Hi
My name is Kevin Hwang in South Korea.
Currently, I am developing a sensor monitoring system (sensor nodes and gateway) using the CC1312R1.
The frequency band we intend to use is 940.1MHz to 946.3MHz.
Using the LAUNCHXL-CC1312R1 Evaluation Board and SMARTRF_STUDIO 7, I measured the output power with a spectrum analyzer,
and even when setting it to 14dBm, it only reaches about 11dBm.
Do you have any information on the RF Matching Value to support the 940MHz band?
If not, could you explain the RF Matching method?
Thank you.
