Is it possible to run Mesh Network on eZ430-RF2500
Other Parts Discussed in Thread: CC2500, SIMPLICITI, MSP430F2274
Hello...I'm an Engineer graduand student from Modena (Italy).
My project dealer gave me some MSP430 F2274 with CC2500 RF transceiver and he told me to implement a mesh network on it. I read some forum about this issue and right now I just know that it can't be done.
But I didn't understand exactly why I can't do it.
-  Why can't simpliciTI  support mesh networking?
-  Why can't MSP430 F2274 support mesh networking as well? Is it a memory problem? why?
I'd like to know some detail about it......
please help me.......
Thanks a lot.
    The SimpliciTI protocol stack was not designed to deal with mesh networking.  This was a design decision on the protocol.  It will support a Star Network with an Access Point as the hub, as well as Reach Extenders, but fundamentally, it is a star network.
    If a mesh network is required, ZigBee will be needed.  There is an equivalent kit called the eZ430-RF2480 that implements a MSP430F2274+CC2480 (ZigBee Processor).
    Mesh networking requires ZigBee, which in turn requires a higher memory MSP430 device.
  • Hi Emmanuel,
    In its basic form, mesh networking requires a routing table that is aware of more than the device it is part of.
    For example, a router in Zigbee is aware of many child devices that it routes for and is able to route messages to other devices that have child devices.
    SimpliciTI natively does not support this routing outside it's own device, which lends itself a really good solution for Star or point to point networks.
  • Hi again....
    I'm thinking to try to connect two Access Point..... I want them to speak each other and to behave as AP and ED at the same time....
    Is it possible? some idea?
  • A SimpliciTI network can only have a single AP; that's part of the specification. If you want mesh networking, you need to look at ZigBee.
    Scott
  • I don't want a complicated mesh network, I just want two AP to behave as ED/AP at the same time......
  • I'll refer you to the SImpliciTI section here (http://tiexpressdsp.com/index.php?title=Low_Power_RF_Solutions#Workshop_Contents ). It if possible to have peer to peer links from an AP, but not multiple APs in a single SimpliciTI network. Maybe this will help.
    Scott
