Impact of SPI clock for RF performance on CC1200
Guru 16800 points
Other Parts Discussed in Thread: CC1200
Please let me know whether SPI clock impacts the RF performance of CC1200.
Especially, I want to know whether SPI clock causes the deterioration of sensitivity.
Nomoto
  • Your question indicate that you see some sensitivity degradation. How do you use the chip? If you use the FIFO you will not have SPI traffic when receiving a packet so you will not see any degradation. We have not tested how the SPI clock impact on the performance if serial mode is used.
  • Hello TER-san,
    Thank you for your reply.
    My customer uses FIFO; therefore, there is another factor to occur degradation.
    Nomoto
  • What kind of degradation do they see?
  • Hello TER-san,
    I recognize the just only following information.
    If data is read via SPI with PKT_SYNC_RXTX asserted, the packet losses occur.
    I think that the timing of read is early; because, assertion of PKT_SYNC_RXTX indicates only sync word detection (PKT_SYNC_RXTX doesn't indicate whether data is in FIFO).
    Nomoto
  • As you see from our software examples we have the packet received interrupt on falling edge to avoid starting to do SPI access before the packet is fully received.
