CC1311R3: CC1311R3
Part Number: CC1311R3
What is the correct way to get RSSi value of the last received message in CC1311?
I found API function <RF_cmdRxHS.pOutput.lastRssi> but looks that is valid for CC1312 only.
Thank you,
Alex Katsovich
  • Hi Alex,
    Which mode and PHY are you using the radio with?
    The RF_cmdRxHS command is meant to be used with the High Speed mode.
    If you're using regular rf_prop mode, you can use an advanced rx command to get the rssi appended. You can see an example implementation of this in the rfPacketErrorRate example, rx.c.
    Cheers,
    Marie H
