Please suggest a Power Amplifier for UHF (433Mhz) with >36dBm (4W) of Saturated Output Power and compatible with CC1352R.
Thank you
You may have issues with spurious emissions at such a high output power (particularly the harmonic power levels) - you would need additional filtering to attentuate these, which TI has not tested.
If you built a test circuit, you could measure how high the harmonic power levels were and see how much additional harmonic attentuation you would need.
Zack
