CC1120 configuration no tx
Other Parts Discussed in Thread: CC1120
This Q' is duplication of this Q' (I guess Siri missed my post so I'm created this new one).
We are trying to solve this issue for OVER A MONTH
We are using CC1120.
What we are trying to achieve is to have a set of 3 configurations (working = valid RSSI readings + transport of data is OK):
  1. Unit A: they only do Tx according to the smartRf configuration for packet Tx (12 bytes preamble + 915 mhz + 4GFSK + Symbol rate 62ksps ).
  2. Unit B: they do Sniff Rx + packet Tx (12 bytes preamble + 915 mhz + 4GFSK + Symbol rate 62ksps ).
  3. Unit C: they do Packet RX and packet Tx (12 bytes preamble + 915 mhz + 4GFSK + Symbol rate 62ksps ).
What do we need?
  • We need that unit type A could talk to both Units type B & units type C.
  • We need that unit type B could talk to units type C.
  • We need that unit type C could talk to units type B.
When using Siri's configuration from here answer  & switching from sniff to continues RX, using the smartRf tool we get configuration errors:
The XOSC2 & SETTLING_CFG.FS_AUTOCAL are both marked ONLY since the smartRf tool set it up when moved from Siri sniff configuration to the Packet Rx.
Unsetting those doesn't fix the issue.
Could we kindly receive a working configuration that can do the 3 points in bullets while keeping the constrains 1,2,3?
Regards.
  • - Which RX_BW/ deviation requirements do you have? For 62 ksps zero IF probably should be used, if you start from the 200 kbps in SmartRF Studio and change the datarate/ deviation you will probably get more robust settings
    <?xml version="1.0" encoding="ISO-8859-1"?>
    <!DOCTYPE configuration SYSTEM "C:/Program Files (x86)/Texas Instruments/SmartRF Tools/SmartRF Studio 7/config/xml/configdata.dtd"[]>
    <dcpanelconfiguration>
        <Devicename>CC1120</Devicename>
        <Description>Saved configuration data</Description>
        <registersettings>
            <Register>
                <Name>AGC_CFG0</Name>
                <Value>0xc0</Value>
            </Register>
            <Register>
                <Name>AGC_CFG1</Name>
                <Value>0xa9</Value>
            </Register>
            <Register>
                <Name>AGC_CFG2</Name>
                <Value>0x60</Value>
            </Register>
            <Register>
                <Name>AGC_CFG3</Name>
                <Value>0x83</Value>
            </Register>
            <Register>
                <Name>AGC_CS_THR</Name>
                <Value>0xec</Value>
            </Register>
            <Register>
                <Name>AGC_REF</Name>
                <Value>0x3c</Value>
            </Register>
            <Register>
                <Name>CHAN_BW</Name>
                <Value>0x01</Value>
            </Register>
            <Register>
                <Name>DCFILT_CFG</Name>
                <Value>0x04</Value>
            </Register>
            <Register>
                <Name>DEVIATION_M</Name>
                <Value>0x48</Value>
            </Register>
            <Register>
                <Name>FIFO_CFG</Name>
                <Value>0x00</Value>
            </Register>
            <Register>
                <Name>FREQ1</Name>
                <Value>0x60</Value>
            </Register>
            <Register>
                <Name>FREQ2</Name>
                <Value>0x72</Value>
            </Register>
            <Register>
                <Name>FREQ_IF_CFG</Name>
                <Value>0x00</Value>
            </Register>
            <Register>
                <Name>FS_CAL0</Name>
                <Value>0x0e</Value>
            </Register>
            <Register>
                <Name>FS_CAL1</Name>
                <Value>0x40</Value>
            </Register>
            <Register>
                <Name>FS_CFG</Name>
                <Value>0x12</Value>
            </Register>
            <Register>
                <Name>FS_DIG0</Name>
                <Value>0x5f</Value>
            </Register>
            <Register>
                <Name>FS_DIG1</Name>
                <Value>0x00</Value>
            </Register>
            <Register>
                <Name>FS_DIVTWO</Name>
                <Value>0x03</Value>
            </Register>
            <Register>
                <Name>FS_DSM0</Name>
                <Value>0x33</Value>
            </Register>
            <Register>
                <Name>FS_DVC0</Name>
                <Value>0x17</Value>
            </Register>
            <Register>
                <Name>FS_PFD</Name>
                <Value>0x50</Value>
            </Register>
            <Register>
                <Name>FS_PRE</Name>
                <Value>0x6e</Value>
            </Register>
            <Register>
                <Name>FS_REG_DIV_CML</Name>
                <Value>0x14</Value>
            </Register>
            <Register>
                <Name>FS_SPARE</Name>
                <Value>0xac</Value>
            </Register>
            <Register>
                <Name>FS_VCO0</Name>
                <Value>0xb4</Value>
            </Register>
            <Register>
                <Name>IF_MIX_CFG</Name>
                <Value>0x00</Value>
            </Register>
            <Register>
                <Name>IOCFG0</Name>
                <Value>0x40</Value>
            </Register>
            <Register>
                <Name>IOCFG1</Name>
                <Value>0xb0</Value>
            </Register>
            <Register>
                <Name>IOCFG2</Name>
                <Value>0x06</Value>
            </Register>
            <Register>
                <Name>IOCFG3</Name>
                <Value>0xb0</Value>
            </Register>
            <Register>
                <Name>IQIC</Name>
                <Value>0x00</Value>
            </Register>
            <Register>
                <Name>MDMCFG0</Name>
                <Value>0x05</Value>
            </Register>
            <Register>
                <Name>MODCFG_DEV_E</Name>
                <Value>0x2e</Value>
            </Register>
            <Register>
                <Name>MODEM_STATUS1</Name>
                <Value>0x10</Value>
            </Register>
            <Register>
                <Name>PARTNUMBER</Name>
                <Value>0x48</Value>
            </Register>
            <Register>
                <Name>PARTVERSION</Name>
                <Value>0x21</Value>
            </Register>
            <Register>
                <Name>PA_CFG0</Name>
                <Value>0x03</Value>
            </Register>
            <Register>
                <Name>PKT_CFG0</Name>
                <Value>0x20</Value>
            </Register>
            <Register>
                <Name>PKT_LEN</Name>
                <Value>0xff</Value>
            </Register>
            <Register>
                <Name>PREAMBLE_CFG1</Name>
                <Value>0x2c</Value>
            </Register>
            <Register>
                <Name>SETTLING_CFG</Name>
                <Value>0x03</Value>
            </Register>
            <Register>
                <Name>SYMBOL_RATE0</Name>
                <Value>0x77</Value>
            </Register>
            <Register>
                <Name>SYMBOL_RATE1</Name>
                <Value>0xbe</Value>
            </Register>
            <Register>
                <Name>SYMBOL_RATE2</Name>
                <Value>0x9f</Value>
            </Register>
            <Register>
                <Name>SYNC_CFG1</Name>
                <Value>0x07</Value>
            </Register>
            <Register>
                <Name>TOC_CFG</Name>
                <Value>0x0a</Value>
            </Register>
            <Register>
                <Name>XOSC1</Name>
                <Value>0x03</Value>
            </Register>
            <Register>
                <Name>XOSC5</Name>
                <Value>0x0e</Value>
            </Register>
        </registersettings>
        <dcpanel>
            <Property role="44" name="m_chkRegView">2</Property>
            <Property role="44" name="m_chkRfParameters">2</Property>
            <Property role="37" name="m_tabUserMode">1</Property>
            <Property role="33" name="m_easyModeSettings">-1</Property>
            <Property role="33" name="m_typicalSettings">-1</Property>
            <Property role="37" name="m_testFuncPanel">2</Property>
        </dcpanel>
        <rfparameters>
            <Property role="46" name="m_cmbFrontends">0</Property>
            <Property role="44" name="m_chkHGMorBYP">2</Property>
            <Property role="46" name="m_cmbEmRevs">-1</Property>
            <Property role="46" name="Xtal frequency">32.000000</Property>
        </rfparameters>
        <conttx>
            <Property role="45" name="m_rbtModulated">1</Property>
            <Property role="45" name="m_rbtUnmodulated">0</Property>
            <Property role="46" name="m_cmbDataFormat">-1</Property>
            <Property role="44" name="m_chkFreqSweep">0</Property>
            <Property role="44" name="m_chkChanSweep">0</Property>
        </conttx>
        <contrx>
            <Property role="44" name="m_chkAutoScroll">2</Property>
        </contrx>
        <packettx>
            <Property role="42" name="m_edtPayloadSize">30</Property>
            <Property role="42" name="m_edtPacketCount">100</Property>
            <Property role="42" name="m_edtPacketCountEsy">100</Property>
            <Property role="42" name="m_edtRandomPacketData">13 0d 89 0a 1c db ae 32 20 9a 50 ee 40 78 36 fd 12 49 32 f6 9e 7d 49 dc ad 4f 14 f2 </Property>
            <Property role="42" name="m_edtPacketData"></Property>
            <Property role="42" name="m_edtAccessAddress"></Property>
            <Property role="42" name="m_edtDeviceAddress"></Property>
            <Property role="44" name="m_chkAddSeqNbr">2</Property>
            <Property role="44" name="m_chkInfinite">0</Property>
            <Property role="44" name="m_chkInfiniteEsy">0</Property>
            <Property role="45" name="m_rbtRandom">1</Property>
            <Property role="45" name="m_rbtText">0</Property>
            <Property role="45" name="m_rbtHex">0</Property>
            <Property role="44" name="m_chkAdvanced">2</Property>
            <Property role="46" name="m_cmbSyncWord">-1</Property>
            <Property role="46" name="m_cmbPreambleCount">-1</Property>
            <Property role="44" name="m_chkAddress">0</Property>
            <Property role="42" name="m_edtAddress"></Property>
            <Property role="46" name="m_cmbLengthConfig">1</Property>
            <Property role="42" name="m_edtLengthConfig">255</Property>
            <Property role="52" name="m_spnPktInterval">200</Property>
            <Property role="44" name="m_chkDefPktInterval">0</Property>
        </packettx>
        <packetrx>
            <Property role="46" name="m_cmbViewFormat">0</Property>
            <Property role="44" name="m_chkSeqNbrIncluded">2</Property>
            <Property role="42" name="m_edtDumpFile"></Property>
            <Property role="44" name="m_chkAdvanced">0</Property>
            <Property role="44" name="m_chk802154gMode">0</Property>
        </packetrx>
        <commandpanel>
            <Property role="44" name="m_chkInsertLength">0</Property>
            <Property role="42" name="m_edtTxFifo"></Property>
            <Property role="42" name="m_edtRxFifo"></Property>
            <Property role="46" name="m_cmbInstrInput">-1</Property>
        </commandpanel>
        <packetRxSniffMode>
            <Property role="42" name="m_edtPreambleLength">24</Property>
            <Property role="42" name="m_edtCarrierSenseThreshold">-90</Property>
            <Property role="45" name="m_rbtRssi">1</Property>
            <Property role="45" name="m_rbtPreamble">0</Property>
        </packetRxSniffMode>
    </dcpanelconfiguration>
        <registersettings>
            <Register>
                <Value>0xc0</Value>
            </Register>
            <Register>
                <Value>0xa0</Value>
            </Register>
            <Register>
                <Value>0x60</Value>
            </Register>
            <Register>
                <Value>0x83</Value>
            </Register>
            <Register>
                <Value>0x0c</Value>
            </Register>
            <Register>
                <Value>0x3c</Value>
            </Register>
            <Register>
                <Value>0x01</Value>
            </Register>
            <Register>
                <Value>0x04</Value>
            </Register>
            <Register>
                <Value>0x48</Value>
            </Register>
            <Register>
                <Value>0x00</Value>
            </Register>
            <Register>
                <Name>FREQ1</Name>
                <Value>0x60</Value>
            </Register>
            <Register>
                <Name>FREQ2</Name>
                <Value>0x72</Value>
            </Register>
            <Register>
                <Value>0x00</Value>
            </Register>
            <Register>
                <Value>0x0e</Value>
            </Register>
            <Register>
                <Value>0x40</Value>
            </Register>
            <Register>
                <Name>FS_CFG</Name>
                <Value>0x12</Value>
            </Register>
            <Register>
                <Value>0x5f</Value>
            </Register>
            <Register>
                <Value>0x00</Value>
            </Register>
            <Register>
                <Value>0x03</Value>
            </Register>
            <Register>
                <Value>0x33</Value>
            </Register>
            <Register>
                <Value>0x17</Value>
            </Register>
            <Register>
                <Name>FS_PFD</Name>
                <Value>0x50</Value>
            </Register>
            <Register>
                <Name>FS_PRE</Name>
                <Value>0x6e</Value>
            </Register>
            <Register>
                <Value>0x14</Value>
            </Register>
            <Register>
                <Value>0xac</Value>
            </Register>
            <Register>
                <Value>0xb4</Value>
            </Register>
            <Register>
                <Value>0x00</Value>
            </Register>
            <Register>
                <Name>IOCFG0</Name>
                <Value>0x40</Value>
            </Register>
            <Register>
                <Name>IOCFG1</Name>
                <Value>0xb0</Value>
            </Register>
            <Register>
                <Name>IOCFG2</Name>
                <Value>0x06</Value>
            </Register>
            <Register>
                <Name>IOCFG3</Name>
                <Value>0xb0</Value>
            </Register>
            <Register>
                <Name>IQIC</Name>
                <Value>0x00</Value>
            </Register>
            <Register>
                <Value>0x05</Value>
            </Register>
            <Register>
                <Value>0x2e</Value>
            </Register>
            <Register>
                <Value>0x10</Value>
            </Register>
            <Register>
                <Value>0x48</Value>
            </Register>
            <Register>
                <Value>0x21</Value>
            </Register>
            <Register>
                <Value>0x03</Value>
            </Register>
            <Register>
                <Value>0x20</Value>
            </Register>
            <Register>
                <Value>0xff</Value>
            </Register>
            <Register>
                <Value>0x18</Value>
            </Register>
            <Register>
                <Name>RFEND_CFG0</Name>
                <Value>0x09</Value>
            </Register>
            <Register>
                <Value>0x03</Value>
            </Register>
            <Register>
                <Value>0x77</Value>
            </Register>
            <Register>
                <Value>0xbe</Value>
            </Register>
            <Register>
                <Value>0x9f</Value>
            </Register>
            <Register>
                <Value>0x07</Value>
            </Register>
            <Register>
                <Value>0x0a</Value>
            </Register>
            <Register>
                <Name>WOR_CFG0</Name>
                <Value>0x20</Value>
            </Register>
            <Register>
                <Name>WOR_EVENT0_LSB</Name>
                <Value>0x2f</Value>
            </Register>
            <Register>
                <Name>XOSC1</Name>
                <Value>0x03</Value>
            </Register>
            <Register>
                <Name>XOSC2</Name>
                <Value>0x00</Value>
            </Register>
            <Register>
                <Name>XOSC5</Name>
                <Value>0x0e</Value>
            </Register>
        </registersettings>
        <dcpanel>
            <Property name="m_chkRegView" role="44">2</Property>
            <Property name="m_chkRfParameters" role="44">2</Property>
            <Property name="m_tabUserMode" role="37">1</Property>
            <Property name="m_easyModeSettings" role="33">-1</Property>
            <Property name="m_typicalSettings" role="33">-1</Property>
            <Property name="m_testFuncPanel" role="37">5</Property>
        </dcpanel>
        <rfparameters>
            <Property name="m_cmbFrontends" role="46">0</Property>
            <Property name="m_chkHGMorBYP" role="44">2</Property>
            <Property name="m_cmbEmRevs" role="46">-1</Property>
            <Property name="Xtal frequency" role="46">32.000000</Property>
        </rfparameters>
        <conttx>
            <Property name="m_rbtModulated" role="45">1</Property>
            <Property name="m_rbtUnmodulated" role="45">0</Property>
            <Property name="m_cmbDataFormat" role="46">-1</Property>
            <Property name="m_chkFreqSweep" role="44">0</Property>
            <Property name="m_chkChanSweep" role="44">0</Property>
        </conttx>
        <contrx>
            <Property name="m_chkAutoScroll" role="44">2</Property>
        </contrx>
        <packettx>
            <Property name="m_edtPayloadSize" role="42">30</Property>
            <Property name="m_edtPacketCount" role="42">100</Property>
            <Property name="m_edtPacketCountEsy" role="42">100</Property>
            <Property name="m_edtRandomPacketData" role="42">13 0d 89 0a 1c db ae 32 20 9a 50 ee 40 78 36 fd 12 49 32 f6 9e 7d 49 dc ad 4f 14 f2 </Property>
            <Property name="m_edtPacketData" role="42"></Property>
            <Property name="m_edtAccessAddress" role="42"></Property>
            <Property name="m_edtDeviceAddress" role="42"></Property>
            <Property name="m_chkAddSeqNbr" role="44">2</Property>
            <Property name="m_chkInfinite" role="44">0</Property>
            <Property name="m_chkInfiniteEsy" role="44">0</Property>
            <Property name="m_rbtRandom" role="45">1</Property>
            <Property name="m_rbtText" role="45">0</Property>
            <Property name="m_rbtHex" role="45">0</Property>
            <Property name="m_chkAdvanced" role="44">0</Property>
        </packettx>
        <packetrx>
            <Property name="m_cmbViewFormat" role="46">0</Property>
            <Property name="m_chkSeqNbrIncluded" role="44">2</Property>
            <Property name="m_edtDumpFile" role="42"></Property>
            <Property name="m_chk802154gMode" role="44">0</Property>
        </packetrx>
        <commandpanel>
            <Property name="m_chkInsertLength" role="44">0</Property>
            <Property name="m_edtTxFifo" role="42"></Property>
            <Property name="m_edtRxFifo" role="42"></Property>
            <Property name="m_cmbInstrInput" role="46">-1</Property>
        </commandpanel>
        <packetRxSniffMode>
            <Property name="m_edtPreambleLength" role="42">12</Property>
            <Property name="m_edtCarrierSenseThreshold" role="42">-90</Property>
            <Property name="m_rbtRssi" role="45">1</Property>
            <Property name="m_rbtPreamble" role="45">0</Property>
  • Dear TER,
    Thank you for your replay.
    Unfortunately this configuration is not working and doesn't answer our needs(we have 3 roles:  TX, SNIFF+ TX and RX+TX) .
    About 3 months ago we realized that we can't establish sniff+200kpbs and valid rssi  following your recommendation we changed configuration to: 124kbps bit rate, 4GFSK 12 byte preamble.
    Everything is working beside the TX of the RX+TX device.
    I have attached three files, in these files the
    SNIFF + TX configuration(Siri's working Sniff configuration+changed preamble_cfg1 to 12 Bytes preamble):
        <registersettings>
            <Register>
                <Value>0xa0</Value>
            </Register>
            <Register>
                <Value>0x0c</Value>
            </Register>
            <Register>
                <Value>0x41</Value>
            </Register>
            <Register>
                <Value>0x1c</Value>
            </Register>
            <Register>
                <Value>0x48</Value>
            </Register>
            <Register>
                <Value>0x00</Value>
            </Register>
            <Register>
                <Name>FREQ1</Name>
                <Value>0x60</Value>
            </Register>
            <Register>
                <Name>FREQ2</Name>
                <Value>0x72</Value>
            </Register>
            <Register>
                <Name>FREQOFF_CFG</Name>
                <Value>0x22</Value>
            </Register>
            <Register>
                <Value>0x0e</Value>
            </Register>
            <Register>
                <Value>0x40</Value>
            </Register>
            <Register>
                <Name>FS_CFG</Name>
                <Value>0x12</Value>
            </Register>
            <Register>
                <Value>0x5f</Value>
            </Register>
            <Register>
                <Value>0x00</Value>
            </Register>
            <Register>
                <Value>0x03</Value>
            </Register>
            <Register>
                <Value>0x33</Value>
            </Register>
            <Register>
                <Value>0x17</Value>
            </Register>
            <Register>
                <Name>FS_PFD</Name>
                <Value>0x50</Value>
            </Register>
            <Register>
                <Name>FS_PRE</Name>
                <Value>0x6e</Value>
            </Register>
            <Register>
                <Value>0x14</Value>
            </Register>
            <Register>
                <Value>0xac</Value>
            </Register>
            <Register>
                <Value>0xb4</Value>
            </Register>
            <Register>
                <Value>0x00</Value>
            </Register>
            <Register>
                <Name>IOCFG0</Name>
                <Value>0x40</Value>
            </Register>
            <Register>
                <Name>IOCFG1</Name>
                <Value>0xb0</Value>
            </Register>
            <Register>
                <Name>IOCFG2</Name>
                <Value>0x06</Value>
            </Register>
            <Register>
                <Name>IOCFG3</Name>
                <Value>0xb0</Value>
            </Register>
            <Register>
                <Name>IQIC</Name>
                <Value>0x00</Value>
            </Register>
            <Register>
                <Value>0x05</Value>
            </Register>
            <Register>
                <Value>0x2d</Value>
            </Register>
            <Register>
                <Value>0x7b</Value>
            </Register>
            <Register>
                <Value>0x20</Value>
            </Register>
            <Register>
                <Value>0xff</Value>
            </Register>
            <Register>
                <Value>0x2c</Value>
            </Register>
            <Register>
                <Value>0x09</Value>
            </Register>
            <Register>
                <Value>0x03</Value>
            </Register>
            <Register>
                <Value>0x77</Value>
            </Register>
            <Register>
                <Value>0xbe</Value>
            </Register>
            <Register>
                <Value>0x9f</Value>
            </Register>
            <Register>
                <Value>0x08</Value>
            </Register>
            <Register>
                <Value>0x20</Value>
            </Register>
            <Register>
                <Value>0x2f</Value>
            </Register>
            <Register>
                <Name>XOSC1</Name>
                <Value>0x03</Value>
            </Register>
            <Register>
                <Name>XOSC2</Name>
                <Value>0x00</Value>
            </Register>
            <Register>
                <Name>XOSC5</Name>
                <Value>0x0e</Value>
            </Register>
        </registersettings>
        <dcpanel>
        </dcpanel>
        <rfparameters>
        </rfparameters>
        <conttx>
        </conttx>
        <contrx>
        </contrx>
        <packettx>
        </packettx>
        <packetrx>
        </packetrx>
        <commandpanel>
        </commandpanel>
        <packetRxSniffMode>
     RX + TX configuration(I changed Siri's configuration using the smartRf tool to packet RX instead of sniff) :
        <registersettings>
            <Register>
                <Value>0xa9</Value>
            </Register>
            <Register>
                <Value>0x19</Value>
            </Register>
            <Register>
                <Value>0x41</Value>
            </Register>
            <Register>
                <Value>0x1c</Value>
            </Register>
            <Register>
                <Value>0x48</Value>
            </Register>
            <Register>
                <Value>0x00</Value>
            </Register>
            <Register>
                <Name>FREQ1</Name>
                <Value>0x60</Value>
            </Register>
            <Register>
                <Name>FREQ2</Name>
                <Value>0x72</Value>
            </Register>
            <Register>
                <Value>0x22</Value>
            </Register>
            <Register>
                <Value>0x0e</Value>
            </Register>
            <Register>
                <Value>0x40</Value>
            </Register>
            <Register>
                <Name>FS_CFG</Name>
                <Value>0x12</Value>
            </Register>
            <Register>
                <Value>0x5f</Value>
            </Register>
            <Register>
                <Value>0x00</Value>
            </Register>
            <Register>
                <Value>0x03</Value>
            </Register>
            <Register>
                <Value>0x33</Value>
            </Register>
            <Register>
                <Value>0x17</Value>
            </Register>
            <Register>
                <Name>FS_PFD</Name>
                <Value>0x50</Value>
            </Register>
            <Register>
                <Name>FS_PRE</Name>
                <Value>0x6e</Value>
            </Register>
            <Register>
                <Value>0x14</Value>
            </Register>
            <Register>
                <Value>0xac</Value>
            </Register>
            <Register>
                <Value>0xb4</Value>
            </Register>
            <Register>
                <Value>0x00</Value>
            </Register>
            <Register>
                <Name>IOCFG0</Name>
                <Value>0x40</Value>
            </Register>
            <Register>
                <Name>IOCFG1</Name>
                <Value>0xb0</Value>
            </Register>
            <Register>
                <Name>IOCFG2</Name>
                <Value>0x06</Value>
            </Register>
            <Register>
                <Name>IOCFG3</Name>
                <Value>0xb0</Value>
            </Register>
            <Register>
                <Name>IQIC</Name>
                <Value>0x00</Value>
            </Register>
            <Register>
                <Value>0x05</Value>
            </Register>
            <Register>
                <Value>0x2d</Value>
            </Register>
            <Register>
                <Value>0x7b</Value>
            </Register>
            <Register>
                <Value>0x20</Value>
            </Register>
            <Register>
                <Value>0xff</Value>
            </Register>
            <Register>
                <Value>0x2c</Value>
            </Register>
            <Register>
                <Value>0x77</Value>
            </Register>
            <Register>
                <Value>0xbe</Value>
            </Register>
            <Register>
                <Value>0x9f</Value>
            </Register>
            <Register>
                <Value>0x0b</Value>
            </Register>
            <Register>
                <Name>XOSC1</Name>
                <Value>0x03</Value>
            </Register>
            <Register>
                <Name>XOSC5</Name>
                <Value>0x0e</Value>
            </Register>
        </registersettings>
        <dcpanel>
            <Property name="m_testFuncPanel" role="37">3</Property>
        </dcpanel>
        <rfparameters>
        </rfparameters>
        <conttx>
        </conttx>
        <contrx>
        </contrx>
        <packettx>
        </packettx>
        <packetrx>
        </packetrx>
        <commandpanel>
        </commandpanel>
        <packetRxSniffMode>
    Siri working TX configuration:
        <registersettings>
            <Register>
                <Value>0xcf</Value>
            </Register>
            <Register>
                <Value>0xa9</Value>
            </Register>
            <Register>
                <Value>0x19</Value>
            </Register>
            <Register>
                <Value>0x41</Value>
            </Register>
            <Register>
                <Value>0x1c</Value>
            </Register>
            <Register>
                <Value>0x48</Value>
            </Register>
            <Register>
                <Value>0x00</Value>
            </Register>
            <Register>
                <Name>FREQ1</Name>
                <Value>0x60</Value>
            </Register>
            <Register>
                <Name>FREQ2</Name>
                <Value>0x72</Value>
            </Register>
            <Register>
                <Value>0x22</Value>
            </Register>
            <Register>
                <Value>0x0e</Value>
            </Register>
            <Register>
                <Value>0x40</Value>
            </Register>
            <Register>
                <Name>FS_CFG</Name>
                <Value>0x12</Value>
            </Register>
            <Register>
                <Value>0x5f</Value>
            </Register>
            <Register>
                <Value>0x00</Value>
            </Register>
            <Register>
                <Value>0x03</Value>
            </Register>
            <Register>
                <Value>0x33</Value>
            </Register>
            <Register>
                <Value>0x17</Value>
            </Register>
            <Register>
                <Name>FS_PFD</Name>
                <Value>0x50</Value>
            </Register>
            <Register>
                <Name>FS_PRE</Name>
                <Value>0x6e</Value>
            </Register>
            <Register>
                <Value>0x14</Value>
            </Register>
            <Register>
                <Value>0xac</Value>
            </Register>
            <Register>
                <Value>0xb4</Value>
            </Register>
            <Register>
                <Value>0x00</Value>
            </Register>
            <Register>
                <Name>IOCFG0</Name>
                <Value>0x40</Value>
            </Register>
            <Register>
                <Name>IOCFG1</Name>
                <Value>0xb0</Value>
            </Register>
            <Register>
                <Name>IOCFG2</Name>
                <Value>0x06</Value>
            </Register>
            <Register>
                <Name>IOCFG3</Name>
                <Value>0xb0</Value>
            </Register>
            <Register>
                <Name>IQIC</Name>
                <Value>0x00</Value>
            </Register>
            <Register>
                <Value>0x05</Value>
            </Register>
            <Register>
                <Value>0x2d</Value>
            </Register>
            <Register>
                <Value>0x10</Value>
            </Register>
            <Register>
                <Value>0x48</Value>
            </Register>
            <Register>
                <Value>0x21</Value>
            </Register>
            <Register>
                <Value>0x7b</Value>
            </Register>
            <Register>
                <Value>0x20</Value>
            </Register>
            <Register>
                <Value>0xff</Value>
            </Register>
            <Register>
                <Value>0x2c</Value>
            </Register>
            <Register>
                <Value>0x03</Value>
            </Register>
            <Register>
                <Value>0x77</Value>
            </Register>
            <Register>
                <Value>0xbe</Value>
            </Register>
            <Register>
                <Value>0x9f</Value>
            </Register>
            <Register>
                <Value>0x08</Value>
            </Register>
            <Register>
                <Name>XOSC1</Name>
                <Value>0x03</Value>
            </Register>
            <Register>
                <Name>XOSC5</Name>
                <Value>0x0e</Value>
            </Register>
        </registersettings>
        <dcpanel>
        </dcpanel>
        <rfparameters>
        </rfparameters>
        <conttx>
        </conttx>
        <contrx>
        </contrx>
        <packettx>
            <Property role="52" name="m_spnPktInterval">100</Property>
        </packettx>
        <packetrx>
        </packetrx>
        <commandpanel>
        </commandpanel>
        <packetRxSniffMode>
  • When you write "not work" please be a bit more specific.
  • Sorry I made a mistake in previous post, You answered faster than my update [I've updated the post] :)
    Not work means that when I loaded the RX+TX configuration the device doesn't TX.
    [with other configuration the hardware is working]
  • How do you know it's not sending anything?
    If you have the receiver in cont. Rx and look at the RSSI graph do you see some energy on the air?
  • You can use the same register settings in both TX, RX, and RX Sniff mode with one exception.
    When using RX instead of sniff mode you must turn off CS termination.
    I used the Siri_Sniff_Mode_RX_changed_PreabmleCFG1_to12Bytes.xml and changed the preamble to 12 bytes.
    For your convenience the register settings are below:
    // Bit rate = 124
    // PA ramping = true
    // RX filter BW = 125.000000
    // Modulation format = 4-GFSK
    // Symbol rate = 62
    // TX power = 15
    // Whitening = false
    // Packet bit length = 0
    // Packet length = 255
    // Performance mode = High Performance
    // Packet length mode = Variable
    // Device address = 0
    // Carrier frequency = 915.000000
    // Manchester enable = false
    // Deviation = 20.019531
    // Address config = No address check
    static const registerSetting_t preferredSettings[]=
    {CC112X_IOCFG3,           0xB0},
    {CC112X_IOCFG2,           0x06},
    {CC112X_IOCFG1,           0xB0},
    {CC112X_IOCFG0,           0x40},
    {CC112X_SYNC_CFG1,        0x08},
    {CC112X_DEVIATION_M,      0x48},
    {CC112X_MODCFG_DEV_E,     0x2D},
    {CC112X_DCFILT_CFG,       0x1C},
    {CC112X_PREAMBLE_CFG1,    0x2C},
    {CC112X_IQIC,             0x00},
    {CC112X_CHAN_BW,          0x41},
    {CC112X_MDMCFG0,          0x05},
    {CC112X_SYMBOL_RATE2,     0x9F},
    {CC112X_SYMBOL_RATE1,     0xBE},
    {CC112X_SYMBOL_RATE0,     0x77},
    {CC112X_AGC_CS_THR,       0x0C},
    {CC112X_AGC_CFG1,         0xA0},
    {CC112X_FIFO_CFG,         0x00},
    {CC112X_SETTLING_CFG,     0x03},
    {CC112X_FS_CFG,           0x12},
    {CC112X_WOR_CFG0,         0x20},
    {CC112X_WOR_EVENT0_LSB,   0x2F},
    {CC112X_PKT_CFG0,         0x20},
    {CC112X_RFEND_CFG0,       0x09},
    {CC112X_PA_CFG0,          0x7B},
    {CC112X_PKT_LEN,          0xFF},
    {CC112X_IF_MIX_CFG,       0x00},
    {CC112X_FREQOFF_CFG,      0x22},
    {CC112X_FREQ2,            0x72},
    {CC112X_FREQ1,            0x60},
    {CC112X_FS_DIG1,          0x00},
    {CC112X_FS_DIG0,          0x5F},
    {CC112X_FS_CAL1,          0x40},
    {CC112X_FS_CAL0,          0x0E},
    {CC112X_FS_DIVTWO,        0x03},
    {CC112X_FS_DSM0,          0x33},
    {CC112X_FS_DVC0,          0x17},
    {CC112X_FS_PFD,           0x50},
    {CC112X_FS_PRE,           0x6E},
    {CC112X_FS_REG_DIV_CML,   0x14},
    {CC112X_FS_SPARE,         0xAC},
    {CC112X_FS_VCO0,          0xB4},
    {CC112X_XOSC5,            0x0E},
    {CC112X_XOSC2,            0x00},
    {CC112X_XOSC1,            0x03},
    I have modified the CC1120_rx_sniff_mode example so that it uses these settings for TX, RX and RX Sniff Mode. The code example is attached.
    Demo.zip
