SMPL_NOFRAME on SMPL_RECEIVE
I'm stuck again, at first I did not have my radio in EP turned on but now I do with this:
                SMPL_Ioctl( IOCTL_OBJ_RADIO, IOCTL_ACT_RADIO_RXON, 0);
                //wait for reply
                NWK_REPLY_DELAY();
Then I send my message from my AP using this, which returns SUCCESS:
if(SMPL_SUCCESS == SMPL_Send(sLID[sNumCurrentPeers], (unsigned char *) &privateToken, 4)){
Next my EP RX interrupt routine gets called so I figure I must have received the message from the AP, so I set a flag and in my main loop I try this:
            result = SMPL_Receive(apLinkID, msg, &len);
            if (result == SMPL_SUCCESS)
                led_one_on();
But I get SMPL_NOFRAME everytime.  Not sure what I'm doing wrong, I would think the fact that my rx routine  is called would mean I'd received a message from the AP.
Thank you
  • solved my own problem.  I incorrectly assumed that the apLinkID I received from doing the initial SMPL_Link on the EP would be the same link ID that I would get when the AP tried to send my EP a message.   They were different so storing and using the link ID passed to me in the RX interrupt handler fixed the issue.
