Hi Wireless Support,
My customer noted the lack of identical load caps in the 32.768kHz crystal on the EVM. https://www.ti.com/tool/LP-EM-CC1354P10
Note they show 12pF and 15pF which is unusual as they are normally identical values unless tuned empirically with a scope and a pure frequency (a lot of work). OR is it just a typo?
If we use the following calculator (I checked the underlying math) https://ecsxtal.com/crystal-load-capacitance-calculator/
I see that our chosen part on the EVM - TZ3581F TAI-SAW https://www.taisaw.com/assets/PDF/TZ3581A%20_Rev.1.pdf gives us a 7pF CL
Assuming ~2pF on the stray board capacitance gives us a 10pF value and ~5pF gives us 4pF.
Did we assume ~1pF on stray capacitance? OR did we actually measure the values by putting out a pure frequency and tuning the caps as implied here https://www.ti.com/lit/an/swra372c/swra372c.pdf ?
If the schematic is correct and we intended to make these two values different we should probably make a note on the schematic or we will answer this question a dozen times.
Also let me know if my calcs were in error above.
Thanks!
Blake
