CC1110 Peripheral Simulation Plug-in (PSP)
I am using IAR's 8051 IDE Workbench and want to simulate the TI CC1110 chip using the CSpy simulator to determine the timing for sections in my code but I didn't see any PSP modules in the install files provided by IAR.
IAR's debugging guide for the EW8051 says on p. 299 "These options set up peripheral simulation, which requires a plugin from a third-party vendor. For information, see the PDF EW_PeripheralSimulationGuide.pdf in the EW_DIR\8051\doc\ directory and the examples in the EW_DIR\8051\plugins\simulation directory."
 I asked IAR to provide information about any module available for the CC1110 but they said to contact TI because IAR doesn't usually provide peripheral simulation plugins.
Can someone from TI send me a link or provide information if a PSP is even available for the CC1110 simulator?
JD
  • Hi JD,
    We do not have a PSP for CC1110 (or any of our CCxxxx devices), unfortunately. To get accurate timing of your algorithms running on the device, I would suggest that you use a logic analyzer and generate events with GPIO.
