Debugging and Programming using swra124
Hi Champs,
Has anyone put together any example code to show how to use the API's in swra124.pdf?
Thanks in advance,
Chuck
  • Hello Chuck,
    I'm trying to use what's on SWRA124 but I found some information is not complete. The information I think missing is the AC timing  information on interface. I see the diagram for the bit timing. But where is the data specifications for byte level timing?  I'm stuck on the response receive on the specifications, 2.4.7, 2.4.8, and 2.4.9. Do you know where I can find the info?
    Takashi
