Other Parts Discussed in Thread: CC1350
Greetings
Im having an issue with slip-radio (cc1350 part with subGHz antenna activated (no rf-switch)), connected to 6lbr. Im using udp protocol for my mesh, and for udp server (on 6lbr) as well. (cetic 6lbr client on my node is running). After sending 1-3 package of like <200 bytes in 2 seconds, udp communication breaks down (on receiving part). When this happens it stops to receive any kind of messages. After 50 seconds the "last seen" sequence on 6lbr site stops to update, and node does not response to anything any more. I've tried to renew connections after the node stops responding, but non of those (udp_remove(args), dag_purge(), and creating new afterwards) helped. The only things that helps is to manually restart the crashed node. There's an important note: 6lbr's slip radio is working fine with other nodes before and after crashed node stops to response.
Could you either suggest a resolve to this issue, or please provide an info of whats the throughput of cc1350 subGHz antenna (if there's a number in bytes, kbytes per second or any other measure).
Thank you in advance.
Best regards
Vladimir
