Other Parts Discussed in Thread: CC1120,
We have a design that uses CC1120 as RX and CC150L as TX.
We are using the CC1120 for RSSI measurments and it has a known errata that the RSSI measurments are inaccurate in datarates higher then 100kbps (or some other lower rate).
We are considering to replace the CC1120 with CC1200 in order to increase the data rate.
Questions:
- Is the CC1200 RSSI measurments accurate at 200-250kbps (2GFSK)?
- Obviously we will need to change the smartRF configurations but will we need to change any thing else in the firmware code?
- Is the CC1120 and CC1200 same foot print?
Thank you
