CC1310: cc1310 gets locked while using IQ dump patch
Part Number: CC1310
Other Parts Discussed in Thread: CODECOMPOSER
Hi!
I tried the IQ raw blind read as instructed in TI's doc:
https://www.ti.com/lit/an/swra571b/swra571b.pdf?ts=1719346980039
On my CC1310 LaunchPad.   After several successful runs the device suddenly locked the debugging and I was not able to reflash it anymore / read from the flash using Flash Programmer 2 / CodeComposer.
I tried to force wipe the entire flash using Flash Programmer 2 as people on the forums said to do, but it didn't help.
It happened after several flashing+debugging sessions, I swapped the LaunchPad board with a new one and again after several debugging sessions it happened again.
Why does the device keep getting locked? What can cause this? I don't have flash lock/debug lock in my CCFG (I use the default in CodeComposer, the same project without the IQ patch worked for months and only after adding the IQ patch it happened)
Thanks!
