I am using CC1101 in my star network design wherein one main powered hub communicates with battery powered nodes.. I wanted to adjust the transmit power of the nodes according to the quality of the received signal of each node in order to save the battery power of the node.
What is the best out of RSSI and LQI to achieve my goal? or can i use combination? If the combination is better, what is the relationship or composition of those two parameters to determine the most healthiest link?
Ushan Karunathilaka
