Other Parts Discussed in Thread: CC1354R10
I would like to know if there is any way to mantain a variable after the instruction "SysCtrlSystemReset()". I would like not to use the NVS...
Thank you,
Sandra
Hi Sandra,
Unfortunately, on CC1352R, the SRAM is set to 0 at boot. On this device you will need to use NVS.
One alternative would be to switch to CC1354R10. On this you can keep SRAM through a shutdown. There is also SRAM Parity.
Cheers,
Marie H
