Part Number: CC1312PSIP
I am developing an OTA update solution based on the TI OAD for TI15.4. I want to minimise the OTA payload size so intend to make use of TOAD.
Should I also use a separate binary image for the TI15.4 stack and my application so that OTA updates can be reduced in size given that the application will most likely need updating more regularly than the stack, or will TOAD actually take care of this and only update the application changes?
In other words, is there a need to use separate stack and application images if using TOAD?
Thanks for your help,
Andy
