CC1312R: Upload FW via serial bootloader
Part Number: CC1312R
what is work flow to upload a FW?
1)switch on the backdoor GPIO pin
2) switch on reset pin (after several ms switch off)
3) run the program in your example to load the FW
4) switch off backdoor pin
5) switch on reset pin (after several ms switch off)
am I right?
Is it possible when there is already FW in the CC1312 somehow to disable ability to read the program from the flash and allow only load new FW?
Thank you in advance.
