Because of the holidays, TI E2E™ design support forum responses will be delayed from Dec. 25 through Jan. 2. Thank you for your patience.
LP-EM-CC1354P10: CCFG on CC1354P10
Part Number: LP-EM-CC1354P10
Champs:
   This PDF page 17 mentioned this: https://www.ti.com/lit/an/swra466e/swra466e.pdf
    ==>  The designer must make sure that the bootloader is enabled in the CCA, CCFG of the flash image to be programmed
    May you guide us where to modify the code for enable the CCA/CCFG for Downloader?
BR Rio
