Part Number: CC1310
Hi
I am using a custom designed CC1310 board based on my application. I am using contiki OS. While flashing by use of JTAG the circuit starts as reset asserted from JTAG.
But once power recycled the system is not starting, need to hard reset the system. While I used a USB to UART converter at its UART port, the circuit starts on power recycle as well.
is there any OS dependency on this. then what could be the resolution. I have tried more latency in the reset pin but of no use.
