Hello
We have device that has CC1110 and we are programing it with CC Debugger. The problem is that in some case (we don't know all variables) device starts to draw more current that it has to draw. We manage to find out that when device draws to much current pin P1_7 is not functional and we suspect that P1_7 is burned or latched up and current consumption is over that pin. When current drawn is normal pin p1_7 is operational.
P1_7 is connected to CC Debugger so we suspect that this is main cause of this problem. Further we found out that when we used CC Debugger with FW rev 0025 problem was occuer less times than when we updated CC Debugger to newest rev (0044). I tried to find rev 0025 but this is nightmare because TI provides only lastest FW versions and revisions. Can anyone give me FW rev 0025 to try to verify that FW rev has connections with this P1_7 problem?
We are making devices with worker wired to ground so ESD shouldn't be cause.
Any ideas are welcome.
Thank you,
Luka
