There are some significant delays in establishing connections with freq. hopping in comparison to Non-Beacon mode. What settings can I change to make this connection faster when adding a node to the network and when either side loses power (causing orphan) or after a disassociate from the sensor?
Kevin
Hi Kevin,
A customer asked the same question some time ago, and one of our colleague gave a detailed answer as to what parameters to change: e2e.ti.com/.../sub- 1-ghz/f/sub-1-ghz-forum/1229028/cc1310-sensor-node-in-ti-15-4-stack-which-of-the-3-supported-modes-beacon-non-beacon-and-frequency-hopping-has-the-shortest-network-joining-rejoining-time/4644110#4644110
Let me know if you need more details.
Arthur
