I would like to draw attention to a function defined in
/****************************************************************************** * Filename: hal_spi_rf_trxeb.c * * Description: Implementation file for common spi access with the CCxxxx * tranceiver radios using trxeb. Supports CC1101/CC112X radios * * Copyright (C) 2013 Texas Instruments Incorporated - http://www.ti.com/ * * * Redistribution and use in source and binary forms, with or without * modification, are permitted provided that the following conditions * are met: * * Redistributions of source code must retain the above copyright * notice, this list of conditions and the following disclaimer. * * Redistributions in binary form must reproduce the above copyright * notice, this list of conditions and the following disclaimer in the * documentation and/or other materials provided with the distribution. * * Neither the name of Texas Instruments Incorporated nor the names of * its contributors may be used to endorse or promote products derived * from this software without specific prior written permission. * * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR * A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT * OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. * *******************************************************************************/ /****************************************************************************** * INCLUDES */ #include <msp430.h> #include "hal_types.h" #include "hal_defs.h" #include "hal_spi_rf_trxeb.h" /****************************************************************************** * LOCAL FUNCTIONS */ static void trxReadWriteBurstSingle(uint8 addr,uint8 *pData,uint16 len) ; /****************************************************************************** * FUNCTIONS */ /****************************************************************************** * @fn trxRfSpiInterfaceInit * * @brief Function to initialize TRX SPI. CC1101/CC112x is currently * supported. The supported prescalerValue must be set so that * SMCLK/prescalerValue does not violate radio SPI constraints. * * input parameters * * @param prescalerValue - SMCLK/prescalerValue gives SCLK frequency * * output parameters * * @return void */ void trxRfSpiInterfaceInit(uint8 prescalerValue) { /* Keep peripheral in reset state*/ UCB0CTL1 |= UCSWRST; /* Configuration * - 8-bit * - Master Mode * - 3-pin * - synchronous mode * - MSB first * - Clock phase select = captured on first edge * - Inactive state is low * - SMCLK as clock source * - Spi clk is adjusted corresponding to systemClock as the highest rate * supported by the supported radios: this could be optimized and done * after chip detect. */ UCB0CTL0 = 0x00+UCMST + UCSYNC + UCMODE_0 + UCMSB + UCCKPH; UCB0CTL1 |= UCSSEL_2; UCB0BR1 = 0x00; UCB0BR0 = prescalerValue; ///* Configuring UCB0BR0 // * Set up spi clk to comply with the maximum spi clk speed for the radios // * according to userguides. Takes the slowest spi clk into account. // */ //switch(systemClock) //{ // case 0: // /* Do not divide SMCLK */ // UCB0BR0 = 0x01; // break; // case 1: // /* Do not divide SMCLK */ // UCB0BR0 = 0x01; // break; // case 2: // /* Divide SMCLK by 2*/ // UCB0BR0 = 0x02; // break; // case 3: // /* Divide SMCLK by 2*/ // UCB0BR0 = 0x02; // break; // case 4: // /* Divide SMCLK by 3*/ // UCB0BR0 = 0x03; // break; // case 5: // /* Divide SMCLK by 4*/ // UCB0BR0 = 0x04; // break; // case 6: // /* Divide SMCLK by 4*/ // UCB0BR0 = 0x04; // break; // default: // /* Divide SMCLK by 4*/ // UCB0BR0 = 0x04; // break; //} /* Configure port and pins * - MISO/MOSI/SCLK GPIO controlled by peripheral * - CS_n GPIO controlled manually, set to 1 */ TRXEM_PORT_SEL |= TRXEM_SPI_MOSI_PIN + TRXEM_SPI_MISO_PIN + TRXEM_SPI_SCLK_PIN; TRXEM_PORT_SEL &= ~TRXEM_SPI_SC_N_PIN; TRXEM_PORT_OUT |= TRXEM_SPI_SC_N_PIN + TRXEM_SPI_MISO_PIN;/* Pullup on MISO */ TRXEM_PORT_DIR |= TRXEM_SPI_SC_N_PIN; /* In case not automatically set */ TRXEM_PORT_DIR |= TRXEM_SPI_MOSI_PIN + TRXEM_SPI_SCLK_PIN; TRXEM_PORT_DIR &= ~TRXEM_SPI_MISO_PIN; /* Release for operation */ UCB0CTL1 &= ~UCSWRST; return; } /******************************************************************************* * @fn trx8BitRegAccess * * @brief This function performs a read or write from/to a 8bit register * address space. The function handles burst and single read/write * as specfied in addrByte. Function assumes that chip is ready. * * input parameters * * @param accessType - Specifies if this is a read or write and if it's * a single or burst access. Bitmask made up of * RADIO_BURST_ACCESS/RADIO_SINGLE_ACCESS/ * RADIO_WRITE_ACCESS/RADIO_READ_ACCESS. * @param addrByte - address byte of register. * @param pData - data array * @param len - Length of array to be read(TX)/written(RX) * * output parameters * * @return chip status */ rfStatus_t trx8BitRegAccess(uint8 accessType, uint8 addrByte, uint8 *pData, uint16 len) { uint8 readValue; /* Pull CS_N low and wait for SO to go low before communication starts */ TRXEM_SPI_BEGIN(); while(TRXEM_PORT_IN & TRXEM_SPI_MISO_PIN); /* send register address byte */ TRXEM_SPI_TX(accessType|addrByte); TRXEM_SPI_WAIT_DONE(); /* Storing chip status */ readValue = TRXEM_SPI_RX(); trxReadWriteBurstSingle(accessType|addrByte,pData,len); TRXEM_SPI_END(); /* return the status byte value */ return(readValue); } /****************************************************************************** * @fn trx16BitRegAccess * * @brief This function performs a read or write in the extended adress * space of CC112X. * * input parameters * * @param accessType - Specifies if this is a read or write and if it's * a single or burst access. Bitmask made up of * RADIO_BURST_ACCESS/RADIO_SINGLE_ACCESS/ * RADIO_WRITE_ACCESS/RADIO_READ_ACCESS. * @param extAddr - Extended register space address = 0x2F. * @param regAddr - Register address in the extended address space. * @param *pData - Pointer to data array for communication * @param len - Length of bytes to be read/written from/to radio * * output parameters * * @return rfStatus_t */ rfStatus_t trx16BitRegAccess(uint8 accessType, uint8 extAddr, uint8 regAddr, uint8 *pData, uint8 len) { uint8 readValue; TRXEM_SPI_BEGIN(); while(TRXEM_PORT_IN & TRXEM_SPI_MISO_PIN); /* send extended address byte with access type bits set */ TRXEM_SPI_TX(accessType|extAddr); TRXEM_SPI_WAIT_DONE(); /* Storing chip status */ readValue = TRXEM_SPI_RX(); TRXEM_SPI_TX(regAddr); TRXEM_SPI_WAIT_DONE(); /* Communicate len number of bytes */ trxReadWriteBurstSingle(accessType|extAddr,pData,len); TRXEM_SPI_END(); /* return the status byte value */ return(readValue); } /******************************************************************************* * @fn trxSpiCmdStrobe * * @brief Send command strobe to the radio. Returns status byte read * during transfer of command strobe. Validation of provided * is not done. Function assumes chip is ready. * * input parameters * * @param cmd - command strobe * * output parameters * * @return status byte */ rfStatus_t trxSpiCmdStrobe(uint8 cmd) { uint8 rc; TRXEM_SPI_BEGIN(); while(TRXEM_PORT_IN & TRXEM_SPI_MISO_PIN); TRXEM_SPI_TX(cmd); TRXEM_SPI_WAIT_DONE(); rc = TRXEM_SPI_RX(); TRXEM_SPI_END(); return(rc); } /******************************************************************************* * @fn trxReadWriteBurstSingle * * @brief When the address byte is sent to the SPI slave, the next byte * communicated is the data to be written or read. The address * byte that holds information about read/write -and single/ * burst-access is provided to this function. * * Depending on these two bits this function will write len bytes to * the radio in burst mode or read len bytes from the radio in burst * mode if the burst bit is set. If the burst bit is not set, only * one data byte is communicated. * * NOTE: This function is used in the following way: * * TRXEM_SPI_BEGIN(); * while(TRXEM_PORT_IN & TRXEM_SPI_MISO_PIN); * ...[Depending on type of register access] * trxReadWriteBurstSingle(uint8 addr,uint8 *pData,uint16 len); * TRXEM_SPI_END(); * * input parameters * * @param none * * output parameters * * @return void */ static void trxReadWriteBurstSingle(uint8 addr,uint8 *pData,uint16 len) { uint16 i; /* Communicate len number of bytes: if RX - the procedure sends 0x00 to push bytes from slave*/ if(addr&RADIO_READ_ACCESS) { if(addr&RADIO_BURST_ACCESS) { for (i = 0; i < len; i++) { TRXEM_SPI_TX(0); /* Possible to combining read and write as one access type */ TRXEM_SPI_WAIT_DONE(); *pData = TRXEM_SPI_RX(); /* Store pData from last pData RX */ pData++; } } else { TRXEM_SPI_TX(0); TRXEM_SPI_WAIT_DONE(); *pData = TRXEM_SPI_RX(); } } else { if(addr&RADIO_BURST_ACCESS) { /* Communicate len number of bytes: if TX - the procedure doesn't overwrite pData */ for (i = 0; i < len; i++) { TRXEM_SPI_TX(*pData); TRXEM_SPI_WAIT_DONE(); pData++; } } else { TRXEM_SPI_TX(*pData); TRXEM_SPI_WAIT_DONE(); } } return; }
1. TRXEM_SPI_WAIT_DONE()
2. TRXEM_SPI_RX()
3. TRXEM_SPI_WAIT_DONE()
4. TRXEM_SPI_WAIT_TX_DONE()
5. TRXEM_SPI_RX()
6. TRXEM_SPI_WAIT_MISO_LOW(x)
.After a bit more searching I figured that these functions exist in the header file itself. More specifically inhal_spi_rf_trxeb.h file.
hal_spi_rf_trxeb.h having the function as macros is shown below.
The said functions are described as macros. I do not understand how these work. I am porting this project to a TIVA C Series device.
/****************************************************************************** * MACROS */ /* Macros for Tranceivers(TRX) */ #define TRXEM_SPI_BEGIN() st( TRXEM_PORT_OUT &= ~TRXEM_SPI_SC_N_PIN; NOP(); ) #define TRXEM_SPI_TX(x) st( UCB0IFG &= ~UCRXIFG; UCB0TXBUF= (x); ) #define TRXEM_SPI_WAIT_DONE() st( while(!(UCB0IFG & UCRXIFG)); ) #define TRXEM_SPI_WAIT_TX_DONE() st( while(!(UCB0IFG & UCTXIFG)); ) #define TRXEM_SPI_RX() UCB0RXBUF #define TRXEM_SPI_WAIT_MISO_LOW(x) st( uint8 count = 200; \ while(TRXEM_PORT_IN & TRXEM_SPI_MISO_PIN) \ { \ __delay_cycles(5000); \ count--; \ if (count == 0) break; \ } \ if(count>0) (x) = 1; \ else (x) = 0; )
I do not understand how the above numbered functions are defined inside the header file with the help of st().
What does the st ( ) function do?
where is it defined?
Any help how I should port this part to the TIVA MCU would be much appreciated.
Thank you for your time.
