My project uses CC1352PSIP and it stopped working after some time. I got the following errors list of errors:
Description Resource Path Location Type
gmake: *** [all] Error 2 simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang C/C++ Problem
gmake[1]: *** No rule to make target 'input-file.error', needed by 'output-file.error'. simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang C/C++ Problem
gmake[1]: Target 'secondary-outputs' not remade because of errors. simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang C/C++ Problem
recipe for target 'all' failed makefile /simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release line 211 C/C++ Problem
The Console reports:
Building target: "simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang.out"
Invoking: Arm Linker
"C:/ti/ccs1220/ccs/tools/compiler/ti-cgt-armllvm_2.1.2.LTS/bin/tiarmclang.exe" @"C:/CC2652PSIP/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_ble_app_config.opt" @"C:/CC2652PSIP/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_build_config.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/build_components.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/factory_config.opt" -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mlittle-endian -mthumb -Oz -DDeviceFamily_CC26X2 -DFLASH_ROM_BUILD -DNVOCMP_NWSAMEITEM=1 -DHEAPMGR_CONFIG=0x80 -DHEAPMGR_SIZE=0x0 -gdwarf-3 -march=armv7e-m -Wl,-m"simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang.map" -Wl,-i"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source" -Wl,-i"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/kernel/tirtos7/packages" -Wl,-i"C:/CC2652PSIP/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg" -Wl,-i"C:/ti/ccs1220/ccs/tools/compiler/ti-cgt-armllvm_2.1.2.LTS/lib" -Wl,--reread_libs -Wl,--define=FLASH_ROM_BUILD=2 -Wl,--diag_suppress=16002-D -Wl,--diag_suppress=10247-D -Wl,--diag_suppress=10325-D -Wl,--diag_suppress=10229-D -Wl,--diag_suppress=16032-D -Wl,--diag_wrap=off -Wl,--display_error_number -Wl,--warn_sections -Wl,--xml_link_info="simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang_linkInfo.xml" -Wl,--rom_model -o "simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang.out" "./syscfg/ti_ble_config.o" "./syscfg/ti_devices_config.o" "./syscfg/ti_radio_config.o" "./syscfg/ti_drivers_config.o" "./syscfg/ti_sysbios_config.o" "./Application/board_key.o" "./Application/rcosc_calibration.o" "./Application/simple_peripheral.o" "./Application/simple_peripheral_menu.o" "./Application/two_btn_menu.o" "./Application/util.o" "./Drivers/NV/crc.o" "./Drivers/NV/nvocmp.o" "./MHLib/SP_Dev_Test.o" "./MHLib/assert.o" "./MHLib/at_cmd_parser.o" "./MHLib/at_params.o" "./MHLib/flash_upgrade.o" "./MHLib/lib_buf.o" "./MHLib/mhATCmdParser.o" "./MHLib/mhFactory.o" "./MHLib/mhI2C.o" "./MHLib/mhI2C0_slave.o" "./MHLib/mhLed.o" "./MHLib/mhLib_crc.o" "./MHLib/mhLib_err.o" "./MHLib/mhLib_user.o" "./MHLib/mhMHX_saveregs.o" "./MHLib/mhMavLink.o" "./MHLib/mhSaveregs.o" "./MHLib/mhodid.o" "./MHLib/mhtasks.o" "./MHLib/mhtimer.o" "./MHLib/mhuart.o" "./MH_ODID/libmav2odid/mav2odid.o" "./MH_ODID/libopendroneid/opendroneid.o" "./NPI/npi_frame_hci.o" "./NPI/npi_rxbuf.o" "./NPI/npi_task.o" "./NPI/npi_tl.o" "./NPI/npi_tl_uart.o" "./Profiles/devinfoservice.o" "./Profiles/simple_gatt_profile.o" "./Startup/main.o" "./Startup/osal_icall_ble.o" "./Startup/rom_init.o" "./iCall/icall.o" "./iCall/icall_cc2650.o" "./iCall/icall_user_config.o" "./iCallBLE/ble_user_config.o" "./iCallBLE/ble_user_config_stack.o" "./iCallBLE/icall_api_lite.o" "./iCallBLE/icall_hci_tl.o" "../cc13x2_cc26x2_app_tirtos7.cmd" -Wl,-lti_utils_build_linker.cmd.genlibs -Wl,-l"ti/devices/cc13x2_cc26x2/driverlib/bin/ticlang/driverlib.lib" -Wl,-llibc.a
Finished building target: "simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang.out"
"C:/ti/ccs1220/ccs/utils/tiobj2bin/tiobj2bin" "simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang.out" "simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang.bin" "C:/ti/ccs1220/ccs/tools/compiler/ti-cgt-armllvm_2.1.2.LTS/bin/tiarmofd" "C:/ti/ccs1220/ccs/tools/compiler/ti-cgt-armllvm_2.1.2.LTS/bin/tiarmhex" "C:/ti/ccs1220/ccs/utils/tiobj2bin/mkhex4bin"
makefile:211: recipe for target 'all' failed
The project uses:
SimpleLink CC13xx CC26xx SDK [6.40.0.13]
SysConfig [1.15.0]
TI Clang v2.1.2.. LTS.
It looks like files with extensions: .out; .bin were created.
What the easiest fix could be used?
Alex
Hi Alex,
Thank you for reaching out. Were any changes made to the linker file or to the build steps? Also to confirm, you are using a CC1352PSIP, correct?
Jan
Hi Jan,
I'm using CC2652PSIP, The linker command file cc13x2_cc26x2_app_tirtos7.cmd was not changed.
There is only one post-build step is present:
"${CCS_INSTALL_ROOT}/utils/tiobj2bin/tiobj2bin" "${BuildArtifactFileName}" "${BuildArtifactFileBaseName}.bin" "${CG_TOOL_ROOT}/bin/tiarmofd" "${CG_TOOL_ROOT}/bin/tiarmhex" "${CCS_INSTALL_ROOT}/utils/tiobj2bin/mkhex4bin"
Alex
Hi Alex,
I haven't seen these errors before. A few things to try:
1. Right-click on the project and press Re-build. Then post the full build log.
2. Could you also open the Problems tab in CCS and screen shot your error messages?
3. Can you try opening a new CCS workspace, import a new project from the SDK and build it? Just to make sure that you're not missing any important files in the SDK.
Cheers,
Marie H
Hi Marie,
1) Suggestion #1
"C:\\ti\\ccs1220\\ccs\\utils\\bin\\gmake" -k -j 8 clean -O
DEL /F "syscfg\ti_ble_config.h" "syscfg\ti_radio_config.h" "syscfg\ti_drivers_config.h" "syscfg\ti_utils_build_linker.cmd.genlibs" "syscfg\syscfg_c.rov.xs" "syscfg\ti_utils_runtime_model.gv" "syscfg\ti_utils_runtime_Makefile" "syscfg\ti_sysbios_config.h" "syscfg\ti_ble_config.c" "syscfg\ti_build_config.opt" "syscfg\ti_ble_app_config.opt" "syscfg\ti_devices_config.c" "syscfg\ti_radio_config.c" "syscfg\ti_drivers_config.c" "syscfg\ti_sysbios_config.c" "output-file.error" "simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang.out"
DEL /F "syscfg\ti_ble_config.o" "syscfg\ti_devices_config.o" "syscfg\ti_radio_config.o" "syscfg\ti_drivers_config.o" "syscfg\ti_sysbios_config.o" "Application\board_key.o" "Application\rcosc_calibration.o" "Application\simple_peripheral.o" "Application\simple_peripheral_menu.o" "Application\two_btn_menu.o" "Application\util.o" "Drivers\NV\crc.o" "Drivers\NV\nvocmp.o" "MHLib\SP_Dev_Test.o" "MHLib\UserDataIn.o" "MHLib\UserDataOut.o" "MHLib\app_oem.o" "MHLib\app_oem_help.o" "MHLib\assert.o" "MHLib\flash_upgrade.o" "MHLib\mhFactory.o" "MHLib\mhLed.o" "MHLib\mhLib_adc.o" "MHLib\mhLib_buf.o" "MHLib\mhLib_crc.o" "MHLib\mhLib_dac.o" "MHLib\mhLib_err.o" "MHLib\mhLib_mem.o" "MHLib\mhLib_tab.o" "MHLib\mhLib_user.o" "MHLib\mhMHX_saveregs.o" "MHLib\mhParTest.o" "MHLib\mhSaveregs.o" "MHLib\mhTimer.o" "MHLib\mhtasks.o" "MHLib\mhuart.o" "NPI\npi_frame_hci.o" "NPI\npi_rxbuf.o" "NPI\npi_task.o" "NPI\npi_tl.o" "NPI\npi_tl_uart.o" "Profiles\devinfoservice.o" "Profiles\simple_gatt_profile.o" "Startup\main.o" "Startup\osal_icall_ble.o"
DEL /F "Startup\rom_init.o" "iCall\icall.o" "iCall\icall_cc2650.o" "iCall\icall_user_config.o" "iCallBLE\ble_user_config.o" "iCallBLE\ble_user_config_stack.o" "iCallBLE\icall_api_lite.o" "iCallBLE\icall_hci_tl.o"
DEL /F "syscfg\ti_ble_config.d" "syscfg\ti_devices_config.d" "syscfg\ti_radio_config.d" "syscfg\ti_drivers_config.d" "syscfg\ti_sysbios_config.d" "Application\board_key.d" "Application\rcosc_calibration.d" "Application\simple_peripheral.d" "Application\simple_peripheral_menu.d" "Application\two_btn_menu.d" "Application\util.d" "Drivers\NV\crc.d" "Drivers\NV\nvocmp.d" "MHLib\SP_Dev_Test.d" "MHLib\UserDataIn.d" "MHLib\UserDataOut.d" "MHLib\app_oem.d" "MHLib\app_oem_help.d" "MHLib\assert.d" "MHLib\flash_upgrade.d" "MHLib\mhFactory.d" "MHLib\mhLed.d" "MHLib\mhLib_adc.d" "MHLib\mhLib_buf.d" "MHLib\mhLib_crc.d" "MHLib\mhLib_dac.d" "MHLib\mhLib_err.d" "MHLib\mhLib_mem.d" "MHLib\mhLib_tab.d" "MHLib\mhLib_user.d" "MHLib\mhMHX_saveregs.d" "MHLib\mhParTest.d" "MHLib\mhSaveregs.d" "MHLib\mhTimer.d" "MHLib\mhtasks.d" "MHLib\mhuart.d" "NPI\npi_frame_hci.d" "NPI\npi_rxbuf.d" "NPI\npi_task.d" "NPI\npi_tl.d" "NPI\npi_tl_uart.d" "Profiles\devinfoservice.d" "Profiles\simple_gatt_profile.d" "Startup\main.d" "Startup\osal_icall_ble.d"
DEL /F "Startup\rom_init.d" "iCall\icall.d" "iCall\icall_cc2650.d" "iCall\icall_user_config.d" "iCallBLE\ble_user_config.d" "iCallBLE\ble_user_config_stack.d" "iCallBLE\icall_api_lite.d" "iCallBLE\icall_hci_tl.d"
RMDIR /S/Q "syscfg"
Finished clean
**** Build Finished ****
**** Build of configuration Release for project simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang ****
"C:\\ti\\ccs1220\\ccs\\utils\\bin\\gmake" -k -j 8 all -O
Building file: "../simple_peripheral.syscfg"
Invoking: SysConfig
"C:/ti/ccs1220/ccs/utils/sysconfig_1.15.0/sysconfig_cli.bat" --script "C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/simple_peripheral.syscfg" -o "syscfg" -s "C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/.metadata/product.json" --compiler ticlang
Running script...
Validating...
Generating Code (simple_peripheral.syscfg)...
Writing C:\CC2652RSIP_PA\simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang\Release\syscfg\ti_ble_config.h...
Writing C:\CC2652RSIP_PA\simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang\Release\syscfg\ti_ble_config.c...
Writing C:\CC2652RSIP_PA\simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang\Release\syscfg\ti_build_config.opt...
Writing C:\CC2652RSIP_PA\simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang\Release\syscfg\ti_ble_app_config.opt...
Writing C:\CC2652RSIP_PA\simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang\Release\syscfg\ti_devices_config.c...
Writing C:\CC2652RSIP_PA\simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang\Release\syscfg\ti_radio_config.c...
Writing C:\CC2652RSIP_PA\simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang\Release\syscfg\ti_radio_config.h...
Writing C:\CC2652RSIP_PA\simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang\Release\syscfg\ti_drivers_config.c...
Writing C:\CC2652RSIP_PA\simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang\Release\syscfg\ti_drivers_config.h...
Writing C:\CC2652RSIP_PA\simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang\Release\syscfg\ti_utils_build_linker.cmd.genlibs...
Writing C:\CC2652RSIP_PA\simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang\Release\syscfg\syscfg_c.rov.xs...
Writing C:\CC2652RSIP_PA\simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang\Release\syscfg\ti_utils_runtime_model.gv...
Writing C:\CC2652RSIP_PA\simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang\Release\syscfg\ti_utils_runtime_Makefile...
Writing C:\CC2652RSIP_PA\simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang\Release\syscfg\ti_sysbios_config.h...
Writing C:\CC2652RSIP_PA\simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang\Release\syscfg\ti_sysbios_config.c...
Finished building: "../simple_peripheral.syscfg"
Building file: "C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/rcosc/rcosc_calibration.c"
Invoking: Arm Compiler
"C:/ti/ccs1220/ccs/tools/compiler/ti-cgt-armllvm_2.1.2.LTS/bin/tiarmclang.exe" -c @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_ble_app_config.opt" @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_build_config.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/build_components.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/factory_config.opt" -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mlittle-endian -mthumb -Oz -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Profiles" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Application" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/controller/cc26xx/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/rom" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/target/_common" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/npi/stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/heapmgr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/dev_info" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/simple_profile" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/osal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/saddr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/sdata" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/rcosc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/devices/cc13x2_cc26x2" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/kernel/tirtos7/packages" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/posix/ticlang" -DDeviceFamily_CC26X2 -DFLASH_ROM_BUILD -DNVOCMP_NWSAMEITEM=1 -DHEAPMGR_CONFIG=0x80 -DHEAPMGR_SIZE=0x0 -gdwarf-3 -march=armv7e-m -MMD -MP -MF"Application/rcosc_calibration.d_raw" -MT"Application/rcosc_calibration.o" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg" @"syscfg/ti_build_config.opt" @"syscfg/ti_ble_app_config.opt" -o"Application/rcosc_calibration.o" "C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/rcosc/rcosc_calibration.c"
Finished building: "C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/rcosc/rcosc_calibration.c"
Building file: "syscfg/ti_devices_config.c"
"C:/ti/ccs1220/ccs/tools/compiler/ti-cgt-armllvm_2.1.2.LTS/bin/tiarmclang.exe" -c @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_ble_app_config.opt" @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_build_config.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/build_components.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/factory_config.opt" -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mlittle-endian -mthumb -Oz -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Profiles" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Application" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/controller/cc26xx/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/rom" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/target/_common" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/npi/stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/heapmgr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/dev_info" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/simple_profile" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/osal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/saddr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/sdata" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/rcosc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/devices/cc13x2_cc26x2" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/kernel/tirtos7/packages" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/posix/ticlang" -DDeviceFamily_CC26X2 -DFLASH_ROM_BUILD -DNVOCMP_NWSAMEITEM=1 -DHEAPMGR_CONFIG=0x80 -DHEAPMGR_SIZE=0x0 -gdwarf-3 -march=armv7e-m -MMD -MP -MF"syscfg/ti_devices_config.d_raw" -MT"syscfg/ti_devices_config.o" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg" @"syscfg/ti_build_config.opt" @"syscfg/ti_ble_app_config.opt" -o"syscfg/ti_devices_config.o" "syscfg/ti_devices_config.c"
Finished building: "syscfg/ti_devices_config.c"
Building file: "syscfg/ti_radio_config.c"
"C:/ti/ccs1220/ccs/tools/compiler/ti-cgt-armllvm_2.1.2.LTS/bin/tiarmclang.exe" -c @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_ble_app_config.opt" @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_build_config.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/build_components.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/factory_config.opt" -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mlittle-endian -mthumb -Oz -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Profiles" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Application" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/controller/cc26xx/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/rom" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/target/_common" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/npi/stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/heapmgr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/dev_info" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/simple_profile" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/osal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/saddr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/sdata" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/rcosc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/devices/cc13x2_cc26x2" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/kernel/tirtos7/packages" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/posix/ticlang" -DDeviceFamily_CC26X2 -DFLASH_ROM_BUILD -DNVOCMP_NWSAMEITEM=1 -DHEAPMGR_CONFIG=0x80 -DHEAPMGR_SIZE=0x0 -gdwarf-3 -march=armv7e-m -MMD -MP -MF"syscfg/ti_radio_config.d_raw" -MT"syscfg/ti_radio_config.o" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg" @"syscfg/ti_build_config.opt" @"syscfg/ti_ble_app_config.opt" -o"syscfg/ti_radio_config.o" "syscfg/ti_radio_config.c"
Finished building: "syscfg/ti_radio_config.c"
Building file: "../Application/simple_peripheral_menu.c"
"C:/ti/ccs1220/ccs/tools/compiler/ti-cgt-armllvm_2.1.2.LTS/bin/tiarmclang.exe" -c @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_ble_app_config.opt" @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_build_config.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/build_components.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/factory_config.opt" -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mlittle-endian -mthumb -Oz -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Profiles" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Application" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/controller/cc26xx/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/rom" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/target/_common" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/npi/stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/heapmgr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/dev_info" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/simple_profile" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/osal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/saddr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/sdata" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/rcosc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/devices/cc13x2_cc26x2" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/kernel/tirtos7/packages" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/posix/ticlang" -DDeviceFamily_CC26X2 -DFLASH_ROM_BUILD -DNVOCMP_NWSAMEITEM=1 -DHEAPMGR_CONFIG=0x80 -DHEAPMGR_SIZE=0x0 -gdwarf-3 -march=armv7e-m -MMD -MP -MF"Application/simple_peripheral_menu.d_raw" -MT"Application/simple_peripheral_menu.o" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg" @"syscfg/ti_build_config.opt" @"syscfg/ti_ble_app_config.opt" -o"Application/simple_peripheral_menu.o" "../Application/simple_peripheral_menu.c"
Finished building: "../Application/simple_peripheral_menu.c"
Building file: "syscfg/ti_ble_config.c"
"C:/ti/ccs1220/ccs/tools/compiler/ti-cgt-armllvm_2.1.2.LTS/bin/tiarmclang.exe" -c @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_ble_app_config.opt" @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_build_config.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/build_components.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/factory_config.opt" -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mlittle-endian -mthumb -Oz -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Profiles" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Application" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/controller/cc26xx/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/rom" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/target/_common" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/npi/stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/heapmgr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/dev_info" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/simple_profile" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/osal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/saddr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/sdata" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/rcosc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/devices/cc13x2_cc26x2" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/kernel/tirtos7/packages" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/posix/ticlang" -DDeviceFamily_CC26X2 -DFLASH_ROM_BUILD -DNVOCMP_NWSAMEITEM=1 -DHEAPMGR_CONFIG=0x80 -DHEAPMGR_SIZE=0x0 -gdwarf-3 -march=armv7e-m -MMD -MP -MF"syscfg/ti_ble_config.d_raw" -MT"syscfg/ti_ble_config.o" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg" @"syscfg/ti_build_config.opt" @"syscfg/ti_ble_app_config.opt" -o"syscfg/ti_ble_config.o" "syscfg/ti_ble_config.c"
Finished building: "syscfg/ti_ble_config.c"
Building file: "C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/board_key.c"
"C:/ti/ccs1220/ccs/tools/compiler/ti-cgt-armllvm_2.1.2.LTS/bin/tiarmclang.exe" -c @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_ble_app_config.opt" @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_build_config.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/build_components.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/factory_config.opt" -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mlittle-endian -mthumb -Oz -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Profiles" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Application" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/controller/cc26xx/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/rom" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/target/_common" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/npi/stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/heapmgr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/dev_info" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/simple_profile" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/osal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/saddr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/sdata" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/rcosc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/devices/cc13x2_cc26x2" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/kernel/tirtos7/packages" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/posix/ticlang" -DDeviceFamily_CC26X2 -DFLASH_ROM_BUILD -DNVOCMP_NWSAMEITEM=1 -DHEAPMGR_CONFIG=0x80 -DHEAPMGR_SIZE=0x0 -gdwarf-3 -march=armv7e-m -MMD -MP -MF"Application/board_key.d_raw" -MT"Application/board_key.o" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg" @"syscfg/ti_build_config.opt" @"syscfg/ti_ble_app_config.opt" -o"Application/board_key.o" "C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/board_key.c"
Finished building: "C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/board_key.c"
Building file: "C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/util.c"
"C:/ti/ccs1220/ccs/tools/compiler/ti-cgt-armllvm_2.1.2.LTS/bin/tiarmclang.exe" -c @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_ble_app_config.opt" @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_build_config.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/build_components.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/factory_config.opt" -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mlittle-endian -mthumb -Oz -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Profiles" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Application" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/controller/cc26xx/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/rom" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/target/_common" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/npi/stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/heapmgr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/dev_info" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/simple_profile" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/osal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/saddr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/sdata" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/rcosc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/devices/cc13x2_cc26x2" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/kernel/tirtos7/packages" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/posix/ticlang" -DDeviceFamily_CC26X2 -DFLASH_ROM_BUILD -DNVOCMP_NWSAMEITEM=1 -DHEAPMGR_CONFIG=0x80 -DHEAPMGR_SIZE=0x0 -gdwarf-3 -march=armv7e-m -MMD -MP -MF"Application/util.d_raw" -MT"Application/util.o" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg" @"syscfg/ti_build_config.opt" @"syscfg/ti_ble_app_config.opt" -o"Application/util.o" "C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/util.c"
Finished building: "C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/util.c"
Building file: "../Application/simple_peripheral.c"
"C:/ti/ccs1220/ccs/tools/compiler/ti-cgt-armllvm_2.1.2.LTS/bin/tiarmclang.exe" -c @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_ble_app_config.opt" @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_build_config.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/build_components.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/factory_config.opt" -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mlittle-endian -mthumb -Oz -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Profiles" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Application" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/controller/cc26xx/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/rom" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/target/_common" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/npi/stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/heapmgr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/dev_info" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/simple_profile" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/osal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/saddr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/sdata" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/rcosc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/devices/cc13x2_cc26x2" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/kernel/tirtos7/packages" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/posix/ticlang" -DDeviceFamily_CC26X2 -DFLASH_ROM_BUILD -DNVOCMP_NWSAMEITEM=1 -DHEAPMGR_CONFIG=0x80 -DHEAPMGR_SIZE=0x0 -gdwarf-3 -march=armv7e-m -MMD -MP -MF"Application/simple_peripheral.d_raw" -MT"Application/simple_peripheral.o" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg" @"syscfg/ti_build_config.opt" @"syscfg/ti_ble_app_config.opt" -o"Application/simple_peripheral.o" "../Application/simple_peripheral.c"
Finished building: "../Application/simple_peripheral.c"
Building file: "syscfg/ti_drivers_config.c"
"C:/ti/ccs1220/ccs/tools/compiler/ti-cgt-armllvm_2.1.2.LTS/bin/tiarmclang.exe" -c @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_ble_app_config.opt" @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_build_config.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/build_components.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/factory_config.opt" -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mlittle-endian -mthumb -Oz -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Profiles" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Application" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/controller/cc26xx/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/rom" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/target/_common" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/npi/stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/heapmgr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/dev_info" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/simple_profile" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/osal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/saddr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/sdata" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/rcosc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/devices/cc13x2_cc26x2" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/kernel/tirtos7/packages" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/posix/ticlang" -DDeviceFamily_CC26X2 -DFLASH_ROM_BUILD -DNVOCMP_NWSAMEITEM=1 -DHEAPMGR_CONFIG=0x80 -DHEAPMGR_SIZE=0x0 -gdwarf-3 -march=armv7e-m -MMD -MP -MF"syscfg/ti_drivers_config.d_raw" -MT"syscfg/ti_drivers_config.o" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg" @"syscfg/ti_build_config.opt" @"syscfg/ti_ble_app_config.opt" -o"syscfg/ti_drivers_config.o" "syscfg/ti_drivers_config.c"
Finished building: "syscfg/ti_drivers_config.c"
Building file: "C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/menu/two_btn_menu.c"
"C:/ti/ccs1220/ccs/tools/compiler/ti-cgt-armllvm_2.1.2.LTS/bin/tiarmclang.exe" -c @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_ble_app_config.opt" @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_build_config.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/build_components.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/factory_config.opt" -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mlittle-endian -mthumb -Oz -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Profiles" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Application" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/controller/cc26xx/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/rom" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/target/_common" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/npi/stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/heapmgr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/dev_info" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/simple_profile" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/osal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/saddr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/sdata" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/rcosc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/devices/cc13x2_cc26x2" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/kernel/tirtos7/packages" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/posix/ticlang" -DDeviceFamily_CC26X2 -DFLASH_ROM_BUILD -DNVOCMP_NWSAMEITEM=1 -DHEAPMGR_CONFIG=0x80 -DHEAPMGR_SIZE=0x0 -gdwarf-3 -march=armv7e-m -MMD -MP -MF"Application/two_btn_menu.d_raw" -MT"Application/two_btn_menu.o" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg" @"syscfg/ti_build_config.opt" @"syscfg/ti_ble_app_config.opt" -o"Application/two_btn_menu.o" "C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/menu/two_btn_menu.c"
Finished building: "C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/menu/two_btn_menu.c"
Building file: "C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/nv/crc.c"
"C:/ti/ccs1220/ccs/tools/compiler/ti-cgt-armllvm_2.1.2.LTS/bin/tiarmclang.exe" -c @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_ble_app_config.opt" @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_build_config.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/build_components.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/factory_config.opt" -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mlittle-endian -mthumb -Oz -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Profiles" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Application" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/controller/cc26xx/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/rom" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/target/_common" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/npi/stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/heapmgr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/dev_info" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/simple_profile" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/osal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/saddr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/sdata" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/rcosc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/devices/cc13x2_cc26x2" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/kernel/tirtos7/packages" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/posix/ticlang" -DDeviceFamily_CC26X2 -DFLASH_ROM_BUILD -DNVOCMP_NWSAMEITEM=1 -DHEAPMGR_CONFIG=0x80 -DHEAPMGR_SIZE=0x0 -gdwarf-3 -march=armv7e-m -MMD -MP -MF"Drivers/NV/crc.d_raw" -MT"Drivers/NV/crc.o" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg" @"syscfg/ti_build_config.opt" @"syscfg/ti_ble_app_config.opt" -o"Drivers/NV/crc.o" "C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/nv/crc.c"
Finished building: "C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/nv/crc.c"
Building file: "../MHLib/SP_Dev_Test.c"
"C:/ti/ccs1220/ccs/tools/compiler/ti-cgt-armllvm_2.1.2.LTS/bin/tiarmclang.exe" -c @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_ble_app_config.opt" @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_build_config.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/build_components.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/factory_config.opt" -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mlittle-endian -mthumb -Oz -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Profiles" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Application" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/controller/cc26xx/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/rom" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/target/_common" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/npi/stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/heapmgr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/dev_info" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/simple_profile" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/osal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/saddr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/sdata" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/rcosc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/devices/cc13x2_cc26x2" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/kernel/tirtos7/packages" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/posix/ticlang" -DDeviceFamily_CC26X2 -DFLASH_ROM_BUILD -DNVOCMP_NWSAMEITEM=1 -DHEAPMGR_CONFIG=0x80 -DHEAPMGR_SIZE=0x0 -gdwarf-3 -march=armv7e-m -MMD -MP -MF"MHLib/SP_Dev_Test.d_raw" -MT"MHLib/SP_Dev_Test.o" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg" @"syscfg/ti_build_config.opt" @"syscfg/ti_ble_app_config.opt" -o"MHLib/SP_Dev_Test.o" "../MHLib/SP_Dev_Test.c"
Finished building: "../MHLib/SP_Dev_Test.c"
Building file: "../MHLib/app_oem_help.c"
"C:/ti/ccs1220/ccs/tools/compiler/ti-cgt-armllvm_2.1.2.LTS/bin/tiarmclang.exe" -c @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_ble_app_config.opt" @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_build_config.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/build_components.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/factory_config.opt" -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mlittle-endian -mthumb -Oz -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Profiles" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Application" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/controller/cc26xx/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/rom" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/target/_common" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/npi/stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/heapmgr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/dev_info" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/simple_profile" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/osal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/saddr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/sdata" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/rcosc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/devices/cc13x2_cc26x2" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/kernel/tirtos7/packages" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/posix/ticlang" -DDeviceFamily_CC26X2 -DFLASH_ROM_BUILD -DNVOCMP_NWSAMEITEM=1 -DHEAPMGR_CONFIG=0x80 -DHEAPMGR_SIZE=0x0 -gdwarf-3 -march=armv7e-m -MMD -MP -MF"MHLib/app_oem_help.d_raw" -MT"MHLib/app_oem_help.o" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg" @"syscfg/ti_build_config.opt" @"syscfg/ti_ble_app_config.opt" -o"MHLib/app_oem_help.o" "../MHLib/app_oem_help.c"
Finished building: "../MHLib/app_oem_help.c"
Building file: "../MHLib/UserDataIn.c"
"C:/ti/ccs1220/ccs/tools/compiler/ti-cgt-armllvm_2.1.2.LTS/bin/tiarmclang.exe" -c @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_ble_app_config.opt" @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_build_config.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/build_components.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/factory_config.opt" -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mlittle-endian -mthumb -Oz -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Profiles" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Application" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/controller/cc26xx/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/rom" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/target/_common" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/npi/stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/heapmgr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/dev_info" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/simple_profile" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/osal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/saddr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/sdata" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/rcosc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/devices/cc13x2_cc26x2" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/kernel/tirtos7/packages" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/posix/ticlang" -DDeviceFamily_CC26X2 -DFLASH_ROM_BUILD -DNVOCMP_NWSAMEITEM=1 -DHEAPMGR_CONFIG=0x80 -DHEAPMGR_SIZE=0x0 -gdwarf-3 -march=armv7e-m -MMD -MP -MF"MHLib/UserDataIn.d_raw" -MT"MHLib/UserDataIn.o" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg" @"syscfg/ti_build_config.opt" @"syscfg/ti_ble_app_config.opt" -o"MHLib/UserDataIn.o" "../MHLib/UserDataIn.c"
Finished building: "../MHLib/UserDataIn.c"
Building file: "../MHLib/UserDataOut.c"
"C:/ti/ccs1220/ccs/tools/compiler/ti-cgt-armllvm_2.1.2.LTS/bin/tiarmclang.exe" -c @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_ble_app_config.opt" @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_build_config.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/build_components.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/factory_config.opt" -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mlittle-endian -mthumb -Oz -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Profiles" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Application" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/controller/cc26xx/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/rom" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/target/_common" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/npi/stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/heapmgr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/dev_info" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/simple_profile" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/osal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/saddr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/sdata" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/rcosc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/devices/cc13x2_cc26x2" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/kernel/tirtos7/packages" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/posix/ticlang" -DDeviceFamily_CC26X2 -DFLASH_ROM_BUILD -DNVOCMP_NWSAMEITEM=1 -DHEAPMGR_CONFIG=0x80 -DHEAPMGR_SIZE=0x0 -gdwarf-3 -march=armv7e-m -MMD -MP -MF"MHLib/UserDataOut.d_raw" -MT"MHLib/UserDataOut.o" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg" @"syscfg/ti_build_config.opt" @"syscfg/ti_ble_app_config.opt" -o"MHLib/UserDataOut.o" "../MHLib/UserDataOut.c"
Finished building: "../MHLib/UserDataOut.c"
Building file: "../MHLib/assert.c"
"C:/ti/ccs1220/ccs/tools/compiler/ti-cgt-armllvm_2.1.2.LTS/bin/tiarmclang.exe" -c @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_ble_app_config.opt" @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_build_config.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/build_components.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/factory_config.opt" -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mlittle-endian -mthumb -Oz -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Profiles" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Application" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/controller/cc26xx/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/rom" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/target/_common" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/npi/stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/heapmgr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/dev_info" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/simple_profile" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/osal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/saddr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/sdata" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/rcosc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/devices/cc13x2_cc26x2" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/kernel/tirtos7/packages" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/posix/ticlang" -DDeviceFamily_CC26X2 -DFLASH_ROM_BUILD -DNVOCMP_NWSAMEITEM=1 -DHEAPMGR_CONFIG=0x80 -DHEAPMGR_SIZE=0x0 -gdwarf-3 -march=armv7e-m -MMD -MP -MF"MHLib/assert.d_raw" -MT"MHLib/assert.o" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg" @"syscfg/ti_build_config.opt" @"syscfg/ti_ble_app_config.opt" -o"MHLib/assert.o" "../MHLib/assert.c"
Finished building: "../MHLib/assert.c"
Building file: "C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/nv/nvocmp.c"
Invoking: Arm Compiler
"C:/ti/ccs1220/ccs/tools/compiler/ti-cgt-armllvm_2.1.2.LTS/bin/tiarmclang.exe" -c @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_ble_app_config.opt" @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_build_config.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/build_components.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/factory_config.opt" -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mlittle-endian -mthumb -Oz -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Profiles" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Application" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/controller/cc26xx/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/rom" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/target/_common" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/npi/stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/heapmgr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/dev_info" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/simple_profile" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/osal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/saddr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/sdata" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/rcosc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/devices/cc13x2_cc26x2" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/kernel/tirtos7/packages" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/posix/ticlang" -DDeviceFamily_CC26X2 -DFLASH_ROM_BUILD -DNVOCMP_NWSAMEITEM=1 -DHEAPMGR_CONFIG=0x80 -DHEAPMGR_SIZE=0x0 -gdwarf-3 -march=armv7e-m -MMD -MP -MF"Drivers/NV/nvocmp.d_raw" -MT"Drivers/NV/nvocmp.o" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg" @"syscfg/ti_build_config.opt" @"syscfg/ti_ble_app_config.opt" -o"Drivers/NV/nvocmp.o" "C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/nv/nvocmp.c"
Finished building: "C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/nv/nvocmp.c"
Building file: "../MHLib/flash_upgrade.c"
"C:/ti/ccs1220/ccs/tools/compiler/ti-cgt-armllvm_2.1.2.LTS/bin/tiarmclang.exe" -c @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_ble_app_config.opt" @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_build_config.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/build_components.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/factory_config.opt" -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mlittle-endian -mthumb -Oz -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Profiles" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Application" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/controller/cc26xx/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/rom" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/target/_common" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/npi/stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/heapmgr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/dev_info" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/simple_profile" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/osal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/saddr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/sdata" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/rcosc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/devices/cc13x2_cc26x2" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/kernel/tirtos7/packages" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/posix/ticlang" -DDeviceFamily_CC26X2 -DFLASH_ROM_BUILD -DNVOCMP_NWSAMEITEM=1 -DHEAPMGR_CONFIG=0x80 -DHEAPMGR_SIZE=0x0 -gdwarf-3 -march=armv7e-m -MMD -MP -MF"MHLib/flash_upgrade.d_raw" -MT"MHLib/flash_upgrade.o" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg" @"syscfg/ti_build_config.opt" @"syscfg/ti_ble_app_config.opt" -o"MHLib/flash_upgrade.o" "../MHLib/flash_upgrade.c"
Finished building: "../MHLib/flash_upgrade.c"
Building file: "../MHLib/app_oem.c"
"C:/ti/ccs1220/ccs/tools/compiler/ti-cgt-armllvm_2.1.2.LTS/bin/tiarmclang.exe" -c @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_ble_app_config.opt" @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_build_config.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/build_components.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/factory_config.opt" -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mlittle-endian -mthumb -Oz -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Profiles" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Application" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/controller/cc26xx/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/rom" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/target/_common" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/npi/stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/heapmgr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/dev_info" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/simple_profile" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/osal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/saddr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/sdata" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/rcosc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/devices/cc13x2_cc26x2" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/kernel/tirtos7/packages" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/posix/ticlang" -DDeviceFamily_CC26X2 -DFLASH_ROM_BUILD -DNVOCMP_NWSAMEITEM=1 -DHEAPMGR_CONFIG=0x80 -DHEAPMGR_SIZE=0x0 -gdwarf-3 -march=armv7e-m -MMD -MP -MF"MHLib/app_oem.d_raw" -MT"MHLib/app_oem.o" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg" @"syscfg/ti_build_config.opt" @"syscfg/ti_ble_app_config.opt" -o"MHLib/app_oem.o" "../MHLib/app_oem.c"
Finished building: "../MHLib/app_oem.c"
Building file: "../MHLib/mhFactory.c"
"C:/ti/ccs1220/ccs/tools/compiler/ti-cgt-armllvm_2.1.2.LTS/bin/tiarmclang.exe" -c @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_ble_app_config.opt" @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_build_config.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/build_components.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/factory_config.opt" -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mlittle-endian -mthumb -Oz -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Profiles" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Application" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/controller/cc26xx/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/rom" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/target/_common" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/npi/stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/heapmgr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/dev_info" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/simple_profile" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/osal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/saddr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/sdata" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/rcosc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/devices/cc13x2_cc26x2" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/kernel/tirtos7/packages" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/posix/ticlang" -DDeviceFamily_CC26X2 -DFLASH_ROM_BUILD -DNVOCMP_NWSAMEITEM=1 -DHEAPMGR_CONFIG=0x80 -DHEAPMGR_SIZE=0x0 -gdwarf-3 -march=armv7e-m -MMD -MP -MF"MHLib/mhFactory.d_raw" -MT"MHLib/mhFactory.o" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg" @"syscfg/ti_build_config.opt" @"syscfg/ti_ble_app_config.opt" -o"MHLib/mhFactory.o" "../MHLib/mhFactory.c"
Finished building: "../MHLib/mhFactory.c"
Building file: "../MHLib/mhLib_adc.c"
"C:/ti/ccs1220/ccs/tools/compiler/ti-cgt-armllvm_2.1.2.LTS/bin/tiarmclang.exe" -c @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_ble_app_config.opt" @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_build_config.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/build_components.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/factory_config.opt" -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mlittle-endian -mthumb -Oz -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Profiles" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Application" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/controller/cc26xx/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/rom" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/target/_common" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/npi/stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/heapmgr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/dev_info" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/simple_profile" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/osal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/saddr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/sdata" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/rcosc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/devices/cc13x2_cc26x2" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/kernel/tirtos7/packages" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/posix/ticlang" -DDeviceFamily_CC26X2 -DFLASH_ROM_BUILD -DNVOCMP_NWSAMEITEM=1 -DHEAPMGR_CONFIG=0x80 -DHEAPMGR_SIZE=0x0 -gdwarf-3 -march=armv7e-m -MMD -MP -MF"MHLib/mhLib_adc.d_raw" -MT"MHLib/mhLib_adc.o" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg" @"syscfg/ti_build_config.opt" @"syscfg/ti_ble_app_config.opt" -o"MHLib/mhLib_adc.o" "../MHLib/mhLib_adc.c"
Finished building: "../MHLib/mhLib_adc.c"
Building file: "../MHLib/mhLed.c"
"C:/ti/ccs1220/ccs/tools/compiler/ti-cgt-armllvm_2.1.2.LTS/bin/tiarmclang.exe" -c @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_ble_app_config.opt" @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_build_config.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/build_components.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/factory_config.opt" -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mlittle-endian -mthumb -Oz -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Profiles" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Application" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/controller/cc26xx/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/rom" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/target/_common" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/npi/stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/heapmgr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/dev_info" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/simple_profile" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/osal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/saddr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/sdata" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/rcosc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/devices/cc13x2_cc26x2" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/kernel/tirtos7/packages" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/posix/ticlang" -DDeviceFamily_CC26X2 -DFLASH_ROM_BUILD -DNVOCMP_NWSAMEITEM=1 -DHEAPMGR_CONFIG=0x80 -DHEAPMGR_SIZE=0x0 -gdwarf-3 -march=armv7e-m -MMD -MP -MF"MHLib/mhLed.d_raw" -MT"MHLib/mhLed.o" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg" @"syscfg/ti_build_config.opt" @"syscfg/ti_ble_app_config.opt" -o"MHLib/mhLed.o" "../MHLib/mhLed.c"
Finished building: "../MHLib/mhLed.c"
Building file: "../MHLib/mhLib_tab.c"
"C:/ti/ccs1220/ccs/tools/compiler/ti-cgt-armllvm_2.1.2.LTS/bin/tiarmclang.exe" -c @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_ble_app_config.opt" @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_build_config.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/build_components.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/factory_config.opt" -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mlittle-endian -mthumb -Oz -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Profiles" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Application" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/controller/cc26xx/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/rom" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/target/_common" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/npi/stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/heapmgr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/dev_info" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/simple_profile" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/osal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/saddr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/sdata" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/rcosc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/devices/cc13x2_cc26x2" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/kernel/tirtos7/packages" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/posix/ticlang" -DDeviceFamily_CC26X2 -DFLASH_ROM_BUILD -DNVOCMP_NWSAMEITEM=1 -DHEAPMGR_CONFIG=0x80 -DHEAPMGR_SIZE=0x0 -gdwarf-3 -march=armv7e-m -MMD -MP -MF"MHLib/mhLib_tab.d_raw" -MT"MHLib/mhLib_tab.o" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg" @"syscfg/ti_build_config.opt" @"syscfg/ti_ble_app_config.opt" -o"MHLib/mhLib_tab.o" "../MHLib/mhLib_tab.c"
Finished building: "../MHLib/mhLib_tab.c"
Building file: "../MHLib/mhLib_buf.c"
"C:/ti/ccs1220/ccs/tools/compiler/ti-cgt-armllvm_2.1.2.LTS/bin/tiarmclang.exe" -c @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_ble_app_config.opt" @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_build_config.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/build_components.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/factory_config.opt" -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mlittle-endian -mthumb -Oz -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Profiles" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Application" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/controller/cc26xx/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/rom" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/target/_common" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/npi/stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/heapmgr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/dev_info" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/simple_profile" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/osal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/saddr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/sdata" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/rcosc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/devices/cc13x2_cc26x2" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/kernel/tirtos7/packages" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/posix/ticlang" -DDeviceFamily_CC26X2 -DFLASH_ROM_BUILD -DNVOCMP_NWSAMEITEM=1 -DHEAPMGR_CONFIG=0x80 -DHEAPMGR_SIZE=0x0 -gdwarf-3 -march=armv7e-m -MMD -MP -MF"MHLib/mhLib_buf.d_raw" -MT"MHLib/mhLib_buf.o" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg" @"syscfg/ti_build_config.opt" @"syscfg/ti_ble_app_config.opt" -o"MHLib/mhLib_buf.o" "../MHLib/mhLib_buf.c"
Finished building: "../MHLib/mhLib_buf.c"
Building file: "../MHLib/mhLib_crc.c"
"C:/ti/ccs1220/ccs/tools/compiler/ti-cgt-armllvm_2.1.2.LTS/bin/tiarmclang.exe" -c @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_ble_app_config.opt" @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_build_config.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/build_components.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/factory_config.opt" -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mlittle-endian -mthumb -Oz -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Profiles" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Application" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/controller/cc26xx/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/rom" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/target/_common" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/npi/stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/heapmgr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/dev_info" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/simple_profile" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/osal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/saddr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/sdata" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/rcosc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/devices/cc13x2_cc26x2" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/kernel/tirtos7/packages" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/posix/ticlang" -DDeviceFamily_CC26X2 -DFLASH_ROM_BUILD -DNVOCMP_NWSAMEITEM=1 -DHEAPMGR_CONFIG=0x80 -DHEAPMGR_SIZE=0x0 -gdwarf-3 -march=armv7e-m -MMD -MP -MF"MHLib/mhLib_crc.d_raw" -MT"MHLib/mhLib_crc.o" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg" @"syscfg/ti_build_config.opt" @"syscfg/ti_ble_app_config.opt" -o"MHLib/mhLib_crc.o" "../MHLib/mhLib_crc.c"
Finished building: "../MHLib/mhLib_crc.c"
Building file: "../MHLib/mhLib_mem.c"
"C:/ti/ccs1220/ccs/tools/compiler/ti-cgt-armllvm_2.1.2.LTS/bin/tiarmclang.exe" -c @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_ble_app_config.opt" @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_build_config.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/build_components.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/factory_config.opt" -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mlittle-endian -mthumb -Oz -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Profiles" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Application" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/controller/cc26xx/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/rom" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/target/_common" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/npi/stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/heapmgr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/dev_info" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/simple_profile" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/osal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/saddr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/sdata" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/rcosc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/devices/cc13x2_cc26x2" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/kernel/tirtos7/packages" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/posix/ticlang" -DDeviceFamily_CC26X2 -DFLASH_ROM_BUILD -DNVOCMP_NWSAMEITEM=1 -DHEAPMGR_CONFIG=0x80 -DHEAPMGR_SIZE=0x0 -gdwarf-3 -march=armv7e-m -MMD -MP -MF"MHLib/mhLib_mem.d_raw" -MT"MHLib/mhLib_mem.o" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg" @"syscfg/ti_build_config.opt" @"syscfg/ti_ble_app_config.opt" -o"MHLib/mhLib_mem.o" "../MHLib/mhLib_mem.c"
Finished building: "../MHLib/mhLib_mem.c"
Building file: "../MHLib/mhLib_dac.c"
"C:/ti/ccs1220/ccs/tools/compiler/ti-cgt-armllvm_2.1.2.LTS/bin/tiarmclang.exe" -c @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_ble_app_config.opt" @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_build_config.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/build_components.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/factory_config.opt" -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mlittle-endian -mthumb -Oz -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Profiles" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Application" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/controller/cc26xx/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/rom" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/target/_common" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/npi/stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/heapmgr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/dev_info" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/simple_profile" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/osal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/saddr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/sdata" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/rcosc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/devices/cc13x2_cc26x2" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/kernel/tirtos7/packages" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/posix/ticlang" -DDeviceFamily_CC26X2 -DFLASH_ROM_BUILD -DNVOCMP_NWSAMEITEM=1 -DHEAPMGR_CONFIG=0x80 -DHEAPMGR_SIZE=0x0 -gdwarf-3 -march=armv7e-m -MMD -MP -MF"MHLib/mhLib_dac.d_raw" -MT"MHLib/mhLib_dac.o" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg" @"syscfg/ti_build_config.opt" @"syscfg/ti_ble_app_config.opt" -o"MHLib/mhLib_dac.o" "../MHLib/mhLib_dac.c"
Finished building: "../MHLib/mhLib_dac.c"
Building file: "../MHLib/mhLib_err.c"
"C:/ti/ccs1220/ccs/tools/compiler/ti-cgt-armllvm_2.1.2.LTS/bin/tiarmclang.exe" -c @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_ble_app_config.opt" @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_build_config.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/build_components.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/factory_config.opt" -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mlittle-endian -mthumb -Oz -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Profiles" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Application" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/controller/cc26xx/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/rom" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/target/_common" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/npi/stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/heapmgr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/dev_info" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/simple_profile" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/osal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/saddr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/sdata" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/rcosc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/devices/cc13x2_cc26x2" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/kernel/tirtos7/packages" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/posix/ticlang" -DDeviceFamily_CC26X2 -DFLASH_ROM_BUILD -DNVOCMP_NWSAMEITEM=1 -DHEAPMGR_CONFIG=0x80 -DHEAPMGR_SIZE=0x0 -gdwarf-3 -march=armv7e-m -MMD -MP -MF"MHLib/mhLib_err.d_raw" -MT"MHLib/mhLib_err.o" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg" @"syscfg/ti_build_config.opt" @"syscfg/ti_ble_app_config.opt" -o"MHLib/mhLib_err.o" "../MHLib/mhLib_err.c"
Finished building: "../MHLib/mhLib_err.c"
Building file: "../MHLib/mhLib_user.c"
"C:/ti/ccs1220/ccs/tools/compiler/ti-cgt-armllvm_2.1.2.LTS/bin/tiarmclang.exe" -c @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_ble_app_config.opt" @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_build_config.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/build_components.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/factory_config.opt" -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mlittle-endian -mthumb -Oz -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Profiles" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Application" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/controller/cc26xx/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/rom" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/target/_common" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/npi/stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/heapmgr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/dev_info" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/simple_profile" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/osal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/saddr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/sdata" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/rcosc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/devices/cc13x2_cc26x2" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/kernel/tirtos7/packages" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/posix/ticlang" -DDeviceFamily_CC26X2 -DFLASH_ROM_BUILD -DNVOCMP_NWSAMEITEM=1 -DHEAPMGR_CONFIG=0x80 -DHEAPMGR_SIZE=0x0 -gdwarf-3 -march=armv7e-m -MMD -MP -MF"MHLib/mhLib_user.d_raw" -MT"MHLib/mhLib_user.o" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg" @"syscfg/ti_build_config.opt" @"syscfg/ti_ble_app_config.opt" -o"MHLib/mhLib_user.o" "../MHLib/mhLib_user.c"
Finished building: "../MHLib/mhLib_user.c"
Building file: "../MHLib/mhMHX_saveregs.c"
"C:/ti/ccs1220/ccs/tools/compiler/ti-cgt-armllvm_2.1.2.LTS/bin/tiarmclang.exe" -c @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_ble_app_config.opt" @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_build_config.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/build_components.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/factory_config.opt" -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mlittle-endian -mthumb -Oz -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Profiles" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Application" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/controller/cc26xx/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/rom" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/target/_common" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/npi/stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/heapmgr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/dev_info" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/simple_profile" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/osal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/saddr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/sdata" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/rcosc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/devices/cc13x2_cc26x2" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/kernel/tirtos7/packages" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/posix/ticlang" -DDeviceFamily_CC26X2 -DFLASH_ROM_BUILD -DNVOCMP_NWSAMEITEM=1 -DHEAPMGR_CONFIG=0x80 -DHEAPMGR_SIZE=0x0 -gdwarf-3 -march=armv7e-m -MMD -MP -MF"MHLib/mhMHX_saveregs.d_raw" -MT"MHLib/mhMHX_saveregs.o" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg" @"syscfg/ti_build_config.opt" @"syscfg/ti_ble_app_config.opt" -o"MHLib/mhMHX_saveregs.o" "../MHLib/mhMHX_saveregs.c"
Finished building: "../MHLib/mhMHX_saveregs.c"
Building file: "../MHLib/mhtasks.c"
"C:/ti/ccs1220/ccs/tools/compiler/ti-cgt-armllvm_2.1.2.LTS/bin/tiarmclang.exe" -c @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_ble_app_config.opt" @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_build_config.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/build_components.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/factory_config.opt" -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mlittle-endian -mthumb -Oz -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Profiles" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Application" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/controller/cc26xx/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/rom" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/target/_common" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/npi/stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/heapmgr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/dev_info" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/simple_profile" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/osal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/saddr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/sdata" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/rcosc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/devices/cc13x2_cc26x2" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/kernel/tirtos7/packages" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/posix/ticlang" -DDeviceFamily_CC26X2 -DFLASH_ROM_BUILD -DNVOCMP_NWSAMEITEM=1 -DHEAPMGR_CONFIG=0x80 -DHEAPMGR_SIZE=0x0 -gdwarf-3 -march=armv7e-m -MMD -MP -MF"MHLib/mhtasks.d_raw" -MT"MHLib/mhtasks.o" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg" @"syscfg/ti_build_config.opt" @"syscfg/ti_ble_app_config.opt" -o"MHLib/mhtasks.o" "../MHLib/mhtasks.c"
Finished building: "../MHLib/mhtasks.c"
Building file: "../MHLib/mhSaveregs.c"
"C:/ti/ccs1220/ccs/tools/compiler/ti-cgt-armllvm_2.1.2.LTS/bin/tiarmclang.exe" -c @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_ble_app_config.opt" @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_build_config.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/build_components.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/factory_config.opt" -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mlittle-endian -mthumb -Oz -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Profiles" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Application" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/controller/cc26xx/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/rom" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/target/_common" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/npi/stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/heapmgr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/dev_info" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/simple_profile" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/osal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/saddr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/sdata" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/rcosc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/devices/cc13x2_cc26x2" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/kernel/tirtos7/packages" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/posix/ticlang" -DDeviceFamily_CC26X2 -DFLASH_ROM_BUILD -DNVOCMP_NWSAMEITEM=1 -DHEAPMGR_CONFIG=0x80 -DHEAPMGR_SIZE=0x0 -gdwarf-3 -march=armv7e-m -MMD -MP -MF"MHLib/mhSaveregs.d_raw" -MT"MHLib/mhSaveregs.o" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg" @"syscfg/ti_build_config.opt" @"syscfg/ti_ble_app_config.opt" -o"MHLib/mhSaveregs.o" "../MHLib/mhSaveregs.c"
Finished building: "../MHLib/mhSaveregs.c"
Building file: "../MHLib/mhParTest.c"
Invoking: Arm Compiler
"C:/ti/ccs1220/ccs/tools/compiler/ti-cgt-armllvm_2.1.2.LTS/bin/tiarmclang.exe" -c @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_ble_app_config.opt" @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_build_config.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/build_components.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/factory_config.opt" -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mlittle-endian -mthumb -Oz -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Profiles" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Application" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/controller/cc26xx/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/rom" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/target/_common" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/npi/stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/heapmgr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/dev_info" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/simple_profile" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/osal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/saddr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/sdata" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/rcosc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/devices/cc13x2_cc26x2" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/kernel/tirtos7/packages" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/posix/ticlang" -DDeviceFamily_CC26X2 -DFLASH_ROM_BUILD -DNVOCMP_NWSAMEITEM=1 -DHEAPMGR_CONFIG=0x80 -DHEAPMGR_SIZE=0x0 -gdwarf-3 -march=armv7e-m -MMD -MP -MF"MHLib/mhParTest.d_raw" -MT"MHLib/mhParTest.o" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg" @"syscfg/ti_build_config.opt" @"syscfg/ti_ble_app_config.opt" -o"MHLib/mhParTest.o" "../MHLib/mhParTest.c"
Finished building: "../MHLib/mhParTest.c"
Building file: "C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src/npi_rxbuf.c"
"C:/ti/ccs1220/ccs/tools/compiler/ti-cgt-armllvm_2.1.2.LTS/bin/tiarmclang.exe" -c @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_ble_app_config.opt" @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_build_config.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/build_components.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/factory_config.opt" -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mlittle-endian -mthumb -Oz -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Profiles" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Application" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/controller/cc26xx/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/rom" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/target/_common" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/npi/stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/heapmgr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/dev_info" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/simple_profile" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/osal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/saddr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/sdata" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/rcosc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/devices/cc13x2_cc26x2" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/kernel/tirtos7/packages" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/posix/ticlang" -DDeviceFamily_CC26X2 -DFLASH_ROM_BUILD -DNVOCMP_NWSAMEITEM=1 -DHEAPMGR_CONFIG=0x80 -DHEAPMGR_SIZE=0x0 -gdwarf-3 -march=armv7e-m -MMD -MP -MF"NPI/npi_rxbuf.d_raw" -MT"NPI/npi_rxbuf.o" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg" @"syscfg/ti_build_config.opt" @"syscfg/ti_ble_app_config.opt" -o"NPI/npi_rxbuf.o" "C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src/npi_rxbuf.c"
Finished building: "C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src/npi_rxbuf.c"
Building file: "C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src/npi_tl_uart.c"
"C:/ti/ccs1220/ccs/tools/compiler/ti-cgt-armllvm_2.1.2.LTS/bin/tiarmclang.exe" -c @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_ble_app_config.opt" @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_build_config.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/build_components.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/factory_config.opt" -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mlittle-endian -mthumb -Oz -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Profiles" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Application" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/controller/cc26xx/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/rom" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/target/_common" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/npi/stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/heapmgr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/dev_info" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/simple_profile" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/osal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/saddr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/sdata" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/rcosc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/devices/cc13x2_cc26x2" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/kernel/tirtos7/packages" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/posix/ticlang" -DDeviceFamily_CC26X2 -DFLASH_ROM_BUILD -DNVOCMP_NWSAMEITEM=1 -DHEAPMGR_CONFIG=0x80 -DHEAPMGR_SIZE=0x0 -gdwarf-3 -march=armv7e-m -MMD -MP -MF"NPI/npi_tl_uart.d_raw" -MT"NPI/npi_tl_uart.o" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg" @"syscfg/ti_build_config.opt" @"syscfg/ti_ble_app_config.opt" -o"NPI/npi_tl_uart.o" "C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src/npi_tl_uart.c"
Finished building: "C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src/npi_tl_uart.c"
Building file: "../MHLib/mhTimer.c"
"C:/ti/ccs1220/ccs/tools/compiler/ti-cgt-armllvm_2.1.2.LTS/bin/tiarmclang.exe" -c @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_ble_app_config.opt" @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_build_config.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/build_components.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/factory_config.opt" -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mlittle-endian -mthumb -Oz -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Profiles" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Application" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/controller/cc26xx/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/rom" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/target/_common" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/npi/stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/heapmgr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/dev_info" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/simple_profile" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/osal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/saddr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/sdata" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/rcosc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/devices/cc13x2_cc26x2" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/kernel/tirtos7/packages" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/posix/ticlang" -DDeviceFamily_CC26X2 -DFLASH_ROM_BUILD -DNVOCMP_NWSAMEITEM=1 -DHEAPMGR_CONFIG=0x80 -DHEAPMGR_SIZE=0x0 -gdwarf-3 -march=armv7e-m -MMD -MP -MF"MHLib/mhTimer.d_raw" -MT"MHLib/mhTimer.o" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg" @"syscfg/ti_build_config.opt" @"syscfg/ti_ble_app_config.opt" -o"MHLib/mhTimer.o" "../MHLib/mhTimer.c"
Finished building: "../MHLib/mhTimer.c"
Building file: "C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src/npi_task.c"
"C:/ti/ccs1220/ccs/tools/compiler/ti-cgt-armllvm_2.1.2.LTS/bin/tiarmclang.exe" -c @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_ble_app_config.opt" @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_build_config.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/build_components.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/factory_config.opt" -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mlittle-endian -mthumb -Oz -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Profiles" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Application" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/controller/cc26xx/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/rom" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/target/_common" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/npi/stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/heapmgr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/dev_info" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/simple_profile" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/osal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/saddr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/sdata" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/rcosc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/devices/cc13x2_cc26x2" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/kernel/tirtos7/packages" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/posix/ticlang" -DDeviceFamily_CC26X2 -DFLASH_ROM_BUILD -DNVOCMP_NWSAMEITEM=1 -DHEAPMGR_CONFIG=0x80 -DHEAPMGR_SIZE=0x0 -gdwarf-3 -march=armv7e-m -MMD -MP -MF"NPI/npi_task.d_raw" -MT"NPI/npi_task.o" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg" @"syscfg/ti_build_config.opt" @"syscfg/ti_ble_app_config.opt" -o"NPI/npi_task.o" "C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src/npi_task.c"
Finished building: "C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src/npi_task.c"
Building file: "../MHLib/mhuart.c"
"C:/ti/ccs1220/ccs/tools/compiler/ti-cgt-armllvm_2.1.2.LTS/bin/tiarmclang.exe" -c @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_ble_app_config.opt" @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_build_config.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/build_components.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/factory_config.opt" -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mlittle-endian -mthumb -Oz -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Profiles" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Application" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/controller/cc26xx/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/rom" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/target/_common" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/npi/stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/heapmgr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/dev_info" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/simple_profile" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/osal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/saddr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/sdata" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/rcosc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/devices/cc13x2_cc26x2" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/kernel/tirtos7/packages" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/posix/ticlang" -DDeviceFamily_CC26X2 -DFLASH_ROM_BUILD -DNVOCMP_NWSAMEITEM=1 -DHEAPMGR_CONFIG=0x80 -DHEAPMGR_SIZE=0x0 -gdwarf-3 -march=armv7e-m -MMD -MP -MF"MHLib/mhuart.d_raw" -MT"MHLib/mhuart.o" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg" @"syscfg/ti_build_config.opt" @"syscfg/ti_ble_app_config.opt" -o"MHLib/mhuart.o" "../MHLib/mhuart.c"
Finished building: "../MHLib/mhuart.c"
Building file: "C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src/npi_frame_hci.c"
"C:/ti/ccs1220/ccs/tools/compiler/ti-cgt-armllvm_2.1.2.LTS/bin/tiarmclang.exe" -c @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_ble_app_config.opt" @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_build_config.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/build_components.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/factory_config.opt" -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mlittle-endian -mthumb -Oz -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Profiles" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Application" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/controller/cc26xx/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/rom" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/target/_common" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/npi/stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/heapmgr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/dev_info" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/simple_profile" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/osal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/saddr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/sdata" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/rcosc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/devices/cc13x2_cc26x2" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/kernel/tirtos7/packages" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/posix/ticlang" -DDeviceFamily_CC26X2 -DFLASH_ROM_BUILD -DNVOCMP_NWSAMEITEM=1 -DHEAPMGR_CONFIG=0x80 -DHEAPMGR_SIZE=0x0 -gdwarf-3 -march=armv7e-m -MMD -MP -MF"NPI/npi_frame_hci.d_raw" -MT"NPI/npi_frame_hci.o" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg" @"syscfg/ti_build_config.opt" @"syscfg/ti_ble_app_config.opt" -o"NPI/npi_frame_hci.o" "C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src/npi_frame_hci.c"
Finished building: "C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src/npi_frame_hci.c"
Building file: "C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src/npi_tl.c"
"C:/ti/ccs1220/ccs/tools/compiler/ti-cgt-armllvm_2.1.2.LTS/bin/tiarmclang.exe" -c @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_ble_app_config.opt" @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_build_config.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/build_components.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/factory_config.opt" -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mlittle-endian -mthumb -Oz -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Profiles" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Application" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/controller/cc26xx/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/rom" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/target/_common" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/npi/stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/heapmgr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/dev_info" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/simple_profile" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/osal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/saddr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/sdata" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/rcosc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/devices/cc13x2_cc26x2" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/kernel/tirtos7/packages" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/posix/ticlang" -DDeviceFamily_CC26X2 -DFLASH_ROM_BUILD -DNVOCMP_NWSAMEITEM=1 -DHEAPMGR_CONFIG=0x80 -DHEAPMGR_SIZE=0x0 -gdwarf-3 -march=armv7e-m -MMD -MP -MF"NPI/npi_tl.d_raw" -MT"NPI/npi_tl.o" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg" @"syscfg/ti_build_config.opt" @"syscfg/ti_ble_app_config.opt" -o"NPI/npi_tl.o" "C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src/npi_tl.c"
Finished building: "C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src/npi_tl.c"
Building file: "C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/dev_info/cc26xx/devinfoservice.c"
"C:/ti/ccs1220/ccs/tools/compiler/ti-cgt-armllvm_2.1.2.LTS/bin/tiarmclang.exe" -c @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_ble_app_config.opt" @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_build_config.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/build_components.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/factory_config.opt" -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mlittle-endian -mthumb -Oz -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Profiles" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Application" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/controller/cc26xx/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/rom" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/target/_common" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/npi/stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/heapmgr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/dev_info" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/simple_profile" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/osal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/saddr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/sdata" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/rcosc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/devices/cc13x2_cc26x2" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/kernel/tirtos7/packages" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/posix/ticlang" -DDeviceFamily_CC26X2 -DFLASH_ROM_BUILD -DNVOCMP_NWSAMEITEM=1 -DHEAPMGR_CONFIG=0x80 -DHEAPMGR_SIZE=0x0 -gdwarf-3 -march=armv7e-m -MMD -MP -MF"Profiles/devinfoservice.d_raw" -MT"Profiles/devinfoservice.o" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg" @"syscfg/ti_build_config.opt" @"syscfg/ti_ble_app_config.opt" -o"Profiles/devinfoservice.o" "C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/dev_info/cc26xx/devinfoservice.c"
Finished building: "C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/dev_info/cc26xx/devinfoservice.c"
Building file: "C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/simple_profile/cc26xx/simple_gatt_profile.c"
"C:/ti/ccs1220/ccs/tools/compiler/ti-cgt-armllvm_2.1.2.LTS/bin/tiarmclang.exe" -c @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_ble_app_config.opt" @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_build_config.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/build_components.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/factory_config.opt" -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mlittle-endian -mthumb -Oz -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Profiles" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Application" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/controller/cc26xx/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/rom" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/target/_common" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/npi/stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/heapmgr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/dev_info" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/simple_profile" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/osal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/saddr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/sdata" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/rcosc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/devices/cc13x2_cc26x2" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/kernel/tirtos7/packages" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/posix/ticlang" -DDeviceFamily_CC26X2 -DFLASH_ROM_BUILD -DNVOCMP_NWSAMEITEM=1 -DHEAPMGR_CONFIG=0x80 -DHEAPMGR_SIZE=0x0 -gdwarf-3 -march=armv7e-m -MMD -MP -MF"Profiles/simple_gatt_profile.d_raw" -MT"Profiles/simple_gatt_profile.o" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg" @"syscfg/ti_build_config.opt" @"syscfg/ti_ble_app_config.opt" -o"Profiles/simple_gatt_profile.o" "C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/simple_profile/cc26xx/simple_gatt_profile.c"
Finished building: "C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/simple_profile/cc26xx/simple_gatt_profile.c"
Building file: "../Startup/main.c"
"C:/ti/ccs1220/ccs/tools/compiler/ti-cgt-armllvm_2.1.2.LTS/bin/tiarmclang.exe" -c @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_ble_app_config.opt" @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_build_config.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/build_components.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/factory_config.opt" -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mlittle-endian -mthumb -Oz -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Profiles" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Application" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/controller/cc26xx/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/rom" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/target/_common" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/npi/stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/heapmgr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/dev_info" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/simple_profile" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/osal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/saddr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/sdata" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/rcosc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/devices/cc13x2_cc26x2" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/kernel/tirtos7/packages" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/posix/ticlang" -DDeviceFamily_CC26X2 -DFLASH_ROM_BUILD -DNVOCMP_NWSAMEITEM=1 -DHEAPMGR_CONFIG=0x80 -DHEAPMGR_SIZE=0x0 -gdwarf-3 -march=armv7e-m -MMD -MP -MF"Startup/main.d_raw" -MT"Startup/main.o" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg" @"syscfg/ti_build_config.opt" @"syscfg/ti_ble_app_config.opt" -o"Startup/main.o" "../Startup/main.c"
Finished building: "../Startup/main.c"
Building file: "../Startup/osal_icall_ble.c"
"C:/ti/ccs1220/ccs/tools/compiler/ti-cgt-armllvm_2.1.2.LTS/bin/tiarmclang.exe" -c @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_ble_app_config.opt" @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_build_config.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/build_components.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/factory_config.opt" -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mlittle-endian -mthumb -Oz -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Profiles" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Application" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/controller/cc26xx/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/rom" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/target/_common" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/npi/stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/heapmgr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/dev_info" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/simple_profile" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/osal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/saddr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/sdata" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/rcosc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/devices/cc13x2_cc26x2" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/kernel/tirtos7/packages" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/posix/ticlang" -DDeviceFamily_CC26X2 -DFLASH_ROM_BUILD -DNVOCMP_NWSAMEITEM=1 -DHEAPMGR_CONFIG=0x80 -DHEAPMGR_SIZE=0x0 -gdwarf-3 -march=armv7e-m -MMD -MP -MF"Startup/osal_icall_ble.d_raw" -MT"Startup/osal_icall_ble.o" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg" @"syscfg/ti_build_config.opt" @"syscfg/ti_ble_app_config.opt" -o"Startup/osal_icall_ble.o" "../Startup/osal_icall_ble.c"
Finished building: "../Startup/osal_icall_ble.c"
Building file: "C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src/icall_cc2650.c"
"C:/ti/ccs1220/ccs/tools/compiler/ti-cgt-armllvm_2.1.2.LTS/bin/tiarmclang.exe" -c @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_ble_app_config.opt" @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_build_config.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/build_components.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/factory_config.opt" -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mlittle-endian -mthumb -Oz -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Profiles" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Application" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/controller/cc26xx/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/rom" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/target/_common" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/npi/stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/heapmgr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/dev_info" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/simple_profile" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/osal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/saddr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/sdata" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/rcosc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/devices/cc13x2_cc26x2" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/kernel/tirtos7/packages" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/posix/ticlang" -DDeviceFamily_CC26X2 -DFLASH_ROM_BUILD -DNVOCMP_NWSAMEITEM=1 -DHEAPMGR_CONFIG=0x80 -DHEAPMGR_SIZE=0x0 -gdwarf-3 -march=armv7e-m -MMD -MP -MF"iCall/icall_cc2650.d_raw" -MT"iCall/icall_cc2650.o" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg" @"syscfg/ti_build_config.opt" @"syscfg/ti_ble_app_config.opt" -o"iCall/icall_cc2650.o" "C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src/icall_cc2650.c"
Finished building: "C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src/icall_cc2650.c"
Building file: "C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src/icall_user_config.c"
"C:/ti/ccs1220/ccs/tools/compiler/ti-cgt-armllvm_2.1.2.LTS/bin/tiarmclang.exe" -c @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_ble_app_config.opt" @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_build_config.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/build_components.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/factory_config.opt" -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mlittle-endian -mthumb -Oz -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Profiles" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Application" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/controller/cc26xx/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/rom" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/target/_common" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/npi/stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/heapmgr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/dev_info" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/simple_profile" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/osal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/saddr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/sdata" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/rcosc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/devices/cc13x2_cc26x2" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/kernel/tirtos7/packages" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/posix/ticlang" -DDeviceFamily_CC26X2 -DFLASH_ROM_BUILD -DNVOCMP_NWSAMEITEM=1 -DHEAPMGR_CONFIG=0x80 -DHEAPMGR_SIZE=0x0 -gdwarf-3 -march=armv7e-m -MMD -MP -MF"iCall/icall_user_config.d_raw" -MT"iCall/icall_user_config.o" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg" @"syscfg/ti_build_config.opt" @"syscfg/ti_ble_app_config.opt" -o"iCall/icall_user_config.o" "C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src/icall_user_config.c"
Finished building: "C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src/icall_user_config.c"
Building file: "C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/app/ble_user_config.c"
"C:/ti/ccs1220/ccs/tools/compiler/ti-cgt-armllvm_2.1.2.LTS/bin/tiarmclang.exe" -c @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_ble_app_config.opt" @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_build_config.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/build_components.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/factory_config.opt" -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mlittle-endian -mthumb -Oz -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Profiles" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Application" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/controller/cc26xx/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/rom" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/target/_common" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/npi/stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/heapmgr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/dev_info" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/simple_profile" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/osal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/saddr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/sdata" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/rcosc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/devices/cc13x2_cc26x2" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/kernel/tirtos7/packages" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/posix/ticlang" -DDeviceFamily_CC26X2 -DFLASH_ROM_BUILD -DNVOCMP_NWSAMEITEM=1 -DHEAPMGR_CONFIG=0x80 -DHEAPMGR_SIZE=0x0 -gdwarf-3 -march=armv7e-m -MMD -MP -MF"iCallBLE/ble_user_config.d_raw" -MT"iCallBLE/ble_user_config.o" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg" @"syscfg/ti_build_config.opt" @"syscfg/ti_ble_app_config.opt" -o"iCallBLE/ble_user_config.o" "C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/app/ble_user_config.c"
Finished building: "C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/app/ble_user_config.c"
Building file: "C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/stack/ble_user_config_stack.c"
"C:/ti/ccs1220/ccs/tools/compiler/ti-cgt-armllvm_2.1.2.LTS/bin/tiarmclang.exe" -c @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_ble_app_config.opt" @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_build_config.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/build_components.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/factory_config.opt" -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mlittle-endian -mthumb -Oz -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Profiles" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Application" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/controller/cc26xx/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/rom" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/target/_common" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/npi/stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/heapmgr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/dev_info" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/simple_profile" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/osal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/saddr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/sdata" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/rcosc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/devices/cc13x2_cc26x2" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/kernel/tirtos7/packages" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/posix/ticlang" -DDeviceFamily_CC26X2 -DFLASH_ROM_BUILD -DNVOCMP_NWSAMEITEM=1 -DHEAPMGR_CONFIG=0x80 -DHEAPMGR_SIZE=0x0 -gdwarf-3 -march=armv7e-m -MMD -MP -MF"iCallBLE/ble_user_config_stack.d_raw" -MT"iCallBLE/ble_user_config_stack.o" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg" @"syscfg/ti_build_config.opt" @"syscfg/ti_ble_app_config.opt" -o"iCallBLE/ble_user_config_stack.o" "C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/stack/ble_user_config_stack.c"
Finished building: "C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/stack/ble_user_config_stack.c"
Building file: "C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/app/icall_api_lite.c"
Invoking: Arm Compiler
"C:/ti/ccs1220/ccs/tools/compiler/ti-cgt-armllvm_2.1.2.LTS/bin/tiarmclang.exe" -c @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_ble_app_config.opt" @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_build_config.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/build_components.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/factory_config.opt" -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mlittle-endian -mthumb -Oz -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Profiles" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Application" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/controller/cc26xx/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/rom" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/target/_common" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/npi/stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/heapmgr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/dev_info" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/simple_profile" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/osal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/saddr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/sdata" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/rcosc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/devices/cc13x2_cc26x2" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/kernel/tirtos7/packages" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/posix/ticlang" -DDeviceFamily_CC26X2 -DFLASH_ROM_BUILD -DNVOCMP_NWSAMEITEM=1 -DHEAPMGR_CONFIG=0x80 -DHEAPMGR_SIZE=0x0 -gdwarf-3 -march=armv7e-m -MMD -MP -MF"iCallBLE/icall_api_lite.d_raw" -MT"iCallBLE/icall_api_lite.o" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg" @"syscfg/ti_build_config.opt" @"syscfg/ti_ble_app_config.opt" -o"iCallBLE/icall_api_lite.o" "C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/app/icall_api_lite.c"
Finished building: "C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/app/icall_api_lite.c"
Building file: "C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/rom/agama_r1/rom_init.c"
"C:/ti/ccs1220/ccs/tools/compiler/ti-cgt-armllvm_2.1.2.LTS/bin/tiarmclang.exe" -c @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_ble_app_config.opt" @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_build_config.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/build_components.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/factory_config.opt" -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mlittle-endian -mthumb -Oz -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Profiles" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Application" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/controller/cc26xx/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/rom" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/target/_common" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/npi/stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/heapmgr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/dev_info" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/simple_profile" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/osal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/saddr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/sdata" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/rcosc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/devices/cc13x2_cc26x2" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/kernel/tirtos7/packages" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/posix/ticlang" -DDeviceFamily_CC26X2 -DFLASH_ROM_BUILD -DNVOCMP_NWSAMEITEM=1 -DHEAPMGR_CONFIG=0x80 -DHEAPMGR_SIZE=0x0 -gdwarf-3 -march=armv7e-m -MMD -MP -MF"Startup/rom_init.d_raw" -MT"Startup/rom_init.o" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg" @"syscfg/ti_build_config.opt" @"syscfg/ti_ble_app_config.opt" -o"Startup/rom_init.o" "C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/rom/agama_r1/rom_init.c"
Finished building: "C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/rom/agama_r1/rom_init.c"
Building file: "C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/app/icall_hci_tl.c"
"C:/ti/ccs1220/ccs/tools/compiler/ti-cgt-armllvm_2.1.2.LTS/bin/tiarmclang.exe" -c @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_ble_app_config.opt" @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_build_config.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/build_components.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/factory_config.opt" -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mlittle-endian -mthumb -Oz -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Profiles" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Application" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/controller/cc26xx/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/rom" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/target/_common" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/npi/stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/heapmgr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/dev_info" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/simple_profile" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/osal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/saddr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/sdata" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/rcosc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/devices/cc13x2_cc26x2" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/kernel/tirtos7/packages" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/posix/ticlang" -DDeviceFamily_CC26X2 -DFLASH_ROM_BUILD -DNVOCMP_NWSAMEITEM=1 -DHEAPMGR_CONFIG=0x80 -DHEAPMGR_SIZE=0x0 -gdwarf-3 -march=armv7e-m -MMD -MP -MF"iCallBLE/icall_hci_tl.d_raw" -MT"iCallBLE/icall_hci_tl.o" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg" @"syscfg/ti_build_config.opt" @"syscfg/ti_ble_app_config.opt" -o"iCallBLE/icall_hci_tl.o" "C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/app/icall_hci_tl.c"
Finished building: "C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/app/icall_hci_tl.c"
Building file: "C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src/icall.c"
"C:/ti/ccs1220/ccs/tools/compiler/ti-cgt-armllvm_2.1.2.LTS/bin/tiarmclang.exe" -c @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_ble_app_config.opt" @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_build_config.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/build_components.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/factory_config.opt" -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mlittle-endian -mthumb -Oz -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Profiles" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Application" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/controller/cc26xx/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/rom" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/target/_common" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/npi/stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/heapmgr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/dev_info" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/simple_profile" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/osal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/saddr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/sdata" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/rcosc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/devices/cc13x2_cc26x2" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/kernel/tirtos7/packages" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/posix/ticlang" -DDeviceFamily_CC26X2 -DFLASH_ROM_BUILD -DNVOCMP_NWSAMEITEM=1 -DHEAPMGR_CONFIG=0x80 -DHEAPMGR_SIZE=0x0 -gdwarf-3 -march=armv7e-m -MMD -MP -MF"iCall/icall.d_raw" -MT"iCall/icall.o" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg" @"syscfg/ti_build_config.opt" @"syscfg/ti_ble_app_config.opt" -o"iCall/icall.o" "C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src/icall.c"
Finished building: "C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src/icall.c"
Building file: "syscfg/ti_sysbios_config.c"
"C:/ti/ccs1220/ccs/tools/compiler/ti-cgt-armllvm_2.1.2.LTS/bin/tiarmclang.exe" -c @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_ble_app_config.opt" @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_build_config.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/build_components.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/factory_config.opt" -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mlittle-endian -mthumb -Oz -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/MHLib" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Profiles" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Application" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/controller/cc26xx/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/rom" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/target/_common" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/npi/stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/hal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/heapmgr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/dev_info" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/profiles/simple_profile" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/osal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/saddr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/services/src/sdata" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/icall/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/common/cc26xx/rcosc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/npi/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/devices/cc13x2_cc26x2" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/kernel/tirtos7/packages" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/posix/ticlang" -DDeviceFamily_CC26X2 -DFLASH_ROM_BUILD -DNVOCMP_NWSAMEITEM=1 -DHEAPMGR_CONFIG=0x80 -DHEAPMGR_SIZE=0x0 -gdwarf-3 -march=armv7e-m -MMD -MP -MF"syscfg/ti_sysbios_config.d_raw" -MT"syscfg/ti_sysbios_config.o" -I"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg" @"syscfg/ti_build_config.opt" @"syscfg/ti_ble_app_config.opt" -o"syscfg/ti_sysbios_config.o" "syscfg/ti_sysbios_config.c"
Finished building: "syscfg/ti_sysbios_config.c"
Building target: "simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang.out"
Invoking: Arm Linker
"C:/ti/ccs1220/ccs/tools/compiler/ti-cgt-armllvm_2.1.2.LTS/bin/tiarmclang.exe" @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_ble_app_config.opt" @"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg/ti_build_config.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/build_components.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/ble5stack/config/factory_config.opt" -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mlittle-endian -mthumb -Oz -DDeviceFamily_CC26X2 -DFLASH_ROM_BUILD -DNVOCMP_NWSAMEITEM=1 -DHEAPMGR_CONFIG=0x80 -DHEAPMGR_SIZE=0x0 -gdwarf-3 -march=armv7e-m -Wl,-m"simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang.map" -Wl,-i"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source" -Wl,-i"C:/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/kernel/tirtos7/packages" -Wl,-i"C:/CC2652RSIP_PA/simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang/Release/syscfg" -Wl,-i"C:/ti/ccs1220/ccs/tools/compiler/ti-cgt-armllvm_2.1.2.LTS/lib" -Wl,--define=FLASH_ROM_BUILD=2 -Wl,--diag_suppress=16002-D -Wl,--diag_suppress=10247-D -Wl,--diag_suppress=10325-D -Wl,--diag_suppress=10229-D -Wl,--diag_suppress=16032-D -Wl,--diag_wrap=off -Wl,--display_error_number -Wl,--warn_sections -Wl,--xml_link_info="simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang_linkInfo.xml" -Wl,--rom_model -o "simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang.out" "./syscfg/ti_ble_config.o" "./syscfg/ti_devices_config.o" "./syscfg/ti_radio_config.o" "./syscfg/ti_drivers_config.o" "./syscfg/ti_sysbios_config.o" "./Application/board_key.o" "./Application/rcosc_calibration.o" "./Application/simple_peripheral.o" "./Application/simple_peripheral_menu.o" "./Application/two_btn_menu.o" "./Application/util.o" "./Drivers/NV/crc.o" "./Drivers/NV/nvocmp.o" "./MHLib/SP_Dev_Test.o" "./MHLib/UserDataIn.o" "./MHLib/UserDataOut.o" "./MHLib/app_oem.o" "./MHLib/app_oem_help.o" "./MHLib/assert.o" "./MHLib/flash_upgrade.o" "./MHLib/mhFactory.o" "./MHLib/mhLed.o" "./MHLib/mhLib_adc.o" "./MHLib/mhLib_buf.o" "./MHLib/mhLib_crc.o" "./MHLib/mhLib_dac.o" "./MHLib/mhLib_err.o" "./MHLib/mhLib_mem.o" "./MHLib/mhLib_tab.o" "./MHLib/mhLib_user.o" "./MHLib/mhMHX_saveregs.o" "./MHLib/mhParTest.o" "./MHLib/mhSaveregs.o" "./MHLib/mhTimer.o" "./MHLib/mhtasks.o" "./MHLib/mhuart.o" "./NPI/npi_frame_hci.o" "./NPI/npi_rxbuf.o" "./NPI/npi_task.o" "./NPI/npi_tl.o" "./NPI/npi_tl_uart.o" "./Profiles/devinfoservice.o" "./Profiles/simple_gatt_profile.o" "./Startup/main.o" "./Startup/osal_icall_ble.o" "./Startup/rom_init.o" "./iCall/icall.o" "./iCall/icall_cc2650.o" "./iCall/icall_user_config.o" "./iCallBLE/ble_user_config.o" "./iCallBLE/ble_user_config_stack.o" "./iCallBLE/icall_api_lite.o" "./iCallBLE/icall_hci_tl.o" "../cc13x2_cc26x2_app_tirtos7.cmd" -Wl,-lti_utils_build_linker.cmd.genlibs -Wl,-l"ti/devices/cc13x2_cc26x2/driverlib/bin/ticlang/driverlib.lib" -Wl,-llibc.a
gmake[1]: *** No rule to make target 'input-file.error', needed by 'output-file.error'.
Finished building target: "simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang.out"
"C:/ti/ccs1220/ccs/utils/tiobj2bin/tiobj2bin" "simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang.out" "simple_peripheral_LP_CC2652PSIP_tirtos7_ticlang.bin" "C:/ti/ccs1220/ccs/tools/compiler/ti-cgt-armllvm_2.1.2.LTS/bin/tiarmofd" "C:/ti/ccs1220/ccs/tools/compiler/ti-cgt-armllvm_2.1.2.LTS/bin/tiarmhex" "C:/ti/ccs1220/ccs/utils/tiobj2bin/mkhex4bin"
makefile:207: recipe for target 'all' failed
gmake[1]: Target 'secondary-outputs' not remade because of errors.
gmake: *** [all] Error 2
**** Build Finished ****
2) Suggestion #2
3) Suggestion #3
I don't have any problems with my other projects. It has many changes from the original SDK project. I will try to find the last working project and play with it.
Alex
Hi Alex,
If you have the last working project, then lets try to see what change triggered this behavior. Once we have that change in hand we can figure out how to eliminate it.
Jan
Hi Jan,
I experimented with file conversions on the Post_build steps of Properties-CCSBuild -Steps
Even all file conversion steps were moved to the special Cmd-file and this window of Post_build steps was empty, files .cproject and makefile had some remains. Most probably they caused the problem.
Alex
Hi Alex,
Does this mean you were able to resolve the issue by modifying the build steps?
Jan
Hi Jan,
No, cleaning the build steps doesn't clean the file makefile (it still have some remains that cause problems). I took last good working project, made changes to functionality (without adding build steps). This resolved my problems.
Alex
Hi Alex,
Glad to hear you were able to resolve the issue. Its possible some project setting or building step got corrupted along the way and that may be the reason this happened.
Jan
