The data sheet of CC1200 says it can support 1250kbps data rate. However SmartRF just has a 500kbps symbol rate with 4-GFSK configuration which supports 1000k bit rate. I also can't manually configure the parameters to support a bit rate higher than 1000kbps by SmartRF user interface. Any idea or suggestion for supporting 1250kbps?
Thanks!
