LP-CC1352P7: The example provided in section 3.8 of the TI RTOS documentation for implementing HWi, SWi, Task threads does not build.
Part Number: LP-CC1352P7
Other Parts Discussed in Thread: SYSBIOS, CC1352P7, SYSCONFIG
Reading through the document for TI-RTOS kernel, the user guide, I decided to implement of the example because it demonstrates how the different thread types work and how we can implement them in a standard way.
Particularly, on the page 101 of the TI-RTOS kernel user guid document, section 3.8 we have an example that begins as:
#include <xdc/std.h>
#include <xdc/runtime/System.h>
#include <xdc/runtime/Error.h>
#include <ti/sysbios/BIOS.h>
#include <ti/sysbios/hal/Timer.h>
#include <ti/sysbios/knl/Semaphore.h>
#include <ti/sysbios/knl/Swi.h>
#include <ti/sysbios/knl/Task.h>
#include <ti/sysbios/knl/Queue.h>
#include <xdc/cfg/global.h>
However, when I try to build I get:
fatal error: 'xdc/cfg/global.h' file not found
NOTE: I first created an empty example from the TI_RTOS driver example directory, and removed everything and added the above include directives.
Also, I know that I am supposed to have a configuration script somewhere in my project, but I do not know how to add that.
The document specifically says to create the configuration script as (Partly mentioned):
var Defaults = xdc.useModule('xdc.runtime.Defaults');
var Diags = xdc.useModule('xdc.runtime.Diags');
var Error = xdc.useModule('xdc.runtime.Error');
var Log = xdc.useModule('xdc.runtime.Log');
var LoggerBuf = xdc.useModule('xdc.runtime.LoggerBuf');
var Main = xdc.useModule('xdc.runtime.Main');
var Memory = xdc.useModule('xdc.runtime.Memory')
var SysMin = xdc.useModule('xdc.runtime.SysMin');
var System = xdc.useModule('xdc.runtime.System');
var Text = xdc.useModule('xdc.runtime.Text');
var Timer = xdc.useModule('ti.sysbios.hal.Timer');
var HeapMem = xdc.useModule('ti.sysbios.heaps.HeapMem');
Program.argSize = 0x0;
System.maxAtexitHandlers = 4;
BIOS.heapSize = 0x2000;
/* System stack size (used by ISRs and Swis) */
Program.stack = 0x1000;
/* Circular buffer size for System_printf() */ SysMin.bufSize = 0x400;
I am trying to build this example using CSS on a MacBook.
Could you please tell me what I should do  to make this example build?
Thanks.
