
                        g_app_context.button_event_pending_processing = false;
                        break;
                    case EVENT_NOTIFICATION_TIMER_FIRED:
                            if (BUILD_SID_SDK_LINK_TYPE == 1) {
                                if (!(g_app_context.link_status.link_mask & SID_LINK_TYPE_1) &&
                                        (g_app_context.app_state == DEMO_APP_STATE_REGISTERED)
                                    && (g_app_context.link_status.time_sync_status == SID_STATUS_TIME_SYNCED)) {
                                    queue_event(g_event_queue, EVENT_CONNECT_LINK_TYPE_1, NULL, false);
                        } else if (g_app_context.app_state == DEMO_APP_STATE_NOTIFY_CAPABILITY) {
                            demo_app_notify_capability();
                        } else if (g_app_context.app_state == DEMO_APP_STATE_NOTIFY_SENSOR_DATA) {
                            demo_app_notify_sensor_data(false);
                        break;
                    case EVENT_BUTTON_PRESS_TIMER_FIRED:
                        TI_LOG_INFO("Button press timeout check timer fired");
                        demo_app_check_button_press_notify();
                        break;
                    case EVENT_CONNECT_LINK_TYPE_1:
                            TI_LOG_INFO("Connecting link type 1");
                            sid_error_t ret = sid_ble_bcn_connection_request(sid_handle, true);
                                TI_LOG_ERROR("Failed to set connect request on link type 1 %d", ret);
                        else
                            if (sid_handle != NULL) {
                                sid_stop(sid_handle, config.link_mask);
                                sid_deinit(sid_handle);
                                app_context->sidewalk_handle = NULL;
                            if (init_and_start_link(app_context, &config, SID_LINK_TYPE_2) != 0) {
                                goto error;
                        break;
                    case EVENT_SET_DEVICE_PROFILE_LINK_TYPE_2:
                            BaseType_t err = xTimerIsTimerActive(g_app_context.device_profile_timer_handle);
                            if (err == pdTRUE) {
                                err = xTimerStop(g_app_context.device_profile_timer_handle, 0);
                                ASSERT(err == pdPASS);
                            struct sid_device_profile curr_dev_cfg = {
                                .unicast_params = {
                                    .device_profile_id = SID_LINK2_PROFILE_2,
                            sid_error_t ret = sid_option(sid_handle, SID_OPTION_900MHZ_GET_DEVICE_PROFILE, &curr_dev_cfg, sizeof(curr_dev_cfg));
                            if (ret == SID_ERROR_NONE) {
                                struct sid_device_profile target_dev_cfg = {
                                    .unicast_params = {
                                        .rx_window_count = SID_RX_WINDOW_CNT_INFINITE,
                                        .unicast_window_interval = {
                                            .sync_rx_interval_ms = SID_LINK2_RX_WINDOW_SEPARATION_1,
                                        .wakeup_type = SID_TX_AND_RX_WAKEUP,
                                if (!memcmp(&curr_dev_cfg, &target_dev_cfg, sizeof(curr_dev_cfg))) {
                                    TI_LOG_INFO("Device profile for Link type 2 already set");
                                } else {
                                    ret = sid_option(sid_handle, SID_OPTION_900MHZ_SET_DEVICE_PROFILE, &target_dev_cfg, sizeof(target_dev_cfg));
                                        TI_LOG_ERROR("Device profile configuration for Link type 2 failed ret = %d", ret);
                                        err = xTimerChangePeriod(app_context->device_profile_timer_handle, pdMS_TO_TICKS(PROFILE_CHECK_TIMER_DELAY_MS), 0);
                                    } else {
                                        TI_LOG_INFO("Device profile Link type 2 set success");
                            } else {
                                TI_LOG_ERROR("Failed to get device profile configuration for Link type 2 ret = %d", ret);
                    case EVENT_SEND_MESSAGE:
                        if (event.data) {
                            struct app_demo_tx_msg *evt_data = (struct app_demo_tx_msg*)event.data;
                            struct sid_msg msg = {.size = evt_data->pld_size, .data = evt_data->tx_payload};
                            send_msg(&evt_data->desc, &msg);
                        } else {
                            TI_LOG_ERROR("Invalid data pointer in event");
                        break;
                    default:
                        TI_LOG_ERROR("Invalid event queued %d", event);
                        break;
                if (event.data != NULL) {
                    free(event.data);
    error:
        vTaskDelete(NULL);
    void button1_handler(Button_Handle handle, Button_EventMask events)
        if (g_app_context.app_state != DEMO_APP_STATE_NOTIFY_SENSOR_DATA) {
            return;
        if (events & Button_EV_CLICKED) {
            bool notify_event = false;
            if (!(g_app_context.button_press_mask & (1 << g_app_context.button_id_arr[DEMO_APP_BUTTON_ID_0]))) {
                g_app_context.button_press_mask |= (1 << g_app_context.button_id_arr[DEMO_APP_BUTTON_ID_0]);
                notify_event = true;
            if (!g_app_context.button_event_pending_processing && notify_event) {
                queue_event(g_event_queue, EVENT_BUTTON_PRESS, NULL, true);
                g_app_context.button_event_pending_processing = true;
    void button2_handler(Button_Handle handle, Button_EventMask events)
        if (events & Button_EV_LONGPRESSED) {
             queue_event(g_event_queue, EVENT_FACTORY_RESET, NULL, true);
    int main(void)
        Board_init();
        Button_init();
        Temperature_init();
        const ITM_config itm_config = {
            .system_clock = 48000000,
            .baud_rate = ITM_921600,
            .defer_logging = true,
        ITM_initModule(&itm_config);
        TI_LOG_INFO("Sidewalk example started");
        ITM_flushModule();
        Button_Params button_params;
        Button_Params_init(&button_params);
        button_params.buttonCallback = button1_handler;
        g_app_context.button_1 = Button_open(CONFIG_BUTTON_0, &button_params);
        assert(g_app_context.button_1 != NULL);
        button_params.buttonCallback = button2_handler;
        g_app_context.button_2 = Button_open(CONFIG_BUTTON_1, &button_params);
        assert(g_app_context.button_2 != NULL);
        LED_Params led_params;
        LED_Params_init(&led_params);
        g_app_context.led_handles[DEMO_APP_LED_ID_0] = LED_open(CONFIG_LED_0, &led_params);
        assert(g_app_context.led_handles[DEMO_APP_LED_ID_0] != NULL);
        g_app_context.led_handles[DEMO_APP_LED_ID_1] = LED_open(CONFIG_LED_1, &led_params);
        assert(g_app_context.led_handles[DEMO_APP_LED_ID_1] != NULL);
        g_event_queue = xQueueCreate(MSG_QUEUE_LEN, sizeof(struct demo_app_event));
        if (g_event_queue == NULL) {
            TI_LOG_ERROR("failed creating queue");
            assert(false);
        g_app_context.sidewalk_state = STATE_SIDEWALK_INIT;
        g_app_context.app_state = DEMO_APP_STATE_INIT;
        g_app_context.link_status.time_sync_status = SID_STATUS_NO_TIME;
            g_app_context.led_id_arr[i] = i;
            g_app_context.button_id_arr[i] = i;
        g_app_context.event_queue = g_event_queue;
        if (pdPASS != xTaskCreate(main_task, "MAIN", MAIN_TASK_STACK_SIZE, &g_app_context, 1, &g_app_context.main_task)) {
            TI_LOG_ERROR("failed creating main task");
            assert(false);
        g_receieve_event_queue = xQueueCreate(MSG_QUEUE_LEN, sizeof(struct app_demo_rx_msg));
            assert(false);
        g_receive_context.receive_event_queue = g_receieve_event_queue;
        if (pdPASS != xTaskCreate(receive_task, "RECEIVE", RECEIVE_TASK_STACK_SIZE, &g_receive_context, 2, &g_receive_context.receive_task)) {
            assert(false);
        vTaskStartScheduler();
        for (;;) {
            assert(false);
    Now that FSK is working on your side, you should not need it anymore, but I have put it there for documentation purposes.
  • Thanks and I would suggest you to create a new example for FSK. By the way, do you have suggestions about how to decrease power consumption of sidewalk device?
  • , we do have the default sid_demo example, which, when configured to use "FSK 900 MHz", will use only FSK.
    Now that your FSK setup works, you can try again by using that unmodified example.
    Arthur
  • Do you mean to ask me to roll-back modification in main.c and use FSK 900MHz in link type to test again?
  • This is what I mean indeed, if you prefer, you can create a new project to test that.
    Arthur
  • Ok, I will but what's the difference?
  • In the main.c, you will notice those checks:
    "2" means the build type is "FSK", while "1" means "BLE".
    This is how the application knows how to behave.
    So in BLE mode, it will only use BLE. And in FSK mode, only FSK. Unless you modify the application with the main.c I sent you previously.
  • Do you mean BUILD_SID_SDK_LINK_TYPE would be set as 2 for FSK when I set Link type as FSK 900MHz in sid_demo.syscfg?
  • That is correct, sysconfig takes care of it for you.
  • Thanks for confirming this. I already do this. Just to clarify. Even I set Link type as FSK 900MHz, sid_demo still use BLE to commission and will switch to FSK after commission, right?
  • No, and this is why we had to modify the main.c file previously.
    sid_demo configured in FSK mode will only use FSK.
  • OK, I see. Thanks for clarifying.
