CC1200 separate antennas for RX/TX
Other Parts Discussed in Thread: CC1200
I would like to use the CC1200 with separate antennas for RX/TX, but not by using a switch. Looking at the ref. design for 440MHz, where would be the best place to split the matching networks (and leaving out the TRX_SW-Signal line)?
Or would you strongly recommend to leave it like it is and use an additional switch?
(Later on, I want to add a separate PA and LNA.)
Thanks for you help.
