CC1125: RSSI calculation with LNA gain
Part Number: CC1125
Dear Team,
I'm little bit confuse to calculate the RSSI
Signal strength at antenna is -110db and its amplified by LNA with a gain of 20db
Now what should be RSSI ?
-110 + 20 = 90 or -110
Does LNA improve the RF sensitivity ?
I'm using 19.2kbps air data rate, as per cc1125 data sheet receiving sensitivity should be -110 db(approx)
In my test set up if i'm giving -110 signal to the antenna port, cc1125 receive the signal but if signal desrease by 1 db (-111db) its not receiving any data.
Now the question is what's the receiving sensitivity of my board, -110db or -110 +20(LNA gain) =90db
