CC1200 sensitivity
Other Parts Discussed in Thread: CC1200
Hi
I have a problem with sensitivity level of CC1200. I'm using standard CC1200 Evaluation Module Kit 868-930MHz but for 38.ksps and 4GFSK modulation with deviation 20KHz have a -100dbm sensitivity level at 920 MHz, bellow is the configuration witche generated in Smart RF studio
{IOCFG3, 0x06},
{IOCFG2, 0x06},
{IOCFG1, 0x30},
{IOCFG0, 0x3C},
{SYNC3, 0x93},
{SYNC2, 0x0B},
{SYNC1, 0x51},
{SYNC0, 0xDE},
{SYNC_CFG1, 0xA8},
{SYNC_CFG0, 0x03},
{DEVIATION_M, 0x06},
{MODCFG_DEV_E, 0x2B},
{DCFILT_CFG, 0x4C},
{PREAMBLE_CFG1, 0x14},
{PREAMBLE_CFG0, 0x8A},
{IQIC, 0x48},
{CHAN_BW, 0x84},
{MDMCFG1, 0x42},
{MDMCFG0, 0x05},
{SYMBOL_RATE2, 0x8F},
{SYMBOL_RATE1, 0x75},
{SYMBOL_RATE0, 0x10},
{AGC_REF, 0x27},
{AGC_CS_THR, 0x01},
{AGC_GAIN_ADJUST, 0x00},
{AGC_CFG3, 0xB1},
{AGC_CFG2, 0x20},
{AGC_CFG1, 0x11},
{AGC_CFG0, 0x94},
{FIFO_CFG, 0x00},
{DEV_ADDR, 0x00},
{SETTLING_CFG, 0x0B},
{FS_CFG, 0x12},
{WOR_CFG1, 0x08},
{WOR_CFG0, 0x21},
{WOR_EVENT0_MSB, 0x00},
{WOR_EVENT0_LSB, 0x00},
{RXDCM_TIME, 0x00},
{PKT_CFG2, 0x00},
{PKT_CFG1, 0x03},
{PKT_CFG0, 0x20},
{RFEND_CFG1, 0x0F},
{RFEND_CFG0, 0x00},
{PA_CFG1, 0x7F},
{PA_CFG0, 0x56},
{ASK_CFG, 0x0F},
{PKT_LEN, 0xFF},
{IF_MIX_CFG, 0x1C},
{FREQOFF_CFG, 0x20},
{TOC_CFG, 0x03},
{MARC_SPARE, 0x00},
{ECG_CFG, 0x00},
{MDMCFG2, 0x02},
{EXT_CTRL, 0x01},
{RCCAL_FINE, 0x00},
{RCCAL_COARSE, 0x00},
{RCCAL_OFFSET, 0x00},
{FREQOFF1, 0x00},
{FREQOFF0, 0x00},
{FREQ2, 0x5C},
{FREQ1, 0x0F},
{FREQ0, 0x5C},
{IF_ADC2, 0x02},
{IF_ADC1, 0xEE},
{IF_ADC0, 0x10},
{FS_DIG1, 0x04},
{FS_DIG0, 0x55},
{FS_CAL3, 0x00},
{FS_CAL2, 0x20},
{FS_CAL1, 0x40},
{FS_CAL0, 0x0E},
{FS_CHP, 0x28},
{FS_DIVTWO, 0x03},
{FS_DSM1, 0x00},
{FS_DSM0, 0x33},
{FS_DVC1, 0xFF},
{FS_DVC0, 0x17},
{FS_LBI, 0x00},
{FS_PFD, 0x00},
{FS_PRE, 0x6E},
{FS_REG_DIV_CML, 0x1C},
{FS_SPARE, 0xAC},
{FS_VCO4, 0x14},
{FS_VCO3, 0x00},
{FS_VCO2, 0x00},
{FS_VCO1, 0x00},
{FS_VCO0, 0xB5},
{GBIAS6, 0x00},
{GBIAS5, 0x02},
{GBIAS4, 0x00},
{GBIAS3, 0x00},
{GBIAS2, 0x10},
{GBIAS1, 0x00},
{GBIAS0, 0x00},
{IFAMP, 0x09},
{LNA, 0x01},
{RXMIX, 0x01},
{XOSC5, 0x0E},
{XOSC4, 0xA0},
{XOSC3, 0x03},
{XOSC2, 0x04},
{XOSC1, 0x03},
{XOSC0, 0x00},
{ANALOG_SPARE, 0x00},
{PA_CFG3, 0x00},
{WOR_TIME1, 0x00},
{WOR_TIME0, 0x00},
{WOR_CAPTURE1, 0x00},
{WOR_CAPTURE0, 0x00},
{BIST, 0x00},
{DCFILTOFFSET_I1, 0x00},
{DCFILTOFFSET_I0, 0x00},
{DCFILTOFFSET_Q1, 0x00},
{DCFILTOFFSET_Q0, 0x00},
{IQIE_I1, 0x00},
{IQIE_I0, 0x00},
{IQIE_Q1, 0x00},
{IQIE_Q0, 0x00},
{RSSI1, 0x80},
{RSSI0, 0x00},
{MARCSTATE, 0x41},
{LQI_VAL, 0x00},
{PQT_SYNC_ERR, 0xFF},
{DEM_STATUS, 0x00},
{FREQOFF_EST1, 0x00},
{FREQOFF_EST0, 0x00},
{AGC_GAIN3, 0x00},
{AGC_GAIN2, 0xD1},
{AGC_GAIN1, 0x00},
{AGC_GAIN0, 0x3F},
{CFM_RX_DATA_OUT, 0x00},
{CFM_TX_DATA_IN, 0x00},
{ASK_SOFT_RX_DATA,0x30},
{RNDGEN, 0x7F},
{MAGN2, 0x00},
{MAGN1, 0x00},
{MAGN0, 0x00},
{ANG1, 0x00},
{ANG0, 0x00},
{CHFILT_I2, 0x02},
{CHFILT_I1, 0x00},
{CHFILT_I0, 0x00},
{CHFILT_Q2, 0x00},
{CHFILT_Q1, 0x00},
{CHFILT_Q0, 0x00},
{GPIO_STATUS, 0x00},
{FSCAL_CTRL, 0x01},
{PHASE_ADJUST, 0x00},
{PARTNUMBER, 0x00},
{PARTVERSION, 0x00},
{SERIAL_STATUS, 0x00},
{MODEM_STATUS1, 0x01},
{MODEM_STATUS0, 0x00},
{MARC_STATUS1, 0x00},
{MARC_STATUS0, 0x00},
{PA_IFAMP_TEST, 0x00},
{FSRF_TEST, 0x00},
{PRE_TEST, 0x00},
{PRE_OVR, 0x00},
{ADC_TEST, 0x00},
{DVC_TEST, 0x0B},
{ATEST, 0x40},
{ATEST_LVDS, 0x00},
{ATEST_MODE, 0x00},
{XOSC_TEST1, 0x3C},
{XOSC_TEST0, 0x00},
{AES, 0x00},
{MDM_TEST, 0x00},
{RXFIRST, 0x00},
{TXFIRST, 0x00},
{RXLAST, 0x00},
{TXLAST, 0x00},
{NUM_TXBYTES, 0x00},
{NUM_RXBYTES, 0x00},
{FIFO_NUM_TXBYTES,0x0F},
{FIFO_NUM_RXBYTES,0x00},
{RXFIFO_PRE_BUF, 0x00},
{AES_KEY15, 0x00},
{AES_KEY14, 0x00},
{AES_KEY13, 0x00},
{AES_KEY12, 0x00},
{AES_KEY11, 0x00},
{AES_KEY10, 0x00},
{AES_KEY9, 0x00},
{AES_KEY8, 0x00},
{AES_KEY7, 0x00},
{AES_KEY6, 0x00},
{AES_KEY5, 0x00},
{AES_KEY4, 0x00},
{AES_KEY3, 0x00},
{AES_KEY2, 0x00},
{AES_KEY1, 0x00},
{AES_KEY0, 0x00},
{AES_BUFFER15, 0x00},
{AES_BUFFER14, 0x00},
{AES_BUFFER13, 0x00},
{AES_BUFFER12, 0x00},
{AES_BUFFER11, 0x00},
{AES_BUFFER10, 0x00},
{AES_BUFFER9, 0x00},
{AES_BUFFER8, 0x00},
{AES_BUFFER7, 0x00},
{AES_BUFFER6, 0x00},
{AES_BUFFER5, 0x00},
{AES_BUFFER4, 0x00},
{AES_BUFFER3, 0x00},
{AES_BUFFER2, 0x00},
{AES_BUFFER1, 0x00},
{AES_BUFFER0, 0x00},
If I'm not wrong with this configurations the receiver in the worst case should be provide -109dbm sensitivity. My question is: Am I in misunderstand with datasheet or some important registers configured not correctly.
Thanks in Advance
