Hi TIer,
My customer use CC1121 as RF transceiver. Can CC1121 use GPIO2 or GPIO3 as event trigger to external MCU/MPU (to wake up MCU/MPU) ?
Thank you.
Hi Jerry,
As the user manual describes, you can indeed do so: https://www.ti.com/lit/ug/swru295e/swru295e.pdf
For instance, according to chapter 3.4.1.1, you could trigger a GPIO using the IOCFGx registers when the PKT_SYNC_RXTX event is received.
Arthur
