Still remaining question : maximum data rate of CC1310 in the band of 433MHz
Other Parts Discussed in Thread: CC1310
I had asked a similar question previous time,
but I'd like to confirm some vagueness on the the maximum data rate
supported by CC1310 in the band of 433MHz.
You, TI employees, said that the current maximum data rate are 1.5 mbps
in the band of 433MHz. I am wondering if we can achieve the maximum with only
the current release of TI-RTOS version and RF core(I am now using 2.20 version).
(In fact, I've tested above 700kbps but the result was high PER. My test was exact?)
 If not, when will be the release of the software that can support high speed mode
in the band of 433MHz, It will be the near or far future?
Thank you in adavnce.
