CC1352P: TX current consumption
Part Number: CC1352P
Hi There,
we are trying to test the TX current consumption under 20dBm and found the current is different on different channel.
do you see the same results? what's the reason? Matching flatness? But, we tested the 125k and 1M PHY, it has different trend.
Test environment, CC1352P-2 LP with Energy trace + Peripheral.
I turn the RF path to SMA and add a loader.
125K coded PHY.
BR. Albin
