I’m working on a project using the CC1310 Sub-1GHz with NoRTOS, and I’m running into an issue where the firmware doesn’t seem to be saved after a power cycle. When I turn the power off and back on, the firmware appears to be lost.
I’m using [Code composer studio(ccs) IDE / Flash Programmer 2] to flash the firmware. The process completes without any errors, but after powering off and on, the firmware doesn’t persist.
Could you provide some guidance on why the firmware might not be saved after a power cycle in NoRTOS? Any suggestions or settings I should double-check would be really helpful.
