LP-CC1311P3: LP-CC1311P3
Part Number: LP-CC1311P3
During standard css debugging sessions, on next session I received
in SmartRF
and in smartRF Flashprogrammer 2
looked in manual but did not found that case.
Marek
  • Hi Marek,
    Did this fail happen after CCS requested to update the FW on the debug probe (XDS110)? If so, the debug probe itself may not have functioning SW.
    If not I would try a mass erase of the CC1311. Unfortunately, Flash Programmer doesn't support this device. Please use Uniflash instead.
    Cheers,
    Marie H
  • Hi Marie,
    It did not happen during fwu of debug probe.
    Can you advice how erase/unlock target with Uniflash please.
    Marek
  • Hi Marek,
    In UniFlash, after selecting the correct device you can go to the Settings & Utilities tab, then under Manual Erase select Erase entire flash (You must reconnect to the target afterwards) and press Erase Entire Flash:
    Zack
