Other Parts Discussed in Thread: CC1310
Hi team,
Please explain whether this output is 433MHZ or 868MHz.
The customer use CC1312R, the communication frequency is 433MHZ, what is the reference hardware circuit? Thanks
Hi Yolande,
The picture that you attached is of a 868/915 MHz reference design. The 433MHz path from LAUNCHXL-CC1352P-4 can be used as the reference design for 433 MHz with CC1312R as well.
HG
Hi HG,
Thank you for your reply.
May I ask where the performance parameters of the LDO inside CC1310 are? I didn’t find them in the manual.
Thanks & Best regards,
Yolande
Hi Yolande,
We do not have the data for the LDO separately. But all the relevant information that the customers may need can be found in the datasheet. Could you tell me more about what performance you are specifically looking for and why you are interested in those?
HG
