why people prefer 2.4G than 868M/433M ?
The range will increase when decreasing the data rate since the noise floor will be lower in the receiver.
At 868 MHz, 250kbps data rate the sensitivity is -94 dBm, 38.4kbps data rate the sensitivity is -102 dBm and for 1.2kbps data rate the sensitivity is -110 dBm.
Each 6 dB improvement will give approx. 2x in range.
You range still seems to be too low.
Are you measuring the range outside with Line of Sight ?
What is your measured conducted output power?
Richard
Thx Rihard again.
Are you measuring the range outside with Line ofSight ?
Yes.
Measured 5dbm in spectrum.
: May i ask anyone can achieve 250kbps with 8K speech quality and TX power 10DBm With distance > 50m?
