Hi team,
Here's the request from customer:
They use 7mm * 7mm CC1310HSM for signal transmission, with a frequency band of 868MHz.
Currently, in PCB design, DIO8, 9, 10, and 11 are used as SPI interfaces, leading out from the TOP layer via where the chip is located to the BOTTOM layer.
At present, they plan to wrap the analog RF front-end part and CC1310 chip together in a shielding case. However, they have previously tested and found that the high order harmonics of the chip SPI signal can interfere with the analog RF signal at the receiving end.
Please provide reference shielding design suggestions to avoid such interference.
Could you help check this case? Thanks.
Nick
