Hi all,
I'm using TI15.4 Stack FH mode with broadcast. I only need broadcast for some nodes of the network.
However, FH broadcast seems to be a global setting on the translator, either it's ON for everyone, or OFF for everyone. This makes the nodes that don't need it, to still wake up and waste power.
I understand this is the way the stack was designed, but is there a way/fix to keep the broadcast disabled only on some nodes? Can I forbid the sensor nodes from waking up for broadcast intervals for example on the sensor code? Surely there must be a way, it doesn't seem like something that farfetched.
I would really appreciate if someone could help me achieve this functionality.
Thank you
