Working code folder, after copying to the same root folder, makes original and copied both the code bases full of fatal errors. SimpliciTI 1.2.x
Other Parts Discussed in Thread: SIMPLICITI
A working code; I just copied and pasted the code folder to the same root folder and then when I make it, it gives following error:
Both original and copied code. Very strange.
Building configuration: Ap_as_Data_Hub - CC1110-Access Point
Updating build tree...
bsp.c
Fatal Error[Su011]: More than one source file specified:
10 (at line 54 of "E:\Code_SimpliciTI\Projects\Examples\SRF04 - AP - CC1110\AP_as_Data_Hub\IAR\
Configuration\smpl_nwk_config.dat")
E:\Code_SimpliciTI\Components\bsp\bsp.c
Error while running C/C++ Compiler
main_AP_Async_Listen_autoack.c
E:\Code_SimpliciTI\Projects\Examples\Applications\main_AP_Async_Listen_autoack.c
mrfi.c
E:\Code_SimpliciTI\Components\mrfi\mrfi.c
nwk.c
E:\Code_SimpliciTI\Components\simpliciti\nwk\nwk.c
nwk_QMgmt.c
E:\Code_SimpliciTI\Components\simpliciti\nwk\nwk_QMgmt.c
nwk_api.c
E:\Code_SimpliciTI\Components\simpliciti\nwk\nwk_api.c
nwk_frame.c
E:\Code_SimpliciTI\Components\simpliciti\nwk\nwk_frame.c
nwk_freq.c
E:\Code_SimpliciTI\Components\simpliciti\nwk_applications\nwk_freq.c
nwk_globals.c
E:\Code_SimpliciTI\Components\simpliciti\nwk\nwk_globals.c
nwk_ioctl.c
E:\Code_SimpliciTI\Components\simpliciti\nwk_applications\nwk_ioctl.c
nwk_join.c
E:\Code_SimpliciTI\Components\simpliciti\nwk_applications\nwk_join.c
nwk_link.c
E:\Code_SimpliciTI\Components\simpliciti\nwk_applications\nwk_link.c
nwk_mgmt.c
E:\Code_SimpliciTI\Components\simpliciti\nwk_applications\nwk_mgmt.c
nwk_ping.c
E:\Code_SimpliciTI\Components\simpliciti\nwk_applications\nwk_ping.c
nwk_pll.c
E:\Code_SimpliciTI\Components\simpliciti\nwk_applications\nwk_pll.c
nwk_security.c
E:\Code_SimpliciTI\Components\simpliciti\nwk_applications\nwk_security.c
uart.c
E:\Code_SimpliciTI\Components\bsp\drivers\code\uart.c
uart_intfc.c
E:\Code_SimpliciTI\Components\bsp\drivers\code\uart_intfc.c
Total number of errors: 18
Total number of warnings: 0
IAR version info
IAR Assembler for 8051
7.60.1 (7.60.1.40026)
C:\Program Files\IAR Systems\Embedded Workbench 5.4\8051\bin\a8051.exe
08-Jun-2010 11:23:30, 892928 bytes
IAR C/C++ Compiler for 8051
C:\Program Files\IAR Systems\Embedded Workbench 5.4\8051\bin\icc8051.exe
08-Jun-2010 11:30:32, 13844480 bytes
IAR Library Builder
4.61T (4.61.20.0)
C:\Program Files\IAR Systems\Embedded Workbench 5.4\8051\bin\xar.exe
02-Feb-2010 17:59:26, 163840 bytes
IAR XLIB
4.61T/386 (4.61.20.0)
C:\Program Files\IAR Systems\Embedded Workbench 5.4\8051\bin\xlib.exe
02-Feb-2010 18:00:12, 532480 bytes
IAR XLINK
4.61T (4.61.20.0)
C:\Program Files\IAR Systems\Embedded Workbench 5.4\8051\bin\xlink.exe
02-Feb-2010 18:01:32, 2338816 bytes
Uninstall Program for FTDI Drivers
2.1.0.1 (2.1.0.1)
C:\Program Files\IAR Systems\Embedded Workbench 5.4\8051\drivers\Analog Devices\ADE7169Fxx\FTDIUNIN.EXE
01-Jun-2010 09:18:58, 414208 bytes
Setup Launcher
2.6.4 (10.50.0.125)
C:\Program Files\IAR Systems\Embedded Workbench 5.4\8051\drivers\Infineon\DAS_v264_setup.exe
01-Jun-2010 09:19:00, 6236517 bytes
show_devices MFC Application
1, 0, 0, 1 (1.0.0.1)
C:\Program Files\IAR Systems\Embedded Workbench 5.4\8051\drivers\Infineon\USCALE Apps\Show_Devices.exe
01-Jun-2010 09:18:58, 217088 bytes
C:\Program Files\IAR Systems\Embedded Workbench 5.4\8051\drivers\Infineon\USCALE Apps\USCALE.exe
01-Jun-2010 09:18:58, 487424 bytes
USCALECtrl Application
1, 1, 0, 0 (1.1.0.0)
C:\Program Files\IAR Systems\Embedded Workbench 5.4\8051\drivers\Infineon\USCALE Apps\USCALECtrl.exe
01-Jun-2010 09:18:58, 2449511 bytes
ToolStickTerminal
1.1 (1.1.0.0)
C:\Program Files\IAR Systems\Embedded Workbench 5.4\8051\drivers\Silabs\applications\Toolstick Terminal\ToolStickTerminal.exe
01-Jun-2010 09:19:02, 61440 bytes
F32x_BulkFileTransfer MFC Application
C:\Program Files\IAR Systems\Embedded Workbench 5.4\8051\drivers\Silabs\applications\USB Bulk\F32x_BulkFileTransfer.exe
01-Jun-2010 09:19:02, 40960 bytes
USBTest Application
1, 0, 0, 0 (1.0.0.0)
C:\Program Files\IAR Systems\Embedded Workbench 5.4\8051\drivers\Silabs\applications\USB HID\USBTest.exe
01-Jun-2010 09:19:04, 1486848 bytes
USBTest Application
C:\Program Files\IAR Systems\Embedded Workbench 5.4\8051\drivers\Silabs\applications\USB Interrupt\USBTest.exe
01-Jun-2010 09:19:02, 225280 bytes
Driver Installation Utility
2.1 (2.1.0.0)
C:\Program Files\IAR Systems\Embedded Workbench 5.4\8051\examples\Silicon Labs\UsbXpress\UsbXpress-example\Host\Driver\USBXpressInstaller.exe
01-Jun-2010 09:19:14, 290816 bytes
3.0 (3.0.0.0)
C:\Program Files\IAR Systems\Embedded Workbench 5.4\8051\examples\Silicon Labs\UsbXpress\UsbXpress-example\Host\FileTransferApp\FileTransfer.exe
01-Jun-2010 09:19:12, 28672 bytes
TestPanel Application
C:\Program Files\IAR Systems\Embedded Workbench 5.4\8051\examples\Silicon Labs\UsbXpress\UsbXpress-example\Host\TestPanelApp\TestPanel.exe
01-Jun-2010 09:19:12, 237568 bytes
IAR CSpyBat
5.6.2.1418 (5.6.2.1418)
C:\Program Files\IAR Systems\Embedded Workbench 5.4\common\bin\CSpyBat.exe
10-Feb-2010 15:45:26, 757760 bytes
IAR Build Utility
C:\Program Files\IAR Systems\Embedded Workbench 5.4\common\bin\IarBuild.exe
10-Feb-2010 15:44:08, 106496 bytes
IAR Embedded Workbench IDE
C:\Program Files\IAR Systems\Embedded Workbench 5.4\common\bin\IarIdePm.exe
10-Feb-2010 15:44:18, 487424 bytes
IAR C-SPY Batch Simulator Driver for 8051
C:\Program Files\IAR Systems\Embedded Workbench 5.4\8051\bin\8051bat.dll
08-Jun-2010 11:21:56, 507904 bytes
IAR C-SPY Emulator Driver for 8051
C:\Program Files\IAR Systems\Embedded Workbench 5.4\8051\bin\8051emu_cc.dll
08-Jun-2010 11:30:44, 2187264 bytes
C:\Program Files\IAR Systems\Embedded Workbench 5.4\8051\bin\8051emu_fs2.dll
08-Jun-2010 11:22:24, 819200 bytes
C:\Program Files\IAR Systems\Embedded Workbench 5.4\8051\bin\8051emu_if.dll
08-Jun-2010 11:30:58, 2105344 bytes
C:\Program Files\IAR Systems\Embedded Workbench 5.4\8051\bin\8051emu_ns.dll
08-Jun-2010 11:22:28, 806912 bytes
IAR C-SPY Library Support Plug-in for 8051
C:\Program Files\IAR Systems\Embedded Workbench 5.4\8051\bin\8051LibSupport.dll
08-Jun-2010 11:22:02, 602112 bytes
IAR C-SPY Processor Descriptor for 8051
C:\Program Files\IAR Systems\Embedded Workbench 5.4\8051\bin\8051proc.dll
08-Jun-2010 11:22:12, 851968 bytes
IAR C-SPY ROM-Monitor Driver for 8051
C:\Program Files\IAR Systems\Embedded Workbench 5.4\8051\bin\8051rom.dll
08-Jun-2010 11:31:24, 2142208 bytes
C:\Program Files\IAR Systems\Embedded Workbench 5.4\8051\bin\8051rom_ad2.dll
08-Jun-2010 11:31:10, 2084864 bytes
C:\Program Files\IAR Systems\Embedded Workbench 5.4\8051\bin\8051rom_sl.dll
08-Jun-2010 11:31:38, 2060288 bytes
IAR C-SPY Simulator Driver for 8051
C:\Program Files\IAR Systems\Embedded Workbench 5.4\8051\bin\8051sim.dll
08-Jun-2010 11:31:52, 2560000 bytes
SiDebug DLL
3, 6, 0, 0 (3.6.0.0)
C:\Program Files\IAR Systems\Embedded Workbench 5.4\8051\bin\SiDebug.dll
01-Jun-2010 09:18:48, 565248 bytes
IAR Workbench Target Descriptor for 8051
C:\Program Files\IAR Systems\Embedded Workbench 5.4\8051\bin\swtd8051.dll
08-Jun-2010 11:22:42, 1232896 bytes
C:\Program Files\IAR Systems\Embedded Workbench 5.4\8051\bin\swtd8051_3rd.dll
08-Jun-2010 11:22:32, 589824 bytes
C:\Program Files\IAR Systems\Embedded Workbench 5.4\8051\bin\swtd8051_cc.dll
08-Jun-2010 11:22:36, 606208 bytes
C:\Program Files\IAR Systems\Embedded Workbench 5.4\8051\bin\swtd8051_fs2.dll
08-Jun-2010 11:22:52, 458752 bytes
C:\Program Files\IAR Systems\Embedded Workbench 5.4\8051\bin\swtd8051_if.dll
08-Jun-2010 11:22:56, 589824 bytes
C:\Program Files\IAR Systems\Embedded Workbench 5.4\8051\bin\swtd8051_ns.dll
08-Jun-2010 11:22:58, 442368 bytes
C:\Program Files\IAR Systems\Embedded Workbench 5.4\8051\bin\swtd8051_rom.dll
08-Jun-2010 11:23:06, 630784 bytes
C:\Program Files\IAR Systems\Embedded Workbench 5.4\8051\bin\swtd8051_rom_ad2.dll
08-Jun-2010 11:23:02, 462848 bytes
C:\Program Files\IAR Systems\Embedded Workbench 5.4\8051\bin\swtd8051_rom_sl.dll
08-Jun-2010 11:23:10, 466944 bytes
C:\Program Files\IAR Systems\Embedded Workbench 5.4\8051\bin\swtd8051_sensium.dll
08-Jun-2010 11:23:14, 593920 bytes
C:\Program Files\IAR Systems\Embedded Workbench 5.4\8051\bin\swtd8051_sim.dll
08-Jun-2010 11:23:18, 446464 bytes
USBHID
1, 8, 0, 0 (1.8.0.0)
C:\Program Files\IAR Systems\Embedded Workbench 5.4\8051\bin\USBHID.dll
01-Jun-2010 09:18:48, 61440 bytes
FTLang
C:\Program Files\IAR Systems\Embedded Workbench 5.4\8051\drivers\Analog Devices\ADE7169Fxx\FTLang.dll
01-Jun-2010 09:18:58, 36864 bytes
Serial Port Property Pages
4.10.1998 (4.10.0.1998)
C:\Program Files\IAR Systems\Embedded Workbench 5.4\8051\drivers\Analog Devices\ADE7169Fxx\FTSERUI.DLL
01-Jun-2010 09:18:58, 22592 bytes
FTDI Ports Class Installer
1.00.2132 (1.0.2132.1)
C:\Program Files\IAR Systems\Embedded Workbench 5.4\8051\drivers\Analog Devices\ADE7169Fxx\ftserui2.dll
01-Jun-2010 09:18:58, 51821 bytes
FTD2XX library
3.01.06 (3.1.6.1)
C:\Program Files\IAR Systems\Embedded Workbench 5.4\8051\drivers\Infineon\USCALE Apps\FTD2XX.dll
01-Jun-2010 09:18:58, 81920 bytes
SiUSBXp
3.1 (3.1.0.0)
C:\Program Files\IAR Systems\Embedded Workbench 5.4\8051\examples\Silicon Labs\UsbXpress\UsbXpress-example\Host\FileTransferApp\SiUSBXp.dll
01-Jun-2010 09:19:12, 90112 bytes
SiUSBXp
3.1 (3.1.0.0)
C:\Program Files\IAR Systems\Embedded Workbench 5.4\8051\examples\Silicon Labs\UsbXpress\UsbXpress-example\Host\FileTransferApp\Source\SiUSBXp.dll
SiUSBXp
3.1 (3.1.0.0)
C:\Program Files\IAR Systems\Embedded Workbench 5.4\8051\examples\Silicon Labs\UsbXpress\UsbXpress-example\Host\TestPanelApp\SiUSBXp.dll
SiUSBXp
3.1 (3.1.0.0)
C:\Program Files\IAR Systems\Embedded Workbench 5.4\8051\examples\Silicon Labs\UsbXpress\UsbXpress-example\Host\TestPanelApp\Source\SiUSBXp.dll
SiUSBXp
3.1 (3.1.0.0)
C:\Program Files\IAR Systems\Embedded Workbench 5.4\8051\examples\Silicon Labs\UsbXpress\UsbXpress-example\Host\USBXpress_API\SiUSBXp.dll
IAR CSpyBat Language Specific Resources
C:\Program Files\IAR Systems\Embedded Workbench 5.4\common\bin\CSpyBat.ENU.dll
10-Feb-2010 15:39:34, 5632 bytes
IAR C-SPY Debugger GUI
C:\Program Files\IAR Systems\Embedded Workbench 5.4\common\bin\DebuggerGui.dll
10-Feb-2010 15:50:12, 1937408 bytes
IAR C-SPY Debugger GUI Language Specific Resources
C:\Program Files\IAR Systems\Embedded Workbench 5.4\common\bin\DebuggerGui.ENU.dll
10-Feb-2010 15:39:44, 69632 bytes
IAR Find In Files
C:\Program Files\IAR Systems\Embedded Workbench 5.4\common\bin\FindInFiles.dll
10-Feb-2010 15:44:34, 352256 bytes
IAR Find In Files Language Specific Resources
C:\Program Files\IAR Systems\Embedded Workbench 5.4\common\bin\FindInFiles.ENU.dll
10-Feb-2010 15:39:42, 4608 bytes
IAR Build Utility Language Specific Resources
C:\Program Files\IAR Systems\Embedded Workbench 5.4\common\bin\IarBuild.ENU.dll
10-Feb-2010 15:39:40, 3072 bytes
IAR Embedded Workbench IDE Language Specific Resources
C:\Program Files\IAR Systems\Embedded Workbench 5.4\common\bin\IarIdePm.ENU.dll
10-Feb-2010 15:39:38, 479232 bytes
IAR IDE Framework
C:\Program Files\IAR Systems\Embedded Workbench 5.4\common\bin\IdeFramework.dll
10-Feb-2010 15:40:18, 1056768 bytes
IAR IDE Framework Language Specific Resources
C:\Program Files\IAR Systems\Embedded Workbench 5.4\common\bin\IdeFramework.ENU.dll
10-Feb-2010 15:39:52, 4096 bytes
IAR C-SPY Debugger Kernel
C:\Program Files\IAR Systems\Embedded Workbench 5.4\common\bin\kernel.dll
10-Feb-2010 15:46:48, 2580480 bytes
IAR C-SPY Debugger Kernel Language Specific Resources
C:\Program Files\IAR Systems\Embedded Workbench 5.4\common\bin\kernel.ENU.dll
10-Feb-2010 15:39:50, 13824 bytes
IAR Log Window
C:\Program Files\IAR Systems\Embedded Workbench 5.4\common\bin\LogWindow.dll
10-Feb-2010 15:44:02, 274432 bytes
IAR Log Window Language Specific Resources
C:\Program Files\IAR Systems\Embedded Workbench 5.4\common\bin\LogWindow.ENU.dll
10-Feb-2010 15:39:36, 10240 bytes
IAR Project Manager Engine
C:\Program Files\IAR Systems\Embedded Workbench 5.4\common\bin\ProjectManagerEngine.dll
10-Feb-2010 15:43:24, 1355776 bytes
IAR Project Manager Engine Language Specific Resources
C:\Program Files\IAR Systems\Embedded Workbench 5.4\common\bin\ProjectManagerEngine.ENU.dll
10-Feb-2010 15:39:28, 12800 bytes
IAR Project Manager Gui
C:\Program Files\IAR Systems\Embedded Workbench 5.4\common\bin\ProjectManagerGui.dll
10-Feb-2010 15:46:56, 872448 bytes
IAR Project Manager Gui Language Specific Resources
C:\Program Files\IAR Systems\Embedded Workbench 5.4\common\bin\ProjectManagerGui.ENU.dll
10-Feb-2010 15:39:26, 163840 bytes
IAR Text Editor
C:\Program Files\IAR Systems\Embedded Workbench 5.4\common\bin\TextEditor.dll
10-Feb-2010 15:44:42, 806912 bytes
IAR Text Editor Language Specific Resources
C:\Program Files\IAR Systems\Embedded Workbench 5.4\common\bin\TextEditor.ENU.dll
10-Feb-2010 15:39:18, 32768 bytes
Shared Library for Xerces-C Version 1.5.1
1, 5, 1 (1.5.1.0)
C:\Program Files\IAR Systems\Embedded Workbench 5.4\common\bin\xerces-c_1_5_1.dll
10-Feb-2010 15:14:58, 1257472 bytes
IAR XmlLib
C:\Program Files\IAR Systems\Embedded Workbench 5.4\common\bin\XmlLib.dll
10-Feb-2010 15:37:40, 102400 bytes
IAR Code Coverage Plug-in
C:\Program Files\IAR Systems\Embedded Workbench 5.4\common\plugins\CodeCoverage\CodeCoverage.dll
10-Feb-2010 15:45:10, 507904 bytes
IAR Code Coverage Plug-in Language Specific Resources
C:\Program Files\IAR Systems\Embedded Workbench 5.4\common\plugins\CodeCoverage\CodeCoverage.ENU.dll
10-Feb-2010 15:39:44, 10752 bytes
IAR ORTI RTOS Plug-in
C:\Program Files\IAR Systems\Embedded Workbench 5.4\common\plugins\Orti\Orti.dll
10-Feb-2010 15:46:02, 647168 bytes
IAR ORTI RTOS Plug-in Language Specific Resources
C:\Program Files\IAR Systems\Embedded Workbench 5.4\common\plugins\Orti\Orti.ENU.dll
10-Feb-2010 15:39:32, 8704 bytes
IAR Profiling Plug-in
C:\Program Files\IAR Systems\Embedded Workbench 5.4\common\plugins\Profiling\Profiling.dll
10-Feb-2010 15:42:52, 507904 bytes
IAR Profiling Plug-in Language Specific Resources
C:\Program Files\IAR Systems\Embedded Workbench 5.4\common\plugins\Profiling\Profiling.ENU.dll
10-Feb-2010 15:39:30, 9728 bytes
IAR Stack Plug-in
C:\Program Files\IAR Systems\Embedded Workbench 5.4\common\plugins\Stack\Stack.dll
10-Feb-2010 15:42:12, 536576 bytes
IAR Stack Plug-in Language Specific Resources
C:\Program Files\IAR Systems\Embedded Workbench 5.4\common\plugins\Stack\Stack.ENU.dll
10-Feb-2010 15:39:22, 7680 bytes
IAR Symbols Plug-in
C:\Program Files\IAR Systems\Embedded Workbench 5.4\common\plugins\SymList\SymList.dll
10-Feb-2010 15:41:50, 487424 bytes
IAR Symbols Plug-in Language Specific Resources
C:\Program Files\IAR Systems\Embedded Workbench 5.4\common\plugins\SymList\SymList.ENU.dll
10-Feb-2010 15:39:20, 3072 bytes
Metadata dll for package '8051_AD_addon_release'
7.60.1 (7.60.1.0)
C:\Program Files\IAR Systems\Embedded Workbench 5.4\install-info\8051_AD_addon_release.dll
17-Jun-2010 11:11:06, 147456 bytes
Metadata dll for package '8051_AD_devices_release'
7.60.1 (7.60.1.0)
C:\Program Files\IAR Systems\Embedded Workbench 5.4\install-info\8051_AD_devices_release.dll
17-Jun-2010 11:10:54, 106496 bytes
Metadata dll for package '8051_autorun_release'
7.60.1 (7.60.1.0)
C:\Program Files\IAR Systems\Embedded Workbench 5.4\install-info\8051_autorun_release.dll
17-Jun-2010 11:11:00, 90112 bytes
Metadata dll for package '8051_clib_src_release'
7.60.1 (7.60.1.0)
C:\Program Files\IAR Systems\Embedded Workbench 5.4\install-info\8051_clib_src_release.dll
17-Jun-2010 11:11:04, 102400 bytes
Metadata dll for package '8051_common_release'
7.60.1 (7.60.1.0)
C:\Program Files\IAR Systems\Embedded Workbench 5.4\install-info\8051_common_release.dll
17-Jun-2010 11:11:12, 94208 bytes
Metadata dll for package '8051_created_infocenter_enu_all'
7.60.1 (7.60.1.0)
C:\Program Files\IAR Systems\Embedded Workbench 5.4\install-info\8051_created_infocenter_enu_all.dll
17-Jun-2010 11:10:56, 94208 bytes
Metadata dll for package '8051_dlib_src_release'
7.60.1 (7.60.1.0)
C:\Program Files\IAR Systems\Embedded Workbench 5.4\install-info\8051_dlib_src_release.dll
17-Jun-2010 11:11:12, 159744 bytes
Metadata dll for package '8051_Doc_release'
7.60.1 (7.60.1.0)
C:\Program Files\IAR Systems\Embedded Workbench 5.4\install-info\8051_Doc_release.dll
17-Jun-2010 11:11:22, 94208 bytes
Metadata dll for package '8051_ew_release'
7.60.1 (7.60.1.0)
C:\Program Files\IAR Systems\Embedded Workbench 5.4\install-info\8051_ew_release.dll
Metadata dll for package '8051_feature_AD_release'
7.60.1 (7.60.1.0)
C:\Program Files\IAR Systems\Embedded Workbench 5.4\install-info\8051_feature_AD_release.dll
17-Jun-2010 11:10:54, 90112 bytes
Metadata dll for package '8051_feature_Atmel_release'
7.60.1 (7.60.1.0)
C:\Program Files\IAR Systems\Embedded Workbench 5.4\install-info\8051_feature_Atmel_release.dll
17-Jun-2010 11:11:00, 131072 bytes
Metadata dll for package '8051_feature_Inf_release'
7.60.1 (7.60.1.0)
C:\Program Files\IAR Systems\Embedded Workbench 5.4\install-info\8051_feature_Inf_release.dll
Metadata dll for package '8051_feature_Misc_release'
7.60.1 (7.60.1.0)
C:\Program Files\IAR Systems\Embedded Workbench 5.4\install-info\8051_feature_Misc_release.dll
17-Jun-2010 11:11:14, 90112 bytes
Metadata dll for package '8051_feature_Nordic_release'
7.60.1 (7.60.1.0)
C:\Program Files\IAR Systems\Embedded Workbench 5.4\install-info\8051_feature_Nordic_release.dll
17-Jun-2010 11:11:16, 94208 bytes
Metadata dll for package '8051_feature_NXP_release'
7.60.1 (7.60.1.0)
C:\Program Files\IAR Systems\Embedded Workbench 5.4\install-info\8051_feature_NXP_release.dll
Metadata dll for package '8051_feature_SL_release'
7.60.1 (7.60.1.0)
C:\Program Files\IAR Systems\Embedded Workbench 5.4\install-info\8051_feature_SL_release.dll
17-Jun-2010 11:11:24, 90112 bytes
Metadata dll for package '8051_feature_TI_release'
7.60.1 (7.60.1.0)
C:\Program Files\IAR Systems\Embedded Workbench 5.4\install-info\8051_feature_TI_release.dll
17-Jun-2010 11:11:10, 90112 bytes
Metadata dll for package '8051_infocenter_all'
7.60.1 (7.60.1.0)
C:\Program Files\IAR Systems\Embedded Workbench 5.4\install-info\8051_infocenter_all.dll
17-Jun-2010 11:11:16, 90112 bytes
Metadata dll for package '8051_infocenter_files_all'
7.60.1 (7.60.1.0)
C:\Program Files\IAR Systems\Embedded Workbench 5.4\install-info\8051_infocenter_files_all.dll
17-Jun-2010 11:10:48, 106496 bytes
Metadata dll for package '8051_infocenter_templates_all'
7.60.1 (7.60.1.0)
C:\Program Files\IAR Systems\Embedded Workbench 5.4\install-info\8051_infocenter_templates_all.dll
17-Jun-2010 11:11:02, 98304 bytes
Metadata dll for package '8051_Inf_addon_release'
7.60.1 (7.60.1.0)
C:\Program Files\IAR Systems\Embedded Workbench 5.4\install-info\8051_Inf_addon_release.dll
17-Jun-2010 11:10:54, 98304 bytes
Metadata dll for package '8051_Inf_devices_release'
7.60.1 (7.60.1.0)
C:\Program Files\IAR Systems\Embedded Workbench 5.4\install-info\8051_Inf_devices_release.dll
17-Jun-2010 11:11:26, 114688 bytes
Metadata dll for package '8051_installer_release'
7.60.1 (7.60.1.0)
C:\Program Files\IAR Systems\Embedded Workbench 5.4\install-info\8051_installer_release.dll
17-Jun-2010 11:11:08, 90112 bytes
Metadata dll for package '8051_lib_bin_release'
7.60.1 (7.60.1.0)
C:\Program Files\IAR Systems\Embedded Workbench 5.4\install-info\8051_lib_bin_release.dll
17-Jun-2010 11:11:30, 106496 bytes
Metadata dll for package '8051_Misc_addon_release'
7.60.1 (7.60.1.0)
C:\Program Files\IAR Systems\Embedded Workbench 5.4\install-info\8051_Misc_addon_release.dll
17-Jun-2010 11:10:46, 94208 bytes
Metadata dll for package '8051_Misc_devices_release'
7.60.1 (7.60.1.0)
C:\Program Files\IAR Systems\Embedded Workbench 5.4\install-info\8051_Misc_devices_release.dll
17-Jun-2010 11:10:46, 204800 bytes
Metadata dll for package '8051_NXP_addon_release'
7.60.1 (7.60.1.0)
C:\Program Files\IAR Systems\Embedded Workbench 5.4\install-info\8051_NXP_addon_release.dll
17-Jun-2010 11:11:04, 94208 bytes
Metadata dll for package '8051_NXP_devices_release'
7.60.1 (7.60.1.0)
C:\Program Files\IAR Systems\Embedded Workbench 5.4\install-info\8051_NXP_devices_release.dll
17-Jun-2010 11:10:48, 151552 bytes
Metadata dll for package '8051_projtemp_release'
7.60.1 (7.60.1.0)
C:\Program Files\IAR Systems\Embedded Workbench 5.4\install-info\8051_projtemp_release.dll
17-Jun-2010 11:11:02, 110592 bytes
Metadata dll for package '8051_qscards_all'
7.60.1 (7.60.1.0)
C:\Program Files\IAR Systems\Embedded Workbench 5.4\install-info\8051_qscards_all.dll
17-Jun-2010 11:10:52, 90112 bytes
Metadata dll for package '8051_SL_addon_release'
7.60.1 (7.60.1.0)
C:\Program Files\IAR Systems\Embedded Workbench 5.4\install-info\8051_SL_addon_release.dll
17-Jun-2010 11:10:52, 188416 bytes
Metadata dll for package '8051_SL_devices_release'
7.60.1 (7.60.1.0)
C:\Program Files\IAR Systems\Embedded Workbench 5.4\install-info\8051_SL_devices_release.dll
17-Jun-2010 11:11:24, 225280 bytes
Metadata dll for package '8051_TI_addon_release'
7.60.1 (7.60.1.0)
C:\Program Files\IAR Systems\Embedded Workbench 5.4\install-info\8051_TI_addon_release.dll
17-Jun-2010 11:10:52, 106496 bytes
Metadata dll for package '8051_TI_devices_release'
7.60.1 (7.60.1.0)
C:\Program Files\IAR Systems\Embedded Workbench 5.4\install-info\8051_TI_devices_release.dll
17-Jun-2010 11:11:10, 102400 bytes
Metadata dll for package '8051_xlink_all'
7.60.1 (7.60.1.0)
C:\Program Files\IAR Systems\Embedded Workbench 5.4\install-info\8051_xlink_all.dll
Metadata dll for package 'common_vcredistx86_2005_sp1_atl_all'
6.0.2900.2180 (6.0.2900.2180)
C:\Program Files\IAR Systems\Embedded Workbench 5.4\install-info\common_vcredistx86_2005_sp1_atl_all.dll
17-Jun-2010 11:10:48, 90112 bytes
Metadata dll for package 'common_vcredistx86_export_2005x86'
1.0.0.0 (1.0.0.0)
C:\Program Files\IAR Systems\Embedded Workbench 5.4\install-info\common_vcredistx86_export_2005x86.dll
17-Jun-2010 11:10:46, 90112 bytes
Metadata dll for package 'IDE_CodeCoverageRelease_plugin'
C:\Program Files\IAR Systems\Embedded Workbench 5.4\install-info\IDE_CodeCoverageRelease_plugin.dll
17-Jun-2010 11:11:30, 90112 bytes
Metadata dll for package 'IDE_CSpyBatRelease_exe_langdll'
C:\Program Files\IAR Systems\Embedded Workbench 5.4\install-info\IDE_CSpyBatRelease_exe_langdll.dll
17-Jun-2010 11:11:02, 90112 bytes
Metadata dll for package 'IDE_DebuggerGuiRelease_dll_langdll'
C:\Program Files\IAR Systems\Embedded Workbench 5.4\install-info\IDE_DebuggerGuiRelease_dll_langdll.dll
Metadata dll for package 'IDE_FindInFilesRelease_dll_langdll'
C:\Program Files\IAR Systems\Embedded Workbench 5.4\install-info\IDE_FindInFilesRelease_dll_langdll.dll
17-Jun-2010 11:11:20, 90112 bytes
Metadata dll for package 'IDE_IarBuildRelease_exe_langdll'
C:\Program Files\IAR Systems\Embedded Workbench 5.4\install-info\IDE_IarBuildRelease_exe_langdll.dll
Metadata dll for package 'IDE_IarIdePmRelease_exe_langdll'
C:\Program Files\IAR Systems\Embedded Workbench 5.4\install-info\IDE_IarIdePmRelease_exe_langdll.dll
17-Jun-2010 11:11:04, 90112 bytes
Metadata dll for package 'IDE_IdeFrameworkRelease_dll_langdll'
C:\Program Files\IAR Systems\Embedded Workbench 5.4\install-info\IDE_IdeFrameworkRelease_dll_langdll.dll
17-Jun-2010 11:11:06, 90112 bytes
Metadata dll for package 'IDE_kernelRelease_dll_langdll'
C:\Program Files\IAR Systems\Embedded Workbench 5.4\install-info\IDE_kernelRelease_dll_langdll.dll
17-Jun-2010 11:11:32, 90112 bytes
Metadata dll for package 'IDE_LibSupportRelease_dll_langdll'
C:\Program Files\IAR Systems\Embedded Workbench 5.4\install-info\IDE_LibSupportRelease_dll_langdll.dll
Metadata dll for package 'IDE_LogWindowRelease_dll_langdll'
C:\Program Files\IAR Systems\Embedded Workbench 5.4\install-info\IDE_LogWindowRelease_dll_langdll.dll
Metadata dll for package 'IDE_MiscRelease_misc'
C:\Program Files\IAR Systems\Embedded Workbench 5.4\install-info\IDE_MiscRelease_misc.dll
Metadata dll for package 'IDE_OrtiRelease_plugin'
C:\Program Files\IAR Systems\Embedded Workbench 5.4\install-info\IDE_OrtiRelease_plugin.dll
17-Jun-2010 11:10:56, 90112 bytes
Metadata dll for package 'IDE_PlatformPackagesRelease_delivery'
C:\Program Files\IAR Systems\Embedded Workbench 5.4\install-info\IDE_PlatformPackagesRelease_delivery.dll
17-Jun-2010 11:10:50, 90112 bytes
Metadata dll for package 'IDE_Platform_release'
C:\Program Files\IAR Systems\Embedded Workbench 5.4\install-info\IDE_Platform_release.dll
Metadata dll for package 'IDE_ProfilingRelease_plugin'
C:\Program Files\IAR Systems\Embedded Workbench 5.4\install-info\IDE_ProfilingRelease_plugin.dll
Metadata dll for package 'IDE_ProjectManagerEngineRelease_dll_langdll'
C:\Program Files\IAR Systems\Embedded Workbench 5.4\install-info\IDE_ProjectManagerEngineRelease_dll_langdll.dll
17-Jun-2010 11:11:12, 90112 bytes
Metadata dll for package 'IDE_ProjectManagerGuiRelease_dll_langdll'
C:\Program Files\IAR Systems\Embedded Workbench 5.4\install-info\IDE_ProjectManagerGuiRelease_dll_langdll.dll
Metadata dll for package 'IDE_SelfTestRelease_dll_langdll'
C:\Program Files\IAR Systems\Embedded Workbench 5.4\install-info\IDE_SelfTestRelease_dll_langdll.dll
17-Jun-2010 11:11:18, 90112 bytes
Metadata dll for package 'IDE_StackRelease_plugin'
C:\Program Files\IAR Systems\Embedded Workbench 5.4\install-info\IDE_StackRelease_plugin.dll
Metadata dll for package 'IDE_SymListRelease_plugin'
C:\Program Files\IAR Systems\Embedded Workbench 5.4\install-info\IDE_SymListRelease_plugin.dll
Metadata dll for package 'IDE_TextEditorRelease_dll_langdll'
C:\Program Files\IAR Systems\Embedded Workbench 5.4\install-info\IDE_TextEditorRelease_dll_langdll.dll
Metadata dll for package 'IDE_XercesXMLRelease_dll_langdll'
C:\Program Files\IAR Systems\Embedded Workbench 5.4\install-info\IDE_XercesXMLRelease_dll_langdll.dll
17-Jun-2010 11:10:58, 90112 bytes
Metadata dll for package 'IDE_XmlLibRelease_dll'
C:\Program Files\IAR Systems\Embedded Workbench 5.4\install-info\IDE_XmlLibRelease_dll.dll
Metadata dll for package 'lms_init_media'
1.0.0 (1.0.0.0)
C:\Program Files\IAR Systems\Embedded Workbench 5.4\install-info\lms_init_media.dll
Metadata dll for package 'lms_init_release'
1.0.0 (1.0.0.0)
C:\Program Files\IAR Systems\Embedded Workbench 5.4\install-info\lms_init_release.dll
Metadata dll for package 'lms_license_support_release'
1.0.1 (1.0.1.0)
C:\Program Files\IAR Systems\Embedded Workbench 5.4\install-info\lms_license_support_release.dll
Metadata dll for package 'lms_safenet_dongle_drivers_media'
7.5.0 (7.5.0.0)
C:\Program Files\IAR Systems\Embedded Workbench 5.4\install-info\lms_safenet_dongle_drivers_media.dll
Metadata dll for package 'lms_utilities_release'
1.1.1 (1.1.1.0)
C:\Program Files\IAR Systems\Embedded Workbench 5.4\install-info\lms_utilities_release.dll
What could be the reason?
