Other Parts Discussed in Thread: LPSTK-CC1352R, , CC1352P7
Hello! I would like to transmit sensor data (temperature, humidity, and illuminance) from the LPSTK-CC1352R Sensortag to the LAUNCHXL-CC1352R1 Launchpad using 6LoWPAN for connectivity. The Launchpad will then be connected to a Raspberry Pi, which will forward the data to the cloud using MQTT. However, using the TI-15.4 Linux Gateway is not an option for this project. Could you recommend a project available in the Resource Explorer that can help achieve this setup?
