Other Parts Discussed in Thread: CC110L, CC1311R3
Hello, I am trying to figure out if I can use the RSSI level from CC113L to read the power level of a sine wave, sort of like a spectrum analyzer.
G
You can convert the RSSI reading to an absolute power level, please see:
SWRA114 (RSSI Interpretation and Timing): https://www.ti.com/lit/swra114
I imagine you would then set the CC110L to run in a continuous RX test whilst also performing a frequency sweep.
You cannot extract the raw IQ data from the CC110L, however. That is possible using a patch for the CC131x and CC135x devices: SWRA571 (CC13xx IQ Samples): https://www.ti.com/lit/swra571
Zack
You would need to look at a 3rd party vendor as we do not have any eval boards available currently (it is not decided what our approach for eval boards for those devices are going forward is yet). You can use our Third Party Wireless Module Search Tool: https://www.ti.com/tool/3P-WIRELESS-MODULES
It is still an active part, so it can be used for new designs.
The alternative would probably be the CC1311R3 SoC.
Regard,
Zack
